Author Topic: 750K2 / 400F Caliper pistons interchangeable?  (Read 5883 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« on: January 08, 2013, 02:28:20 PM »
I've a badly pitted 400F caliper piston, and a serviceable '750K2 piston.  They're dimensionally the same (externally).... but the '400 piston has a blanking plate in its end....versus the open ended 750 part. The 'blanking' plate rattles, though is captured in some way that I haven't yet fathomed.  That said, I don't think I can transfer it across due the 400 piston appears to have a thinner wall where this plate fits.
Any comments on whether I can use the K2 piston... and if I have to somehow mimic this blanking plate.
Cheers...
Re: 750K2 / 400F Caliper pistons interchangeable?
« Reply #1 on: January 08, 2013, 02:31:57 PM »
Yes you can but you may get the dreaded brake squeal due to no nylon washer between pad and piston
« Reply #2 on: January 08, 2013, 02:36:08 PM »
But, on the plus side, if it squeals you know it's working/ not siezed!  ;D
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Lobo
« Reply #3 on: January 08, 2013, 02:38:35 PM »
Thanks Bryan... Assuming then OK to simply install the open end against the pad.
« Last Edit: January 09, 2013, 12:21:57 AM by Lobo »
Online SteveD CB500K0
« Reply #4 on: January 09, 2013, 10:45:09 AM »
Kevin400F (Kevin Hunter) on the .net site makes these from phenolic resin.
Quite a few members have used them - some from here!
Steve
