CB350/400
brake master cylinder circlip removal
Topic: brake master cylinder circlip removal (Read 6044 times)
59viperman
April 04, 2013, 10:00:36 PM »
can someone please tell me how to remove the circlip from the front brake master cylinder, I have bought a rebuild kit because mine is leaking [ like the petrol tank] . I have removed the ring below the rubber boot but I cant shift the circlip. I am using circlip pliers but its a three handed job trying to keep the piston down while I get at it. any tips before I throw it in the bin and buy a new one ?
Re: brake master cylinder circlip removal
April 05, 2013, 07:31:32 AM »
Reseverence and the correct bent pliers mate. I always use a plumbers type blowtorch to warm up down the hole and remove rust then if you push the piston in as far as possible a lot of the time it sticks down
tom400f
April 05, 2013, 12:43:37 PM »
See posts here:
http://www.sohc.co.uk/index.php?topic=4812.msg22283#msg22283
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
59viperman
April 05, 2013, 01:07:02 PM »
thanks chaps will try everything,
59viperman
April 05, 2013, 07:51:05 PM »
eureka, job done. ha ha
CB350/400
