Author Topic: Neutral switch connection  (Read 6147 times)
Offline Seamus
« on: April 09, 2013, 06:00:12 PM »
Silly question but how does the wire attach to the switch?
Received a 400/4 in parts to assemble and I did not take it apart. Wondering if something is missing.
Thanks in advance
Offline hairygit
Re: Neutral switch connection
« Reply #1 on: April 09, 2013, 06:04:09 PM »
There should be a little tiny (easily lost! >:() bolt in the top of it, and the single wire has an eye terminal on it, which is held by the bolt
Offline Seamus
« Reply #2 on: April 09, 2013, 07:02:12 PM »
Thanks mate. Appreciate the quick reply. Is the bolt a phillips type head screw?
PS do you still want the barrels?
Offline steven400/4
« Reply #3 on: April 09, 2013, 08:33:48 PM »
mine has a spring witch you push down then put your wire in the hole let spring go and it holds it in place
cb400f2 x7
honda ss 50
gsx 1400
Offline Seamus
« Reply #4 on: April 09, 2013, 11:13:33 PM »
Thanks Steven, I will have a closer loook tomorrow and see which type I have. (Guess there are two). The wire to mine does not have a loop to fit a screw, so possibly the same as yours. (I hope so as I dont have the screw)
Offline Seamus
« Reply #5 on: April 10, 2013, 04:21:16 PM »
Correct for your type Steven. Poked it through the little hole under the spring. Thanks for the heads up on that one.
Offline steven400/4
« Reply #6 on: April 10, 2013, 05:23:03 PM »
no problem mate
cb400f2 x7
honda ss 50
gsx 1400
