Author Topic: Anyone have or used one of these, looking for some feedback  (Read 7062 times)
Offline stuartni
Re: Anyone have or used one of these, looking for some feedback
« Reply #1 on: July 05, 2013, 03:38:47 PM »
not to dear now im tempted  :P
Offline busa
  • busa
« Reply #2 on: August 13, 2013, 09:25:44 PM »
I have one similar to this  and it is very easy to use.   I used it for my race bikes  all the time.  changing from slick to wets  when didn't have spare rims.   Give you at tip.   get some good tyre soap.  with a brush.  and good pair of levers  and rim guards. this is the one I use.  I know its not the same as above   but  just as easy to use  and is only  about  £40.00
« Last Edit: August 13, 2013, 09:31:44 PM by busa »
Offline mick
« Reply #3 on: August 13, 2013, 10:13:59 PM »
I have the same one Busa handy bit of kit  ;), saves all that jumping up and down with your heels on the tyre edge  ::), cheers Mick.
« Reply #4 on: August 13, 2013, 10:44:34 PM »
Where did you guys picks yours up ? - I'm fed up of paying other people to do it so might as well invest / learn to do it myself!! :-).
Offline mick
« Reply #5 on: August 14, 2013, 07:11:45 AM »
Hi James I got mine off ebay can't remember which seller ? probably the cheapest knowing me  ;) cheers Mick.
Offline busa
  • busa
« Reply #6 on: August 14, 2013, 05:40:13 PM »
« Reply #7 on: August 14, 2013, 06:30:30 PM »
Nice one thanks guys. Any tips / techniques on using them (sorry probably a stupid question but a tyre changing virgin :-) ).
Offline busa
  • busa
« Reply #8 on: August 14, 2013, 10:34:17 PM »
yeah  make sure you take the valve out of the tyre before you do anything,   then put the wheel on the change   put the blade in behind the wheel rim.  and put down on the lever.   turn the wheel  about quarter turn  do the same  until the tyre bead drops  then turn the wheel over  do same    ..  once this is done  if work between  9 and 3  as a clock face.  it is easier  press tyre into centre of rim. around the 9 O clock     and  use lever  to lever tyre over rim at the 3 O clock.  keep working aroung the tyre until  the bead on that side if of the rim.   the go back to the same process.  and lift the tyre  and start to lever the lower bead  over.  only practice  will help you more  and realy find your own technique.
MIKE550/4
« Reply #9 on: August 15, 2013, 04:46:37 PM »
I have found with tyre levers its that last third which I struggle with,
the first item I posted comes with the bar and looking at videos of it in use looks a ot easier
unsure now which one to buy
Offline busa
  • busa
« Reply #10 on: August 15, 2013, 05:24:30 PM »
struggle with the last third.    use loads of  soap.  even use the blade on tyre changer  to help.
« Reply #11 on: August 15, 2013, 09:25:22 PM »
Thanks guys. Will probably grab one and will let you know how I get on...
