Author Topic: wiring loom earth lead  (Read 6347 times)
Offline Graham drums
« on: July 13, 2013, 01:08:50 PM »
Hi does anyone know where the green earth lead in the wiring loom fixes to under the left hand panel where most of the electrics are fitted.
It is quite short and I can only see it fits on one of the air box bolts, but they are insulated by the rubber grommets that mount the box Or do I need to earth the air box with the bolts then attach to one of them.
many thanks
Graham
Re: wiring loom earth lead
« Reply #1 on: July 13, 2013, 02:01:22 PM »
What bike would help
Offline steven400/4
« Reply #2 on: July 13, 2013, 02:13:27 PM »
if its a 400/4 it goes to the bolt that holds battery box in
cb400f2 x7
honda ss 50
gsx 1400
« Reply #3 on: July 13, 2013, 03:56:42 PM »
Hi Sorry new to this, its a CB 400/4 1975
Saw the other comment about the air box but currently it is insulated from the frame by the rubber mounts so do I need to make sure the air box / battery holder is earthed, then it makes sense.
Cheers,
Graham
« Reply #4 on: July 14, 2013, 12:38:36 AM »
The bolts go through a steel spacer so when tight there is a direct contact to the steel frame
Offline tom400f
« Reply #5 on: July 14, 2013, 10:10:22 AM »
But blurry I'm afraid but hopefully good enough
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
« Reply #6 on: July 20, 2013, 04:38:54 PM »
Cheers all for the information and the photo
Will post some pictures when it is finished.
Graham
Online SteveD CB500K0
« Reply #7 on: July 20, 2013, 06:06:42 PM »
Put your bike in your signature Graham, and a photo as an avatar!
Steve
