Author Topic: CB400F Air Manifold  (Read 5184 times)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
CB400F Air Manifold
« on: July 25, 2013, 08:51:03 AM »
This ones nagging me... help!
I've assembled the black air manifold rubbers (4 carb + 1 inlet) dry, ie without any type of sealant. Consequently they could never be described as air-tight, particularly the large rubber in from the Airbox.  I appreciate we're on the atmospheric side of the carbs, and rest assured that the air filter will always be clean - ie little cause for 'leaks'.... But should I disassemble (ugh) and 'fix'  or is this how it all should be? (unable to verify mixture / running at high speeds as still awaiting the tank)
All rubbers by the way, new & nicely flexible.
Cheers,
Offline tom400f
Re: CB400F Air Manifold
« Reply #1 on: July 25, 2013, 09:33:37 AM »
I'm sure Bryanj etc will be better placed to comment, but I would say there's a decent vacuum at that point so sealing is wise. Furthermore, my (essentially new) manifold has a gooey substance under those rubbers.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #2 on: July 25, 2013, 09:41:58 AM »
Aye, thanks Tom. Had a recurring memory of that large rubber glued in....boll..ks!
Anyone / Bryan able to suggest best goo to use? Silicon sealant? On all 5 rubbers?
Cheers,
Simon
« Last Edit: July 25, 2013, 09:47:42 AM by Lobo »
« Reply #3 on: July 25, 2013, 05:01:02 PM »
Never bothered with any goo there and never had a problem. the 500 had a "drain" tube open to atmosphere on the carb side of the aircleaner which always seemed a bit daft to me but worked.
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: July 26, 2013, 02:40:43 AM »
Thanks Bryan, with that observation I'll give up at the first sign of difficulty in the dismantle & simply monitor the performance / plugs instead.
Cheers,
Simon
