Other Stuff
Tricks & Tips
MOTORCYCLE BIKE FRAME SCISSOR STAND
Topic: MOTORCYCLE BIKE FRAME SCISSOR STAND (Read 9318 times)
bomber
SOHC Member
August 28, 2013, 02:37:03 PM »
Hello,
I'm stuck.
I have to take front wheel off (bolt holding calliper on my CB550 sheered thread) but I don't have centre stand.
Is any one using MOTORCYCLE BIKE FRAME SCISSOR STAND?
They seems to be the cheapest option out there to lift the whole bike.
Any other ideas?
Many thanks
One step forward, two steps backward...
Honda CB550F 1976
cb750stu
SOHC Expert
Re: MOTORCYCLE BIKE FRAME SCISSOR STAND
August 28, 2013, 05:38:42 PM »
Hi Bomber I'm using one at the moment for my 750 build plenty strong to hold full bike weight I've just strapped the frame down with 2 ratchet straps easy to remove wheels forks etc !!!
1976 CB750 F1 SS in bits !!! but getting there
busa
busa
SOHC Associate
August 28, 2013, 06:39:40 PM »
I use one of these they are easy to use and move around with the bike on it
this is my one
bomber
SOHC Member
August 28, 2013, 10:29:26 PM »
Thanks,
Stu are you using one like this
http://www.ebay.co.uk/itm/DRAPER-04992-MOTORCYCLE-BIKE-FRAME-SCISSOR-STAND-LIFT-500KG-/190666511275?_trksid=p3284.m263&_trkparms=algo%3DSIC%26its%3DI%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D21%26pmod%3D230376708199%26ps%3D54
My concern is that there is no space for the pipes if you are using lift with flat bottom like yours Busa
Honda CB550F 1976
cb750stu
SOHC Expert
August 29, 2013, 08:03:26 AM »
No its one like this im using
http://www.ebay.co.uk/itm/HEAVY-DUTY-HYDRAULIC-MOTORCYCLE-BIKE-ATV-QUAD-4-WHEEL-WORKSHOP-SCISSOR-LIFT-JACK-/300952895343?pt=UK_Motorcycle_Parts&hash=item461230bf6f
hairygit
August 29, 2013, 12:38:46 PM »
Hey Stu, the one you appear to be using has a max capacity of 300lbs, a CB750 complete is pushing 500lbs, be careful as you progress with the build!
cb750stu
SOHC Expert
August 30, 2013, 08:07:04 AM »
Yeah i know ive only got the frame and engine on the stand i didnt want to risk it collapsing it will be coming off when i get the wheels on !!!
bomber
SOHC Member
August 30, 2013, 09:57:59 AM »
Good point about weight.
Still looking for something I can use while keeping pipes one.
Honda CB550F 1976
busa
busa
SOHC Associate
August 30, 2013, 08:53:10 PM »
good point bomber, I never really noticed. but saying that the stand can be used the other way aswell
bomber
SOHC Member
September 01, 2013, 08:21:26 AM »
Busa, would you hang bike on the bottom of the engine? I would prefer to rest the bike on the frame.
I'm going to make a stand form MDF as I don't have much cash and I'm not convinced what I have found so far on the web.
Honda CB550F 1976
matthewmosse
Reply #10 on:
September 01, 2013, 08:55:03 AM »
I use a chain hoist and loop of baler string rather than a bike lift. Chain hoists are relatively cheap and east to get with lifting capacities that are genrally inpressive, downside is having a good place to hang them from. Also usefull for removing landrover engines or installing them.
busa
busa
SOHC Associate
Reply #11 on:
September 03, 2013, 08:35:08 PM »
defo by the frame. if you have a garage you can hang the frame from the back under the seat with rachet straps and the same around the headstock.. I have done this for spraying.frame without engine in place. also had it hanging with engine in
if you want to just take the wheels of. get a pair of paddock stands make sure the one for rear has the blade lifters and not hooks
I am sure you will find a way. it all depends what you are planning to do
Other Stuff
Tricks & Tips
