CB750
Would like a longer side stand
Topic: Would like a longer side stand (Read 5662 times)
Warthog1959
Newbie
September 01, 2013, 09:30:38 PM »
Hi,
Does anyone know of a compatible side stand that is a couple of inches or so longer than stock. I have quite a Lean on my F2 and now I have fitted shocks that are 1" or so longer the lean is even more. Any other solutions appreciated.
Simon
LesterPiglet
1977 CB550F2
Re: Would like a longer side stand
September 02, 2013, 04:50:05 PM »
Check the forks on the sidestand are not bent. Check the hole that the bolt goes through is not enlarged and finally check your sidestand isn't bent.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Warthog1959
Newbie
September 02, 2013, 08:50:18 PM »
Well there is some back and forward movement of the side stand even when the bolt is fully tightened. But not enough to require another 2" in length. This side stand is stubby to say the least.
No sign of any other bending.
What is the solution when the hole has enlarged? this frame has recently been powder coated.
LesterPiglet
1977 CB550F2
September 02, 2013, 09:18:14 PM »
I would think drill it larger and put a sleeve in.
Green1
September 02, 2013, 11:07:25 PM »
You don't need much play in the stand to get massive lean angles The bolt hole on my dads trophy is less than a thou over size and you have to place a two inch block under it to raise the bike to were it should be.Don't forget to check the condition of the bolt they can where quite a bit.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Warthog1959
Newbie
September 03, 2013, 06:58:33 PM »
Amazing really, Thanks, I'll give it my attention and see what happens. This forum is first class by the way, the knowledge base is huge.
Yoshi823
Biker to the bone...
September 04, 2013, 10:39:16 AM »
I fitted CBX1000Z forks & shocks to my CB750F2 & kept the standard sidestand without any problems. It did lean over more but not dramatically.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
CB750
