Author Topic: engine rig  (Read 4897 times)
Offline billy192
    • Shermonkel
engine rig
« on: October 28, 2013, 08:05:14 AM »
Ok  I have made my engine rig, I just need to wire the starter and coils.
am I correct in thinking i need the following wires (I don't want the whole loom)
a switched Live to the Black/white on the coils as my ignition switch ( the coils wired to the points as normal)
a switched earth to the solenoid red / yellow
will this give the minimum to start and run the engine?
Billy
Billy
Re: engine rig
« Reply #1 on: October 28, 2013, 11:50:47 AM »
Yes if the other small solenoid wire is switched live
Offline billy192
    • Shermonkel
Re: engine rig
« Reply #2 on: November 04, 2013, 05:11:16 PM »
Thanks BryanJ
so on the solenoid, earth one wire and switch the other to live?
Billy
Billy
Re: engine rig
« Reply #3 on: November 05, 2013, 07:32:31 AM »
Yup, on the solenoid there are two small wires, one has to go to negative and one to positive with a switch in one of them or the starter will be engaged all the time
Offline billy192
    • Shermonkel
Re: engine rig
« Reply #4 on: November 06, 2013, 02:35:25 PM »
Thanks Bryan
Billy
Offline billy192
    • Shermonkel
Re: engine rig
« Reply #5 on: November 16, 2013, 08:55:31 AM »
on the solenoid does it matter which is live and which is earth?
Billy
Re: engine rig
« Reply #6 on: November 16, 2013, 04:00:02 PM »
Not if you have two small wires coming out, try 12v across those and see if the solenoid "clicks"
On some car solenoids the main power wire is connected to one side of the energising coil internaly so the lead needs to be earthed and on others thes coil is connected internaly to the casing so the lead need to be powered but in both those cases there is only one small lead/connection on the outside
Offline billy192
    • Shermonkel
Re: engine rig
« Reply #7 on: November 24, 2013, 07:24:24 PM »
new points and condenser
so I wired up a ignition switch
 and a starter button
and booom works a treat
https://www.youtube.com/watch?v=iA83zsiosKA&list=HL1385320654&feature=mh_lolz
Billy
