Front mudguard item prices
Topic: Front mudguard item prices (Read 3844 times)
MIKE550/4
October 28, 2013, 06:55:56 PM »
not usually one to moan about prices but this seems excessive for such little parts
6 rubber washer mounts 40513310000
6 collars 40514310000
6 bolts 92101-060200A
47 quid delivered ? for basically 6 rubber washers, 6 bolts and 6 collars
is there an alternative ..... hardware shop ?
mickwinf
Re: Front mudguard item prices
October 28, 2013, 07:57:45 PM »
I reckon its these small items which cause the cost of restoration to spiral to a level you never expect. the larger items are easy to estimate but all these little bits add up!
peterengland
SOHC Member
November 08, 2013, 03:52:50 PM »
hell, I would just go to the hardware shop, a bolt is a bolt and as long as it does the job, what the hell?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
November 09, 2013, 06:50:25 AM »
A bolt yes but you can't get the top hat washers or special sized grommets at the local hardware shop
LesterPiglet
1977 CB550F2
November 09, 2013, 02:19:20 PM »
Surely the tyre will let go before enough stress is put on those bolts.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
MIKE550/4
November 09, 2013, 03:56:27 PM »
well I forked out in the end, the bolts I could get elsewhere, the top hat washers and grommets I have not seen anything else like this in hardware shops so they had me over a barrel really
