Author Topic: airbox assembly k3  (Read 8158 times)
MIKE550/4
  • Guest
airbox assembly k3
« on: January 06, 2014, 03:16:48 PM »
I have all the original parts but assembly is not happening for me
pics tonight once I have tried a few more times
anyone got a pic of their top of airbox for k3 by any chance
MIKE550/4
  • Guest
Re: airbox assembly k3
« Reply #1 on: January 06, 2014, 06:30:28 PM »
Firstly I have read the manuals and I cant find nothing about these mounting plates
I have gone by the csmnl diagram but not convinced its right or maybe I have read it wrong
the left has a big spacer the right has a thinner one which goes through the air filter box
so guys enlighten me , the left even though tight still rattle about..... I have obviously got this wrong
« Reply #2 on: January 06, 2014, 07:10:25 PM »
thinks the short bracket is for carb side,longer bracket is rear wheel  side !!!
how does the lower assembly fit ??
Offline Ewan 500 K1
  • jings crivens help ma boab
    • Adams Bros Probe 2001
« Reply #3 on: January 06, 2014, 07:57:58 PM »
comparing the parts diagram with the photo it looks lilke you have number 14 on wrong Mike . Bolt should go through the hole at the foot of the longer side ... not the hole in the shorter side like you have it ?
500K1/550K3 mongrel cafe racer project for now at http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
Offline Piki
« Reply #4 on: January 06, 2014, 08:35:16 PM »
Hey,tomorrow I Will go to mi Garage and I take pics from my 550 k3 for you.
MIKE550/4
  • Guest
« Reply #5 on: January 06, 2014, 08:47:39 PM »
thanks piki appreciate that
just the top part of airbox and side shot should do
the manual photos not that clear on this section
Offline Piki
« Reply #6 on: January 06, 2014, 10:48:20 PM »
Look the number 15, his position is wrong, his position is on the bottom of the air filter box(look the diagram, there is a little hole) That piece is for fit the air box with the number 12.
Tomorrow more!!!
MIKE550/4
  • Guest
« Reply #7 on: January 06, 2014, 11:02:56 PM »
i think I get it now
no 15 goes on inside of airbox
no 29 goes through plenum chamber , through the airbox and into no 15
would still like to see the pictures Piki to clarify   8)
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8 on: January 07, 2014, 02:44:07 AM »
^^ That is correct.
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
Offline Piki
« Reply #9 on: January 08, 2014, 08:52:38 AM »
Hello Mike, look:
Subido en subir imagenes
« Reply #10 on: January 08, 2014, 09:06:31 AM »
Piki, in the last picture. Your breather element/condensation trap or what ever other people call it,  isn't it up side down?. Nice clean bike.
Offline Piki
« Reply #11 on: January 08, 2014, 11:32:59 AM »
Hi trigger,  it is in the correct position!!!
MIKE550/4
  • Guest
« Reply #12 on: January 08, 2014, 12:14:32 PM »
Yeah that looks right, next part goes in upside down with spout pointing up
thanks for the photos
MIKE550/4
  • Guest
« Reply #13 on: January 08, 2014, 07:17:04 PM »
So after lots of input think I am there just need correct 18mm washer ;D
if this is wrong I am fitting pods  ;D
« Last Edit: January 08, 2014, 09:10:56 PM by MIKE550/4 »
MIKE550/4
  • Guest
« Reply #14 on: January 08, 2014, 08:01:20 PM »
its where the washer is now just wrong size fitted
18mm needed ;)
« Last Edit: January 08, 2014, 09:11:36 PM by MIKE550/4 »
