Author Topic: STEERING LOCK REPLACEMENT  (Read 8593 times)
Offline MikeM
Re: STEERING LOCK REPLACEMENT
« Reply #15 on: February 13, 2014, 08:03:57 PM »
cheers guys managed to get this out today and ordered a replacement.... do I have to keep anything back from this set I took out..... looks like in kit you get new spring
 also on refit do the bars have to be in certain place ?
« Reply #16 on: February 13, 2014, 08:11:43 PM »
Nice hole Mike, and no scratches to the frame.
Offline MikeM
« Reply #17 on: February 13, 2014, 08:17:45 PM »
hi
yeah it came out pretty clean, tapped the disc off was quite easy, drilled as guys said until the pins just collapsed and then prised out..... not to bad a job for first time
Offline totty
« Reply #18 on: February 13, 2014, 09:06:39 PM »
You may need to keep the rivet and washer, the rivet that came with mine was smaller.
The spring must go with the end that is more tightly wound pushed onto the lock or it jams. You have to insert it with the key turned, but that will be obvious when you try it.
Offline tom400f
« Reply #19 on: February 14, 2014, 11:45:28 AM »
If you get the genuine part it comes with no spring and no rivet so you have to reuse these.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
