k3 throttle cable pulley
Topic: k3 throttle cable pulley (Read 9323 times)
MikeM
SOHC Expert
February 28, 2014, 06:46:38 PM »
spoke to a couple of members who have what I assume is a different set up to what I have
attaching the throttle cables to the pulley on top of carbs
on what I have seen pics ( 500 and 400f ?) of the cable nipple go into 2 holes on the same pulley one to open and one to close
on the k3 I assume its different
ie one goes into pulley other one goes into a cradle that swings up
so am I correct and if so does the cable go under the carbs or as I have it now over the carbs
also cable route correct ..... under rpm, down the left hand side of bike
pics
route first
through the rpm counter
down the left and onto the carbs
now this place for fitting the cable on top of carb
I hope in this pic you can see where I think it goes different to other 550s and 500s ?
pic showing what I am trying to connect
and lastly connected into this cradle but the wire going over the carbs which I am not convinced is correct so thought I would ask
mickwinf
Re: k3 throttle cable pulley
February 28, 2014, 08:20:49 PM »
Mike you have got it wrong, the two throttle cables fit on the pulley similar to the older models, on your last pic you have the cable connected to the choke operating lever, the K3 has a cable operated choke, the choke cable fits to that lever from above.
MikeM
SOHC Expert
February 28, 2014, 08:31:09 PM »
so there are two holes in the pulley where I have the first cable ?
struggling to find the second hole....
LesterPiglet
1977 CB550F2
February 28, 2014, 08:34:26 PM »
Zoom in on the pulley here. Looks like a hole right on the end.
http://www.cmsnl.com/cb550k3-four-england_model14671/partslist/E17.html#row16026393004
'Then' and 'than' are completely different words and have completely different meanings. Same with 'of' and 'have'. Set and sit. There, their and they're. Set/sit. Bought/brought FFS. Bloody Americans.
Les Ross. Certified by a Professional
matthewmosse
February 28, 2014, 08:50:02 PM »
the top cable runs quite a long way along that grove in the pulley and the hole / cutaway is a swine to get it in, especially if the cable inner snaps outside work, 20 miles from decent tools and in 4 inches of snow and frost - I gave up and just turned the idle screw right up. Look below the choke cable, on the pulley, long needle nose pliers with a double crank in them help, or it might have been a 90 deg bend set.
MikeM
SOHC Expert
February 28, 2014, 09:40:43 PM »
so is the 2 holes close to each other ? and not one on each end of pulley
also does then the top cable reach to furthest away hole
matthewmosse
February 28, 2014, 10:18:27 PM »
I think I need to go outside and look at mine (tomorrow) I'm struggling to recall exact details but it was a bit confusing or counter intuative. Might the long cable pass under the pulley thing and have a fairly long slot? I'm struggling to recall which set of carbs did what, having had 500 and 550k3 carbs on my regular bike.
Just to add, studying the cnsl pic in the link, and wracking my addled beer soaked brain, the long cable I'm sure goes under the carbs and you hook it into that slot that can be seen at the back of the pulley, then the short cable is running over the top which I think is how you have it. I'm afraid my laptop screen is a wreck so pictures are often a blur of red and green in places.
Last Edit: February 28, 2014, 10:27:24 PM by matthewmosse
mickwinf
February 28, 2014, 11:11:52 PM »
If you send your email address I can send you a 550k3 supplement which has lots of info and photos about the carbs.
matthewmosse
March 01, 2014, 12:48:33 PM »
On my k3 carbs the cable runs short over the top, long under the spindle and up the back of the pulley, the round cutout holds the top cable, bottom slot that follows the perimeter of the pulley - end result puts the ends of the cable about 40 mm appart I'd geuss. I think I also figured out why the bike conked out when last used as all the cables are off. Silly reason for a bike to get laid up for years!
mickwinf
March 01, 2014, 01:40:12 PM »
this pic from the US site might help. The bottom cable nipple goes in the slotted part near to the hole for the top cable, not obvious at first look.
MikeM
SOHC Expert
Reply #10 on:
March 01, 2014, 02:45:12 PM »
arrghh getting frustrating now
pull to top .....
closing cable on bottom holder
top cable over the top of pulley and nipples pushes sideways into the hole
bottom cable ( close ) under the pulley in the groove of pulley and nipple sits sideways in the groove
end result not able to move throttle on grip, I am obviously doing something wrong, read manuals supplement and seem to be doing it correct
so guys any more ideas hope the vid helps it to show better
MikeM
SOHC Expert
Reply #11 on:
March 01, 2014, 02:45:35 PM »
https://www.youtube.com/watch?v=u-53LnbeuAU&feature=youtu.be
matthewmosse
Reply #12 on:
March 01, 2014, 05:45:37 PM »
tried swapping the cables over inside the twist grip? Or taking the twistgrip off the bars. Seems very odd, might be something binding somewhere, taking the twistgrip out of the equation might help figure out the culprit.
mickwinf
Reply #13 on:
March 01, 2014, 07:49:42 PM »
Just a thought, does the opening cable go on the bottom of pulley, try swapping them around.
MikeM
SOHC Expert
Reply #14 on:
March 01, 2014, 07:57:10 PM »
just loosened off the throttle stop and the cables now move, quite hard to move but maybe easier with the rubber grip on the throttle
I guess I now have to set it up ?
