Author Topic: fork drain screw bolt sheared  (Read 31726 times)
Offline MikeM
Re: fork drain screw bolt sheared
« Reply #30 on: March 26, 2014, 12:29:57 PM »
Sounds expensive though how come one kit is like a tenner otheris pushing 100 ?
looks same contents ?
ka-ja
  • Guest
« Reply #31 on: March 26, 2014, 03:44:21 PM »
Hi oddjob,
                        1D-2D etc is the depth ie 1 times Diameter, 2 times Dia. and so on---Ken
                   I only have standard pitch/depth inserts, but willing to loan for postage costs
« Last Edit: March 26, 2014, 03:48:18 PM by ka-ja »
ka-ja
  • Guest
« Reply #32 on: March 26, 2014, 04:02:24 PM »
Hi,
     Sizing is on thread size 6mm.1D is 6mm dia and 6mm deep, the depth needs to match depth of the hole because it is difficult to remove excess once the thing is fitted, or if the hole has no bottom and you end up with the insert too deep----Ken
ka-ja
  • Guest
« Reply #33 on: March 26, 2014, 07:09:24 PM »
Hi,
     They are making the assumption they are selling to engineering trade I suppose---Ken
Offline MikeM
« Reply #34 on: March 27, 2014, 08:41:23 AM »
cant find a 10 mm deep coil, can you use two? say 5mm each ?
ka-ja
  • Guest
« Reply #35 on: March 27, 2014, 09:10:14 AM »
Hi,
     PM me and I will try to help, you need a 6mm helicoil by 1.5 depth if available, but a 6mm standard length should do, as the helicoil is far stronger than the original thread, and it seals under the bolt head, not on the threads---Ken
« Last Edit: March 27, 2014, 09:16:45 AM by ka-ja »
Offline MikeM
Offline hairygit
« Reply #37 on: March 27, 2014, 07:17:48 PM »
No, it's not a good idea to try and use 2! I have seen 1.5 dia ones which are 9mm long for M6, I may even have some buried at the back of my workshop, I will check for you tomorrow
Sent from my GT-S5839i using Tapatalk 2
Offline hairygit
« Reply #38 on: March 27, 2014, 07:30:56 PM »
Just found the e bay item you want, number 111273402176  he does them in packs of 10, less than £3 including post, they are 1.5xD which is 9mm long, just in case I can't find any
« Reply #39 on: March 27, 2014, 08:58:20 PM »
Hairy, there would be no point sending Mike a helicoil without the tap and insert tool. Even if he bought a helicoil kit, it doesn't come with a tap wrench.
« Last Edit: March 27, 2014, 09:00:52 PM by trigger6969 »
Offline hairygit
« Reply #40 on: March 27, 2014, 09:42:12 PM »
Hi Trigger, I had assumed from Mike's last post that he had ordered a kit but couldn't get a kit with Dx1.5 coils:))
Offline MikeM
« Reply #41 on: March 27, 2014, 10:10:04 PM »
thanks all
just bought the 8mm kit , no big deal I will order the 9mm coils as well,  great fun this drilling lark  :-\
« Reply #42 on: March 27, 2014, 10:29:30 PM »
Sorry, Hairy. I am getting lost here Mike. Why have you ordered a 8mm helicoil kit when the oil drain bolt is 6mmx10mm? When you say 8mm do you mean the length???
« Reply #43 on: March 28, 2014, 07:27:19 AM »
Get a cheap set of "rats tail" files as if there is any coil left outside after fitting to full depth you use the triangular file to put a notch in the coil wire at the edge of the hole and break off the excess---hope that makes sense asit's a damn site easier to do than explain
Offline MikeM
« Reply #44 on: March 28, 2014, 07:48:00 AM »
http://www.ebay.co.uk/itm/25-Piece-Helicoil-Thread-Repair-Kit-M6-x-1-0-x-8-0mm-/310678382294?pt=LH_DefaultDomain_3&hash=item4855dfe6d6#ht_1761wt_952
what I have ordered  ;D
m6x1x8.......... could not find a 9mm kit but hairygit gave me link to the coils....... and tap is in the kit
