Other Stuff
What is it?
Cam info
Topic: Cam info (Read 5632 times)
teebee67
Newbie
Cam info
May 26, 2014, 10:34:26 PM »
Hi,
I bought a used big bore kit off Ebay. With the kit was a camshaft which is marked on the end with H7Y. Can anyone identify the cam from this?
Any help much appreciated.
Cheers,
Tony
Trigger
Engines built on reputation, not advertising.
Re: Cam info
May 26, 2014, 10:52:27 PM »
Tony, is the cam shaft from a CB550? I have seen his number on american cams.
teebee67
Newbie
Re: Cam info
May 27, 2014, 08:30:26 AM »
Hi,
Sorry I should've stated it is from a CB750 SOHC.
Cheers,
Tony
Re: Cam info
May 31, 2014, 04:34:57 PM »
Numbers on the end tend to be casting marks and mean nothing, some US makers mark the special cams but not many. All you can do is measure the lobes and compare to standard along with aftermarket "hot" cams
ka-ja
Re: Cam info
May 31, 2014, 07:15:04 PM »
Hi,
My 400/4 road/track cam has similar stamped numbers/letters on the timing end of the camshaft---ken
Other Stuff
What is it?
Cam info
