Author Topic: K2 carb throttle spindle carrier.  (Read 5895 times)
Offline r1_pete
« on: June 06, 2014, 08:39:44 PM »
My carb throttle spindle carrier / mounting bracket is broken, on taking it to bits I find the 10mm shaft is running in a 13mm bore in the ally casting.
Before I go hunting for another casting, are there different sizes, or should there be a bushing in each of the casting lugs which the shaft runs in?
do these issues ever stop, I had less hassle with the E Type.....
Cheers.
Pete.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Re: K2 carb throttle spindle carrier.
« Reply #1 on: June 07, 2014, 07:56:43 AM »
Can you post a pic or P/N of what is broken Pete. I broke up a set of K2-K6 carbs to steal the floats/clips etc. from them for my K0.
Also have the alloy carrier for K7 carbs but that's totally different.
Cheers.... AshD
Offline r1_pete
« Reply #2 on: June 07, 2014, 10:52:02 AM »
Its the bit circled which has broken off on mine, I tried welding it, but the metal is like an aero chocolate bar and just will not weld neatly.
1971 CB450
Offline mickwinf
« Reply #3 on: June 07, 2014, 04:39:56 PM »
Pete if that is similar to the 500/550 type there was a pin that locates the shaft via a groove in the shaft itself, it stops side to side movement, usually gets broken when the shaft is forcibly removed (don't ask how I know :-[ )
« Reply #4 on: June 07, 2014, 05:46:23 PM »
I am pretty sure I have one of those spare Pete but may have spindles etc. still on it. It's no use to me as the 750K0 has 4 separate carb cables. I will have to venture in the garage which is chocker so give me a day to find it and I will send pic, if you are interested.
Cheers .. AshD
« Last Edit: June 07, 2014, 05:48:15 PM by AshimotoK0 »
Offline r1_pete
« Reply #5 on: June 07, 2014, 08:06:38 PM »
Yes please Ash, no rush, I'm not having much luck with this build, everything seems to be broken...
1971 CB450
« Reply #6 on: June 08, 2014, 09:12:24 PM »
Wow must tidy that garage and get rid of the Midget!!!!  ::)
Here goes ... ones definitely off a '77 K7 (lower one in photo) and I think the top is K2-K6 but I will let you decide. Spindle nice and free on top one.
Cheers ...AshD
« Last Edit: June 08, 2014, 09:15:06 PM by AshimotoK0 »
Offline r1_pete
« Reply #7 on: June 10, 2014, 11:21:59 AM »
Cheers Ash, I have PM'd you.
1971 CB450
« Reply #8 on: June 10, 2014, 10:06:30 PM »
No PM yet Pete
Cheers  ... AshD
« Reply #9 on: June 26, 2014, 12:22:01 PM »
Arranged shipping by MyHermes Pete to your daughters work.
Collection date   Collected from   Delivery to   Weight   Parcel no.
27/06/2014   HU3 2DJ   S40 3QT   1 - 2 kg   9021373247153980   Track
Total (ex VAT)   Â£3.32
Total VAT   Â£0.66
Total (inc VAT)   Â£3.98
Cheers ... AshD
