Author Topic: Cam Chain Play  (Read 5087 times)
Offline Lynx
  • Repair & Despair Under One Roof
Cam Chain Play
« on: July 08, 2014, 10:25:24 AM »
My newly rebuilt 400 has just clocked up 500 miles on the road. So I decided to do an oil and filter change, re-torque the head bolts and adjust the valve clearances. One thing struck me which I found a bit strange was that I could roll the cam backwards and forwards a bit as there is some slack on the chain. Is this normal? I know on most bike the cam chain would be tight. I've tried slackening off the tensioner bolt with the engine off and running, but no change. It's a new chain and when I rebuilt it, all the tensioner parts looked good.
Yamaha RD500LC
Triumph Speed Triple RS.
Previous bikes include
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline tom400f
Re: Cam Chain Play
« Reply #1 on: July 08, 2014, 11:08:45 AM »
The hole the tensioner rod runs in has a blanking cap at the top of it. It's common 400F procedure to remove this and press down gently on the rod with (say) a torx screwdriver while you loosen the pinch bolt. The spring on its own is not trusted to do the job.
Give that a try and see how it looks afterwards.
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline Lynx
Re: Cam Chain Play
« Reply #2 on: July 09, 2014, 02:15:11 PM »
Thanks Tom. That seems to have quietend the chain. So I presume the slack has gone.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
Offline tom400f
Re: Cam Chain Play
« Reply #3 on: July 09, 2014, 03:24:41 PM »
Ok great. With one of the tappet covers off (which is how I assumed you were observing the slack) you could rock the crank and see if there's any backlash in the valve movement...
1978 CB400F2 Yellow
Offline Lynx
Re: Cam Chain Play
« Reply #4 on: July 09, 2014, 06:12:22 PM »
I had the cam box cover off to torque the head, but I'll try just a tappit cover.
Yamaha RD500LC
CB350K3 x2
CB250G5
CX500C
VF500F2
VF1000FE
