Author Topic: swingarm bushing dimensions  (Read 16618 times)
Offline MikeM
« on: July 20, 2014, 02:46:11 PM »
anyone got the dimensions for the plastic swingarm bushings.... main one that main bolts slides through?
550k3
Offline MikeM
Re: swingarm bushing dimensions
« Reply #1 on: July 21, 2014, 09:25:52 AM »
anyone? got a guy making me some brass bushings
Offline hairygit
« Reply #2 on: July 21, 2014, 12:01:30 PM »
Mike, the plastic bush dimensions are rather irrelevant, as they change when fitted. Best thing to do is measure the inside diameter of your swinging arm and the outside diameter of the collar which which the pivot bolt fits into. Although , I'm not sure brass would be the best material to make them from, phoshour bronze would be much better due to it's oil retaining properties, and these are readily available on e bay from germany for less than £15.00 a pair delivered, and I use them so I know they fit and work well
Sent from my GT-S5839i using Tapatalk 2
Offline MikeM
« Reply #3 on: July 21, 2014, 12:56:27 PM »
drop us a link to them ones would you please mate, sound just what I am after
Offline JustcallmeMrT
« Reply #4 on: August 09, 2014, 10:13:33 PM »
I found these - havent ever used hem but am interested as well.  Are these the ones youve used?
http://m.ebay.de/itm/131207862914?nav=SEARCH
Offline hairygit
« Reply #5 on: August 10, 2014, 08:39:20 AM »
Yep, they're the ones! Make sure before fitting them that you soak them for 24-48 hours in engine oil (clean oil!) or better still EP90 gear oil. This is because phosphor bronze is porous and will last even longer if lubricated before fitting! ;D
« Reply #6 on: August 10, 2014, 09:48:56 AM »
Thanks for the tip!
« Reply #7 on: August 10, 2014, 09:59:24 AM »
I have fitted loads of those bushes from Frank in Germany. They are very good quality but, press them in. Do not use a hammer as these damage easy.
Offline Erny
  • CB750K7 CB550K1
« Reply #8 on: March 24, 2019, 08:36:28 PM »
I'm going to refresh this topic. Got new bushings supplied by PO with bike, but they are too small (OD) so I can just push them inside swingarm by thumb, morever have play over the brand new collar.
Can someone recommend where I should buy proven quality? Is it still from twowheelsfrank from Germany?
https://www.ebay.de/itm/132265500481?ul_noapp=true
« Last Edit: March 24, 2019, 08:39:16 PM by Erny »
CB750K7 US model (1977)
CB550K1 US model (1975)
« Reply #9 on: March 24, 2019, 08:49:05 PM »
As you are in mainland Europe, i would suggest and recommend you buying them from Frank. If you were in UK, I would suggest you buying them off my Ebay page 😀😀😀
Offline Erny
  • CB750K7 CB550K1
« Reply #10 on: March 24, 2019, 09:05:08 PM »
Video that shows all... https://youtu.be/wPl_rxV-z1s
And photo of package and bushings itself
Offline Erny
  • CB750K7 CB550K1
« Reply #11 on: March 24, 2019, 09:06:21 PM »
So twowheelsfrank is Frank you mentioned, right?
« Reply #12 on: March 24, 2019, 09:07:28 PM »
I would check your swing arm Erny. Those bushes are the same as you will get if ordered from Frank or myself. They are the correct ones for your bike.
« Reply #13 on: March 24, 2019, 09:08:04 PM »
Yes
« Reply #14 on: March 24, 2019, 09:09:30 PM »
Erny, the ones in the picture above, I take it they were the ones the PO gave you or the picture from the video?
