Author Topic: replica shock absorbers  (Read 13817 times)
Re: replica shock absorbers
« Reply #15 on: August 09, 2014, 06:37:06 PM »
Best to take them apart in a press. The damper rod will need hard chrome.
Offline wolfheze
« Reply #16 on: August 09, 2014, 08:03:40 PM »
I am fairly certain that the damper rod will be fine, like i said the dampers look almost new, the only thing wrong with them visually is some very light pitting on the shrouds.
« Reply #17 on: August 10, 2014, 04:06:52 PM »
You have to pull the shroud down along with the spring then the retaining collet(s) will come out
Offline wolfheze
« Reply #18 on: August 10, 2014, 06:17:26 PM »
Ok thank you
