CB350/400
Carburettor Rebuild Time... Help!
3
Topic: Carburettor Rebuild Time... Help! (Read 16111 times)
Drew400
400/4 I restored
August 10, 2014, 05:07:44 PM »
Hello all,
Time for your expert advice on a different topic please - carburettor rebuilding.
I have inserted an image to support my questions.
The bits have all come back from cleaning, plating, etc. and are gagging to go back together. However, both my manual and my photos are slightly inadequate to help my lack of experience and memory!
I recall pulling out the main jet with the leaf spring and after that the needle jet 'fell' out of the carb body. However, I'm trying to put them back and the needle jet will only go in as far as (i.e. flush to) the bottom of its channel in the carb body. Thus, there in not the space to push in the main jet behind it. Naturally, I don't want to force it as that would presumably mean it won't fall out again if I invert the carb body. Is this making sense?
Also, my set of carb gaskets from David Silver includes some small ones (o-rings really) that I don't know what they're for, Do you?
Thank you all in anticipation of further help to my (increasingly) long-term project.
D.
Previous bikes:Puch Maxi 50, CD175, Suzuki T500, CX500, Z200, GS850, XS1100, GT750 (kettle), RD400, GTR1000 (not too many boastables in there!), CB750F2 Phil Read Replica
Trigger
Engines built on reputation, not advertising.
Re: Carburettor Rebuild Time... Help!
August 10, 2014, 06:06:35 PM »
Drew, Number 2 is correct (not sure if the is round the right way) But, have you changed the O'ring on the main jet? One O'ring is for the main jet. One is for the air screw . You will need two on each side of the T pipe that is the T pipe that goes between the carb body's. You should have one on your float body. And one is for the drain screw.
Last Edit: August 10, 2014, 06:15:26 PM by trigger6969
Drew400
400/4 I restored
August 10, 2014, 06:16:17 PM »
Thanks Trigger, much appreciated.
Any thoughts on why my needle jet won't slide in far enough to allow the main jet to slot in behind it?
Cheers,
D.
Trigger
August 10, 2014, 06:25:57 PM »
Drew, i think you are on about the tube? Try putting it in the other way. I can not see clear from your picture, its not you its my eyes. The jet only goes in upto the o'ring and then the leaf spring holds it in.
Last Edit: August 10, 2014, 06:27:50 PM by trigger6969
Drew400
400/4 I restored
August 10, 2014, 08:15:24 PM »
Yes indeed (the tube with all the holes in its side). I've tried both ways, although the way I've photographed is the correct way, I believe. If it would go in a bit further there would then be space to insert the jet, as you say, up to the o'ring. I'm very reluctant to push it in harder! Hmmm.
p.s. Delayed reply due to watching another Marquez MotoGP win (at least the first 12 laps were exciting!).
Norniron
SOHC Expert
August 10, 2014, 09:03:38 PM »
Insert it like this pic
1977 400 cafe
1972 500/4
2013 triumph STR675
Trigger
August 10, 2014, 09:08:05 PM »
The 400 expert has made his comment
ewanhughes
Newbie
August 10, 2014, 10:00:43 PM »
Have you seen this before Drew?
It really is the badger's nadgers of carb rebuild documents!
http://www.docstoc.com/docs/97200467/CARB-REBUILD-101
Drew400
400/4 I restored
August 10, 2014, 10:08:07 PM »
Thank you again, all.
Cheers,
D.
Clem2112
Midlife
SOHC Expert
CB400F1 1976 R1200GS 2016 Matchless G80 1955
August 10, 2014, 11:29:57 PM »
One thing
The airscrew has no O ring .... Just the spring.
Clem2112
Midlife
SOHC Expert
Reply #10 on:
August 10, 2014, 11:40:37 PM »
O rings are for the main jet, float valve and the drain screw. The 4 larger ones are for the fuel feed connector tubes or the inlet tee.
Drew400
400/4 I restored
Reply #11 on:
August 11, 2014, 08:27:03 AM »
Thanks again, I'm now clear on the gasket set.
I'll have another go at inserting the needle jet tube in the next few days. Maybe it's just a bit of a tight fit after the carbs were cleaned, but it's still a source of slight worry to me (I don't like pushing hard on carb bits as they all seem so delicate!).
Cheers for now,
D.
Trigger
Reply #12 on:
August 11, 2014, 08:47:36 AM »
Spot on Clem. You are right about the air screw. Drew, wipe a little Vaseline on the tube to see it it will slide in. Has the tube been cleaned?
Drew400
400/4 I restored
Reply #13 on:
August 11, 2014, 09:45:54 AM »
Thanks again Trigger,
I have cleaned the tube only with petrol and airline, but the carb body has had the full sonic and vapour blast treatment.
I'll try the old Vaseline trick when I next get into my garage. Sadly, the day job gets in the way of the rebuilding classes, eh?!
Cheers,
D.
Trigger
Reply #14 on:
August 11, 2014, 09:53:54 PM »
Drew, the tubes need to be nice and clean and all the holes checked. As Norniron once said, You may think that they are clean but, have a look with a microscope. He was right.
3
CB350/400
