Other Bikes
Import Suzuki parts list
Topic: Import Suzuki parts list (Read 3180 times)
August 13, 2014, 07:43:29 AM »
Does anybody know where i can get part numbers for a 1991 Suzuki GS400 twin carbs, cycle parts are identical to 500 but not sure on carb jets, needles, etc
Johnwebley
Re: Import Suzuki parts list
August 13, 2014, 01:59:01 PM »
have you tried
CMSnl.com
they do Suzi stuff
Trigger
Engines built on reputation, not advertising.
August 13, 2014, 06:28:06 PM »
I have the same problem with trying to find the tappet clearance on a Import Suzuki. The information is not available, well maybe in Japan.
August 14, 2014, 06:41:10 AM »
CMSNL only list the 500 John, and I need to know if the needle and jet are different.
Trigger most Suzukis had the same clearance bit like Hondas
Trigger
August 14, 2014, 08:18:50 AM »
Already gone down that road Bryan, it did not work. Many Suzuki's are different. Honda are different with listings of 0.10mm and 0.12mm on the CX which is wrong. Compared to the CB500 Four at 0.05 and 0.08. Air cooled and water cooled are always different.
These GSX-R400's run hot due to the rad resting on the down pipes.
Trigger
August 14, 2014, 06:56:44 PM »
Too old Oddjob. Looking for 1984 to 1986.
Other Bikes
