Author Topic: powder coating how many parts?  (Read 4398 times)
Offline antonypo
  • wheres the breaks on these cb 750's !
« on: October 03, 2014, 10:05:58 PM »
Well I have decided to powder coat in black although I'm tempted to match the colour of the tank but not sure it's the right thing to do.
Anyway how far do you go with this? I can imagine sending the frame and swing arm but do you send both yolks and what about the battery box and back brake arm?
What about the foot pegs?
I'm sure you will all have experience of this so looking forward to the replies.
Also been warned about the tag on the frame could get blown off in the process and devalue the bike without it??
Antony
Offline MarkCR750
Re: powder coating how many parts?
« Reply #1 on: October 03, 2014, 11:02:00 PM »
You can have as many parts of the bike powder coated as you like, battery box and stands, footpegs etc, the powdercoat finish is far more resilient than paint so it is ideal for such parts (remember to ask for gloss finish) just make sure you get a quote up front, black is the only colour that will look ok on your frame, you can remove the data plate before sending the frame in, carefully remove the rivet heads with a small drill (very slow speed if you use an electric drill) then gently tap the rivets through with a centre punch, don't bother preparing the frame yourself just get it sand blasted, sand blasting and powder coating together cost me £200.
« Last Edit: October 03, 2014, 11:04:20 PM by MarkCR750 »
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline UK Pete
« Reply #2 on: October 03, 2014, 11:45:01 PM »
Just be careful i had a frame and swing arm done they powder coated where the swing arm bearings go, and a few other places where i didnt want paint, make sure you tell them where to plug and mask up, the last one i did was £120 for frame swingarm and all the brackets
pete
« Reply #3 on: October 04, 2014, 08:49:14 AM »
I probably went over the top with mine, but I wanted to do it once only, this was my list. For the F2 I will only do the frame and parts that see the most wear such as stands.
1   Frame
2   Swinging arm
3   Rear brake torque arm.
4   Oil tank
5   Top Yoke (Alloy)
6   Bottom Yoke
7   Speedo/Rev counter bracket
8   Front indicator brackets left
9   Front indicator brackets right
10   Engine mount front (triangular)
11   Engine mount rear
12   Stoplight bracket (small L shape)
13   Left footrest: bracket
14   Left footrest: footrest
15   Left footrest: rubber protector.
16   Right footrest: bracket
17   Right footrest: footrest
18   Right footrest: rubber protector.
19   Passenger footrest bracket (left)
20   Passenger footrest bracket (right)
21   Tail light number plate holder (CB750F1)
22   Tail light number plate holder (CB750F2)
23   Main stand
24   Side stand
25   Handle bar clamp Alloy.
26   Handle bar clamp Alloy.
27   Battery holder
« Reply #4 on: October 04, 2014, 09:01:40 AM »
Hope Kettle738 doesn't see this post  ::) His answer to the title would be none,zero
« Last Edit: October 04, 2014, 09:10:26 AM by AshimotoK0 »
Offline antonypo
« Reply #5 on: October 04, 2014, 11:11:41 AM »
great answers as usual. THANKS !
Antony
