Author Topic: Crankcase Breather  (Read 9178 times)
Offline ShaunJ
Crankcase Breather
« on: November 07, 2014, 02:21:39 PM »
It looks like the bottom half of my crankcase breather filter is completely missing. This is the one that is located directly beneath the battery box. Two pipes are connected to the cap which effectively go direct to the atmosphere. I can't seen to track down a replacement bottom part. Two questions first one is does it matter? The second one is are there alternatives to the OE filter?
Present CB750 K7
Re: Crankcase Breather
« Reply #1 on: November 07, 2014, 02:27:44 PM »
http://www.cmsnl.com/honda-cb750k7-four-england_model14390/partslist/F15.html#results
Take another look here so you can see what your looking for best bet EBAY.
Bitsa
Offline ShaunJ
« Reply #2 on: November 07, 2014, 02:53:37 PM »
Thanks Bitsa. It looks like DK have one on eBay for £30. I need to double check mine as it looks slightly different, maybe there were differences between UK and USA specification. Might make them an offer as I am not sure it will work and I am from Yorkshire  :)
Present CB750 K7
« Reply #3 on: November 07, 2014, 07:14:50 PM »
Shaun
Yer right :D, all its for is to reburn the gases from the cases etc you can do away with it if you like.On the older ones the vent from the rocker just goes into the atmosphere and the case gases went back into the oil tank.It was for the states as usual so its up to you do you want her original?
Bitsa
Offline hairygit
« Reply #4 on: November 07, 2014, 07:37:12 PM »
The same canister is used on the 750F1, took mine off and threw it away many years ago, makes no difference to the running. Just fitted a longer breather from the casings to go down and out near the stand pivot. If you're a true Yorkshireman you can just extend the pipe with a bit of garden hose or similar (pinch a bit from a neighbour's hose?) and hey presto, no money spent>:D
Sent from my GT-S5839i using Tapatalk 2
« Reply #5 on: November 07, 2014, 08:12:22 PM »
Agree with Hairygit git but would find something better than a friggin garden hose you green bugger
Bitsa
Offline hairygit
« Reply #6 on: November 07, 2014, 09:23:35 PM »
T'was a joke Bitsa:o But seriously, just extend the breather down the back of the engine and out by the c/stand.
« Reply #7 on: November 07, 2014, 09:25:44 PM »
Yeah of course mate but what you said is right
Bitsa
« Reply #8 on: November 07, 2014, 09:28:20 PM »
Bet NurseJulie could find you some interesting rubber tubing from her hospital   ;D
Offline hairygit
« Reply #9 on: November 07, 2014, 09:44:01 PM »
Is that another of your fetishes coming to light here Ash?:o
« Reply #10 on: November 07, 2014, 09:51:19 PM »
For frac sake give it up guys no wonder wonder why women think we are  sad pricks
Bitsa
Offline ShaunJ
« Reply #11 on: November 07, 2014, 09:59:39 PM »
Thanks for all the suggestions guys. Certainly something to think about. Nurses.... Rubber Tubes.... Fetishes.... I completely forgot about the Crankcase Breather  :o
Present CB750 K7
« Reply #12 on: November 08, 2014, 12:13:50 PM »
Shaun
Saw one today on ebay k7 breather
Bitsa
Offline ShaunJ
« Reply #13 on: November 08, 2014, 04:56:49 PM »
Thanks Bitsa
There were two one for £30 or offers and the other for £15 both from DK. Obviously I bought the cheaper one.
Present CB750 K7
« Reply #14 on: November 08, 2014, 06:55:25 PM »
Shaun
well done that's you sorted WHO's next?
Bitsa
