CB750
Throttle command
Topic: Throttle command (Read 8461 times)
El__burro
SOHC Expert
Throttle command
November 14, 2014, 06:39:32 PM »
Hello, I am looking to purchase a dual/twin throttle control for my cb750.
Ideally I would go for a Tomaselli domino as I have this mounted on another bike and i find it ok. Unfortunately budget restrictions apply.
I have come across the Doherty 77 replica but it's so cheap that I am a bit hesitant.
Anyone has used this or have some feedback to share.
El__burro
UK Pete
Re: Throttle command
November 14, 2014, 06:59:32 PM »
Are you talking of a twin cable push pull throttle or something else?
pete
Link to sandcast restoration
El__burro
SOHC Expert
November 14, 2014, 07:00:24 PM »
Yes, that one.
UK Pete
November 14, 2014, 08:59:45 PM »
i have one you can have for £5+ postage, it was on a honda 750 but its not original has a dent and needs cleaning and painting
El__burro
SOHC Expert
November 14, 2014, 09:09:22 PM »
Thanks for the offer but I have the same, just wanted to replace it with a twist grip only.
K2-K6
November 14, 2014, 09:50:14 PM »
Don't know if they are the same but Doherty did make twist-grips for moto-x bikes years ago, they were fairly basic but also seemed quite tough and worked ok.
El__burro
SOHC Expert
November 16, 2014, 05:17:01 PM »
Just purchased a Doherty 77 replica.
I'll post an update once i have an idea.
El__burro
SOHC Expert
October 16, 2015, 02:11:41 PM »
Just to say that the Doherty type twin pull, (that i have) pulls both cable to the same direction, Infact I can only use with 1 cable. I'm not sure this should be the case.
El__burro
Chris400F
October 16, 2015, 04:30:30 PM »
Presumably yours looks something like this, which is intended for use on twin carburettor machines with a separate cable for each carb.
El__burro
SOHC Expert
October 16, 2015, 04:31:05 PM »
exactly!
Chris400F
Reply #10 on:
October 16, 2015, 04:49:36 PM »
For a push pull setup how about something like this:
https://www.venhill.co.uk/Controls,_Levers_&_Handlebars/MOTORCYCLE_CONTROLS/TWISTGRIPS/888_VENHILL_FAST_ACTION__PUSH-PULL_TWISTGRIP.html
or this (cheaper!):
http://www.caferacerwebshop.com/twin-push-pull-black-twistgrip-7-8-or-22mm-type-1.html
r1_pete
SOHC Member
Reply #11 on:
October 18, 2015, 04:38:03 PM »
The VTR1000 twistgrip body will work with the standard grip, and give you what you need, plus its all Honda and will look factory.
http://www.ebay.co.uk/itm/Honda-VTR-1000-Firestorm-1998-throttle-tube-twist-grip-/281809688483?hash=item419d2a97a3:g:wsgAAOSw3ydV3Hps
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
El__burro
SOHC Expert
Reply #12 on:
October 18, 2015, 06:08:51 PM »
Nice, the VTR one looks very nice, shame I didn't see it before. I'll think of it when/if i need to replace the Doherty type.
El__burro
yozzer74
Reply #13 on:
October 27, 2015, 10:26:49 PM »
I'm thinking of buying one of these for mine anyone used before was thinking of the venhill 888 but at over hundreds pounds a little exspensive .these are half the price .
Greebo
Reply #14 on:
October 30, 2015, 04:22:19 PM »
Talking of Throttle >>>take a look here, its Brilliant
https://www.youtube.com/watch?v=0sCbJCDHVpg
CB750
Throttle command
