Author Topic: Sintered pads  (Read 9086 times)
Sintered pads
« on: November 19, 2014, 05:57:40 PM »
Hi Chaps
Has anyone who has fitted sintered front pads noticed much difference? Have overhauled the front calliper which really needed doing so I'm sure the breaking will feel a bit better anyway but not sure if I should fit standard pads or sintered.
Ta
Julie
Re: Sintered pads
« Reply #1 on: November 19, 2014, 07:14:58 PM »
on my 500-4,I am using the "cheepo"
 Dave Silver pads,
 I am sure they are the same for your 400
Re: Sintered pads
« Reply #2 on: November 19, 2014, 07:17:49 PM »
Yes John but, you forgot to mention that you have 4 pads. Vesrah is good.
Re: Sintered pads
« Reply #3 on: November 19, 2014, 07:31:26 PM »
"Back in the day" we all used sintered pads and believed that they were better in the wet.
Truth be told, they were still rubbish in the wet.
We drilled our discs too...
Re: Sintered pads
« Reply #4 on: November 19, 2014, 07:45:50 PM »
Cant say I have heard of them but as Trig says yes to vesrah
DS ones last lot had to grind down to fit crap
Bitsa
Offline hairygit
Re: Sintered pads
« Reply #5 on: November 19, 2014, 07:50:34 PM »
I seem to recall that sintered pads used to score brake discs on some bikes, and as Steve said, there wasn't much improvement in wet weather braking, which was what they were supposed to do!
Sent from my GT-S5839i using Tapatalk 2
Re: Sintered pads
« Reply #6 on: November 19, 2014, 08:23:45 PM »
Bitsa
 fair does Bitsa,the DSS pads fitted perfectly first time for me,no filing the paint of the circumference,WOW,spelt that 1st time !!
little copper grease and hey presto,yes,they are hard,and have taken some time to bed in
Re: Sintered pads
« Reply #7 on: November 19, 2014, 08:27:11 PM »
John
This was a few years ago now maybe improved now like a lot of parts.They were just to big to go in the caliper.Once fitted worked fine
Bitsa
Offline Green1
Re: Sintered pads
« Reply #8 on: November 19, 2014, 08:31:21 PM »
Mine are also cheapo DSS pads they also went straight in.They also took an age to bed in so I roughed mine up with 40 grit paper and rounded the leading edge and they have now stopped squeaking
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: Sintered pads
« Reply #9 on: November 19, 2014, 10:19:23 PM »
These old discs where designed to run with non sintered pads and the advantage of using sintered with these sytems is maybe hard to see. It also seems accepted that with sintered you'd expect the disc itself to share the wear during use and ultimately change the disc itself far more often which doesn't really happen with old type non sintered pads.
As you've said Julie, there should be an improvement after servicing the caliper. i'd go with standard or Vesrah.
Offline tom400f
Re: Sintered pads
« Reply #10 on: November 20, 2014, 08:48:52 AM »
I used EBC ones:
http://ebcbrakesdirect.com/store/automotive/vt/1/mk/c5e6fc21-8874-49f5-84bd-1094e5dd73b8/md/df880e96-a293-4bac-8d64-343e713de0b3/vid/4ff7e117-9fc2-4dcf-b45b-16009dd7d8c5
This is on the basis of that btinternet 400F restoration site but I didn't think to ask here first.
They seem OK but only used in the dry. Anyone else used them?
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline ka-ja
  • ken
  • yoshi 460
Re: Sintered pads
« Reply #11 on: November 20, 2014, 09:22:32 AM »
Have used sintered pads for years, they do improve braking, but increase disc wear, and I too object to the phase "male menopause", I am on my 2nd. childhood, and its great!
nice bike,nothing in the bank
Re: Sintered pads
« Reply #12 on: November 20, 2014, 10:54:17 AM »
So it's a toss up between slightly better braking and slightly more wear on the disc. Maybe I should just go for 'normal' and see if they feel any better now the caliper has been services. Thanks for your advise.
Julie
Re: Sintered pads
« Reply #13 on: November 21, 2014, 07:19:38 AM »
I ordered EBC organic pads in error for my Tiger 1050. They were no better or worse than the HH pads I normally use but wore out completely in 5000 miles. That's twice as quick as I would expect.
Not relevant to our old bikes I know, but it would indicate that they are made with a softer compound (recycled compost? How can brake pads be organic?)
Re: Sintered pads
« Reply #14 on: November 21, 2014, 09:22:04 AM »
Must be made from banana skins Steve.
