Author Topic: 750 PISTONS AND RINGS  (Read 3998 times)
Offline PeterPen
« on: November 29, 2014, 11:24:22 AM »
Took the engine out of the K6, barrel base oil leak. All good except for pistons, ring lands worn. discovered another barrel and pistons in good shape, apart from a missing ring. Got a ring set and was about to swap pistons. Compression rings were 10 thou thicker, couldn't source correct rings. Had to assemble with worn. What are the barrels from? I can't remember. I did buy a K7 in pieces and also a K6 with spares.
Thanks Peter
Re: 750 PISTONS AND RINGS
« Reply #1 on: November 30, 2014, 12:23:32 AM »
F series have different rings which probably means K7 and 8 as well
« Reply #2 on: November 30, 2014, 05:56:25 AM »
Some also have different STD pistons.
Offline 750rideruk
« Reply #3 on: November 30, 2014, 09:28:56 AM »
I have an unused 836cc kit. Pistons, rings, gudgeon pins etc and head gasket available £90.00 carriage paid if interested
