Author Topic: Solid states  (Read 4713 times)
Solid states
« on: December 04, 2014, 05:27:46 PM »
Hi. Just got a solid state Rectifier/Regulator for the old F2. Of course its arrived without any wiring diagram or instructions. Have posted a photo, can anybody tell me where the black and white wires connect to. They are both male spade fittings. Also, I assume it bolts on in place of the existing regulator. Thank you very much.
Offline archmill
Re: Solid states
« Reply #1 on: December 04, 2014, 11:33:10 PM »
Hi Royhall, had much of the same problem with one I bought on E-bay. Do you have any idea of what bike it fits or a part number ?
Archmill
Offline UK Pete
Re: Solid states
« Reply #2 on: December 05, 2014, 08:24:04 AM »
Here you go fella
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
Re: Solid states
« Reply #3 on: December 05, 2014, 09:12:47 AM »
Hi Roy,
1st up I've a K2.... and assume the F2 is essentially the same..... Pete?
The unit you have replaces 2 original bits, ie the regulator (gold box) & the rectifier (black jobby under the fuse holder in the bottom pic)
The unit's loom plug you have (3 yellows / green / red ) connects to the existing loom plug that went to the original rectifier. (white terminal block, top pic / RHS)
The flying leads (black / white) go to the existing loom connectors (same colours) that fed the regulator.  There will be a spare green left over (regulator earth) from the bike loom here... just tape it up & tuck it away.
The below (embarrassing) pic of my bike as I bought it showing those black & whites going to the bike loom, and my restored pic as a ref showing the original bits you're now replacing,
Along with Pete's wiring diagram hope this helps...
Simon
« Last Edit: December 05, 2014, 09:30:42 AM by Lobo »
Offline UK Pete
Re: Solid states
« Reply #4 on: December 05, 2014, 02:12:36 PM »
Hi Roy,
Simon
yep they are the same
pete
Re: Solid states
« Reply #5 on: December 05, 2014, 03:16:38 PM »
Thanks guys that's cleared it up. The wiring on the F2 looks like its the same but the layout is slightly different. See photo. Cheers all.
Re: Solid states
« Reply #6 on: December 05, 2014, 06:53:58 PM »
You can still find original I have some
Bitsa
