Author Topic: CB750F1 Bike 2 Project Cafe style Orange and Black  (Read 50741 times)
Offline martin_uk
Re: CB750F1 Bike 2 Project Cafe style Orange and Black
« Reply #60 on: April 26, 2015, 08:21:17 PM »
You cant see in pic, but is cracked and slot is wrong :'(
2015_0426beforel0014 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline yozzer74
« Reply #61 on: April 30, 2015, 01:46:12 PM »
Hi Martin what are you doing with your top yoke .if your running clip ons.
Offline martin_uk
« Reply #62 on: April 30, 2015, 04:18:27 PM »
As I want to keep options open to be able to change back, I will leave standard mounts, may fit a short section of 7/8 tube.
I know many Cafe Racer style fans will disagree, but I am aiming not to make any changes that cant be undone ;D
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #63 on: May 02, 2015, 09:01:03 PM »
Started the frame fit up and found the swinging arm caps would not stay in place, struggled for 20 mins so put to one side.
Went back to it later and was able to fit with a bit of jigling :o
Test fit of clip ons and dummy tank found that steering stops need modifying to stop bars hitting tank.
Trouble is the stops on lower yoke are quite narrow and drilling will weaken.
With forks in place tried mudguard fit  :-[ the one supplied and painted is too narrow :'( School boy error not to check before painting!
Now starting to doubt plan, maybe better to do as modified F1 with standard bars and front mudguard?
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #64 on: May 04, 2015, 10:15:35 AM »
Decided to modify steering stops.
To save having to remove lower yoke, it can be done in situ.
Needed extra long drill to drill from front (need longer drill to allow chuck to clear yoke) and then drill M4 tapping size 3.3mm from rear.
Used M4 Allen screws and seems to do the trick :)
2015_0503after0033 by nitram2010, on Flickr
2015_0503after0036 by nitram2010, on Flickr
2015_0503after0037 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #65 on: May 04, 2015, 10:25:30 AM »
Steering lock didnt want to come out.
I havepreviously  used a M6 bolt held in place with stiff wire inside frame tube and tyre lever.
Didnt have a key and you have to turn a little to left to align.
It came out a bit, but no further.
2015_0503after0006 by nitram2010, on Flickr
Decided to drill.
2015_0503after0011 by nitram2010, on Flickr
Small chisel to try turning to left.
2015_0503after0013 by nitram2010, on Flickr
Manage to lever out and could see why it was a struggle.
2015_0503after0016 by nitram2010, on Flickr
2015_0503after0018 by nitram2010, on Flickr
2015_0503after0021 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #66 on: May 04, 2015, 10:31:03 AM »
Fitted instruments, but F1 bracket studs get in way. Luckily I have a spare K8 one to try  ;D
2015_0503after0023 by nitram2010, on Flickr
2015_0503after0024 by nitram2010, on Flickr
2015_0503after0028 by nitram2010, on Flickr
DSS replica brake master cylinder wont clear clip on mounting, so trying an alternative
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline UK Pete
« Reply #67 on: May 04, 2015, 07:08:42 PM »
Good work martin, i like the modified stops and well done on getting that awkward lock out
pete
Offline martin_uk
« Reply #68 on: May 05, 2015, 04:51:43 PM »
pete
Thanks Pete, still not sure about clip ons, as they were uncomfotable 30 years ago :o
Not planning any long journeys.
I do like the look and can afford to play around, with two completed CB750's  :)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #69 on: May 05, 2015, 07:16:39 PM »
Removing seals in forks was tricky.
Tried a slide hammer with lipped plate behind seal to pull out. but ended up drilling and fitting screw and using claw on crow bar to lever out.  Be careful not to catch fork leg with drill.
2015_0503after0004 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #70 on: May 06, 2015, 02:51:11 PM »
Ordered up some bits from caferacerseats yesterday and parts arrived today ;D
2014_1213partscafe0002 by nitram2010, on Flickr
Unfortunately front mudguard is 100mm wide at fixings (was described as 120mm) and I need about 135mm.
Anyone found a suitable mudguard or have a suggection on filling the gap?
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline yozzer74
« Reply #71 on: May 06, 2015, 07:13:16 PM »
Hi Martin don't no if it's what your looking for but I got one like this for mine good fit too
Offline martin_uk
« Reply #72 on: May 07, 2015, 02:19:19 PM »
Very nice  :) but looks expensive  :'(
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline yozzer74
« Reply #73 on: May 07, 2015, 06:46:15 PM »
No it want that bad 75 pound I bought a mud guard from cafe racer .ended up in dust bin . Was no were near the size it should have been .
Offline martin_uk
« Reply #74 on: May 08, 2015, 04:35:43 PM »
Checking main bearing clearance with Plastigauge.
Thought I would do as a precaution.
Crank shaft fitted to upper case which is on a  Workmate bench opened to accomodate studs .
Plastigauge applied to all main bearings and held in place with grease.
2015_0508after0015 by nitram2010, on Flickr
Fitted lower case and torqued main bearing bolts.
Remove bolts and case.
Looks to be about 2 thou on all, which is within tolerance.
2015_0508after0023 by nitram2010, on Flickr
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
