Aluminium seat pan help
Topic: Aluminium seat pan help (Read 5145 times)
JustcallmeMrT
December 20, 2014, 08:01:06 PM »
Hi gents, I'm looking to make a custom seat pan, and was thinking of doing it in aluminium. What thickness would you use? Is 3mm overkill - can I go thinner so it's easier to form?
simonster
SOHC Associate
Re: Aluminium seat pan help
December 20, 2014, 08:39:08 PM »
I used 3mm ( actual measured thickness 2.75mm) to create my seat pan and it formed ok with a medium sized rubber mallet. It holds it shape perfectly but I personally wouldn't go any less than 2.5 mm as the costs and extra weight are negligible between those thicknesses. I've also formed a few other pieces in 3.5 mm and its strength seems to increase a lot for that extra mm and although its also workable you may need to add heat especially on tight corners or curves.
JustcallmeMrT
December 20, 2014, 09:31:34 PM »
Thanks for the info Simonster. Any tips on which foam to use in the upholstery of it?
simonster
SOHC Associate
December 20, 2014, 09:57:28 PM »
I formed the shape using heavy gauge upholstery foam cut into shape with an electric kitchen knife with a one inch layer of cushion foam topper. The heavy foam provides the firm shape and the cushion foam topper gives it the soft cushion feel through the seat.
