Author Topic: Nearly There CB750K2  (Read 34206 times)
Offline sprinta
Re: Nearly There CB750K2
« Reply #45 on: January 11, 2015, 12:00:36 AM »
Still not 100 p/c certain on the colour Trig
Bitsa
see if Bryan says different
I had a Planet Blue UK K2 in 74, so it is the correct colour, see attached.
« Reply #46 on: January 11, 2015, 12:07:51 AM »
Cheers Sprinta  ;) Could of done with you earlier  ;D ;D ;D
Offline Green1
« Reply #47 on: January 11, 2015, 12:22:10 AM »
Sprinta did it have the red line at the 70mph mark on the speedo?  ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #48 on: January 11, 2015, 12:56:39 AM »
My K2 100% English model... forgive the polished pilot lights housing - now corrected.
The Honda parts diagram (I have) covers all countries, and specifies for the K2 the following colours ....CM, LU, LV, LX, MV..... or Candy Ruby Red, Brier Brown Metallic Custom, Flake Sunrise Orange, Candy Gold Custom & Planet Blue Metallic Custom.
Notably the parts book does not specify the colours being limited to certain countries.... whereas other parts it certainly does.
As a double check I had a look at the Side Panels section .... all the same K2 colours, no stipulated countries.
« Last Edit: January 11, 2015, 01:02:48 AM by Lobo »
« Reply #49 on: January 11, 2015, 09:55:38 AM »
Oh well there you go.Who the hell cares anyway as long as its the colour you want? ;) ;)
Bitsa
Offline philward
« Reply #50 on: January 11, 2015, 06:19:27 PM »
Hi Guys
Bike started on the button first turn of the motor! Sounds awesome (a normally much over used word but not in this case). I had forgoten what a 4 into 4 exhaust sounds like.
Rode it down the close and very smooth
However, the bikes ticking over at about 3k (very evenly) even though the tickover screw aren't touching the bar. I have my thoughts on where to start but before I start tinkering I thought I'd consult your collective knowledge.
What's your thoughts on where to start first?
Have statically timed the ignition but not used a strobe on it yet as its ticking over too high. Not yet used vac gauges for same reason.
Havn't run it long enough to get accurate plug colour.
Offline hairygit
« Reply #51 on: January 11, 2015, 06:34:56 PM »
Throttle opening cable to tight? About 10-15 degrees of play at the twistgrip is a good starting point, and if it has 2 cables, dont forget they both need some play in them. Well done on getting her fired up though:)):))
Offline philward
« Reply #52 on: January 11, 2015, 06:38:47 PM »
Yep - checked them straight away - both got play in them
« Reply #53 on: January 11, 2015, 06:48:16 PM »
If the tick over screw is not any where near the bar adjust each slide by 1/4 of a turn lowering the slide and try again sounds to me bench sync, pardon the wording is too high go from there
Bitsa
Offline philward
« Reply #54 on: January 11, 2015, 06:54:12 PM »
Thanks Bitsa - that was my thoughts but you guys have more specific 750 knowledge so good to hear your views. Not doing anymore tonight as had enough excitement for one weekend!
Offline sprinta
« Reply #55 on: January 11, 2015, 07:15:57 PM »
Hi
Sorry, but I can't remember that detail  and I do not have any photos of the clocks.
« Last Edit: January 11, 2015, 07:17:56 PM by sprinta »
Offline philward
« Reply #56 on: January 11, 2015, 07:34:43 PM »
I forgot to mention - started without choke - never touched choke lever. Needles need lowering a notch?
« Reply #57 on: January 11, 2015, 08:17:49 PM »
Dunno start off with the needles in the middle notch but that should not cause high tickover
No choke at all suggests its set mega rich
Bitsa
Offline philward
« Reply #58 on: January 11, 2015, 08:56:07 PM »
Ended up tinkering - tick over sorted. How many turns out for pilot screw? Went to check workshop manual but only have original K0 Honda manual (with 4 cable carb info)
« Reply #59 on: January 11, 2015, 09:04:38 PM »
Are you talking about the air screw Phil ? If so 1+1/8  ;)
