Author Topic: Nearly There CB750K2  (Read 36175 times)
Offline Phil Ward (RIP)
Re: Nearly There CB750K2
« Reply #75 on: January 13, 2015, 08:32:21 PM »
Hi again guys
Just having a weigh up of moving the needle position as Trig suggested. I'm familiar with workings of carbs but just looking at in situ carbs and am I right in thinking that I can't remove carb slides without undoing the individual carb bodies from the aluminium carb holding plate (to allow the carb tops past the lifters). Hence taking the whole carb bank off the bike each time I move the needle?
Offline hairygit
« Reply #76 on: January 13, 2015, 09:15:55 PM »
Yep, unfortunately that is the case:o
« Reply #77 on: January 13, 2015, 09:29:04 PM »
Thanks - airbox 1st or can I squeeze them out first?
« Reply #78 on: January 13, 2015, 09:58:15 PM »
Phil there is no cutting corners on this one. Air box.
« Reply #79 on: January 13, 2015, 11:25:35 PM »
Carbs off - needles set on 3rd notch down - remember putting clips back in that notch now. Think it should be on middle? (thought I'd put it back where it was when I stripped it down when I rebuilt them)
Guess that would make it run rich - will put it up a notch
Whats your view on middle notch - std airbox, repo 341's and 836 kit?
« Reply #80 on: January 13, 2015, 11:34:14 PM »
Are you saying that you have fitted a bigbore kit Phil ?
« Reply #81 on: January 13, 2015, 11:39:45 PM »
Graham
Yep - a cruzimage 836 kit on standard compression (consulted forum about 14 months ago after research on .net info from hondaman)
« Reply #82 on: January 13, 2015, 11:41:52 PM »
Graham
So, what size jets do you have in the carbs ?
« Reply #83 on: January 13, 2015, 11:46:30 PM »
Can't remember now (12 mths ago when I put them together but can check tomorrow night) - it was DS kit for K2
« Reply #84 on: January 13, 2015, 11:48:20 PM »
This is going to be fun  ;)
« Reply #85 on: January 13, 2015, 11:51:47 PM »
Thanks for that!
« Reply #86 on: January 13, 2015, 11:56:45 PM »
Sorry, but you have gone up about 12%. Everything else needs to go up. Standard jet is 100 so, that needs to be 112 minimum. On a 810cc i use 130 jet.
« Last Edit: January 14, 2015, 12:00:15 AM by Trigger »
« Reply #87 on: January 14, 2015, 12:06:31 AM »
I'm sure I'll get there with the amount of knowledge on here! Did discuss jetting when I bought kit - I'll dig the thread out tomorrow - thanks Graham
« Reply #88 on: January 14, 2015, 12:10:26 AM »
The bigger the main jet, then lower the needle needs to be to stop the fuel. Maybe this is why it started OK without the choke.
« Reply #89 on: January 15, 2015, 06:21:37 PM »
Trig - update on jetting.  New mains are 110's and pilots 40 (the ones I got from DS).  Put clip on centre notch and will try that and go from there. Have dug old jets out and they where 100's.
Carbs all back together and set up on bench as per manual. Will put them on and let you know how it runs.
PS - did I see a SOHC member post a thread recently that they are doing a full range of jets. Can't find thread now. Or has DS got genuine items at reasonable prices?
