Author Topic: CB750 engine numbers  (Read 4255 times)
Offline Bully40
« on: January 29, 2015, 01:57:03 PM »
Hi all,
This is my first post so be gentle with me! I have recently bought a box of bits formerly known as a 1976 CB750F1. The engine that came with the bike was already stripped and is just the lower half so
I then bought a second engine for the cylinders etc.
The problem I have is that the first engine has a serial number I can't seem to find any information on, the number is B750GE 1004187, is this an engine number from a different model altogether?
it all looks identical to the second engine which is a CB750E-2560070. the first engine has the black finish which I believe should be the later run of these engines maybe?
Any info will be greatly appreciated.
Re: CB750 engine numbers
« Reply #1 on: January 29, 2015, 05:14:32 PM »
The GE makes it a European model F2
Offline Bully40
« Reply #2 on: January 29, 2015, 09:04:26 PM »
Thanks for the info, I was starting to wonder what the hell I had here, I think I will use that engine as the base and the "proper" one as a donor.
Cheers for now 😊
