Author Topic: CB750K8 Oil gallery cap and lower crankcase plugs  (Read 3389 times)
Offline martin_uk
« on: February 22, 2015, 03:36:20 PM »
These always seem to be chewed up as have quite a shallow hex head.
Thread is 20 x 1.5
Has anyone tried alternatives?
I see there are some sump drain plugs with same thread, allen key fitting seems better, although not original.
Interested in your thoughts  :)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: CB750K8 Oil gallery cap and lower crankcase plugs
« Reply #1 on: March 03, 2015, 06:05:21 PM »
I decided to go ahead and order a couple of these as thread is same size as Honda cap and had advantage of magnet to trap metal particles and fairly cheap  ;)
http://www.ebay.co.uk/itm/281523874391?_trksid=p2059210.m2749.l2649&var=580549659651&ssPageName=STRK%3AMEBIDX%3AIT
Arrived today and although slightly different to image (head is concave)
2015_0303eng0022 by nitram2010, on Flickr
Not too keen on reduced section at base of threads as means sealing washer can misalign.
Have ordered up some Dowty Viton washers which I think would work better.
You could not use O ring as does not have retainer groove like original.
2015_0303eng0015 by nitram2010, on Flickr
Magnet is quite strong
2015_0303eng0021 by nitram2010, on Flickr
Loosely fitted without washer
2015_0303eng0016 by nitram2010, on Flickr
The original has a 14mm head, so presumably Honda did not want them overtightened, so care would be needed.
Not sure if I will fit, but If I do will probably start with top gallery so easier to keep an eye on.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
