Author Topic: valve pitting after only 2 k  (Read 5620 times)
Offline billy192
    • Shermonkel
« on: February 22, 2015, 06:52:40 PM »
i am stripping my head and it has done 2000 miles since i put in new valves had them lapped but i was shocked to find the exhaust ones had lots of pitting.
what causes this pitting please?
Billy
Billy
Re: valve pitting after only 2 k
« Reply #1 on: February 22, 2015, 06:59:08 PM »
First question. where did you get the valves from? That is nasty
Offline billy192
    • Shermonkel
« Reply #2 on: February 22, 2015, 07:56:08 PM »
I cant remember i get most of my stuff from DS i will have to check :-(
Billy
« Reply #3 on: February 22, 2015, 07:59:45 PM »
Billy, can you show me a picture of the valve seats mate?
Offline billy192
    • Shermonkel
« Reply #4 on: February 23, 2015, 08:43:21 AM »
the inlet seems fine.
Billy
« Reply #5 on: February 23, 2015, 08:54:53 AM »
Did you replace all the ex valves? Is that pitting on all the ex valves ?
« Reply #6 on: February 23, 2015, 05:50:01 PM »
Unless the tappet clearance was too tight that is bad material mate
« Reply #7 on: February 23, 2015, 08:55:14 PM »
I have the same thoughts on this Bryan, that is why i asked: where did you get the valves from.
Still would like to know the history Billy. Did you replace all the valves? Is all the EX valves have the same pitting ?
Offline billy192
    • Shermonkel
« Reply #8 on: February 24, 2015, 07:04:39 PM »
inlet look good no pitting at all. same make of valves. ex all the same pitting , i do think the gap may have been on the tight side.
i do tend to keep them on the tight side, yes my fault. :-[ :-[ :-[
Billy
« Reply #9 on: February 24, 2015, 07:29:45 PM »
If the gap was closed that much, then the valve would not be closing and this must of been popping. All you can do is re-cut the valve seats and re-dress the valves and try again
