Author Topic: Blasting barrels and head CB750K0  (Read 5652 times)
« on: April 29, 2015, 08:02:23 AM »
Getting through all of the cycle parts for three bikes in the blast cabinet at work. Many happy hours spent, so far
I now need to clean up my very dirty and oily barrels from my CB750K0.
I can remove all of the oil and grime in the parts washer at work but I then I  need to blast them before painting. I am considering assembling and bolting  the head (with plugs in)  and barrels onto a scrap crankcase upper that I have, using spare, scrap cam covers, cam tensioner housing and blocking up the exhaust inlet ports  and bores/cam tunnel with some rubber sealing method. I would assemble with old but intact gaskets. I will then blast in the blast cabinet using fine grit at lowish pressure. What does everyone think? How does everyone else clean these up by blasting without getting blast media in the internal parts?
Ash
Offline martin_uk
Re: Blasting barrels and head CB750K0
« Reply #1 on: April 29, 2015, 09:06:51 AM »
I am paranoid about getting blasting media inside engine as it only takes one piece to cause major damage and seems to find its way into places you didnt know existed >:(
Your proposed method would certainly lessen risks.
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #2 on: April 29, 2015, 10:06:19 AM »
I was thinking of possibly pressuring the internals with compressed air and spraying all of the interfaces with soap solution to check for possible grit ingress points. I can't really think of another method other than wire brushing, which I did on my 400/4 way back but it never looks squeaky clean.
Ash
Offline UK Pete
« Reply #3 on: April 29, 2015, 03:11:55 PM »
My method is to totally de-grease, then mask up all passage ways holes and gasket surface with good quality gaffa tape , blast the items  be it head barrells crankcases, airgun all loose blast media, and jet wash , then heat dry in oven and and blast with air again, if any trace of the blast media is left i repeat the jetwash  heat dry and air blast process
bung up any thread holes, and mask up all oilways ,
« Reply #4 on: April 30, 2015, 10:17:01 AM »
A good way to block the oil ways is fill with silicon sealant and pick/blow out with a air line after blasting
Offline Saisei
« Reply #5 on: April 30, 2015, 09:17:34 PM »
Some ingenious solutions here. Just wondering if there's a reason not to use vapour blasting other than cost?
« Reply #6 on: April 30, 2015, 10:11:26 PM »
Vapour blasting is only cleaning/finish and oxidation sets in quick on cast aluminum. Always better to paint in VHT to seal the engine.
