Author Topic: Alternator refurbishment  (Read 5579 times)
Offline ginger_jim
  • Anyone for a Guinness?
« on: May 08, 2015, 12:50:12 PM »
Hi all, the output loom for the stator and field coil needs to be refurbished as basically knackered.  Everthing has gone brittle due to age and heat from the oil I guess. Any recommendations for refurbishing as I might as well get everything checked as part of the process?
Re: Alternator refurbishment
« Reply #1 on: May 08, 2015, 01:17:09 PM »
A member named Big Al makes the sub loom for the alternator. Had one off him last month. As long as the coil is not going to ground it should be OK.
Offline jackdlad
« Reply #2 on: May 08, 2015, 04:40:37 PM »
Theres a guy on the great ebay whos offering this service, MOTORCYCLE GENERATOR ALTERNATOR REWIND SERVICE punch that in or go to www.elliottmc.co.uk if its knackered twill cost around a 100 squid,it might not be in that case its a fiver for testing it,hope this helps.
Offline ginger_jim
« Reply #3 on: May 08, 2015, 05:16:43 PM »
Thanks Trigger, its the wires between the sub loom and the windings/coil that are the problem.  Got it all sorted now by a local guy called Mr Williams in Teignmouth, Devon.  He confirmed the tests I did, just needs some new wire (which is protected against heat and oil ingress)to the sub loom, which incidentally I got off Big Al - hes in Manchester right?
Mr Williams is charging £15 for his work - you cant be bad to that now can you  :D
« Reply #4 on: May 08, 2015, 06:42:22 PM »
£15? Absolute bargain! The joys of living in the Westcountry with old fashioned ways and service  ;D
« Reply #5 on: May 08, 2015, 06:55:44 PM »
That was a good hairy. I was trying to think who we used for alternators re-winds years ago, it was Westcountry windings but, i see that they are located in Harlow know  ;D ;D
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #6 on: May 08, 2015, 08:57:38 PM »
Excellent value (£15) to carry out the insulation & continuity tests of the windings.
If you need some heat shrink sleeve & high temp sleeve to complete the repair just let me know, I will post some free of charge
Big Al... based in Manchester
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline ginger_jim
« Reply #7 on: May 09, 2015, 09:26:53 AM »
Thanks for the offer Al, much appreciated.
« Reply #8 on: May 09, 2015, 03:45:30 PM »
The only time I have ever seen the coils go down is with physical damage after an accident, never yey seen one burnt out
