Author Topic: Wheels done - pics!  (Read 10123 times)
Offline JustcallmeMrT
Re: Wheels done - pics!
« Reply #15 on: May 14, 2015, 12:04:52 PM »
Lacing the first took me a bit over an hour, the second only took about 30 minutes.  Trueing was the tricky bit.  The front wheel went in first and only needed minimal adjustment.  I was being super cautious with it though and got it within 0.2mm after about an hour.  Rear wheel was trickier.  Spent an hour on it one evening and every time I seemed to get one area sorted it would mess up another.  I was getting frustrated so left it until the next day.  With a clear head I got it to within 0.3mm within half an hour or so.  I'm a bit worried about tension, but each spoke has the same 'pinging' tone, so will try it and see!
« Reply #16 on: May 14, 2015, 07:36:39 PM »
Nice work - I've got a set of DID rims on the way from David at SAISEI so BryanJ I'll probably be calling you to understand your 'method'...thanks for sharing Mr T and Bryan
« Reply #17 on: May 15, 2015, 06:38:35 AM »
No problem, you got the number and times available?
« Reply #18 on: May 15, 2015, 12:14:19 PM »
On the lacing I just took loads of pictures before dismantling the old ones.
Regards
