Author Topic: Cb750 engine builders  (Read 7903 times)
Offline captaink
  • Old racers never die. ' they just go faster '
« on: July 16, 2015, 10:11:35 PM »
Hi, I'm considering either rebuilding my cb750 f2 engine or getting a reliable Honda engine builder to do it.
Is there anyone in the Kent area or within 100 miles or so ?
Keith
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
Offline tom400f
Re: Cb750 engine builders
« Reply #1 on: July 16, 2015, 11:17:40 PM »
When Lobo next lands his dreamliner he'll probably recommend
http://www.stotfoldengineers.co.uk
if you want it done for you
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline captaink
« Reply #2 on: July 17, 2015, 07:33:05 PM »
Spoke to D & M engineering today they build Honda race engines but there looking at March next year to start a rebuild, busy or what !
They said I should rebuild it myself, compared to British bikes there easy.
He also said if I need any advise he'd be pleased to give it.
A very helpful fella.
Anyway I have built about three engines and there still running good so I'll give it a go.
Advise was to use genuine parts but some pattern parts would be ok, which the route I always wish to take anyway.
With the Brit bikes the pattern parts are made of butter and are not up to it.
Anyway the engines already started the strip tease.
Pictures to follow soon
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline RGP750
« Reply #3 on: July 17, 2015, 07:36:53 PM »
Hi where abouts in Kent are you.?
If you get stuck there are several of us here that can help
you if needed.
Cheers Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline captaink
« Reply #4 on: July 17, 2015, 09:58:14 PM »
I'm in West malling !
I'm confident it will be good but I'm not afraid to ask.
When I was an apprentice many years ago the sign on the wall was ' IF IN DOUBT  ASK'
One question... Any special tools needed for the strip down ?
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline hairygit
« Reply #5 on: July 17, 2015, 10:02:55 PM »
A special socket for the clutch retaining nut, reasonable on e-bay, and a tool to remove the generator rotor, although it is not necessary to remove it to strip or rebuuld the motor, only if you need to remove it from the crank.
Offline captaink
« Reply #6 on: July 18, 2015, 04:30:00 PM »
Well you answered a question before I even asked it.
I stripped the engine today, well some of it.
A few screws of the alternator cover/ bolts seized in tight but I drilled them out successfully.
Where I'm at right now is head and cylinders off, clutch out except for the clutch basket which seems to need a tool... answered already
I still cant split the cases all bolts are out and there's very small case movement but around the rotor area seems not to budge.
I was assuming there's a seal behind the rotor area which would hold the cases back.
all other seals are out
The cases appear to have never been apart.
The valves look crappy and have been passing oil which the previous owner suggested.
Initial findings are new valves, maybe seats, but Ill have it all checked anyway
Rockers look really nice and bores look very clean
new pistons and rings, new cam chain and probably a lot more.
Anything I have missed on the engine that would stop the cases ?
Regards Keith
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #7 on: July 18, 2015, 05:46:30 PM »
Just ordered a clutch tool on e bay £10. ;)
I think this engine and the bike had been pressure washed and stood up a while, externally no oil but the ally's fluffy.
Most Brit bikes are oily , the advantage is they clean up well... but drip on your garage floor
The engine once stripped will go to the aqua cleaners.
Quite often I have seen the cases are painted, is this the general rule for the CB's engine ???
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline hairygit
« Reply #8 on: July 18, 2015, 06:45:07 PM »
Yes, for the engine cases tend to be painted a silver/grey, the alternator , selector cover and clutch cover tend to be roughly polished then lacquered by Honda, many of us polish them far better than Honda ever did, and dob't lacquer them, just clean them regularly, aa if you get a pinhole in the lacquer the alloy corrodes beneath it looking awful, so your choice on that score!
Offline captaink
« Reply #9 on: July 19, 2015, 03:12:25 PM »
Here's the engine at the start, sorry looking
the last picture is the clutch cover which needed to have some screwS drilled out.
That starter motor does not seem to come out, perhaps I'm doing something a miss.
It touches the rear right hand bolt fixing and wont go back anymore.
« Last Edit: July 19, 2015, 03:14:48 PM by captaink »
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #10 on: July 19, 2015, 05:28:30 PM »
I think my next post on the bike build will be on the projects section as I'm wandering a bit
Regards Keith
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline westfieldandy
    • good-bits
« Reply #11 on: July 28, 2016, 03:14:48 PM »
I am in sussex,
just finishing my current customer build, I can certainly help if you need it.
www.good-bits.co.uk
https://youtu.be/cOcQZ2oVeFE
if you need futher help, i am based in sussex, just go on site and get details there.
andy
