Author Topic: Flasher relay cb750 k2.  (Read 4325 times)
Offline El__burro
« on: July 23, 2015, 11:12:56 AM »
Good morning,
this Saturday I'll be going to the Kempton park market to shop for bits and bobs.
I need a flasher relay but I am not sure if I need a 12V 42W?
El__burro
Re: Flasher relay cb750 k2.
« Reply #1 on: July 23, 2015, 11:37:08 AM »
Most these days are marked on loading, you should be looking for 21w+21w+3w, because the idiot light repeater bulb comes into the total.
Offline El__burro
« Reply #2 on: July 24, 2015, 01:17:12 AM »
thanks but i don't have the idiot light for the indicators.
so 42w is good!?
« Reply #3 on: July 24, 2015, 06:01:04 AM »
Surely the idiot light is an m.o.t. requirement in the U.K.?
« Reply #4 on: July 24, 2015, 07:26:35 AM »
If its fitted it must work if not there as long as you can see an indicator its OK
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #5 on: July 24, 2015, 04:14:40 PM »
42W sounds good to me El burro.  Its a 40yr old Honda, if it flashes at 50 rpm or 100 fpm I don't think anyone would notice. But, 42W is indeed the correct rating if only the two bulbs.
Simon
