Author Topic: CR 750 for road use build  (Read 35787 times)
Offline Phil Ward (RIP)
Re: CR 750 for road use build
« Reply #60 on: November 08, 2017, 09:16:58 PM »
Ref mudguard - just finished mine
Offline MarkCR750
« Reply #61 on: November 08, 2017, 10:25:33 PM »
That’s starting to look very good Phil 👍
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline burchy75
« Reply #62 on: November 09, 2017, 12:12:44 AM »
Having just gone through all 5 pages I love this build.  As someone just starting out on their Cr750 journey it's brilliant to be able to draw on all the photos, research, pointers and tips from you lot (as well as drool over the bikes coming together).  I'm a million miles away from finishing mine but really great to see how other people are going about their builds.
Keith - very envious of your work space, it looks spotless.  I've just had a damn good sort out of my garage here (mainly so I can hunt down parts for my build) but most of the time it looks like a bomb's gone off!
« Reply #63 on: November 09, 2017, 12:20:28 AM »
Have these on eBay for a CR genuine NOS if anyone is interested
https://www.ebay.co.uk/itm/142571808851?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Offline captaink
  • Old racers never die. ' they just go faster '
« Reply #64 on: November 10, 2017, 01:57:42 PM »
Mudguards look pretty good Phil
What are they made up from ?
CR750 Replica
Norton Manx's 1947 & 1956
Norton CS1 1930
Norton International  1934
Norton 16H 1924
Norton Model 18 1929
Norton Commando / Colorado Norton Works
Triumph 1947 GP Replica
Triumph Bonniville 1967
BSA Goldstar Daytona 1956
Harley Duo Glide 1961
The Rickman project
And the CR dick Mann replica project
Sold a few of the Bikes so only got these left
Gt40...Car I know
E type fhc 1964... Car I know
" Greedy I Know
« Reply #65 on: November 10, 2017, 08:21:58 PM »
Standard mudguard - used the brace but lowered by 13 mm to accomodate 18 inch wheel (otherwise the mudguard has a large gap between tyre and mudguard) . Then cut the stays to suit. Welded back of U section where they overlap the brace (near the fork lowers) then blind drilled and tapped M6 to be able to screw through the brace into the stay. Used m6 allen button screws with nylon washers between guard and stay with half nuts to give plenty of clearence to the tyre at the other end of the stay. The blade is from Tony Huck at Maitland Racing - at £25. Its very tight with wheel and tyre being smaller and wider. You have to fit the brace behind the offside disc brake arm swivel (where as the brace goes on the outside of the nearside disc arm swivel (as standard bike). You have to be quite creative with the brace mounting sequence as the bolts at the rear can't come out as they foul the ally rim (due to the 18 inch rim being lower). I cut the rear nearside brace hole in a U (as apposed to a hole) so it can 'slot' over the bolt.
This setup creates the next problem - the fact that the brace sits behind the offside brake arm swivel means the brake set up will need re-shimming to ensure everything runs parallel - thats the next job.
So overal cost me £25!
Hope that all makes sense.
« Reply #66 on: November 11, 2017, 08:19:48 PM »
Just realised your running Gold Wing forks/brakes - so maybe you could use the Gold Wing mudguard brace with the stays from a SOHC model
Offline captaink
« Reply #67 on: November 13, 2017, 02:53:51 PM »
Thanks Phil, food for thought, bike looks good mate, when do you anticipate completion ?
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
« Reply #68 on: November 13, 2017, 08:27:50 PM »
Hopefully next summer - main thing to decide on is whether to go for the narrower alternator or keep with the standard and cut fairing - I would lose the electric start if I go for the narrower alternator as the Electrex World product - http://www.electrexworld.co.uk/acatalog/RPK-1750-Honda-CB750-SOHC-Alternator-System.html - ditches the starter gears. Plus adds about £750 to the build cost (alternator plus cover).
Ultimately I'm looking for the same look as your posts original CR picture with not quite the expensive detail!
Offline captaink
« Reply #69 on: November 17, 2017, 06:04:49 AM »
The devils in the detail Phil
I don't like to spend lots of money on the paintwork but that's what everyone sees on the finished job
Question
Do you know the entire length of the original CR mudguards  ? and what length is yours. ? what diameter wheels are you using ?
It looks good and as near as it can be.
My forks are GL1000 and ill need some mods as well as a fork brace.
« Last Edit: November 17, 2017, 06:13:11 AM by captaink »
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
Offline captaink
« Reply #70 on: November 17, 2017, 06:44:24 AM »
I can see that others may have had problems posting pictures.
I am , it used to be ok but now no go
I usually upload pictures from my phone to my Yahoo, downsize them in photoshop to around 450kb
and use the site attachments and other options bar, browse, load the picture and post.... But no go.
thoughts ?
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
« Reply #71 on: November 17, 2017, 08:36:54 AM »
I have just added jpeg to the list of allowed attachments - maybe Yahoo or the resizer has switched from jpg
I've also increased the allowance for each attachment to 2M and the total per post to 6M
Steve
Offline MarkCR750
« Reply #72 on: November 17, 2017, 12:25:22 PM »
Thanks Steve [ Guests cannot view attachments ]
That’s better, didn’t even have to resize it, our pug doing her ET impersonation.
« Last Edit: November 17, 2017, 06:34:36 PM by MarkCR750 »
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
Norman Nippy 50cc
Sir J.Stewart.
« Reply #73 on: November 17, 2017, 08:48:00 PM »
Question
Not sure on original mudguard length but mines 780mm. Ref paint, I agree - mine will be right as per that Aussie rep (your original picture) which is what I've also based mine on. I have a guy who is a car sprayer who has done all my bikes - charged me £70 labour for my standard k2 tank/side panels (I do basic prep) - its mint. Its not what you know, its who you know!!!!!
Offline captaink
« Reply #74 on: November 17, 2017, 10:48:41 PM »
Still cant post a picture, Ill try another route ? :-X
No,  again My system says Server error ???
« Last Edit: November 17, 2017, 10:54:00 PM by captaink »
CR750 Replica
Norton CS1 1930
Norton 16H 1924
The Rickman project
Gt40...Car I know
" Greedy I Know
