Author Topic: Regulator rectifier recommendation needed  (Read 10011 times)
Offline JustcallmeMrT
« on: September 06, 2015, 08:38:18 PM »
Hi all,
Is there a difference between the different brands of new combined reg/rec units?  Can someone give me a recommendation for a good one?
Thanks!
Re: Regulator rectifier recommendation needed
« Reply #1 on: September 07, 2015, 11:44:36 AM »
All seem much of a muchness but all need exceptionally good earths at all points and if you reverse the battery for even a split second they are toast
« Reply #2 on: September 07, 2015, 09:14:55 PM »
Fair enough.  Will definitely be checking to ensure its all wired up correctly before connecting the battery.
Offline gtmdriver
« Reply #3 on: September 07, 2015, 09:29:48 PM »
Electrex World seem to do good quality stuff.
Offline s7paul
« Reply #4 on: September 08, 2015, 09:34:56 PM »
I've had an Electrex unit on mine for 10 years, with no problems.
Offline Ashdowner
« Reply #5 on: September 14, 2015, 08:24:25 AM »
I've done all the checks on my charging system and the maximum charge rate seems to fluctuate. Sometimes if I up the revs the charge rate actually goes down, and sometimes it gets to max 13.5v. Are the combined units more stable and what's the highest charge rate that anyone has recorded from them?
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #6 on: September 15, 2015, 12:35:38 PM »
Hi Ashdowner,
If you're still on your 40yo Voltage Regulator I guess it won't be perfect; it's a very mechanical device with 'points' that open & close - all rather subject to wear & tear & consequently imprecise.
My guess is that if any of us delved deeply into the readings of our own VRs we might well be alarmed too.
If it's bothering you or resulting in duff charging / blowing lights etc then surely replace it with a (relatively) cheap modern electronic all-in-one Regulator / rectifier unit - which certainly will be more stable.
My thoughts only...
Simon
Offline Ashdowner
« Reply #7 on: September 27, 2015, 04:50:50 PM »
I'am thinking about it. Might buy one for the bikes Christmas present
« Reply #8 on: September 27, 2015, 05:01:45 PM »
I recently got a Recifier/regulator (RR24) I think from Wemoto,made by Electrex World,
 fitted in 15 mins,
 looks and works great,
 went for a 100mile ride that evening,nice bright lights,
 very happy,
I reccommend !!!
« Reply #9 on: September 27, 2015, 05:04:49 PM »
I grabbed the electrex world unit as well, but haven't fitted it yet, will report back once I've had a few runs.
Offline kevski
« Reply #10 on: March 31, 2019, 11:32:17 AM »
Electrex world ones all the time, made in the UK, unlike the rubbish M&P sell form China, i know this as i bought 3 in succession that failed dismally, got my money back ,and Electrex world one put on and job done.
Offline mike the bike
« Reply #11 on: March 31, 2019, 06:40:07 PM »
That's worth knowing.
