CB750
Cb750 poor running
Topic: Cb750 poor running (Read 3784 times)
El__burro
SOHC Expert
Cb750 poor running
November 25, 2015, 11:55:15 PM »
Hello,
I am trying to sort out the poor running of my bike, (not much response when i open the throttle) I have given the carbs a good clean but i am not sure about the right setting also I would like to check the valves to see if things improve.
What would you check first?
regards
El__burro
Johnwebley
Re: Cb750 poor running
November 26, 2015, 07:48:17 AM »
check the plugs,
they can tell you such a lot,
set the ignition timing with a strobe,
you could check tappet clearence,make sure its not to tight
CB750
Cb750 poor running
