Author Topic: Honda Seat Foam manufacturer... Honda Subbies ...let's make a list.  (Read 2544 times)
Just noticed that my original CB500K0 seat foam has 'Bridgestone 164B02 or is it 164802' printed on it in blue ink  plus 323 922A embossed into it. It's definitely a rubber foam compound...you can tell by the smell when you burn it. Bob-The-Seat (Moretti) is currently making me a new foam but I think I will chop decent bits out of the old foam to use on repairs on my CB250's seats. So I guess BS must have been an OEM supplier of the foams to Honda.
Also noticed on my CB750K0 wiring loom that each coloured wire has Sumitomo 1969 printed on them in tiny text.
Other Honda  'subbies' / OEM's  I know of are Tec for switches , Hitachi & Nippon Denso for alternators/regulators/Solenoid switches/flasher relays.  Riken for piston rings. ART for Pistons, Koyo for bearings, NOK for oil seals, Yuasa for batteries, Nippon Denso/Nippon Seiki/Fuji for clocks.
D.I.D.  Chains ..wheel rims , Sankei ..Exhaust Systems, Daido Metal ....Shell bearings,  Bridgestone/Nitto/Japanese Dunlop......Tyres,  Tokiko .....Hydraulic brake parts,    Stanley Electric .... Lighting,  ASK .... Brake linings. Neiman ... Euro model locks.  Nippon Oil & Fats... candytone  paint, KeiHin ...carbs, NGK spart plugs or is it ND or both? Showa ...suspension compents.
Any more anyone?
« Last Edit: December 31, 2015, 07:05:58 PM by AshimotoK0 »
Offline Orcade-Ian
    • Older Vehicle Web
Re: Honda Seat Foam manufacturer... Honda Subbies ...let's make a list.
« Reply #1 on: December 31, 2015, 08:09:53 PM »
Can't add to your comprehensive list Ash, but mentioning Dunlop jogged my memory.  I bought a brand new VF 750S back in 1983 A474 JJX the shaft drive one called Sabre in US and the tyre label (perhaps on the swing arm or rear footrest hanger) actually said DUNROP. If anyone has an unrestored one I love a pic of that label.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline UK Pete
« Reply #2 on: January 01, 2016, 12:33:52 PM »
What a good list ash, looks like honda made the frame , cast the engine parts and subbed the rest out , then made final assembly
It reminds me when i was a site manager, We subbed out every part of the building works and i had to tie it all together and make sure it all came together, what an effing head ache that was , glad i dont do that anymore
pete
« Reply #3 on: January 01, 2016, 12:58:11 PM »
Ha ha .. came in from Pub last night and added to the list but fell asleep over my laptop and lost it all  ::) . Some weird ones in the Sandcast manual from 4/69
Mitsubishi ... CB750 sandcast ... early  K0 Valves  (CB500 too)
ARAI ... oil seals
NTN  & Nachi & Koyo... bearings
Mitsuba..... Horn & Starter Motors
Oil Filter element .... Tokyo Roki
Takasago ... Sandcast primary chain
Toyo .... Sandcast Bar switches
Toyosha .. Sandcast /early K0 'Antimon' alloy tank filler cap.
Yamada ... CB500/4 oil pump
Uehara ... CB500 Alternator cover plate
Signal-stat... USA flasher relays
Asahai ... Disc brake pads
« Last Edit: January 01, 2016, 01:22:22 PM by AshimotoK0 »
