500 Four Steering Lock Key Question
Topic: 500 Four Steering Lock Key Question (Read 5487 times)
paulbaker1954
I'll just be 5 minutes dear!!
January 25, 2016, 04:21:36 PM »
My project bike has a key that fits ignition and seat lock. Should it be the same key for the steering lock or was this always a different key?
I am hoping it's the same key and that my steering lock is just a bit rusted/gummed with crud (I didn't want to try and force anything in case I break the only key I have !!)
Thanks all
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Trigger
Engines built on reputation, not advertising.
Re: 500 Four Steering Lock Key Question
January 25, 2016, 04:49:47 PM »
Very good question
It should be the same key and the key number can be found on the face of the barrel. These are a pig of a steering lock so, may have been changed.
ST1100
January 25, 2016, 08:41:58 PM »
On both, the '72 and the '76 500/4's I found one key for ignition and seat, and a different, smaller key for the steering lock.
For the refurb I now ordered a complete lock-set, with one key fitting all 3 barrels.
STOC #637
January 26, 2016, 06:12:18 AM »
The number should be visible on all the lock faces so you should be able to check
