Author Topic: Master Cylinder Holes Question  (Read 9519 times)
Offline paulbaker1954
« on: February 09, 2016, 08:25:35 AM »
Just rebuilding my Master Cylinder and have a ? I am sure I have seen this ? before somewhere but cant find it !!
There are two holes in the base of the reservoir. One is clear and reatively large the other is my problem. Is it a very small hole or what. I tried poking with the end of a safety pin but hesitant to get more agreesive until I know what it should be like.
Hopefully picture is self explanatory
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline mickwinf
Re: Master Cylinder Holes Question
« Reply #1 on: February 09, 2016, 08:53:30 AM »
yes its a tiny hole and it must be clear to work properly
« Reply #2 on: February 09, 2016, 09:47:46 AM »
I managed to make things worse by breaking the end of a pin in the tiny hole as I tried to clear it of years of hardened gunge.
I thought I needed a new one until a very nice man drilled the hole out with a pillar drill and a tiny bit. The crucial thing then is to make sure there is no swarf sticking out into the master cylinder bore, ripping up your seal with potentially disastrous consequences.
Offline peterengland
« Reply #3 on: February 09, 2016, 05:47:20 PM »
The only thing I found to clear the hole was to snip a bristle from my wire brush and it worked a treat. No pin in the house was small enough
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #4 on: February 10, 2016, 11:47:48 AM »
Hey peter thats a great tip - thanks !!
« Reply #5 on: February 10, 2016, 04:22:01 PM »
To see if its clear get one of the small torches (on obviously) and put it over the hole and look down the bore to see if you can "See The Light"
« Reply #6 on: February 10, 2016, 05:15:44 PM »
To see the light at the over side of the tunnel, first you must find the tunnel ;D ;D
« Reply #7 on: February 11, 2016, 06:29:31 AM »
You can't possibly see the light at the end of the tunnel Trigger as contrary to the rumour that it has been turned off to save money in fact the bulb has been nicked!!
« Reply #8 on: February 11, 2016, 06:31:23 AM »
In my experience light at the end of the tunnel means there's another train coming
« Reply #9 on: February 11, 2016, 06:54:30 AM »
Not if its the Salperton tunnel
« Reply #10 on: February 11, 2016, 08:37:32 AM »
Or the Blisworth tunnel  ;)
Offline Rozabikes Tim
« Reply #11 on: February 11, 2016, 08:46:23 AM »
Love the way these posts go off at tangent. No real interest in hoes in brake cylinder but banter great off topic..
Offline ka-ja
  • ken
  • yoshi 460
« Reply #12 on: February 11, 2016, 09:20:39 AM »
Light at the end of the tunnel? It was some bu***r with a torch bringing me more work!
« Last Edit: February 11, 2016, 09:22:48 AM by ka-ja »
nice bike,nothing in the bank
« Reply #13 on: February 11, 2016, 09:47:25 AM »
There's never light at the end of the tunnel, only more hassle.
« Reply #14 on: February 11, 2016, 05:50:20 PM »
If you can't see light at the end of the tunnel,  poke it with a wire brush bristle.   There, back on track.
