Author Topic: Main and Side stand Springs Refitting - Help  (Read 4955 times)
Offline paulbaker1954
« on: February 15, 2016, 08:50:37 AM »
Anyone any tips for refitting these springs. I think the main I can manage but the  side was a b****** to get off, it has so much tension I could hardly pull it even with a length of wire wrapped around the end to make a pulling loop (which is a trick I have used before on my Trophy)   and heavy gloves  >:( >:(
Paul
« Last Edit: February 15, 2016, 10:41:33 AM by paulbaker1954 »
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline Woodside
Re: Main and Side stand Springs Refitting - Help
« Reply #1 on: February 15, 2016, 09:44:55 AM »
You can put a washer in between each Coil and that sometimes opens the spring up enough to pop on....then just pull washers out....works sometimes
« Reply #2 on: February 15, 2016, 10:06:07 AM »
Aha in the absence of washers I guess a pile of 2p coins would work  :)
Offline Woodside
« Reply #3 on: February 15, 2016, 01:04:09 PM »
Yup
On the sandcast only site they use £2 coins
« Reply #4 on: February 15, 2016, 01:28:09 PM »
Yup
Likes it !
Offline RGP750
« Reply #5 on: February 15, 2016, 02:06:33 PM »
I put the spring on first and use the stand as a lever  and put the bolt in last.
It can sometimes take a few goes and another time goes straight in.
good luck
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
« Reply #6 on: February 15, 2016, 06:03:57 PM »
good luck
Is that how you fitted yours Rich, when you fitted it back to front?  ;D ;D ;D ;D :-* :-* :-*
Offline Green1
« Reply #7 on: February 15, 2016, 07:19:55 PM »
I use washers Only people on the Sandcast site can afford to use £2 coins. ;D
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline RGP750
« Reply #8 on: February 15, 2016, 07:22:38 PM »
Yes Julie,
 and the way i did it when i turned it around.
The spring the  right way that is not the stand.
Trigger spotted it in a visit so i had to put it around the propper way ;) ;)
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
Offline Green1
« Reply #9 on: February 15, 2016, 07:26:53 PM »
I was wondering how you could fit the stand the wrong way.   ???
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
