Author Topic: CB550 Mainshaft crankcase plug  (Read 1530 times)
Offline Seabeowner
« on: March 07, 2016, 12:01:03 AM »
Advice please.
Engine all stripped down. Should I always replace the 34mm plug on the end of the gear mainshaft? Part no 91207-374-000. Any ideas why it is special order from DS? And what is the difference between the CB550 and the CB400 plug (91207-333-000)..they appear to be the same dimensions.
I also need the crankshaft seals and CMSNL do a set with all seals including the plug which seems cheap at 19 euros +VAT. If anyone has this set, are the crankshaft seals correct with the location flange at one end as the pics are rubbish?
Thanks folks. Phil
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
