Author Topic: I must be mad  (Read 28372 times)
Offline Woodside
I must be mad
« on: April 24, 2016, 03:19:36 PM »
Finally dug out all my spares today...and the frame and engine of a 500 I've had for some time....
Hopefully in amongst all this I Have enough to to put it all back together....
Except for the pipes....
Just somthing to pass the time...
I know we all like pictures so here goes a few...
See anything missing that's gonna be a arse.
Offline Woodside
Re: I must be mad
« Reply #1 on: April 24, 2016, 03:20:44 PM »
More
Re: I must be mad
« Reply #2 on: April 24, 2016, 04:12:12 PM »
Is that the engine bit top left corner first pic? Or just a 500cc wheelbarrow!
Looks like you've most of the pieces there and should keep you busy for a while.
Re: I must be mad
« Reply #3 on: April 24, 2016, 05:40:38 PM »
Mix of US and UK parts there, didn't see a rear mudguard, they can be difficult
Offline UK Pete
Re: I must be mad
« Reply #4 on: April 24, 2016, 05:50:33 PM »
You have your work cut out , and yes you must be mad just like all of us lol
pete
Offline mike the bike
Re: I must be mad
« Reply #5 on: April 24, 2016, 06:13:32 PM »
Yup, looks all there, should be MOTing it by Friday
Re: I must be mad
« Reply #6 on: April 24, 2016, 06:35:37 PM »
Hope you are good at jigsaw puzzles ;) Is it US or UK ?
Offline Woodside
Re: I must be mad
« Reply #7 on: April 24, 2016, 07:22:31 PM »
U.K.
Last on road 1977
Kind off backs up milage on clocks 6547
I have an original tax disc with a Del Boy note still in the back
Offline Woodside
Re: I must be mad
« Reply #8 on: April 24, 2016, 07:27:16 PM »
So far so good
All went together relatively easily...
And I seem to have most parts correct for a k0..
I'm sure you will tell me differently and I will welcome the comments...
I have the correct seat and cover for it but I couldn't resist the photo opportunity .
Fuse board air box are in behind the side panels.
..I'm really kicking myself I could've picked up a useable set of pipes but past them up the other day...very pi$$ed of about that....
The wheel barrow is indeed a 500 but currently seized solid
Re: I must be mad
« Reply #9 on: April 24, 2016, 07:33:52 PM »
Wiring can be a bugger, as it is all round pins (apart from the ignition block) Hard to find parts is the tank trim.
Offline Woodside
Re: I must be mad
« Reply #10 on: April 25, 2016, 10:22:46 AM »
Well good news is I just contacted the chap with the pipes I past up and he still has them....so I now have a set for the bike...They  are reasonable and use able. ..but I don't think I have the 4 brackets for them I will have a good double check later but if anyone  has an old set I have a home for them..
Hopefully lift the engine in later and if ipad is playing ball ill get some more pics
Offline UK Pete
Re: I must be mad
« Reply #11 on: April 25, 2016, 11:23:30 AM »
Tax in post ;D ;D ;D ;D ;D ;D
I remember the day, pre internet , mobile phone and mass immigration, oh to go back to the simple hippy days of the 70,s, when big brother was not watching, mind you the down side was people like jimmy saville could get away with things undetected , we were alot more gullible then
Anyway good luck with the build , its starting to take shape
pete
Offline Woodside
Re: I must be mad
« Reply #12 on: April 25, 2016, 09:37:05 PM »
I should've named this post "building a barn find"
I am starting to wish I had cleaned some parts abit before assembly as it is all abit grubby but all very well preserved.
But this is a build up just to see what I have and more importantly what I need..
Things I know I need..
Oil filter housing....can't believe I don't have one here ...
Genuine case screws
I found 2 exhaust brackets....I've searched everywhere I cannot see the other pair.
Offline Woodside
Re: I must be mad
« Reply #13 on: April 25, 2016, 09:38:47 PM »
A few more
Offline Woodside
Re: I must be mad
« Reply #14 on: April 25, 2016, 09:41:36 PM »
First foot brake I grabbed must have been on one of matts sidecar outfits....
Luckily I found another
This was in the box but I can't place it...any suggestions
« Last Edit: April 25, 2016, 09:52:05 PM by Woodside »
