SOHC.co.uk Forums => CB500/550 => Topic started by: Laverdaroo on November 13, 2021, 09:32:00 PM
Title: 550 F2 started!
Post by: Laverdaroo on November 13, 2021, 09:32:00 PM
Had a free afternoon so set about something stimulating to stay ahead of what’s happening on ‘Mejima’
Carbs off and fully stripped but not seen green residue before, it got brighter the older and drier it got…..how queer!
Opened up and no float retainers, so that’s the first blag/purchase request. Anybody got 4 they want to part with?
I’ll order a new main spring, as you can see, interesting alternative figment
The sonic cleaner is being wragged to death in the pantry and will probably be on most of tomorrow at this rate, there’s a fair bit to sort out! And clean!
It appears they’ve been opened before as there’s new screws on the top and bottom but no evidence of any internal intrusion. That being said there are various o rings in places they shouldn’t be in the spindles etc. just bobbing about not doing anything as they’re too big and just bob up and down the arms so someone’s faffed about.
I presume because I need four of the metal float retaining clips that live in the bowls they’re dearer than diamonds and rarer than hens teeth? Can anybody help?
Title: Re: 550 F2 started!
Post by: Laverdaroo on November 13, 2021, 09:34:00 PM
(https://uploads.tapatalk-cdn.com/20211113/dd0d174a63417ff0ccc3a2e004461de8.jpg)
Post by: Laverdaroo on November 13, 2021, 09:34:26 PM
(https://uploads.tapatalk-cdn.com/20211113/0d1b21b3da5c2c2657c6558ef1bab0a4.jpg)
Post by: Laverdaroo on November 13, 2021, 09:35:14 PM
(https://uploads.tapatalk-cdn.com/20211113/2879c5ee0bf8e729576fed0f2d978dd1.jpg)
Post by: Bryanj on November 13, 2021, 10:00:57 PM
Main jet clips were available on ebay from Holland and if not try sirius consolidated in canada, i have dealt with them for odd bits ans whilst website is clunky and 'orrible service is good.
O ring kits you get from Nurse Julie direct rather than ebay
Post by: Bryanj on November 13, 2021, 10:03:59 PM
Hardest part to find will be the small pin located between 2&3 that bottom of return spring goes to
Post by: Nurse Julie on November 13, 2021, 10:12:21 PM
I have the brass float pins in stock Roo, or do you mean the springs?
Post by: Laverdaroo on November 13, 2021, 10:40:10 PM
The springs that sit on top of the main jet tower and spring the floats, ye rknow what I mean.
I've got good pins thanks Julie .. Probably the only, easy to remove bit of the whole operation tbh :)
Julie's sorted me out for o rings Bryan and if you mean the little barrel bit for the spring? Well funny thing that, ..........when splitting the carbs apart, not one but one good one and one mangled one fell out of a greasy dirty corner stuck together with a load of crap. Winner!
What's the best attack on the bowls and tops for shining them up? Polish or have plated? (if poss)
Talking of which, can you buy the gaskets for the tops on their own or only with a kit. Im going to use the original brass wear if it comes up ok but will need gaskets, presumably if not its going to be gasket paper/crunchy nut cornflakes packet and a sharp Stanley?
Post by: Bryanj on November 13, 2021, 10:45:59 PM
Solvol and elbow for shine, top gaskets rarely break and tend to be in sets tho i did see a lone one on ebay. I have a very oldparts book that shows individual O rings and gaskets,it may well be the one in Alladins cave as Ash had all my scans for his dropbox
Post by: Laverdaroo on November 13, 2021, 11:09:30 PM
Nice on mate, I thought so on the elbow bit :) I was enquiring on the gaskets as ones bound to fail or break in teh polishing process. Just pre empting a 'bugger' moment!
It appears that ebay is dry of them at the min but common Motor in the states do them at $8 each plus a billion quid customs clearance, but at least they're available. Be easier if there were a set over here but you an have it all. Meant to ask, where do I look for this code to identify which type they are< Im sure I've seen it on here somewhere, P something carbs or am I mad? Not really started to read up just going at a  bit of cleaning at the min but I'm sure there was a set to have and set not to have?   No?
Post by: Bryanj on November 13, 2021, 11:49:10 PM
The code is on the carb flange where it bolts to the bracket, i just googled 500 four main jet clips and went down the list and sirius came up with stainless ones about $38 a set of 4
Or ebay 113717285385 from holland £33 a set
Post by: Laverdaroo on November 14, 2021, 12:00:35 AM
AAhhh, I was looking for 550 clips although they're the same I presume?   i'll have look mate, cheers Bryan,
Post by: Laverdaroo on November 14, 2021, 12:03:55 AM
Is this the pin that needs drilling out to remove the long balance bar? Once out, what would you replace it with, a rivet pin tapped in and filed flat?
Post by: Laverdaroo on November 14, 2021, 12:04:18 AM
(https://uploads.tapatalk-cdn.com/20211114/3a7ca39b3f8cf43dfed72352c6450f7f.jpg)
Post by: Nurse Julie on November 14, 2021, 09:05:21 AM
Roo.... Trig has a box of used carb jet springs here that he's just told me about 🙄🙄🙄.
Edit...... I've found 2 in the box that are usable Roo.
Edit...... Found another 2 as well.
Post by: Laverdaroo on November 14, 2021, 11:57:43 AM
ooo, ooo, BAGSEY!!!!! 8)
Post by: Nurse Julie on November 14, 2021, 11:59:46 AM
OK Roo, see what else you need that we may have or you'll be spending more on post than parts 🤣🤣🤣🤣
Post by: Laverdaroo on November 14, 2021, 12:21:09 PM
[/quote]
[/quote]
ha ha, I will. I only set about it as it was that or start painting windows............BOL++CKS to that thought I, I must have something to fiddle with in the shed and Mejima was the first thing I saw so before I knew it the carbs were being split on thekitchen table 8)
Chewy is getting moved to the hall for the winter so I can fiddle with Rosey, (the VFR) and the 550 so it appears that its going to be a busy winter ;D
As soon as  get the frame replacement (up in Wakefield still) I can start sticking bits on it and see what else I need. I'l keep you posted Julie ;D ;D ;D
I knw youre a Gin fiend, whats Trig's tipple?
Post by: Laverdaroo on November 14, 2021, 12:26:20 PM
Looks like someone has already removed the pin, the surface is far too flat for the original finish.
Also the butterfly looks out of line with the cable clamps.
The whole thing is out of jig a bit, it appears its had a hard life but Im sure it will nanny up ok.  Is that the pin then, I cant see any way of getting the bar out as it rocks slightly to either side but theres nothing else physically there that could effect the removal. If it is, what do I replace it with?
I thought that a shaft from a used rivet might be good as its fairly soft and can be filed soon to suit once in? What does the consensus use when tackling this issue. The bar has  to come out its well hammered and needs sorting, its not going back on like it is.
Post by: Bryanj on November 14, 2021, 01:10:28 PM
You tap the hole and make a bolt with a pin end to fit in the groove of the shaft that you will see when its out
Post by: Laverdaroo on November 14, 2021, 01:14:35 PM
Righto,  going to venture out to the shed in a bit for a fiddle in a bit so I'll have a go and report back.
Cheers Bryan.
Post by: Laverdaroo on November 14, 2021, 04:10:18 PM
I bought some special brass bolts which have a protruding end on them, you tap out the alloy bracket, file down the brass end to match the slot in the bar and your good to go. I have a few, you want one?
See if the flat part of that pin is separate from the bracket, to me that looks to be part of the pin, in which case you can just lever under the flat part and get the pin out.
Yes please that would be really helpful Ken, cheers. I'll pm you my address mate.
Post by: Laverdaroo on November 29, 2021, 09:46:42 PM
Bit of an update,
Had rge carbs fully apart and cleaned all the way through with teh bodies off to my pal with the vapour blaster in Yeoville and when theyre done they should have a nice clear ceracote to them and looking like new with a bit of luck. I stared teh unenviable task of cleaning up the caps and bowls wich were in a right state but came up fairly well for the first go. Ive not actually seen them in daylight yet but they looked half OK for a start off.
Julie kindly found me a set of used springs for the bowls so thats taken care of now and they're ready for bobbing together once I scoot down and collect my bag of 'shiny' on Saturday form the blasters.
Onwards 8)
So on this one I'm going to have the side panels on it so asking for advice from anyone who's bought an after-market set off fleabay. Are they any good and was there a consensus on where was best to get them from, eg a particular seller etc.
Any advice gratefully received and absorbed.
Post by: Laverdaroo on November 29, 2021, 09:55:25 PM
Sorry forgot to spell check that lot :o
Post by: Nurse Julie on November 29, 2021, 09:58:02 PM
We get all our side panels from Kaz at LPM. They are excellent quality and a lot stronger than the OEM ones.
https://lpmreplicaparts.com/
Post by: Laverdaroo on November 29, 2021, 10:51:43 PM
The all seeing eye strikes again!
Thanks Julie, You're ace ;) :) :)
Post by: Sesman on November 30, 2021, 07:23:45 AM
Second that side panel supplier. I have one on my restored 550F2. Perfect.
Post by: Laverdaroo on November 30, 2021, 06:45:51 PM
Ordered today afetr speaking to Karen there,shes a right hoot!
Thanks again julie x
Post by: Laverdaroo on November 30, 2021, 06:48:20 PM
Couldn’t get these up last night due to the Tapatalk thingy not working!
So, only two caps to do but getting there.
For the record, I HATE POLISHING METAL
Post by: Laverdaroo on November 30, 2021, 06:50:54 PM
.(https://uploads.tapatalk-cdn.com/20211130/1dca68ccc6e2b30c948e1b5a77859c65.jpg)
Post by: Laverdaroo on November 30, 2021, 06:51:50 PM
.(https://uploads.tapatalk-cdn.com/20211130/594f531f0a6c1a00468dd920de4ae59e.jpg)
Post by: Laverdaroo on November 30, 2021, 07:01:34 PM
Just got home to a long awaited parcel from the states……….the air boxes for Chewy and the 550 (Mejima)from SteelDragon.
Beautifully made and super chuffed.
I went for these as on Chewy, there’s no rear mudguard so having a complete back panel should reduce the crap being flung into the carbs/filter and(https://uploads.tapatalk-cdn.com/20211130/ecc82f1e6bba410ebb9de692657d17d7.jpg)
Due to a lack of space, look quite cool. Rather than faff about with pods but wanting the open look as requested by The Long Haired General, I thought at least it’s a complete box to aid in the intake and not have to faff so much getting pods to play ball on an individual basis…..sort of thing.
Hoping to have a fiddle on Saturday as the pipes are coming back all finished and then I’ll bob the filter on and bar a run up and tune, Chewy’s done!
I can get on and start minePiccies to follow
Post by: McCabe-Thiele (Ted) on December 01, 2021, 05:07:21 PM
Wow Roo - they look stunning - like something off a Hotrod V8  - lovely looking finish - is there any type of filter element or is it pure Bee type Honeycombs!
Post by: Laverdaroo on December 01, 2021, 06:01:36 PM
Ace aren't they Ted?
There's a K&N type foam strip between two of the Bee screens. I was more interested in the smoother air flow to aid in the tuning rather than the looks but they look fantastic which is brilliant.
I'm so knackered at the end of the day in this pants weather I can't make it to the shed on an evening after making lunches, shower etc but I'm gagging to get them fitted. With the finished exhaust system coming on Saturday It means I'm done...........for now! ;D
So looking forward to seeing it finished and outside, albeit briefly. Chewy's been given a pass to come and live under the stairs for the winter so I can concentrate on mine. I've the 550 (Mejima)to get stuck into and a fork rebuild, brake line change, swap swing arm and do some other fettling on the VFR (Rose)ready for next year so heaps to crack on with. With Chewy under the stairs I wont have to play 'Workshop Tetris' every time I want to have a go at something!
Post by: Laverdaroo on December 03, 2021, 12:15:22 AM
Evening all, could anybody confirm that this will fit my 77 550F
https://nrp-carbs.co.uk/shop/index.php?route=product/product&path=50&product_id=4437T
hey dont have the 550 listed and kinda chancing my arm but seems good value as a kit and Hoping its compatable.
cheers , the hoarding continues....... 8).
Post by: Bryanj on December 03, 2021, 02:42:36 AM
You dont get the blanking plug in front of sprocket or seal for clutch arm in that kit, all the majour stuff is same
Post by: Laverdaroo on December 03, 2021, 06:14:08 PM
Brilliant, thanks Bryan, I knew you'd know.  ;) 8)I'll get one ordered up and the other two bits to complete the lot. Cheers mate.
Post by: Laverdaroo on December 04, 2021, 06:28:17 PM
Anyone got one pf these taking up space they want a donation for? It's the brake rod arm for Mejima. There's a few on flea bay and even a stainless, bespoke, done beautifully by a flat cap wearer in a shed somewhere for £52 :o but I'm just after a standatd one if anybody has one that needs a new home? I appreciate theyre hens teeth :(
part number:43451323020
Post by: Nurse Julie on December 04, 2021, 06:38:14 PM
Not promising Roo but i may have one. Ill need to measure them up as they are all slightly different lengths and angles on the end. Don't hold your breath though 😁😁😁
Post by: Laverdaroo on December 04, 2021, 06:51:48 PM
No rush Julie  I wont, still hoarding but thought I bought one but cant find it so evidently didnt and bought a tourq rod instead. even though I had one of those ::)
Thanks for looking.......
Post by: Bryanj on December 04, 2021, 08:47:54 PM
I have a few but also a few to build so will have to check one list against the other
Post by: Laverdaroo on December 05, 2021, 01:40:42 AM
Any spares gratefully paid for .......
Post by: Nurse Julie on December 05, 2021, 02:59:13 PM
Sent you an email Roo.
Post by: Laverdaroo on December 11, 2021, 05:36:37 PM
Came to day Julie, just opened it..................oooo, shiny, thats a belter, cheers Julie, youre a star as ever. Cheers mate :) :) 8)
Post by: Nurse Julie on December 11, 2021, 05:41:08 PM
Great, I'm pleased you're pleased 😊😊😊. It's always nice to find homes for parts to forum members.
Post by: Laverdaroo on December 11, 2021, 05:42:44 PM
Just got the carb bodies back from Nathan the vapour blaster at Chameleon Vapour Blasting in Yeovil………..Blasted and treated with  ACF50 £30 done. Sooper dooper, job for this evening then on the kitchen table
Post by: Laverdaroo on December 11, 2021, 05:44:35 PM
(https://uploads.tapatalk-cdn.com/20211211/82188317f44aad5a9ab5373fbbb86fa5.jpg)
Post by: Laverdaroo on December 11, 2021, 06:19:05 PM
I know but trying not to buy a set of CR's!! :o
Its been sitting for years hence but I think they'll be servicable wont they? It shouldnt effect the fueling I dont think.........unless I'm kidding me self?
Post by: Laverdaroo on December 11, 2021, 09:04:49 PM
I will, I learnt the hard way years ago on an old honda of a pals. That was before I knew how brittle they can be.
I've got some bits to plate and the bar to have rechromed yet so I'm in no rush but I'm going to go down the shed in a bit and grab some bits and bobs  to spread out onto the kitchen table and have a fettle. I'll probably put at least a couple together tonight whilst formulating a plan for the rest of the bits to complete them.
It's only screws, springs etc to plate and some of the brass to clean up a bit and ACF up but its quite nice whilst planet Rock's burbling about in the background. 8)
Post by: heli_madken on December 11, 2021, 11:15:12 PM
Now thats my idea of a Saturday night!!
Let me know the trick to convincing my wife its also her idea of a Saturday night?
Post by: Laverdaroo on December 12, 2021, 12:15:05 AM
Its easy, just buy her a new sewing machine but more importantly,  build her  a new 400 from a knachered old barn find ;D ;D
Post by: Laverdaroo on December 12, 2021, 11:29:28 PM
Ok, so getting there with the carbs and although I thought there might be some bits to plate, I didn’t expect in excess of 40!!
I’ve been through the lot and anything not quite up to scratch is getting plated.
One thing I did notice on the strip abs forgot about until now is that the 90 degree vent on carb body three is completely missing and so is the little spring on the butterfly shaft. (Shown)
HUGE long shot but anyone got a knackered Number 3 body they want rid of? I presume these are unobtainable as shown in the fiche so looking for solutions please if anyone can come up with anything?
Cheers all
(https://uploads.tapatalk-cdn.com/20211212/d5413ff10ab8187f838374d70026b4b3.jpg)
Post by: Laverdaroo on December 12, 2021, 11:29:59 PM
(https://uploads.tapatalk-cdn.com/20211212/b5865e40ef74ff0fca0c1345eda72a35.jpg)
Post by: Laverdaroo on December 12, 2021, 11:55:17 PM
Is that right Ken, phew! I'm so meticulous and simply couldnt see it and thought it wasnt there from a 'previous fiddler' as the needles had been moved up a notch and the usual screw murdering inside.   Everything gets placed in pots as it comes apart and I NEVER lose anything. A bit dissapointed up until you just told me that theres only three! Thats great news, cheers mate. :o :o :) :)
Never thought about aquarium fittings thats particularly cunning of you and I'm going straight to the 'Drawer of Great Dissapointment' in the kitchen to a have a look. I had some chromed ones for a koi set up lurking about and might still have a couple somewhere. Wicked idea mate. :) :) :) :) :)
Post by: McCabe-Thiele (Ted) on December 13, 2021, 06:38:19 AM
Those carbs are coming on a treat Roo.
You must be younger than me to have two builds on the go!
There are lots of aquarium fittings on e-bay with some choice in diameters as well.
Post by: Laverdaroo on December 13, 2021, 07:01:45 AM
I've got the ball and the spring just not the illusive and now it seems, not required screw. I've ordered a couple of fittings in brass off flea bay so I can make something up as the 'Drawer of Great Disappointment' in the kitchen didnt produce as predicted.
Post by: McCabe-Thiele (Ted) on December 13, 2021, 07:42:14 AM
I've had my man drawer evicted from our kitchen - I have had to make do with a totally unsuitable bedside cabinet.
Post by: Laverdaroo on December 13, 2021, 07:55:08 AM
Ted, you need to put your foot down mate, that’s really unfair!
Everyone knows that bread bag ties, loose bits of hairy string, tap washers and random sealer and poo bags simply aren’t to be found in bedside cabinets!
Just not right!
Post by: andy120t on December 13, 2021, 08:05:10 AM
I once read an article from a kitchen company about how much space was 'wasted' in kitchens...and they used the kitchen drawer as an example. Clearly the writer didn't understand the concept of 'important stuff that might be useful one day' needing a home.
  I've also recently lost my drawer to a kitchen redesign and I can't now find anything. On the plus side, when my adored wife asks where anything is...sellotape, scissors..fuses... I just point her to where she now has the oh-so-useful-slide-out-bin-storage . Thanks Howdens, what was wrong with the bin under the sink?!
Post by: Nurse Julie on December 13, 2021, 08:54:50 AM
Hi Roo.
If the kitchen junk draw fix doesn't work, I have a complete #3 body. It's not as blingy as yours though but you could sort that out.
Post by: Laverdaroo on December 13, 2021, 10:17:42 AM
Hi Roo.
Nice one Julie, I’ll have a fiddle with this brass fitting that’s coming to see if I can make it fit with a bit of ‘nannying’ but if that fails which it probably will, what sort of dosh would need to be slithered across your palm to secure it?
Post by: Laverdaroo on December 13, 2021, 10:24:16 AM
Hi Roo.
I’ve ordered one of these to have a play…..(https://uploads.tapatalk-cdn.com/20211213/f8fe9fd2b5bb7e6e3bfd174ba1f79849.jpg)
Post by: Nurse Julie on December 13, 2021, 03:28:14 PM
Hi Roo.
I've sent you an email Roo with some pics.
Post by: Laverdaroo on December 13, 2021, 04:44:29 PM
no, not really. Well I am but dont feel it at the minute Ted, this working outside is doing me in! :-[
I'm only playing with the carbs as there' so much to do on them and trying to get ahead whilst I wait for a couple of finishing off bits for 'Chewy'
Post by: Laverdaroo on December 21, 2021, 10:07:59 PM
Evening all,
Quick substance question.
This part of my carb assembly is rather shagged out and I’m lucky enough to discover that not 10 miles from the burrow door, there resides a chrome plater and refinisher, wicked…..who knew?
Doug Taylor Metal Refinishers
Banwell, western-super-mud
Anyway, as they’re close I think I might trundle down and get this rather worse for wear rod re done. Question is, what finish is it, is it Nickel plate?
Just so I know what to ask for, yer know
That would be harder than chrome, right? Or is there something more hard wearing that I could  enquire about?(https://uploads.tapatalk-cdn.com/20211221/09a0e3e80759e5d133cf8c170f52d458.jpg)
Post by: Laverdaroo on December 21, 2021, 10:08:48 PM
(https://uploads.tapatalk-cdn.com/20211221/27477bb36bf639df2fe7dfe065246101.jpg)
Post by: Sesman on December 21, 2021, 10:43:26 PM
Hi, Roo.
I’m sure somebody more knowledgeable will be along in a minute, but my understanding is that the original finish was chrome. I believe most either leave well alone part from a good polish with steel wool and 2000grade emery or have it hard chromed by the likes of philpotts. Personally I’ll be polishing the feck out of mine then a light spray with lacquer.
Post by: K2-K6 on December 21, 2021, 10:57:06 PM
Precision spindles are usually chromed then ground to give final dimension to fit.
Nickel not generally used as final finish (maybe "undercoat" ) on these bikes. Ordinarily would be more of a brassy look on Nickel plating for reference.
Post by: Laverdaroo on December 21, 2021, 11:06:58 PM
mmmm, all sounding terribly expensive but I'm not leaving it like that. Might have a quiet fettle on a bit tmrw eve and see what it comes up like with a view to doing all of it.
Thanks fella's..
I bloody hate polishing n all ::) ;D
Post by: McCabe-Thiele (Ted) on December 22, 2021, 02:52:12 AM
Have you tried evaporust on the shaft?
Not sure if the rust is where it is visible but it will look better after a couple of days in soak.
Post by: Oddjob on December 22, 2021, 02:15:25 PM
There is a theory the spindle were hard chromed but seeing how they rust etc it's not looking likely. My experience of hard chrome is that it's virtually indestructible, had my fork stanchions done years ago now and they are totally unmarked after many thousands of miles. I had mine hard chromed, cost me £22.50. Maybe Philpotts could help out.  Mine was done at Dynasurf in Sandbach. Normal bright chrome isn't recommended, I suspect it wouldn't fit afterwards, even my hard chromed one was a tight fit. Plus I'd imagine it would rust pretty quick.
Post by: Laverdaroo on December 22, 2021, 05:27:44 PM
That's why I was asking Ken I thought I might have heard it was hard chromed but I'm such an air head these days I couldnt remember where I'd read that.
I'll give Philpotts a call I think, hopefully they might be able to sort it so that it fits once done. Cheers for all the info mind, it's very much appreciated.
Post by: Laverdaroo on December 22, 2021, 05:42:38 PM
 I havent Ted, I dont use it. I've heard mixed results tbh and tend to use other nastier fluids to strip things. I'm going to go at it with the wire wheel later to get it back to smooth at least and then probably send it off to someone that might be able to fettle it
for me externally.
Post by: Laverdaroo on December 29, 2021, 01:10:23 PM
Spent the best part of 6 hours in the shed yesterday plating all the gubbins and tranklements for the 550 carbs so I can start to bob them all back together with just the main chunk of the holding bar to finish off but to reduce the pile of twiddly bits is a good thing so I’m going to crack on. In between decorating and faffing about doing Christmas jobs, I’ll endeavour to get some more done.
I’ve polished the granny out of the balance bar and it’s come up reasonably well but I’m still going to have a run out tmrw on the VFR as the last ride of the year to the platers to see if they can suggest anything.
Onwards though, which is great
Post by: Laverdaroo on December 29, 2021, 01:12:49 PM
(https://uploads.tapatalk-cdn.com/20211229/9961b0430ed141f32bc3ea4f0c1b6dbb.jpg)
Post by: Laverdaroo on December 29, 2021, 01:14:42 PM
(https://uploads.tapatalk-cdn.com/20211229/20269c41ba8beb4c44b716dd69ed56f8.jpg)
Post by: Laverdaroo on December 29, 2021, 01:15:13 PM
(https://uploads.tapatalk-cdn.com/20211229/b55148fbe7568c2b8a282aa93e168ed7.jpg)
Post by: Laverdaroo on December 29, 2021, 01:16:04 PM
(https://uploads.tapatalk-cdn.com/20211229/c8c11eff0bb391eab196ab65bbe0be27.jpg)
Post by: Laverdaroo on December 29, 2021, 01:16:42 PM
(https://uploads.tapatalk-cdn.com/20211229/e15c7f8b4be30f097f4b0e2c24521584.jpg)
Post by: Phil Ward (RIP) on December 29, 2021, 01:17:33 PM
Been there - That could be my garage roo!
Post by: Laverdaroo on December 29, 2021, 01:24:52 PM
Its a right pig isnt it? ;D
This is the third time I've been through this now, doing builds and I hate it each time although its quite satisfying. Reasonably happy with the results though so onwards. 8)
I'm really just finding things to do while I wait for bits to finish the 400 to come in but they've got to be transferable to the kitchen so I can do it in front of the fire if I need to as I'm working late at the min and cant face a cold shed just now. ;D Its only because I need the fire on to plate everything, I was in there........... ;D ;D.
Another job ticked off but it wont be the last time the vats come out on this one I think!
Post by: Oddjob on December 29, 2021, 09:41:36 PM
I'm going to experiment with plating all my carbs bit in yellow passivate instead of bright, as I've got 2 sets I can do one of each and see which I prefer. As the carb bodies are black yellow might be a better contrast. I'm also going to see how leaving them in the passivate longer affects the colour, I might even have a mix of yellow/gold and silver plated bits or I may even do a couple of pieces black just to see how they come out.
Is that just zinc or zinc/nickel Roo?
Post by: Laverdaroo on December 29, 2021, 10:19:14 PM
This lots in zinc, it doesn’t stick to the hard chromed bits and comes off with wire wool which is what I want.  I seem to have the mix just right now as the zinc is sticking to what it supposed to like the proverbial to a blanket.(https://uploads.tapatalk-cdn.com/20211229/a5fcc5af2bb63617326e734214af55e0.jpg)
Come up nicely in most areas so chuffed with this lot. As you know there’s nothing worse after heaps of prep for it to go T U!
Post by: Oddjob on December 30, 2021, 12:01:56 AM
What bits are hard chromed Roo?
Post by: Laverdaroo on December 30, 2021, 12:09:57 AM
Sorry, I appear to have hard chroming on the brain, I meant shiny hard spindles such as the ones that lift the slides in the body. They are dead hard and very shiney and I didnt want to alter the diameter but as it happened as it was so shiny it hasnt taken and come off with a slight rub with soft wire wool. I purposely didnt attack those areas with any form of abrasive in teh cleaning so not to thin anything out. All the steelparts have taken beautifully though and all going together well on the kitchen table at the moment.
Post by: Laverdaroo on December 30, 2021, 09:43:29 PM
In between helping with the decorating, fitting new double glazed units into the back door and   Faffing with house stuff, I managed to get an hour in on the carbs today after an evening’s fettling in the shed yesterday.
Not coming up too bad and just the big bracket type back plate to finish off and fit and they’ll be done. I won’t bench sync them yet or do the float heights, they’re just a big faff out the way before I can get her on the bench and stripped.
Quite chuffed although a bit of blooming on a couple of bits but I can live with that as the coverage is good and they’ll get an autosol (https://uploads.tapatalk-cdn.com/20211230/3f8850232cf3dd9a634fa70c33c2d646.jpg)
before they’re fitted and most will rub off with that but feel I’ve earned my ‘Ned in the Shed’ badge today
Post by: Laverdaroo on December 30, 2021, 09:43:53 PM
(https://uploads.tapatalk-cdn.com/20211230/3ff74728753720e56cd37cc1c179c5bd.jpg)
Post by: Laverdaroo on December 30, 2021, 09:44:21 PM
(https://uploads.tapatalk-cdn.com/20211230/303f66d8e476ff7800e783dd6a802840.jpg)
Post by: Laverdaroo on December 30, 2021, 09:45:53 PM
(https://uploads.tapatalk-cdn.com/20211230/48a336e0f1a13499aa4baf1962848818.jpg)
Post by: Rozabikes Tim on December 30, 2021, 10:03:20 PM
Well done Ned!
Post by: Nurse Julie on December 30, 2021, 10:24:30 PM
Looking great Roo.
Post by: Laverdaroo on December 30, 2021, 10:29:18 PM
Still waiting for my brass right angle to repair the breather in carb 3 but no rush n all that….
Still pondering how to fix it in, would solder work or some silicon tape or hairy string? Not sure until it comes.
Post by: Bryanj on December 31, 2021, 01:05:09 AM
Solder wont workas carbs are monkey metal, very tight fit with locktite
Post by: Oddjob on December 31, 2021, 01:38:26 AM
Still wondering why you didn’t just buy a plastic right angled pipe connector Roo, you could just sand the end until it fitted the body, no one will ever see it with the pipe on.
Always wondered why Honda failed to fit spring washers under the heads of the choke flap screws, if one of those come loose it’s going straight into the combustion chamber. Ok, so they peened the back of the screws a little when new but I’m willing to bet nobody does that when they get refitted, another thing, Mark Paris recommends cutting down any protruding part of the carb balancing adapter screws on the intake manifolds so that they don’t upset the airflow, so presumably the same thing could apply to the choke flaps screws, so I intend to replace the screws with stainless ones, fit a spring washer then file them flat on the reverse, whilst not mounted of course so that no chance of metal filings going into the carb bodies. Maybe I’m just going ott but then again maybe it will make a very small difference.
Oh and Roo, Mark also says approx 5 psi in the forks and I think it was approx 10mm of preload. I’ll check that when I can find his notes on the 500.
Post by: AshimotoK0 on December 31, 2021, 07:56:18 AM
I always wondered about this Service Bulletin attached, concerning an M6 nut finding itself inside the engine on the CB750/Sandcast air filter housing.
Then I got talking to a bloke who was the Service Manager at Freddie Friths's in Grimsby in 1970  and he told me that the very 1st CB750 he worked on for repair not servicing was that very fault. He also  told me that the comedian Dick Emery came in and test drove one of the 1st CB750's, as he was in pantomime in Cleethorpes .. but as we all know Dick went on to buy one from Tippets of Surbiton
Post by: Laverdaroo on December 31, 2021, 09:15:11 AM
I didnt Ken as being in the aquatics trade as a fishery manager and dealing with all things pumps,air lines and the like Ive heaps of expoerience with fittings and although didnt twig at he time until ypu mentioned it, I know that after time theose plastic fittings get brittle and are effected by heat after a while too so went belt and braces on the fittimg.I bought one that was toosmall to start then ordered a couple of options to file down to tap in. They'lllast longer and wont be as much of a potential fail. It would be just my luck to have em all sorted, fit them and then pull out the fitting and have to take the carbs off again to refit. Plus, I'll always know its there and it'll bug me.
I wandered about the choke flap screws so dabbed a bit of loctite on them but to be fair, after plating them they are a particularly tight fit and I cant see them coming out but  did have exactly that thought whilst putting them together.
The rest of it may come in the post today back from the repairers and I'll have another go at finishing them off but for now, I'm off chub fishing for the afternoon, I havent managed to have any dangling all christmas and I want a session in before the end of the year. Even just to say Ive been and had a mooch about.
Nice one on the fork cap PSI rating Ken, let me know.
Did you have a chance to find me one of those brass screws to attach the actuator bar back onto these carbs Ken, you mentioned you had a few knocking about, is one still up for grabs?
Post by: Oddjob on December 31, 2021, 04:39:02 PM
Ahh yes the retaining screw for the bar, not yet managed to find the brass ones but I supplied Phil (Sesman) with a stainless one instead. I have a few sizes of them, what thread size would you like and I'll alter one to fit, I fit it in a drill and file the stub done until it fits the slot in the bar, they are too big as standard.
Post by: Laverdaroo on December 31, 2021, 05:38:41 PM
Ang on, I'll have a measure after tea, just got back in from hunter gathering 8)
Post by: Sesman on December 31, 2021, 06:32:21 PM
Thread drift warning….has the frame arrived?
Post by: Laverdaroo on December 31, 2021, 06:35:34 PM
Nope but we located it and I sent a minion to go fetch it so it was safe. I'm driving up to wakefield on sunday to go get it!   anglo saxon, anglo saxon etc...
Post by: Oddjob on December 31, 2021, 06:52:42 PM
I was wrong, memory is starting to fail  ;D 10 psi for the forks and he says fit 3 washers (but doesn't say how thick they are) in the forks so they effectively preload the springs. So I'd say say 5-10mm of preload. My springs are mismatched in length, so what I'm thinking is to fit the springs etc, no preload at all, place a heavy weight on the top of the fork top, maybe my old vice, measure to see how far it compresses the fork and mark it. Do the other fork and then match the preload so they both compress the same distance. Not sure if that's the correct way but it makes some sort of sense.
Trim those screws into the inlet manifolds, measure the bores of them all and see if they match, if not make them match, smooth out any casting marks, rough spots etc. Should get another 5bhp doing that without affecting engine response.
If you want a little more power, get the cam lobes modified, no more lift, just more duration. So 5 degrees of overlap and 10 degrees of duration. Engine won't be cammy with such a mild mod. Think I have a spare cam so may just try that one.
Post by: Sesman on December 31, 2021, 07:42:57 PM
Bloody hell, Roo. That’s just ridiculous.
Post by: Laverdaroo on December 31, 2021, 07:52:52 PM
Isn’t it!
I opened up a ‘whole can of Northerner’ at Hermes, got a full refund, apology letter and a £50 credit on my PayPal account!
The feckers!
Post by: Bryanj on December 31, 2021, 07:59:42 PM
You did well with Hermes, i have complained several times and got nowhere
Post by: Laverdaroo on December 31, 2021, 08:30:13 PM
I was beyond rude and beat the service lass into submission and I also sent an email to the CEO, he rang back himself orif it wasnt it was his 2IC. Turns out hes a biker and when I pointed out it was an irreplaceable  vintage cb550 frame he couldn't have been more helpful tbh, funny that isnt it!
Post by: Sesman on January 01, 2022, 12:13:05 AM
Good on yer. Happy new year Roo.
And a Happy New Year to all.
Post by: Laverdaroo on January 01, 2022, 07:34:21 PM
Had a result today!
Upon chewing the fat with a fellow frozen daft biker in the cheddar gorge this afternoon, talking about all things SOHC (he turned up on a mint 500). I was boring him to sleep regarding the carb issues I’ve had and breather fittings etc when he said he had a bunch of old bits n bobs back home and sure he could cannibalise something for me.
Sure enough, pulled from a stripped carb outside in a bucket of water…….one breather angle. And it fits a treat. Winning!  Cheers for that Dave. Aren’t bikers bloody marvellous?(https://uploads.tapatalk-cdn.com/20220101/0022916d889d803d6d6644e2e89e5755.jpg)
Post by: Laverdaroo on January 01, 2022, 07:43:02 PM
Found this today also hiding in amongst the 550 bits, the long lost tacho cable holder for Chewy. Knew I had one!(https://uploads.tapatalk-cdn.com/20220101/fa8693dee3a4bdf25bff128ad453a8e6.jpg)
Post by: Laverdaroo on January 01, 2022, 07:47:57 PM
Two out of three isn’t bad but I’ve been cleaning and batching things to get plated, replaced etc and what I thought was a reasonably good rear brake pedal, spring has  been reduced to this!
I happened upon this one for a K3 I think, wondering if I could somehow nanny it to work but I don’t think it’ll be a goer now the two are next to each other.(https://uploads.tapatalk-cdn.com/20220101/98a6b5bf9cf78617fde29303e099a11e.jpg)
I know these are unobtainable now so has anybody had any luck finding/making/modifying anything to suit without reinventing the wheel?
Post by: Laverdaroo on January 01, 2022, 07:48:30 PM
(https://uploads.tapatalk-cdn.com/20220101/8718aea5efdf641c56f9737fe1992c88.jpg)
Post by: Laverdaroo on January 01, 2022, 07:57:02 PM
Id like more of a chat about the cam scenario as that sounds like an easy win for little faff but not opened her up yet, for all i know the lobeson mine will be past repair or similar. Nice one on the sfork DIMS Ken, thats brilliant.
Post by: Oddjob on January 01, 2022, 09:26:18 PM
Doesn't really matter about the lobes Roo, they will be repaired as the difference is made to them.
As for the spring, get the part you need glowing red, bend it into the new shape and let cool, you should be able to adapt the K3 spring to match the F2 one I reckon with a little work, replate afterwards.
Post by: Laverdaroo on January 01, 2022, 09:35:47 PM
Do you think although it's a coil less than the spec one, it'll be sufficient?
I had thought about it. I also emailed a company about making some and see wht they say. If anything because of their name. I kid you not... FLEXOSPRINGS, Bristol.....Brilliant, does exactly what it says on the tin ;D ;D
I know they get reground but as I mentioned, It'll just be my luck that they'll be shagged out in a place thats unrepairable! ;D I'd like to have that chat though at some point. I've had nothing to do with modifying engine internals  but only from never having to before. Fully converse with the whys and the benefits etc but not had much to do with it. It's always been two stroke tuning and 4 stroke resto so never approached the tune side from differing internals.
I'm off to get the frame from wakefield in the morning but when I get home I'll maybe have a go at that spring with the gas bottle and torch. Thanks mate.
Post by: Oddjob on January 02, 2022, 12:24:26 PM
Looks enough metal on the other spring to make another loop to match the F2 spring Roo. Just find something the right diameter to bend it round.
Post by: Laverdaroo on January 02, 2022, 03:02:16 PM
Gonna have a go on a hot Ken, only just got back from B’ham to finally get my hands on the frame that I bought of Phil back in November!!!
Anyway WHOOP WHOOP! Next stop, the blasters.
Cheers Phil by tjecc be way, it’s a little cracker and no tin worm anywhere, thanks heaps for supplying such a good starting point mate, you’re a ledge(https://uploads.tapatalk-cdn.com/20220102/67408c2742c5f5301d3de59c5139fa23.jpg)
Post by: Laverdaroo on January 02, 2022, 03:02:32 PM
Yeah, still decorating
Post by: Sesman on January 02, 2022, 04:54:07 PM
 :)Glad,to be of service…crack on.
Post by: Laverdaroo on January 02, 2022, 05:41:03 PM
On like yer don’t know. It’s going to be blasted tmrw
Post by: Laverdaroo on January 07, 2022, 05:50:23 PM
Been slowly fettling the carbs over crimbo and have nanny’d them into something half decent now I think.
Got a box of polishing ingredients in today from Scotland as per Oddjob’s recommended recipe on ‘the preferred polishing method’ so I’m going to have another go at the caps and bowls but really want to see if I can get the balance bar a bit better.
The frame landed finally and already been sent to Yeovil to be blasted and etch primed.
Over the break I also fired the new Steel Dragon air box to Chewy which looks great and started buttoning up the cable routing and holding blocks for all the carb over flows and breathers etc. I’ve settled on a small block of black nylon which I bought from an engineers in town for 3 quid or something like that. I’m going to make a 15mm x 20mm x 100mm block up and drill it to take all the pipe work. This will then be fixed to the lower crossmember of the frame below the swinger, all tidy and out of the way and not a cable tie in sight……..brilliant.
Will report back on progress as and when (https://uploads.tapatalk-cdn.com/20220107/21974289597de98a4fa9ac88b7d0da91.jpg)
attempted
Post by: Laverdaroo on January 07, 2022, 05:51:48 PM
(https://uploads.tapatalk-cdn.com/20220107/544a8900ffd419bc882cdc9ea9df4dfe.jpg)
Post by: McCabe-Thiele (Ted) on January 07, 2022, 07:26:29 PM
 Wow Roo - those carbs look like new - they make mine look like the  before picture!
Post by: Laverdaroo on January 07, 2022, 08:01:09 PM
Give over Ted, yours looked fab in the last piccie I saw of the bike. Apologies for the awful cable holder on the clutch, thats due for replacement with the proper one which I was reunited with whilst tidying up at the weekend :D Did you ever manage to find a replacement for yourself, you were looking for one werent you?
Hows you and your beloved, feeling better after the dreaded lurg last week? You back on form? And how are the pups, all good?
Post by: Oddjob on January 14, 2022, 06:48:07 PM
How did the hunt for the fork ears go Roo? Did you end up buying that pair?
Post by: Laverdaroo on January 14, 2022, 08:25:57 PM
Yes I did, they came yesterday. They are just what was described and yes, pretty chuffed tbh.
Post by: Oddjob on January 14, 2022, 09:34:55 PM
I’ll keep my eyes open for a chain guard for you.
Post by: Laverdaroo on January 14, 2022, 11:25:26 PM
Thanks mate,Ive search alerts all over the place looking ;D
Post by: Laverdaroo on January 14, 2022, 11:48:34 PM
These two are the best I've seen this week.......
https://www.ebay.com/itm/193328973293?hash=item2d034e05ed%3Ag%3A1z8AAOSw0vdeKH-c&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5335821165&customid=tksparts%2BHonda%2BCb550&toolid=10049
https://www.ebay.com/itm/224753050559?hash=item34545363bf%3Ag%3AngUAAOSwSLlhwqY7&mkevt=1&mkcid=1&mkrid=711-53200-19255-0&campid=5335821165&customid=tksparts%2BHonda%2BCb550&toolid=10049
Awful lot of money! :o
Post by: mickwinf on January 15, 2022, 08:45:05 AM
Wow they are expensive, but very hard to find a good used one, luckily i got a decent one a couple of years ago from Trigger as my original was very bad and too far gone to rechrome. What is interesting looking at the pics of the nos ones is the quality of the chrome is not great, and the spot welds show prominently . also the shape which looks like a dent to clear the shocker, definitely made to a price!
Post by: Laverdaroo on January 15, 2022, 03:46:47 PM
Not great are they and top, top dollar! I can feel Kempton autojumble coming on I think! :-[
Post by: Laverdaroo on January 15, 2022, 04:46:43 PM
Picked the frame up from the blasters this arvo. 75 and he bobbed me a coat of acid etch on it straight after blasting after a hoover off. What a star!
It’s come back looking great apart from the following four or five piccies.
(Now, being technically challenged as I am, as my crap typing and general laptop management shows, I can only put one photo up at a time from my phone via the Tapatalk thingy and on my laptop I just get file too big to send. Even if it’s just text so given up posting replies on that now!.
Anyway, have to put them up one at a time even on small, so bear with and just chuckle quietly to yourself and don’t let on please ‍)
So, bit of old gravel rash on the n/s rail underneath, but if a ‘ding’ on the n/s rail also, so I reckon it’s been poked by something by mistake in the garage and or either been on concrete blocks and/or been dropped off it’s side stand into a kerb or similar at some point in it’s history? No biggie and no real damage I think so quite chuffed, especially when you consider it’s in excess of 40 odd years old. It’s in better nick at 44 than I was
I reckon the ding will fill with weld once drilled and then flatted off and the bottom will sand out fine before painting.
It’s a bit ‘rippley’  on the top spine though, is that a manufacturing process thing?
What do you lot reckon or has Phil sold me a ‘cut n suit spesh’ before giggling manically and running off into the sunset via the Timmy Taylors brewery? (Kidding Phil)
Forgive the rather used appearance of the workshop, it only looks ‘decidedly used’ because it is
Post by: Laverdaroo on January 15, 2022, 04:48:11 PM
(https://uploads.tapatalk-cdn.com/20220115/6a8cd8122e8c642ff8be3f13dabe6072.jpg)
Post by: Laverdaroo on January 15, 2022, 04:48:57 PM
(https://uploads.tapatalk-cdn.com/20220115/e54b988b26de5a48eb1f27237b5dfc90.jpg)
Post by: Laverdaroo on January 15, 2022, 04:49:21 PM
(https://uploads.tapatalk-cdn.com/20220115/e692eb941414de12d704f6c234c06670.jpg)
Post by: Laverdaroo on January 15, 2022, 04:49:46 PM
(https://uploads.tapatalk-cdn.com/20220115/20b4219e37615ab8c3fe9c39d8c693df.jpg)
Post by: Laverdaroo on January 15, 2022, 04:50:42 PM
(https://uploads.tapatalk-cdn.com/20220115/24c91c626a10cf2ce4d6750f64296267.jpg)
Post by: Laverdaroo on January 15, 2022, 04:51:20 PM
(https://uploads.tapatalk-cdn.com/20220115/0cba8cd0579b29b41323ff99145ad25d.jpg)
Post by: Bryanj on January 15, 2022, 05:04:58 PM
The "dink" is probably crashbars, never seen ripples like that,might be worth getting alighnment checked as to sidestand its a lot farther forward on 500, dont know on 550F
Post by: Laverdaroo on January 15, 2022, 05:30:36 PM
Thnks Bryan, I've got it booked in with a pal down here to have it measured up next week. Looks straight enough from what I can measure here with plumb bobs and a tape but I'll wait to see. There are absolutely no stress marks on it anywhere but Ive not seen that before either and wondered if it was a generic thing from the time. I wouldnt have thought so but I have to ask as my experience of these is still relativly new.
Post by: Sesman on January 15, 2022, 05:44:56 PM
Jesus, Roo. Frame came fro DK and reminded on the crate until picked up by you nephew. I certainly don’t recall the ding in down loop,or,whatever you call it and the welding on the rear loop is a surprise too.
Post by: Laverdaroo on January 15, 2022, 05:55:16 PM
Is that blanking plug on the ficheBryan, I'm struggling to locate it on cmsnl?
Post by: Laverdaroo on January 15, 2022, 06:21:00 PM
Its 40 odd years old Phil, its no biggie and to be fair it ws a bit gooey in those areas anyway. I'll get it sorted. I wasnt aware of the ding either but these things happen.I'll be right, I'm sure. Like I say,i was plesantly surprised if I'm honest. ;D
Post by: Sesman on January 15, 2022, 06:38:57 PM
Phew, thank the Lord. I was getting a little worried there. Strange thing is that frame was supplied to replace a bad one I’d been sent previously, but I went through the same process as yourself and wound up doing an alignment check, during which I had some minor repairs done so that frame was surplus to requirements as mine is a 77F2.
Incidentally I’ve found a seat lock loop/holder that will fit that frame you can have. PM me and I’ll post it.
It would seem that good frames are becoming very rare now. The recent surge in USA import activity will eventually exhaust stocks and price rises will be inevitable, if demand remains of course.
Glad you are progressing.
Post by: Laverdaroo on January 15, 2022, 06:56:12 PM
Yeah, I hear you on the frame front. Its soooooooo not a problem Phil, I was pleasantly chuffed as I see that these aren't too bad a thing to get sorted. The frame ripples are a bit weird as the rest of the bike is spot on so god only knows how thsts happened hence the question. I thought it was crash damage but the metal is straight on the inside as I stuck the camera thing into the frame and all seems fine as to what I can make out anyway. Bob's gonna sling it on the jig for me next week anyhow just to be sure and I'm going to go over some of the crap 1970's welding to tidy it up so all will be well and I'm not to concerned. Super chuffed to have found a replacement frame tbh, as you say, theyre as rare as unicorn plop at the minute. There was an absolute sh1tter for sale over crimbo and some loon paid £600 fo it and it was clearly fooked!
Depends how badly you want it I suppose.
I'm just treading water at the min doing bits and bobs as I was waiting on some bitsf or the 400 but theyr'e sorted now so it's three spot welds to do and she's done but I'm waiting before the big reveal/grimace until I can say its actually done, done :D
Soon as the bench is free the 550's going on to be done but now that there's a possibility of a fishery coming up fpr sale thet we're interested in, we've just put the house up for sale this week so its decorating tastic here at the min :-[
I will get some more done though before the weekendis through, Im itching to get out there and do a bit ;D
So does 'The Long Haired General' after the moaning about the painting by me (cunningly trying to get her to send me outside ;D  ;)
Post by: Bryanj on January 15, 2022, 07:23:15 PM
Its on the transmission page, should be 91207374000 but check
Post by: Nurse Julie on January 15, 2022, 08:42:30 PM
The frame looks OK Roo. I've never seen those ripples along the top tube either 🤔🤔🤔
Post by: Laverdaroo on January 15, 2022, 11:18:49 PM
 Thanks mate. couldnt find it.
Post by: Laverdaroo on January 15, 2022, 11:35:43 PM
ordered, just all the bearings and the rubber and plastic for the engine and we can start the dismantle once there's abit of room.
Post by: Bryanj on January 16, 2022, 06:12:58 AM
Dont forget the "hidden" crankcase bolt and you have my number, just not this week as i am away in deepest darkest Cornwall
Post by: Oddjob on January 16, 2022, 06:36:42 AM
I'm fairly sure the ripples are not uncommon. Seem to remember seeing them when I took the paint off my frame in the late 70s, I think they are harder to see with black paint on but with grey there is light and shadow so they show up a lot more.
Post by: Sesman on January 16, 2022, 08:42:26 AM
Me too. I have them on my 77 F2, but the plot is straight and true. The light and angle of view can also exaggerate them. I gave mine a good rub down to flatten them slightly and after powder coat they are barely detectable.
I’m sure they are as a result of the manufacturing process, but i can’t explain how or why.
Post by: Seabeowner on January 16, 2022, 08:49:45 AM
Third that, pretty sure there is some on one of mine.
Post by: Sesman on January 16, 2022, 08:53:20 AM
Roo.
On bearings, rubber and plastic. Are you aware that the gasket sets don’t include the rubber ‘pontefract cakes’ in the cam/head?
Just checking as it was extremely frustrating when I got to the final assembly stage and found they’re not supplied. NJ stocks them. If your not familiar with the camshaft set up there is bit of a trick to getting the cam chain on the sprocket. It involves ensuring you have the chain resting on the cam on the correct side of the cam wheel/shaft. The manual photos give you a good clue.
Post by: Oddjob on January 16, 2022, 10:07:39 AM
A trick I found useful was putting the barrels on, then putting the camchain tensioner in place, making sure it's located in the slot in the bottom crankcase. Now undo the locking nut on the tensioner and push the blade back as far as it will go by hand, nip up the locking nut and when you come to fit the chain onto the sprocket you'll find it a lot easier.
Post by: Bryanj on January 16, 2022, 11:21:15 AM
Itl be because the top is not a "tube" but two stampings welded together and stamping causes stretching and shrinking of the metal
Post by: Oddjob on January 16, 2022, 12:50:32 PM
Roo, need a favour. Can you measure what size the top mount is on the rear suspension. Not the thread but the section where the mount sits, I need to order some rubber mounts for my dampers but don't know what size they are and the frame not available to measure ATM.
Post by: Laverdaroo on January 16, 2022, 07:19:20 PM
just decorating Ken but I'll do it tonight for you mate.  Bear with........
Post by: Laverdaroo on January 23, 2022, 08:46:10 PM
Right, house decorated and on the market..........and breath!
House done,,,,,,,tick
Been fishing,,,,,,,,tick
Blanked like a dog,,,,,,,,,,tick! ;D
Shed o'clock! 8)
Still waiting on a bit of room but got the all clear on the frame, it's a gnats biased to the right by .5mm and I reckon I can live with that. Happy days :)
Amazing that nobody has really noticed these ripples until 'numb nuts' here chucks a bit of grey acid etch at the frame. I think you're right Ken Cool its a standard thing, I had an idea it was a manufacture process thing from the stamping but glad it's all cool and straight. Cost me 4 bottles 'of Dog' for the check......winning! ;D
Thanks for all the advice on the hidden bits and bobs. I've got the Pucks Phil but didnt know about the other  points about hidden bolts etc. Ive not done one of these before so looking forward to the pondering sessions if I'm honest......That is when I get my shed back and can get at stuff! I'm no where near re-assembly, that would involve dissasembly and currently all the crap from the house that, apparently doesn't look good to perspective buyers has to go in the shed.
I mean, what's wrong with a  lifesize Valentino Rossi standing next to an M1 R1?? I ask yer, some folk!  It looked ace under the stairs and now its on my bench in the sodding shed!
Onwards ;D
Post by: Laverdaroo on February 05, 2022, 03:59:45 PM
Managed a bit more work on the carbs today in between doging hopuse jobs for 'The Long Haired General' and currently bobbing them together in the bit of space Ive ,anaged to climb nto in the shed to have a quite fettle with Planet Rock to sooth the soul for a few hours.
Whilst fiddling my thoughts wandered to brakes and teh twin disc set up I want to do on the front. Ive managed to get a complete set up of twin discs, calipers, new stainless pistons and honda seals so I have all I need for the bottom until I start on the hub modifications (as read on here by Bryan and the rest of the super knowledgable) in the various chats and posts. That being said, I think I might be asking a few questions come the time. However, I havent really thought of what master cylinder I'm going to run on the renthal bars i have for the final build. Theyre 7/8" medium rise street bars in a matt black cerecote finish and look superb. I'd like a reasonably priced master to go with t but getting a little confused on the ratio's required for the build up. Ive read 17mm cylinders and plungers, 19mm and I think 16 too. I realise the extra force required for teh extra caliper but get a little 'hooped' when it comes to the ratios; smaller bore more pressure meaning smaller plunger or larger piston to fill the larger sytem at the same pressure.
Can anyone help out on this?
Phil, (SESMAN) di you o a twin set up, up front? What di you come to as a good solution?
Anyway back into it, just thought I'd type ths now before I climb back into my hollow to continue in the shed.
Answers on a post card please....
Post by: Oddjob on February 05, 2022, 04:06:44 PM
I'm using a CB1300 front master cylinder on mine Roo, it has a mirror mount if that's important. A lot don't. It also has a front brake light switch on it in case you want to ditch the lower yoke version. I got the braided brake lines from HEL.
I'm lucky as I own a CB1300 and just replaced the clutch and brake master cylinders for radial ones so the old ones were spare. The clutch MC will also be used if I can finish the hydraulic clutch conversion I'm planning.
https://www.ebay.co.uk/itm/203648282305?hash=item2f6a622ec1:g:GOcAAOSw1dhhZY0w
I have a spare original cap for the reservoir and a spare lever if your getting that.
Post by: Sesman on February 05, 2022, 05:10:43 PM
Hi, Roo.
I went with the early GL1000 master as it looks period.
Post by: Laverdaroo on February 05, 2022, 09:17:05 PM
Thanks ella's looking now. Would eiher of you know what iameter piston that is in te master (mm)?
Post by: Sesman on February 06, 2022, 08:36:58 AM
I think it’s 17.5mm, but couldn’t swear to it. I’d rather not strip it to find out. ;D.
I do know a later 80s wing m/c with 15mm is popular, but I can’t vouch for it.
Post by: McCabe-Thiele (Ted) on February 06, 2022, 11:53:35 AM
Looking at those strange ripples on the top of the frame reminds me of pressing marks I have seen on some  front wings back in the 1960's to mid 1970's on cars - from my memory it was caused by a lack of lubricant during the manufacturing / forming process. It was usually near the end tip of a wing where the lubricant had failed to reach or had broken down.
I have no idea how they make a bike frame but I suspect it could be from when the frame was made.
Post by: Laverdaroo on February 06, 2022, 11:58:50 AM
After everyone looking at theirs an me bobbing about to see collections of bikes etc it turns out it si manufacturing from the stamping of teh individual processes involved. It wasmy forst thought too Ted.
Looking at whats out there and not wanting to spend teh earth on levers master cylinders and the like and the fact I'm going to nee a pair of matching levers and poerches Im looking all ove the net. The chinese do an awful lot but at £30 for a pair I'll skip that I think.
Its probably going to be Rizoma or Brembo but still looking...............
Post by: Laverdaroo on February 06, 2022, 12:46:01 PM
Soooo, hit a snag!
Went to fit the Steel Dragon air boxes to the fresh built carbs just to have a look……as you do, and it appears they don’t fit! Eeek!
Looking insite there’s a lip that’s 1mm higher than the opening meaning the carbs only go on 5mm rendering the grub screw holes useless and with no seal.
Bit of a sod as I’ll have to get em apart and have them machines somewhere, ( my local guy is all Covid’d up to the max). Bit of pain as I presumed they’d be a bolt on win, sadly not!
I’ve dropped them a mail but I’m not kicking and screaming, these things usually happen to me so it’s par for the course. They’re in the states and the economies of scale don’t compute so I’ll sort it but ‘bloody ‘el)
Anyone got their lathe up and running and fancy an easy guvvy job for beer tokens?(https://uploads.tapatalk-cdn.com/20220206/2b394ef6b52d7adbac1f95aed83fa4eb.jpg)
Post by: Laverdaroo on February 06, 2022, 12:47:00 PM
(https://uploads.tapatalk-cdn.com/20220206/fbe236abe7aaf6ece07fd31a0b824476.jpg)
Post by: Laverdaroo on February 06, 2022, 12:47:24 PM
(https://uploads.tapatalk-cdn.com/20220206/2f1ba33d424e7879d23032ea6011e5fd.jpg)
Post by: Oddjob on February 06, 2022, 03:00:06 PM
Roo looking at those pics IF the funnels went onto the carbs fully the dome nut would hit the choke mechanism stopping it working.
It also looks like the funnels clamp onto the tube causing the problem, maybe try releasing those little grub screws and moving the funnels forward and then clamping them back up, try that and see if it solves the problem.
I'm not keen on those boxes BTW, the idea is that the funnel gives an airtight seal OR the carbs will pull air from anywhere, if that means it pulls air from any gaps between the funnels and the carbs it will mean unfiltered air is getting into the engine and that causes wear your not going to like. How tight are they onto the carbs? maybe try a small piece of rubber around the carbs if there's a gap.
Post by: Bryanj on February 06, 2022, 04:27:07 PM
Looking closer i think the inner bits are held tight into the outers by the smaller grub screws in which case you could remove theouters and shorten the inners
Post by: Laverdaroo on February 06, 2022, 09:52:09 PM
Yeah, they are Bryan. They come apart pretty easily but not that impressed with the fittings. All the machining is spout on bar the fit but the grub screws are crap.
I’ve taken half a mil off the inside to get em to go on with some Abram et cloth hot glued to a soft buffing wheel I’ve got for the drill. Worked a treat. I’ll put the miss fit down to yer man over the pond, knocking his dial on the lathe. Easy done but what a ball ache!
Bigger o rings installed to reduce air leaks if any are tempted but I might get em tigged together to be sure at some point, dunno.
Anyway, they’re in snd they fit.
Best job, callipers to clean and get sorted….
Onwards and onwards……..(https://uploads.tapatalk-cdn.com/20220206/b677eb204c4ff861f583ea197138e280.jpg)
Post by: Laverdaroo on February 06, 2022, 09:52:39 PM
(https://uploads.tapatalk-cdn.com/20220206/2090c597ff49600b548a3c30feeac2b7.jpg)
Post by: Laverdaroo on February 06, 2022, 09:53:02 PM
(https://uploads.tapatalk-cdn.com/20220206/7cb9ea8b19a2ada674225b812224653a.jpg)
Title: Re: 550 F2 started!
Post by: Laverdaroo on February 06, 2022, 09:53:34 PM
(https://uploads.tapatalk-cdn.com/20220206/ae3f54ad197a81f510075afd66ad99f5.jpg)
Post by: Oddjob on February 06, 2022, 10:01:36 PM
Those domed nuts look very close to the choke lifters, have you checked they don't foul.
Post by: Laverdaroo on February 06, 2022, 10:10:45 PM
yep, all clear, it's the angle of the photograph. I had to file down the choke lever by a couple of mil also to get it to operate without fouling. All good and happy.....ish with the fit on the table, it'll be a different scenario when trying to get em on this good on the bike but I'm planning on a dry build anyway so we'll see. Happy for now. Ended up making a shouldered screw up for the balance bar and it works a treat. Just bobbed it in with a bit of thread lock to be sure.
Miss my bench lathe though, all this faffing about is knackering my fingernails yer know :o 8) ;D
Post by: Sesman on February 07, 2022, 08:10:58 AM
Looking really smart, Roo.
Post by: McCabe-Thiele (Ted) on February 07, 2022, 12:23:56 PM
All looking good now Roo panic phase over!
Post by: Laverdaroo on February 07, 2022, 06:14:42 PM
Cheers fella's, theyve been a bit of a pig but kinda enjoyed the head scratching.
Just not the polishing! :(
 ;D
Post by: Laverdaroo on February 10, 2022, 07:03:06 PM
Reeto, cheers Phil
Post by: Laverdaroo on March 07, 2022, 07:22:26 PM
Right, after a day of groaning and more Anglo Saxon vocabulary muttering, I managed to get all the frame mounting bolts free from the engine and strip all the crap off the old frame ready to get the lump out.
All were ok but very much ‘in there’ and I got through a gas bottle in the plumbers torch and several ‘tapping sticks’ were employed in the removal of the swines!
Even with my heaviest ‘tapper’ the swing arm pivot bolt is very firmly and quite adamantly, ‘staying put’  which is a little tiresome.
I’m going to pop the lump out tonight to allow better access to the bleed nipple and try to get it out so I can fire some penatrant down its neck straight onto the inner tube and see if that frees it with some more heat and ignorance………..keep yer posted!
What a manky, greasy, uncared for motor, nothing has yielded without a fight and that’s with absolutely drenching it in plus gas for a month, every day.
The comparison of before’s and after’s are going to promote a smug grin come the time.I reckon, really looking forward to getting on now. Bar a couple of bits I’ve all I need for the rebuild so it’s strip, blast, paint and build
So far, out of everything that’s been attempted, no bolts ‘necked’ off as yet with just the swinger to get out and the top n bottom yolks to whip off. (Not ‘triple trees’! Wtf?
The swinger bolt has about 90 degrees of travel currently after being persuaded with a large lump of timber but the bolt moves with the arm so I guess the tube inside is solid to it as there is no lateral movement at all.
As a worst case scenario if replacing the swing arm bushes and caps, which I am, is it possible to run a metal blade in between the frame and face edge of the bearing cap that sits in between the arm and the frame? The frames junk so not precious about saving it. I figured if not I’ll just cut it off and see if I can get it pressed out………..it’s proper in there. If it’s anything like the front lower mounts as shown, I wonder if they’ll shift at all. This one over an hour to get out!(https://uploads.tapatalk-cdn.com/20220307/3123497696cc2bdf1a38f1df74d69a8d.jpg)
Post by: Laverdaroo on March 07, 2022, 07:24:23 PM
(https://uploads.tapatalk-cdn.com/20220307/276f97d76c14556b8c3867977c089f41.jpg)
Post by: Laverdaroo on March 07, 2022, 07:26:41 PM
(https://uploads.tapatalk-cdn.com/20220307/eb7aefaf74c5788731f3f27cb80b69a3.jpg)
Post by: Laverdaroo on March 07, 2022, 07:29:39 PM
(https://uploads.tapatalk-cdn.com/20220307/f20693a8ca40d86d653d3525eda099bd.jpg)
Post by: K2-K6 on March 07, 2022, 07:58:05 PM
If you've some bits-n-pieces to do it, with the engine out then lay the frame down so that the free end of the pivot bolt is on the saddle of a trolley jack (stay with me, but it's simpler than it sounds) you may need something here, an old socket perhaps, to get the Jack to push the pivot only and not touch the frame.
Now use a chain round the bike frame and the trolley jack frame (underneath where the front wheels are) and secure that (an old drive chain could be used) now when you jack it the frame is captive but the bolt is pushed through like it's in a hydraulic press.
This may get it moving as you can apply quite a tonnage to it.
Post by: Oddjob on March 07, 2022, 08:40:14 PM
Get the lump out first Roo, wonder why the PO has fitted the rear brake arm upside down? Oh just spotted, rear sets?
Don't forget to remove the tacho drive from the cam cover before removing the engine, they snap off very easily. Remove as much as possible, eg clutch, genny, everything that bolts on including head and barrels unless of course your leaving it in one lump, which I doubt.
If all else fails with the swinging arm you can cut the frame out around the pivot pin so at least it's away from the frame.
Post by: Laverdaroo on March 07, 2022, 09:37:46 PM
That’s a heavy bugger isn’t it‍
Lump out, forks and head set out, no bolts reusable who’d have thunk?
Even the fork tops have witness marks from a pair of grips or moley’s………I hate folk with a tool belt!
I finally got everything moving but needless to say, the centre stand has been cut out and after several more pages of the “My Ladybird Book of Anglo Saxon Phrases & Greetings”, I’ve come in for a brew and a warm!
I got the nipple off the swinger and it’s in fantastic condition and doesn’t appear to have ever been used………..Ever!
I’ve had the frame glowing red and you can see the tube inside turn with the bolt through the grease nipple hole.            (Nipple) so it’s gonna have to be pressed out, it’s not worth the time I think.
Anyway, I think the grinders coming out after me brew and I’ll cut the sod off the frame.
Talking of which, which parts of the frame are known for rotting out or whatever, like the stand plate’, lower tubes, mounting points etc?
The frames in really good nick because it’s had a complete covering of an eighth of an inch of greasy shite all over it for it’s entire life which has saved the frame and swinger beautifully. The only part that’s goosed is around the swing arm pivot point where the has gone to town fitting that crap on it.
I’m happy to cut all the useful bits off and stash em if anybody might want them for a build to replace bits n bobs. Otherwise sadly it’s off in the scrap bin at work. Kills me but I can’t stash it and unless you’ve all the gubbins for putting it right in terms of tools……….. it’s scrap(https://uploads.tapatalk-cdn.com/20220307/908928df029ffd009e98beb981528991.jpg)
Post by: Laverdaroo on March 07, 2022, 09:38:38 PM
(https://uploads.tapatalk-cdn.com/20220307/4a06b65e55d3a6815479cebe37f7abeb.jpg)
Post by: Laverdaroo on March 10, 2022, 12:36:49 AM
Bit more progress tonight with the clutch off and just waiting on a puller so I can get the other side off in readiness to remove all the gear mech and hopefully split the cases before the weekend. It’s not coming apart easily and being a bit of a bugger and only found one necked off bolt that appears very old in the head, I’ve managed to get all of them
Put up until now
Managed to get the spindle out of the centre stand and save it to be tidied up and reused. The bolt finally came out of the swing arm pivot via the gas bottles and the press at the garage in the next village. Big up Ubley Service Station
Things appear to be going well but expecting a catastraf*ck fairly shortly and of course, I’ll keep you posted(https://uploads.tapatalk-cdn.com/20220310/da7e34df537aab134a3c261f6b98c213.jpg)
Post by: Laverdaroo on March 10, 2022, 12:37:22 AM
(https://uploads.tapatalk-cdn.com/20220310/36bb3177027c70806aa9afe204e62080.jpg)
Post by: Laverdaroo on March 10, 2022, 12:37:56 AM
(https://uploads.tapatalk-cdn.com/20220310/42ad46f5c97bc9585c4db0b9256773d2.jpg)
Post by: Laverdaroo on March 10, 2022, 12:38:27 AM
(https://uploads.tapatalk-cdn.com/20220310/66bace0b1bd7da174140b3faec451a0c.jpg)
Post by: Oddjob on March 10, 2022, 01:40:14 AM
Puller? I presume you mean rotor puller, you do know the cases will come apart with the rotor still on the crank?
As for primary shaft, use the bottom engine hanger bolt with a footrest still on it, thread in and use the footrest like a slide hammer.
What's all the dust like substance?
Post by: Laverdaroo on March 10, 2022, 07:08:28 PM
Yeah, I know but its a full strip as I dont want to be taking this apart again and want it right, I'm in no rush an simply enjoying the fiddling tbh.
Yes a three leg job like the two I already have but cant find as they're filed away somewhere!
A common problem in my shed, it always is when youre stuck for room, everything gets filed away in boxes! >:( :( :(
Post by: Laverdaroo on March 10, 2022, 07:23:40 PM
Thats just crap off the bench Ken, it was on there for a while before I took the piccy, the motor is filthy., Cant wait  to get to the cleaning stage if I'm honest, the OCD meter is going mental ;D
Post by: Oddjob on March 10, 2022, 10:35:33 PM
I have an original Honda rotor puller Roo, it's shaped like a cross with different threads on each of the arms. Works a treat even when the crank is out of the case.
https://www.ebay.co.uk/itm/293326225468?hash=item444b9b003c:g:sVMAAOxyJs5RZT7f  Same part £58.50 at DS. Just shows you how some people rip others off.
You could have borrowed it if you were closer.
Post by: Laverdaroo on March 10, 2022, 10:58:31 PM
bloody hell! :o
Post by: Sesman on March 11, 2022, 06:57:15 AM
I left the rotor on the crank until the motor was completely stripped. It’s quite easy to tap the alternator rotor off using a well placed piece of wood and hammer. Undo the alternator rotor bolt now though.
The primary drive can be removed using the 16mm long engine mounting bolt, using it as an improvised slide hammer.
Post by: Bryanj on March 11, 2022, 07:47:31 AM
Bring it up Roo, just let me know so i find mine from its safe place!
Post by: Seabeowner on March 11, 2022, 06:55:27 PM
M16 x 1.5. Used a car wheel bolt that I bought for a few quid. Shape the end. Used it four/five times.
Post by: Laverdaroo on March 13, 2022, 07:32:26 PM
Thanks chaps,
Still waiting for the puller so carried on after you all saying that it’s easy removable whilst off so carried on as I had a free afternoon.
Well that was a bugger!
Everything that could get stuck, was and everything that was stuck was encased in thick shite, tar, and black goo. Presumably from the weeping motor, left for years.??
The whole lots apart and I now have the hideous job of degreasing the lot prior to getting it off to get vapour blasted in Yeovil.
There was some interesting goo in the pan, the consistency of extra thick peanut butter, a bugger to shift but it’s coming out with a great deal of hot water and elbow.
The motor is blathered and once split……there was a whiff of sealant between the cases and only in certain places. Where there wasn’t any the motor has pissed oil out and presumably moisture also, the oil thst came out was definitely on the browner side of awful!.
The primary chain is proper goosed, as is the cam chain, but strangely I forgot to have a look to see the extent of the chaffing of the cases to see how destructive it’s been whilst I was out in the shed.
It’s been standing for years as half of some of the internals have a mist of rust on where some bits have been out of the oil whilst laid up, like the selector drum
All should nanny up but I’ve not been here with one of these motors before to this level so brace yerselves(https://uploads.tapatalk-cdn.com/20220313/d8efda55c005d9ab52cebf0ab13678d2.jpg)
 for all the daft questions as they’re coming, just don’t know when yet
Just from observations whilst stripping it I’ve a few questions but I’ll make a list and bob em on here nearer the time of need. For now it’s degrease tastic for the foreseeable ‍
Post by: Laverdaroo on March 13, 2022, 07:32:55 PM
(https://uploads.tapatalk-cdn.com/20220313/dfb0dfa1274528726b9c1bf825796f60.jpg)
Post by: Laverdaroo on March 13, 2022, 07:33:57 PM
(https://uploads.tapatalk-cdn.com/20220313/4895c43d55e34b8f13f47ec5360e9b7d.jpg)
Post by: Laverdaroo on March 13, 2022, 07:35:30 PM
(https://uploads.tapatalk-cdn.com/20220313/6c0c7ac313d358595cd96e4775c8a84b.jpg)
Post by: Sesman on March 13, 2022, 07:39:03 PM
Yup, that primary is totally knackered.
Post by: Laverdaroo on March 13, 2022, 07:40:18 PM
 ;D ;D
Post by: Sesman on March 13, 2022, 07:41:25 PM
How’s the rest looking Roo?
Post by: Laverdaroo on March 13, 2022, 07:42:03 PM
The whole thing is a lot of a shitter but I WILL bring it back, it deserves it :)
Post by: Sesman on March 13, 2022, 07:43:32 PM
Post by: Laverdaroo on March 13, 2022, 07:51:43 PM
To be honest, better than expected. I didnt neck any bolts off so thats good!
Like I said a few bits witha bit of rust on but nothing that a good nanny wont sort out. I havent had alook at the bearings at all yet, nor the shells etc. I was just on for a strip down, bag up an tidy up.
Ill order some more bags later and then as I take something out of a bag to work on it gets put away fettled in a clean bag ready to re fit. Thats the plan any way but for now i need to get the cases gone as they take up a lot of bench space .
I have a few questions but until its in my hands its only half a question so I'll wait but for now the bikes stripped and bagged the barrels are off for a rebore and only show minimal marks from standing but Itll be done as a matter of course.
Post by: Oddjob on March 13, 2022, 08:04:12 PM
The first set of pics you sent me Roo show a snapped off bolt just above number 2 spark plug.
Post by: Laverdaroo on March 13, 2022, 08:24:57 PM
Thats historic and not one of mine!
I'VE not necked any ;) 8)
Stop being picky ;D ;D   Historic damage is a given, creating new damage through thuggery isnt! ;D
Post by: Oddjob on March 14, 2022, 07:12:50 AM
LMAO, we only have your word for that and Bryan told me what an unsavoury character you were. 😬😬😬😬
Post by: Laverdaroo on March 14, 2022, 07:14:14 AM
He’s absolutely right!
Post by: Bryanj on March 14, 2022, 08:01:45 AM
Well we are all northeners Ken!
Post by: Oddjob on March 14, 2022, 05:45:03 PM
Is Roo Northern?
If so I'll forgive him then
Post by: Sesman on March 14, 2022, 06:04:02 PM
He’s posh….from Harrogate I believe.
Post by: Laverdaroo on March 14, 2022, 06:47:09 PM
Yep, right posh me ;D ;D
head to the Yorkshire Show Ground and I lived and grew up on the first council estate you came to on the right.............Just up from the tip on the right hand side on the  Wetherby Road.
Dead posh, we had our own mud to play with and everything, it was ace! ;) ;D ;D
Post by: Oddjob on March 14, 2022, 06:47:20 PM
Oh a Yorkshire lad eh! I'll retract my forgiveness then, we still haven't forgotten the War of the Roses round here, we won in the end BTW  ;D ;D ;D
Post by: Laverdaroo on March 14, 2022, 06:48:16 PM
Nooooooooooo, noooooooooooo yer didnt, you were very much mistaken on that outing ;D
Post by: Sesman on March 14, 2022, 07:53:08 PM
Me too. We lived in a lake………
Post by: Laverdaroo on March 14, 2022, 07:54:17 PM
You were lucky!............
And so on ;D ;D ;D
Post by: Sesman on March 14, 2022, 07:56:44 PM
Post by: Laverdaroo on April 19, 2022, 11:26:56 AM
Morning all,
after a brief diversion to get some fishing done and a bit of a shed tidy, were back on it. Things have fallen a bit behind but I've been busy-ish doing bits and pieces whilst bits have been sent out to be worked on by various folk up and down the Mendips and Lincolnshire ( ;)) so parts are coming in to enable the build. I had a week off to research and order up everything OI need to replace and refresh the back end of the VFR with a new swing arm, bearings, seals, rebuilt shock from the states, new EBC front discs, all new EBC braided lines (all 13 0f them for the brakes) and clutch. New KTech fork internals, seals and fixings. Ill get to that before the MOT in May............................I hope!!" :o
I'm a bit stuck as the blaster I use has had covid TWICE in a month bless him. The pennance for having young kids at school I guess but thats been a bit of faff as I cant get any cases back until next week when he's had his isolation period ::) meanng the rebuikd is having to wait so the shed is a sea of plastic bags with parts in at the min. That and Ive Bristol Badgers motor being worked on in there too, so its a little busy in there. ;D ;D ;D
I've everything for the engine now bar a qasket kit, could anyone advise me on the most accurate for the job as there are heaps out there and I dont want to get stuffed by ill fitting items,I might have asked before but cant remember tbh.  Anyone save me looking back?
I've the pontefract cakes already but whats teh best for the job peeps, you lot know more than I on tjis one.
Huge thanks go to Oddjob for the constant advice and chat and the bits n bobs that have been sent over and to Julie and Trigg for the rebore and new pots.......ace!
I still cant get a picture up on here without resorting to rhe phone as the PC says file to big even though I compress it to death so they'll have tp be separates so bear with but I'll get a few up of the mayhem so far :D.
I madr some templates up and started drilling the discs for the front but waiting for some more drill bits as the RHS disc is made of indestructium and simply wont drill so I've got some Kriptonite bits coming today. I only have 9 holes to do but so far they've eaten 8 drill bits and the discis hardly marked........they were brand new too! Its interesting that one drill bit did nearly two discs and this particular section has eaten all these, I'll sort it.
I sent the frame to a pal of mine to have all the factory welds redone and tidied up as some of them are absolutely shocking. There was even bits of wire hanging off it from back when it was made.
Anyway, that's being soreted so in the mean time I'm on with the froint end and working on the forks and front wheel etc.
Got a sea of stripped and worked on parts but I'm kind of on schedule, just funds playing a  factor now as I lost my current contract last week so back on the job market which sucks a fat one but not fretting yet!
He  ::) ;D ;)says
Post by: Laverdaroo on April 19, 2022, 11:33:25 AM
(https://uploads.tapatalk-cdn.com/20220419/0240e65d8916de8de0cd8141193293e0.jpg)
Post by: Laverdaroo on April 19, 2022, 11:34:17 AM
(https://uploads.tapatalk-cdn.com/20220419/0536e61692b7ff2542cdacd4a8fa9232.jpg)
Post by: Laverdaroo on April 19, 2022, 11:35:02 AM
(https://uploads.tapatalk-cdn.com/20220419/bd1f8f34d971a93feadab9e57a33c14f.jpg)
Post by: Laverdaroo on April 19, 2022, 11:37:15 AM
(https://uploads.tapatalk-cdn.com/20220419/9ea135b77adc1afc39fbfa451840944c.jpg)
Post by: Laverdaroo on April 19, 2022, 11:37:54 AM
(https://uploads.tapatalk-cdn.com/20220419/096eee60209faecda93397e512f669c8.jpg)
Post by: Laverdaroo on April 19, 2022, 11:38:35 AM
(https://uploads.tapatalk-cdn.com/20220419/ae5cf2623133c776005b234bde9bce3a.jpg)
Post by: Laverdaroo on April 19, 2022, 11:45:04 AM
(https://uploads.tapatalk-cdn.com/20220419/225346c556d7f6d01d375c8d01a91c29.jpg)
Post by: Johnny4428 on April 19, 2022, 12:10:19 PM
That looks like a “boring” job! 🤣 (somebody had to say it) nice work!
Post by: Laverdaroo on April 19, 2022, 12:12:26 PM
Love making the patterns, drilling the discs is a PROPER dull job. Be glad when Ive done tbh ;D
Post by: Oddjob on April 19, 2022, 02:23:23 PM
If you can afford it and can find them buy genuine Honda gasket sets for top and bottom. Can't go wrong, they fit perfectly everytime and you get almost everything you need except the pontefract cakes.
Post by: Johnny4428 on April 19, 2022, 05:37:23 PM
(Pontefract cakes) 🤣🤣
Post by: Oddjob on April 19, 2022, 05:54:38 PM
I've always called them that, not sure anyone else did but started to refer to them like that when I first joined and it seems to have caught on.
Post by: Bryanj on April 19, 2022, 07:55:57 PM
Called them that for years, exactly what they look like but a bit small and chewier
Post by: Laverdaroo on April 19, 2022, 09:15:23 PM
Sesman mentioned it on here a while ago and made a mental note to use where applicable. It tickled me at the time ;D its' so apt. You're such a hip, 'trend setter' ken ;) ;D
Post by: Laverdaroo on April 19, 2022, 09:16:54 PM
And failing that? Vesrah? Ive used a few of them before on two stroke gubbins and seem to be reasonable. Would such a thing be a suitable alternative?
Post by: Johnny4428 on April 19, 2022, 09:53:03 PM
I am amazed to find that you can still get them.( Pontefract cakes that is )😜😜
Post by: Sesman on April 19, 2022, 10:01:44 PM
I’ve had real problems finding Vesrah full kits. I recommend buying the top end set and separate alternator and clutch gaskets. Nurse Julie stocks the liquorice.
Post by: Laverdaroo on April 20, 2022, 12:36:15 AM
got the liquorice and everything except any gaskgets.
I can waddle off and have a read up now I know what the score is. You hear some horror stories and I cant be arsed faffing about with shite gaskets so skip the hassle and ask on here, at least I know the advice will be right and I wont waste my dosh.
Thanks chaps :)
Post by: Bryanj on April 20, 2022, 01:34:09 AM
Only difference 500 to 550 is the clutch cover gasket and that can be got seperate
Post by: AshimotoK0 on April 20, 2022, 02:39:33 AM
When Ken visited me in-between lockdowns he didn't look much like this  ;D ;D
[attachimg=1]
Post by: Laverdaroo on April 20, 2022, 10:10:12 AM
Give over Ash, thats a dead ringer for him ;D
Post by: Oddjob on April 20, 2022, 03:16:24 PM
Not even close.
No tattoos.
No beard
No hair
No glasses
I had socks on.
I do have a dog but it's a pedigree.
I also have a collection of vinyl records but they are in a box in the loft.
Other than that, yep you got me spot on.
Post by: SteveD CB500K0 on April 20, 2022, 03:19:15 PM
Photo of the dog please.
We should have a dog thread (?)
Post by: Laverdaroo on April 20, 2022, 03:20:36 PM
Not even close.
No tattoos.
No beard
No hair
No glasses
I had socks on.
Thought so
Post by: Laverdaroo on April 20, 2022, 03:21:13 PM
We should have a dog thread, top idea
Post by: Oddjob on April 20, 2022, 03:37:20 PM
Here's our little Tilly.
She's on the left along with Ruby on the right. 4 years apart and came from different breeders from different parts of the country. They look like Mother and Daughter.
Sadly Ruby passed away last year, leaving Tilly completely heart broken, still hasn't got over it, just mopes about the house now looking lost.
(https://i.postimg.cc/gjKybwXD/IMG-2586.jpg) (https://postimg.cc/JHGHbzQD)
Post by: Seabeowner on April 20, 2022, 07:36:07 PM
Every 500 gasket set I've bought included the pontefract cakes/pucks, every 550 didn't.
Post by: Johnny4428 on April 20, 2022, 08:30:34 PM
What on earth? Is that from same manufacturers? For instance would a Vesrah gasket set for the 500 have them.
Post by: Oddjob on April 20, 2022, 09:37:00 PM
A genuine Honda set doesn't come with them. I never buy any other type.
Post by: Seabeowner on April 21, 2022, 07:10:00 PM
Only have a 500 and 550 NE brand at present. But have had other brands years ago, but not sure on Vesrah.
Post by: Laverdaroo on April 21, 2022, 08:28:03 PM
I might be looking in the wrong bit but there isnt a part number for the Honda 550 kit in the book or am I being blinky and cant see it?
Post by: Bryanj on April 21, 2022, 08:54:49 PM
Honda top set starts 06110, bottom set 06111. 500 is then 323 550 is 374 last 3 numbers more or less dont matter
Post by: Laverdaroo on April 21, 2022, 10:13:56 PM
so 550 top set would be 06110374S01
bottom set would be 06111374T00               jst had a quick look up at DSS
thanks Bryan, youre a ledge mate. I havent forgotten about your parts book its permanently on the kitchen table being studied on a daily basis. Am I ok to hang onto it a bit longer ......soz to be cheeky! :)
Post by: Bryanj on April 22, 2022, 03:19:34 PM
Youre fine, i know where it is!
Post by: Laverdaroo on April 23, 2022, 11:16:06 AM
Thanks mate, you're a gent. ;) :)
On a different matter........... I posted up in the desperately seeking page but I'll bob a copy up on here too,    more exposure etc ;)
Hi all,
******Has anybody got one of these lurking anywhere that they want rid of? My tank didnt come with one on so hard to lift once the catch it disengaged. I've a new lock for it fitted but just need the spring...............Anybody?
Part number 177353-90000 fuel filler spring (CB550, 750 et al)
Post by: Laverdaroo on April 27, 2022, 01:27:44 AM
So, interesting. I’ve spent the last couple of nights stripping the wheels down to get them sorted but have got a bit stumped. All going well, wheels stripped, hubs in dishwasher to get the crap off etc.
But when trying to part number up the Cush drive I hit a snag. My rear hub, as shown, has 4 Cush inserts that the wheel studs push into, just like the 400. When I look in the parts book all I can find are the part numbers snd diagrams for the hub with the removable Cush blocks, like what you get on more modern bikes still.
Did the 550 have this hub arrangement or not snd if not what the bloody hell have I ended up with? The rims are Akront ally ones and are in fair nick but this hub has me a bit stumped. Any ideas for Cush drive part numbers anyone?(https://uploads.tapatalk-cdn.com/20220427/7882481f659be4c83fa5ffbab47479cf.jpg)
Post by: Laverdaroo on April 27, 2022, 01:28:44 AM
(https://uploads.tapatalk-cdn.com/20220427/f5c425cd4bd2b17e877ba82d470b2060.jpg)
Post by: Oddjob on April 27, 2022, 04:53:46 AM
That's not a 550 hub Roo. no idea what it is. It looks like a Honda, the brake plate looks like a 550 one though. Probably replaced by PO when the brake liner broke up, as they do.
Post by: Bryanj on April 27, 2022, 05:11:48 AM
I agree nott a 500 or 550, could it be a 450, ask Ash
Post by: deltarider on April 27, 2022, 09:59:07 AM
I've seen them on the CB350F and CB400F.
Post by: Laverdaroo on April 27, 2022, 11:08:23 AM
I havent chucked a tape at it yet but I thought 400 wben I first noticed it, Ash, any idea?
I'll measure it this arvo when I get home and into the burrow.
Bit odd s its been laced to the 550 rim. Soes anybody have one of teh cush inserts that they can measure for me? When I took them out they were flush with the top of the rim as they shpould be but had a 7mm gap underneath and didnt go all the way down to the bottom of the recess like tehy do on the 400. Also when you turn the hub over there are holes in the back so you can tap out the bushes, (not that I didnt have to muler them into submission and drill them out).
So some similarities to the 400 but not quite and still need to get these cush's sorted! The spokes are passable so I'll probably reuse them which is a bit easier as at least somebody else has had the faff of sizing them but As mentioned, a bit stumped tbh!
Post by: Laverdaroo on April 27, 2022, 11:09:04 AM
(https://uploads.tapatalk-cdn.com/20220427/b58cc5c28ad585085e5fabad6ac432b6.jpg)
Post by: Oddjob on April 27, 2022, 02:47:33 PM
Looks Honda but stamping isn't Honda. No 617 model, they stopped using middle number just before 500.
Either way it's not the right one.
Post by: Laverdaroo on April 27, 2022, 03:45:38 PM
NI I kno but holing to matcch something up with it hence the request for the dims of the rear cush inserts.
Post by: Laverdaroo on May 01, 2022, 12:00:43 PM
Can anybody just clarify something for me?
I've taken the bearings out of my 'mystery hub' and see that the two sizes are 6305LU and 6304LU (single rubber shield) As it seems that the majority of manufacturers /suppliers only carry the 2RS (twin rubber shield) variants and it' order only for the LU, would it be detrimental to fit a 2RS item?
I appreciate that the spindle is lubricated but does part of that lubrication spread to the back of the bearing when in use hence the open rear side of the bearing? Kind of answering my own question but thought to ask before purchasing through a bearing supplier rather than DSS?
Post by: Bryanj on May 01, 2022, 07:40:26 PM
Fine to use 2rs, if you insist on only one but the 2 and remove one side(not)
Post by: Laverdaroo on May 01, 2022, 10:44:10 PM
Nice one, thanks Bryan :)
Post by: Laverdaroo on May 05, 2022, 03:35:31 PM
Ken, these are the shots I’ve been trying to send, FYI……..(https://uploads.tapatalk-cdn.com/20220505/d66153e0afb7e42712a7ae8d77c6bd1c.jpg)
Post by: Laverdaroo on May 05, 2022, 03:36:03 PM
(https://uploads.tapatalk-cdn.com/20220505/e7f890f763660da717eb2c241ba1f0d0.jpg)
Post by: Laverdaroo on May 05, 2022, 03:36:32 PM
(https://uploads.tapatalk-cdn.com/20220505/ea15b5867b4c3e892bd0ff6901f6182e.jpg)
Post by: Laverdaroo on May 05, 2022, 03:37:31 PM
(https://uploads.tapatalk-cdn.com/20220505/7e8758514b88cf6785bdf5eab58ecacd.jpg)
Post by: Oddjob on May 05, 2022, 04:39:29 PM
First off, have you checked all the threads? no point in restoring them if one is stripped and whilst you could helicoil it as it's the brake anchor points you need to ensure it's a really good job if you needed to do it.
Secondly, need some measurements. Overall length, top edge down to the bottom where the studs fit. Also distance between top edge and upper bolt hole for mudguard.
Thirdly, I can see some sort of marking near the anchor point but the pics won't enlarge so I can't make them out. Can you read them?
Post by: Laverdaroo on May 05, 2022, 05:06:03 PM
Got a quick meeting then I’ll have a look and forward them over on here bud
Post by: Laverdaroo on May 05, 2022, 05:59:43 PM
Right here we go, all the marks I can find plus dims etc…. You can see where some oaf has had them burning in the wire wheel at some point.
Expensive build isn’t the phrase for it Ken(https://uploads.tapatalk-cdn.com/20220505/72304856894bdd69dd0d6711d70549b3.jpg)
Post by: Laverdaroo on May 05, 2022, 06:00:30 PM
(https://uploads.tapatalk-cdn.com/20220505/3390f1df71e12de1f7823a302cb28dc1.jpg)
Post by: Laverdaroo on May 05, 2022, 06:02:29 PM
(https://uploads.tapatalk-cdn.com/20220505/593f4617765dbf6e569b229ddc3988a1.jpg)
Post by: Laverdaroo on May 05, 2022, 06:03:02 PM
(https://uploads.tapatalk-cdn.com/20220505/9aec243128a7ec5df048a8b1ef2b127b.jpg)
Post by: Laverdaroo on May 05, 2022, 06:04:48 PM
(https://uploads.tapatalk-cdn.com/20220505/578201fca45cadd9be13a7ed8562923c.jpg)
Post by: Laverdaroo on May 05, 2022, 06:07:06 PM
Just spotted, the left lower, shagged.
Cheque book out again it seems, bloody hell!(https://uploads.tapatalk-cdn.com/20220505/7a7f6970ca340c3f6c43d771f9b56833.jpg)
Post by: Oddjob on May 05, 2022, 06:11:49 PM
Sorry Roo but just checked the fork stanchions I was going to get hard chromed. For some unknown reason someone seems to have taken an hacksaw to them or maybe a thin grinding blade like off a Dremel. It's about 1" above the point where the bottom yoke would clamp and I'm thinking the breakers the forks came off cut the fork ears off for some reason and weren't too bothered about the stanchions being damaged in the process. Both stanchions show the exact same mark in the exact same place, so just above the small skirt that the fork ears have on the base. One is slightly deeper and longer than the other cut, the cuts themselves aren't that deep and the metal is quite thick and it's possible that the hard chromers, who grind off the surface and then replate back to over thickness and then grind off again to normal thickness, could get rid of the marks but I'm loath to take a chance on what is an essential part of the bike safety. I doubt they'd snap but can we really take that chance?
Just checked my sliders, all 3 sets and they all measure 3550mm top to bottom and 1150 from top to the top of the thread hole, so looks like they are correct. Some good news at least.
Post by: Laverdaroo on May 05, 2022, 11:58:14 PM
OO,bugger thats a bit of a swine but I'm like you Ken, not the forks, not worth it. The crap  mystery ones that I have have exactly the same marks on and I came to the same conclusion as you have regarding cutting bits off and missing with the disc cutter!
Thanks for having a look for me though, good man yer.
I rechecked all the threads and they're all a go, just a sod about that lower as I'm not sure if it can be repaired. Under closer inspection, its been like that for a lot of years and the corrosion is right into the metal so I'm wondering if it'll just pop and fart if they try to tig some material to it to try an reshape. I'll have to see what I can find out but a bit disheartened this evening. Especially after gettimg a close look at the fork bottoms :-\ Serves me right forbuying a shitter ;D ;D
I went for a restorative mooch about on the VFR today and to stretch me legs and thought, " I wonder when the MOT is due, I'll have a look when I get home ".  18th of May...........eek!  :o :o :o :o :o
I've got his lot to sort out before then so all next week I'll be head down sorting her every night!          I've been hoarding it all for ages so it's time to get it on as the rear brake has gone really spongy after several fettles and Im pretty sure I have a leak somewhere although theres no loss of fluid. The lines are 20 years old and I suspect the age might have caused a small crack somewhere.
They're notoriously a bugger to bleed and fit but I'm not to phased, its just a process and I've done it a few times now to have the job sorted but reading up, I realise the changing of the lines is a right bugger, 8 hours in the manual...gulp!
Ive a set of stailess goodridge going on to start and a different swing arm that has a slightly better set up than my 2002 unit. Just means maintenance is easier as they have a habit of siezing up and are a pig to shift so Ill bob that on with a freshly rebuilt shock from the states.
Nobody would rebuild them over here and say it cant be done. This chap rebuilds, recharge, sorts all the remote out and rebuilds it and then fitts a spring to suit your weight......spot on. I just bought a shock of a wreck over there, shipped to him from a breakers for free, he fettled it and sent it to me...........Superb result.
Bit to be doing mind ;D ;D ;D!
Post by: Laverdaroo on May 05, 2022, 11:58:28 PM
(https://uploads.tapatalk-cdn.com/20220505/f6e6308eae64dd17b306befaf49c39e2.jpg)
Post by: Oddjob on May 06, 2022, 04:34:27 AM
I might have a pair of sliders you can have Roo. They weren't up to my extremely high standard so I bought some more. No charge, it's about time you got a break. Pay for postage and I'll finish them off and post them down to you. Might be a week or 2 though as I'm doing some plastering and brickwork, it will be one day working and one day in bed recovering, such is my health at the moment. I'm not about to pop me clogs or anything, it's just the pain that working causes me these days. Thank god for Tramadol  ;D ;D
If you look on page 4 of my project thread you can see the right hand one, the left hand didn't turn out as good, almost but there were some small marks that refused to come out and I ended up with a dip in the alloy trying to get it out. Decided in the end to just replace them. Hope you like polished as they are kinda bright, the left hand one wants finishing off which I didn't do as I lost interest in it.
Post by: Oddjob on May 06, 2022, 02:22:06 PM
Check the fork stanchion thread Roo, some for sale on there.
Post by: Laverdaroo on May 06, 2022, 03:11:30 PM
Will do bud, cheers
Post by: Sesman on May 06, 2022, 04:02:17 PM
Roo, has your parcel arrived?
Post by: Laverdaroo on May 08, 2022, 02:22:19 PM
NO Philbut they did try to drop something off yesterday, Ive just got back from fishing So I'm just wading through the post and sorting stuff but doesnt appear so.
I'll wait to see what theyre going to do, my Posty is ace so Im sure it'll get herer. Exciting.........books! Love a book!!! :)
Ken, yup I'll have tghe bottoms but Impaying you for them! Pop em on the pile mate ;) There's an MASSIVE favour coming your way bud, cant thank you enough mate. Thats a huge cock up sorted with those forks from Si (3scs).
That starter cover came saturday, well chuffed for a fiver form a breakers. Thats two breaks in a row with your forks mate!
Bloody hell 8) ;D
As ever, youre a start ken, cheers
Post by: Laverdaroo on May 08, 2022, 02:23:00 PM
(https://uploads.tapatalk-cdn.com/20220508/456b088916c53faf5b40dd9a8c6519c4.jpg)
Post by: Oddjob on May 08, 2022, 08:35:21 PM
Bargain for a fiver Roo.
Post by: Laverdaroo on May 08, 2022, 10:00:47 PM
well chuffed,some good news for a change  ;D ;D ;D ;D
Post by: Laverdaroo on May 09, 2022, 10:49:36 AM
Quick one cos I just don’t know snd struggling with reading 50,000 threads on the subject.
What colour plastigauge do I need to buy to check these shells, never used it before as I’m a crank shell measuring virgin?
Mum will be chuffed after all these years
Never had to do it before, green or red?
Don’t laugh!
Post by: Bryanj on May 09, 2022, 11:20:49 AM
According to their website red and if you are on minimum clearance that is a bit big as clearance is 0.0007 to 0.0019  whilst the plastigauge is 0.001 to 0.002
Post by: Laverdaroo on May 09, 2022, 11:33:06 AM
Thats what was getting my knickers in a twist a bit. I'll get some red and just cut the bits in half then? ;D ;D ;D ;D ;D ;D
Cheers Bryan, I may need a bit of question answering on this but I'll get all the bits I need and clear a space, have a thunk n a  swear and probably be back on here. I get my cases back in a week or so and just prepping as yer do.
What has anybody else used, just the red (thinnest ones)?
Post by: McCabe-Thiele (Ted) on May 09, 2022, 12:10:25 PM
Don’t laugh!
Beware of cheap Green as it might be the wrong size range.
Hope  it helps but this is a reprint from Ash when I was doing my crank on the 400.
.Hi Ted ... yes the GREEN is still red but for small clearsnce bearings (typically 1 to 2 thou")
You put crankshaft in upside down top half ... place strip across journal (see below about using oil ..I use smear of silicone grease)  then carefully place crankcase lower on top case and clamp with main bolts to correct torque... hope this helps ... Best wishes Ash.
28 | © MAHLE 2018
Bolt Boots, Bearing Guard and
Plastigage
Clevite® Plastigage
Plastigage was designed as a final check of
total vertical oil clearance during reassembly. It
was not meant as a replacement for properly
measuring crankshaft journals, housing
bores or bearing dimensions before engine
reassembly with accurate mics and gauges.
To properly use Plastigage during reassembly,
readings should be taken on the bearing cap
half shell while the weight of the crankshaft or
piston and rod assembly is supported by the
other half shell.
Place a small amount of oil on the crankshaft
journal only where the Plastigage will be placed
and wipe any excess oil off with a clean rag.
This will result in a more accurate reading by
preventing the PLASTIGAGE from sticking to
the journal.
Place a strand of Plastigage across the length
of the journal parallel to the crankshaft.
Set the cap in place and tighten bolts to the
proper OEM torque specification. NOTE: if the
crankshaft is moved at this point it will smear
the Plastigage, resulting in inaccurate readings.
Carefully remove the cap and measure the
crushed Plastigage using the graduations
printed on the package. Measure the crush
along the entire length of the Plastigage, noting
the highs and lows for proper clearance.
After you have made your measurements,
carefully remove the crushed Plastigage from
the components without scratching the bearing
or the journal.
Clevite® Plastigage is available in four different
sizes to check total vertical oil clearance on
connecting rod and main bearings. Each
package has a measuring scale printed in
inches and millimeters. Strips are color coded
for easy size identification and are soluble in oil.
MPG1 .001”—.003” (.025 —.075mm) Green*
MPR1 .002”—.006” (.050 —.15mm) Red*
MPB1 .004”—.009” (.10 —.23mm) Blue*
MPY1 .009”—.020” (.23 —.50mm) Yellow*
(*Sold in quantities of 12 strips only)
Bolt boots, bearing guard and plastigage
Post by: Bryanj on May 09, 2022, 02:12:35 PM
Looking on the plastigauge uk website the green is now the biggest and red the smallest plus there are now 5 colours, nothing seems to be for less than 0.001" but theoretically it would just be wider than the biggest mark on the card
Post by: Oddjob on May 09, 2022, 04:14:55 PM
Roo, both of the rotors I removed are too rusty to use. I've had one in rust remover for 4 days now and it's still not great. I think it's best if you carried on using your current one, I'll scrap both of these.
If I go down the the hard chromers I'll take those fork tubes with me and see what they think, it's possible they could weld the cut shut, grind it down, hard chrome it and it would be good to use. I'd say the cuts are around 1-2mm deep is all.
Post by: Laverdaroo on May 09, 2022, 05:21:01 PM
RE the rotors Ken, no worries. Like you say, mineshould work it just looks really odd. I'll call it a historic war wound :D
The forks from Simon that you put in contact with me sound pretty good and have just been fettled by Philpots so I think it might be good to get those and your super bling sliders if they're really upfor grabs?
Post by: Oddjob on May 09, 2022, 09:03:48 PM
I'm in the middle of some severe DIY ATM Roo, so all bike work has stopped. Not sure how long it will be before I get back to the bike if I'm honest. Still haven't picked up my stuff from the chromers yet, keep forgetting.
Post by: Laverdaroo on May 10, 2022, 12:15:08 AM
Dont worry Ken,I'mnot rushing anythijg and today shinesa new perspective on things so to speak! Well, in sheer desperation I thinkIve accepted a contact for 6 weeks relief managing a koi and bloody goldfish farm,........not bad :)
It's in South Carolina...... ......USA!!!!:o
Think I might just have lost the plot!
Post by: Bryanj on May 10, 2022, 12:27:45 AM
Think of all those American cheap parts!
Post by: Laverdaroo on May 10, 2022, 12:54:58 AM
Thats jjust what i said to The Long Haired General ;D ;D ;D
Post by: Sesman on May 10, 2022, 07:55:11 AM
Hey, Roo.
Best of luck with that job, another great adventure. I once visited a ‘sports shop’ in South Carolina; It sold both fishing and hunting gear; the shop was as big as Morrisons. There were a few persons looking at rods and lures, but they were 20 wide and 5 deep at the gun counter…keep your head down.
Post by: Johnny4428 on May 10, 2022, 08:14:28 AM
Wow Roo! That’s a great gig!
Post by: Laverdaroo on May 10, 2022, 10:58:06 AM
It is but I've the 'General to consider and all thats going on here at the moment,l eaving her to sort the hpuse sale out and the new lease oon a lake we're  trying to finalise but I think I'll probably do it. It wont be a 'fest' of any measure as the site is in the middle of 'Hicksville' and I think the town population is  eoughly around 2000 people so there's probably Duelling Banjo's as the localdialing tone on the telephone or similar!! :o
If anybody says 'Squeal like a pig' or 'Sure gotta puurty mouth', I'm out of there!
Saying that Ive aready looked and theres a massive bike breakers 40 miles from the farm so I dont think I'll be that bored!
How many T140's and Tridents do you think I can  I get in my hand luggage?? ;D
Post by: Johnny4428 on May 10, 2022, 12:26:37 PM
Suitcase outbound? Container inbound? Sounds just right!
Post by: Laverdaroo on May 10, 2022, 12:42:23 PM
My thinking exactly Johnny, get yer orders in now folks ;D
Post by: Oddjob on May 10, 2022, 12:51:11 PM
If you lease a lake Roo be sure to stock it with HUGE carp and I'll pop down and try my hand. Not been fishing now for years due to work but my BIL owns a fishing shop in Stockport and even has a extremely large pond in his back yard, it's that big it has a boat on it. He was in the Sunday papers many years ago with aerial shots of his private fishing pond, as they called it. When the M60 motorway extended through Stockport they were filling in fishing ponds I'd fished as a kid, they netted them first, then drained them until they were only a couple of feet deep but still left thousands of fish in them. We went along with carp nets and waders and just scooped up loads and loads of Perch, Tench, Bream, Carp, Roach, Rudd and Gudgeon. There were small Crucian Carp that looked like gold coins in the net, it looked like we'd struck gold, my son caught one in his pond many years later and I've never seen a bigger Crucian even in the Angling Times, the pond is riddled with blood worm so everything grows huge. House was bought for £34k and was last valued at 500K, he's a very lucky guy.
Post by: Laverdaroo on May 10, 2022, 01:32:09 PM
I've been a fishery manager/lecturer for years and used to run/general manage all of the waters that CEMEX/RMC had for about 10 years whilst teachimg at Sparsholt College.
Im looking to develop this site into a small 4acres carp fishery that you can rent for a day or week and have the whole site to yourself or for a maximum of 5 anglers. There is a massive hole in the available fishing sites down here in the south west so if I can get a  couple of these under my belt this year and a few next year, I might have theopportunity to get meself sorted before I shuffle off this mortal coil ;D
A particular site down here has a 5 are site and through day tickets and pellet sales he turned over £127k last year....Im having some of that!
Big carp are what I grow Ken, My best pal has a bait factory too so finally after hoarding  and buying too much kit over the years, not only do I now have the tackle I actually want and need and but now, also cheap a bloody good, bait selection with which to use it.....perfect!
Soon as its up and at em, you have a  gratis ticket of course mate, come for a jolly. ;)
I've  floating long reach diggers to get in to tear it about and the site to develop but really looking forward to getting stuck in if my proposal is accepted by the landlord.
Exciting times but frustrating about leaving the shed......I think I'm already getting shed anxiety!..............Sad git ;D ;D
Post by: Laverdaroo on May 10, 2022, 01:34:14 PM
One from Sunday morning Ken at 23lb11oz but that’s it as this is a roughly toughty bike forum and not for worm drowner’s(https://uploads.tapatalk-cdn.com/20220510/367f56fb278924ed7aca5fcea68f8ff0.jpg)
Post by: Oddjob on May 10, 2022, 02:35:21 PM
I'm not sure who's the ugliest there  ;D ;D ;D
One of my favourite spots to fish over the years has been Trawsfynydd, it's near Bala in North Wales. Does a day ticket and you can either fly fish the entire reservoir or coarse fish certain parts. I used to swing tip the coarse parts with red/white maggots and have had huge bags. Your allowed 6 trout on a day ticket, it's where the Welsh Trout championship is held or used to be, dunno now. Lots of rainbow and brown, biggest I caught was a 6lb rainbow, couldn't even get it under the grill it was so large. They bite so hard they pull the rod off the rest everytime, great days fishing but wear midge repellant.
If you've never tried it I'd recommend it, day ticket from Post Office in the small village. Was around £6 last time I went but that's many years ago now.
Post by: McCabe-Thiele (Ted) on May 10, 2022, 04:00:00 PM
I went Carp Fishing yesterday after 90 minutes I was so cold I had to pack up - my first day this year at a local club water. Blanked😢
Post by: Oddjob on May 11, 2022, 01:22:14 AM
Just had a thought Roo.
I now have a CB650 primary chain tensioner and brand new primary chain tensioner bracket spare.
If your interested you could fit them into the engine whilst it's apart, the bracket is custom made and cost me £50 and the tensioner another £50. You could have them both for £1000  ;D ;D
Just kidding, £100 plus P&P which shouldn't be a lot as they aren't that heavy.
The tensioner is hard to find and the bracket needs a decent engineer to make, I got 2 made for £100 as he couldn't be bothered to make just one so I needed to sweeten the pot so to speak.
Should extend the life of the chain, make it quieter for longer and stop the crankcase damage that a worn primary chain causes. I'll be doing this mod in my engine.
I was going to bung them on Ebay with a new Primary chain, new dampers and the tensioner and bracket for £250 but yours if your interested.
Pics here.
http://www.sohc.co.uk/index.php/topic,27555.msg263157.html#msg263157
Post by: Laverdaroo on May 11, 2022, 11:42:13 AM
pop it on the pile Ken please ::)
Post by: Oddjob on May 11, 2022, 02:58:55 PM
Didn't come with that small hook bracket Roo but TBH it's not needed for the conversion anyway.
You have a read on how it's done? within your skill set?
Post by: Laverdaroo on May 11, 2022, 03:08:06 PM
I'll have a proper read later as I have had a quick skim but in the middle of changing all the brakes and lines on the VFR......... What a vile job! They really couldnt have squeezed any more bike under those plastics, there is so little fiddle room it means the untwisting of lines to get them in the right spot and bent the right way is an utter pig!
#Be glad when Ive done this.
Wheel bearings in, discs done, pads in so all thr fronts done, just the proportioning valve to do, ABS pump to hoo up and the rear linked gubbins.
What a pig!
What's worse is that the bench is currently covered in CB750 motor and bags of CB550 bits meaning yet again, I'm grovelling about on the bloody floor!
I think I'm going to need a new hip ;D
Post by: Laverdaroo on August 06, 2022, 05:15:55 PM
Ok,
so after gathering the gubbins required for looking at getting the shells identified and replaced, I've hit my first hurdle which it appears, all seem to have when undertaking this job.
Basically, there are no markings on my crank except the ones shown in the frst web which read 74.4.22. There is nothing else on there at all even after washing with two separarte batches of petrol, (just in case Id used the premix can)!
In this instance how do you measure up or identify the correct shells to order?
I have identified the cases as having the marks BBBBB
The crank measures from Number 1 to 4 with the last bearing being numbered 5...
1= 33.01mm
2= 32.99mm
3= 33.00mm
4= 33.01mm
5= 33.02mm
I have a number 2 printed on all the rods but again, nothing else has survived the last 40 odd years of no maintenance and I'm struggling a bit.
The crank measurements are pretty  consistant so looking at the chart would that mean that this is an all BROWN case?
I've got this right round my ears as I never measure anything this small, not that much call for micrometres in fishery management and not that familiar with the scales and the mental picture with which to work this outm its just not going in!
 When ever I've used my lathe it's always been to the nearest mm not to be measuring thou's and these micro scales so I'm a bit lost tbh.
Any help gratefully received as this is very much wearing a bit thin now.
Post by: Oddjob on August 06, 2022, 05:21:39 PM
If the cases are all B's then you've really only ever had either greens or browns fitted. If the crank had a 1 it was a green, if it was a 2 it was a brown.
I'd just fit all browns, they are the slightly bigger shell and so long as you run it in correctly you'll be fine.
Same applies to the rods, only greens or browns for a No2 rod. Fit all browns again.
Post by: Laverdaroo on August 06, 2022, 05:22:50 PM
(https://uploads.tapatalk-cdn.com/20220806/ab3024dce0de5493006f4cfd59a03e10.jpg)
Post by: Laverdaroo on August 06, 2022, 05:23:23 PM
(https://uploads.tapatalk-cdn.com/20220806/387d46bfa232897469dda0215aa08391.jpg)
Post by: Laverdaroo on August 06, 2022, 05:37:06 PM
Nice one Ken, I was starting to confuse myself and new I'd read that you could fit all the same just run it in very carefully. That is a given after this much shed time so happy with that Browns all round it is.
So.....................ANYONE GOT A FULL SET OR SPARE BROWN SHELLS UP FOR GRABS??
Looking in the book it appears I need  10 x #13316 323 000 and 8 x #13216 323 003
Would this be right the? Surely they could have made a far more complicated system than this and written things on the parts in more invisible ink? ;D ;D
Post by: Bryanj on August 06, 2022, 08:09:15 PM
The markings are there but not easy to see on a used crank. Honda probably believed you would only need to replace shells when replacing the crank which would be more visible.
You can always come and visit for me to measure if you want mate but give me a bit of warning so i can find and calibrate the mic
Post by: Oddjob on August 06, 2022, 09:02:09 PM
DS has them both in stock Roo.
The ones you can fit all the same are black shells as they are the thickest shell so will wear to the right size so long as you run the engine in carefully.
Post by: Laverdaroo on August 07, 2022, 01:03:10 AM
Yeah, seen the, and have themin my basket already,justseing if anyonehad somefunds to recoupfrom buying the wrong unsfirst time round.
Just short of a fiver less than 300 quid for 18..........eek!
While I'm on, is it sensible to wire brush these and give em agood fettle with some sort of solvent to get this crap off them, they're looking pretty shoddy and I dont fancy putting em back in my nice clean, prepped cases looking like that? Themak is quite engrained so being the king of bling and all things shiney, what do you reckon?
Post by: Laverdaroo on August 07, 2022, 01:03:34 AM
(https://uploads.tapatalk-cdn.com/20220807/7c58437960d7932328bef1cec883bd8a.jpg)
Post by: Laverdaroo on August 07, 2022, 01:03:54 AM
(https://uploads.tapatalk-cdn.com/20220807/22ddb7819807f40187b526414d090fc8.jpg)
Post by: Laverdaroo on August 07, 2022, 01:04:15 AM
(https://uploads.tapatalk-cdn.com/20220807/774bcde6eeaa9230b65eb6e64a8d2524.jpg)
Post by: Oddjob on August 07, 2022, 01:42:15 AM
You can clean them if you want. Don’t go mad though.
Post by: Laverdaroo on August 07, 2022, 12:11:14 PM
Just wanted them a bit more presentable and all the staining off them so the engine is re set on the inside as the outside if you like. Any marks in the futire will be easier to diagnose if everything is set to a base level of clean I think.
Post by: Oddjob on August 07, 2022, 12:24:17 PM
You seem to have caught the bug Roo, there is no cure I'm afraid.
Post by: Laverdaroo on August 07, 2022, 12:56:49 PM
I know Ken, you swine ;D ;D ;D ;D ;D
What do you reckon, a brass wire brush and a drop of unleaded or acetone or similar?
Is there anything I need to be careful of?
Bought the shells just now..........OUCH! :o
Post by: Oddjob on August 07, 2022, 02:03:30 PM
Use the new discs, use something like light blue or purple and see how it goes. if it doesn't do to well being metal use red, that'll do it. Don't use dark green unless you want them looking polished  ::) ::) Don't do inside the eye or the flat parts where the stamping is though. Degrease it first with petrol or brake cleaner.
Post by: Laverdaroo on August 07, 2022, 05:23:51 PM
Sound, thanks mate thats saved me a heap of experimental time, cheers. Just on with doing the 'Ash's replacement of the HT lead' thing today and going fairly well if I say so myself. Looking forward to the epoxy to dry and I can get on with the shaping and finishing bit.
Hot kettle, dog snoozing gently at the door in the sun, planet rock on and a strong cup of tea whilst fiddling about in the shed with bike bits..............utter bliss ;) :) 8)
Post by: Laverdaroo on August 09, 2022, 01:05:04 PM
Shells have come…………..partially from a time warp it appears(https://uploads.tapatalk-cdn.com/20220809/f66c86b6691b6a885853ff1ca0ef2775.jpg)
Post by: Oddjob on August 09, 2022, 01:15:35 PM
Ones on the left are production done in the 90s IIRC. The ones on the right are period ones. I have some in pairs in boxes, never seen that in the UK, they were all sold singly over here. The boxes came from Australia originally.
Not sure if I've said this Roo but those discs, when they come they must be fitted with the fronds facing the same direction as the Dremel rotates. Easy way to do this is to look at the disc, one side has a small indent/hole, face this indent to it faces the Dremel and they are the correct orientation.  My BIL just bought some after watching me clean some of his pieces and he complained the fronds were hitting him in the face, he clearly didn't read the instructions on the Amazon page.
Not sure if you've got a Dremel Flexible shaft for your Dremel Roo but if not let me know and I may have a spare one lying around. I've returned 3 Dremels under warranty and they always send a brand new boxed kit in return so I had some spare shafts, just given my BIL one and my daughter has claimed one to but I may have another somewhere. The difference the shaft makes is amazing.
Post by: Laverdaroo on August 09, 2022, 01:36:18 PM
Top tip Ken, thanks mate, I was going to ask but thought they looked fairly self explanitiry tbh but appreciate the heads up buddy.
A flexible end would be great, I have them for the various drills and for screwdrivers etc but not for the dremel. Mine's a bit shagged out and been usd to death  but working fine still so Im not going to update it until this one dies. A flrxible end bit would be ace mate if you can spare it, youre a gent, cheers.
I figured those were original shells bud haven't seen any like that for ages, only ordered them yesterday, Charlotte is good in their office, she clocks order mistakes and lets you know when you've had that part already or if a kit you order has the extra part in it or whatever. Shes been brilliant at Silver's throughout the 400 build and now the 550. I know they're dear and that the postage is astronomical but, as 99% of Honda dealers are, they are good and dead swift, bless em.
Right, have to ask cos I see it often but have no idea,  what does IIRC stand for................I AM Northen after all!! ;D
Post by: Trigger on August 09, 2022, 01:44:51 PM
Did you get your crank measured up with a mic Roo ?
Did come in pairs in boxes in the UK. Also came in singles. Here is one dated 1988
[attachimg=1]
Post by: McCabe-Thiele (Ted) on August 09, 2022, 01:47:57 PM
My conrods had that light surface rust so I soaked them in Evaporust - they came out like new castings.
Post by: Laverdaroo on August 09, 2022, 01:51:25 PM
Thanks ted, I ordered some last night to get the crap off afetr a try with some fuel and some other gubbins. Theyre clean but look a bit rough so evaporust was bought last night for the job. Thanks mate 8)
Post by: Laverdaroo on August 09, 2022, 02:04:06 PM
(Attachment Link)
Yes I had it done at a machine shop down in Keynsham and went through it all woith him as he was cleaning the mating faces of some engine parts for me. We came to the conclusion that it would be brown shells and that was reinforced by Ken on here. Dave at the machine shop did al the sums as I cant seem to 'click' with all these micro measurements. With the brown shells in an dfitted I sjhould get a plastiguage clearance of a thou and a half which was reccomended in several articles and on the net for a good clearance. Hope we all had our eyes in or I might be selling some shells on Ebay!
Im planning to plastiguage the crank with the new shells in to check,  thats the best way to go about it isnt it?
Post by: Oddjob on August 09, 2022, 02:34:29 PM
Yeah that's fine to do that Roo.
I suspect the box was imported Graham to cover a shortage of that colour shell over here. The main warehouse for Honda in Europe was in Holland, maybe that's why CMS are based there now.
I used to regularly browse the store room at Queenies and I never saw any shells in boxes, they were all in little bags with brown paper wrapped shells. Which funnily enough is what's in the box, 2 shells in bags. Makes me wonder why they did that, seems a waste of a box.
Title: Re: 550 F2 started!
Post by: Laverdaroo on August 09, 2022, 02:41:26 PM
nice, cheers Ken, Ive ordered some blinds and a new pair of shades inpreparation of those fork sliders coming 8) :o ;D
Post by: Oddjob on August 09, 2022, 02:46:55 PM
Bought the wood to fix my workmate yesterday. £30 for one piece of hardwood, not even a big piece  :o
Going to see if I can make 2 new worksurfaces later today. This is an original Black and Decker workmate from the late 70s, nearly 50 years old. It's been left outside in all weathers, had engines dumped on it loads of times, I've used it as a step ladder etc. There's very little of the original blue paint left on the metal now  :D I was thinking of dismantling it totally and having it powder coated, shining up the alloy braces etc so it looks brand new again. There's a TV program in that I reckon  :D :D
Post by: Laverdaroo on August 09, 2022, 02:50:27 PM
I think youre probably right mate, I still have my Dad's which he always had as long as I can remember, that has no paint on it either and just rust red.
Apart from the wood, they never seem to die so the? Think yoiure a MASSIVE tart for thinking of powder coating it but if you do it I'll have to do mine and I cant afford it at the moment after buying those shells and it sounds a fab idea! ;D ;D ;D ;D
Post by: Oddjob on August 09, 2022, 05:53:28 PM
I've never claimed NOT to be a massive tart  ;D ;D ;D
Halfway done and already made a few mistakes. Saw the back edge of the stationary board was level with the mounts, as my wood is slightly wider I just centralised the holes, bloody winding handles wouldn't turn then as they hit the wood. Remove all over again and having to redrill the holes is annoying.
Try getting the winding mechanism out, had to grind 2 of the washers off as the split pins in the handle wouldn't come out and when one did it still wouldn't come off the bar. Bloody nightmare this is turning out to be.
Post by: SteveD CB500K0 on August 09, 2022, 05:56:46 PM
I wonder if there’s a forum where you can get advice on restoring 50-year-old Black & Decker Workmates.
I have two.
One was my dads and one mine which he bought me in the late 70s.
I bought my son one when he bought his first house
Post by: Oddjob on August 09, 2022, 11:29:56 PM
The project is stopped. Black and Decker in their wisdom decided to secure the work top to the metal underneath by just drilling a hole in the wood and using an 8mm bolt/screw fully threaded and forcing the bolt to, in essence thread itself into the wood. I experimented with hole sizes on a spare piece of wood. 6mm was too small, couldn't get the bolt started, 7mm was too big so settled for 6.5mm. 3 bolts went in ok but one just span and TBH the other 3 didn't feel that tight. So I decided to countersink the wood and fit some 8mm nuts in there instead. I thought I had the correct length bolts but found them 5mm too short. I have hundreds of bolts lying around but could I find 8 x 8x45mm ones. Nope. So onto ebay and found some in stainless. In a few days they'll arrive and I can finally finish this. The wood is done, holes for the pegs are drilled and the bolt holes are done. Just need the bolts now and I can get round to finishing this.
If you ever try this Steve, good luck getting the handles off the threaded bar. Nothing I did made any difference.
Post by: Laverdaroo on August 10, 2022, 12:10:27 AM
Rattle cans it is then! ;D ;D ;D ;D ;D ;D ;)
Post by: Oddjob on August 15, 2022, 06:30:43 PM
Tried cleaning the frame of the workmate so I could paint it but the rust was so bad and some paint was peeling in big sheets and some paint just refused to come off that eventually I decided sod it, I'll just get it powder coated and let someone else do all the work. So dropped it off today, £90 to do the metal parts of the frame, I suppose it's a fair bit of metal but he reckons costs have gone through the roof since the Government stopped him using red diesel in his compressor, now he has to use white diesel and we know how expensive that is these days.
Alloy frame braces are almost done, looking very nice as well. Got some new feet for it as well. Starting to feel like Triggers broom. Need some new rubber boots for the fold out legs next.
Post by: Laverdaroo on August 16, 2022, 09:37:53 AM
Loving the update Ken, Are we going to get  an invite to the grand reveal?
Post by: Oddjob on August 16, 2022, 01:43:12 PM
I may do a thread on it's restoration. I hate doing those as I never take pics of them before, I just can't be bothered. It's only when the parts start looking really nice I think "I wish I'd taken some pics".
New rubber feet ordered. Powder coater said it would be cheaper to buy a new one, I said, you can't buy a new one and if you can they ain't half as good as the old ones. Good for another 50 years i reckon, you might see me on Antiques Roadshow with it  ;D ;D
Post by: Laverdaroo on August 16, 2022, 03:17:13 PM
Now then, Id pay to see you #@%$ the expert, reeling off part numbers. I reckon you'll have a work of art when done mate. You never know, there might be a  'hipster revival in 'Workmates' similar to when  Raleigh Choppers started to cost the earth as they became super cool!
Might be worth a fortune and be classed as wall art Ken;D ;D
Post by: Bryanj on August 16, 2022, 03:25:21 PM
Sod off you two, i can remember selling them new
Post by: Laverdaroo on August 16, 2022, 06:17:37 PM
 ;D ;D ;D Spit of tea ;D ;D ;D
Is that inbetween lighting the gas lamps on the street Bryan? ;)
Post by: Bryanj on August 16, 2022, 11:25:33 PM
Nope inbetween moping the quarry tile shop floor and adding up the 6 foot long paper till roll in me head on the wooden box that went "ting"when you opened the drawer
Post by: Laverdaroo on August 16, 2022, 11:53:12 PM
You had a ting! you were lucky ;D ;)
Post by: Laverdaroo on August 16, 2022, 11:57:22 PM
So, done it again!
Forgot to take photos on dissasembly! Could any of you lovely chaps and chappesses'ss's tell me the assembly order of the enclosed please? Thought I had it but cant get it right and get the bugger to turn once the screws are in the body. Any help greatfully absorbed.
Post by: Laverdaroo on August 16, 2022, 11:57:33 PM
(https://uploads.tapatalk-cdn.com/20220816/ebc04c71f3e9d688fa11763c0ec6e7fc.jpg)
Post by: Oddjob on August 17, 2022, 01:23:48 PM
If no one knows for certain I've got some starters lying around doing nothing, I'll take one apart and let you know.
Did you remove the screw and take out all the insides as well?
Looks to me as 2 smaller washers on the brushes end and the 2 larger on the splined end.
Post by: Laverdaroo on August 17, 2022, 04:45:47 PM
my only point of reference is a chap on the net taking one to bits from a cb750 which is similar.
From what I think , its small washer, castle-ated washer (one with legs on) on the brush end with the legs facing up, then two shim washers on the bottom and the plastic firbre washer thingy against the end cap so that it doesnt ark against the cover????
Ive tried it together several ways always with the lines on the outside to line up and once done up wont rotate so summuts wrong!
cant get me head round it tbh, proper scratcher!
Post by: Laverdaroo on August 17, 2022, 04:49:49 PM
If you would if you get 5 mate that would be brilliant. Sick of swearing at it and the internet is drawing a blank also. Vheers Ken.
Post by: Laverdaroo on August 17, 2022, 05:08:45 PM
Stand down mate, managed to sort it had the shims in the wrong order it appears, anyway, fettled and checked and all good so onto the next part for nannying!
Cheers for the offer Ken.
Post by: Laverdaroo on August 19, 2022, 06:27:15 PM
Managed to finally get out this week after being holed up at home with what was quite a nasty stomach bug, been blowing chunks for days but managed to get out today as feeling slightly better. Basically felt sea sick for three days!
Anyway, manned up and been out collecting bits, posting bits, buying bits etc and took a trip down to DJ Engineering at Keynesham near me to pick up the head and barrels after they got decked out on the mill for me.
The gasket surface were far from good so he’s taken 2 thou of both faces for me so hopefully all being well, I’ll have a go at cleaning the cases up with a view to getting the crank and gearbox in this weekend.
Hooray, something going together finally!(https://uploads.tapatalk-cdn.com/20220819/90fb08207533b37e885c761d969ef119.jpg)
Post by: Oddjob on August 19, 2022, 08:46:45 PM
Well those look nice Roo.
Good news for me too.
Will finally get round to assembling the workmate so I can do some polishing. Picked this up today.
(https://i.postimg.cc/QMJmhXsN/IMG-2798.jpg) (https://postimg.cc/KK4B5hRC)
Finished the alloy braces, painted all the logos and even did the little holes as well. Took me ages.
(https://i.postimg.cc/cC2MXC7h/IMG-2799.jpg) (https://postimg.cc/XBKCvVzB)
(https://i.postimg.cc/y8qyRJ8Y/IMG-2800.jpg) (https://postimg.cc/vcznFZnp)
(https://i.postimg.cc/7ZgMnx51/IMG-2801.jpg) (https://postimg.cc/cvLnsGM6)
Just finished painting all the other bits that required it. I'll post a pic of it assembled once it's done. Not sure yet whether to varnish the new worktops or to just leave them as they'll get hammered anyway.
Post by: Laverdaroo on August 19, 2022, 10:04:47 PM
kin wl Ken, thats the swingers mate. Never mind the varnish I was expecting OEM transfer of the 'Rule' down one side, 180 degree angle finder in the middle and associated decals. Get it varnished or at least danish oil it, it'll make it a bit more supple and will dent rather than split when you miss what you're tw*tting ;D
Post by: Laverdaroo on August 19, 2022, 10:07:47 PM
Besides, that's not the right black, wrong colour code, rookey mistake ;)
 ;D
Post by: Oddjob on August 21, 2022, 12:41:18 PM
The rebuild did not go well. The frame is built but the wood isn't mounted yet, my idea of improving the way it mounted onto the frame just didn't pan out. So more parts on order and try again. Getting a little sick of this now  ;D ;D
Post by: Laverdaroo on August 21, 2022, 12:48:13 PM
Bloody hell Ken, why did you try to modify it? I thought B&D did quite a good job at the design in the 70's why would you wan to change it?...............stop fiddling with stuff! ;D ;D ;D
Post by: Oddjob on August 21, 2022, 01:00:50 PM
Because they essentially just used an interference fit with the bolts, they used a threaded bolt and just forced it into the wood, this created it's own thread as it got pulled in. This was fine BUT the hole I drilled to accept the old bolts was ever so slightly bigger than the B&D hole, I think they used imperial drill sizes and I used metric. So the bolts were ok until you went to tighten them and then they started to spin. Feeling that eventually the top would come off I decided to devise a new way of securing the bolts so I enlarged the area around the bolt hole with a hole cutter so a 8mm shouldered nut would sink into the wood and not get in the way. Turned out that worked ok BUT the bolt head underneath now fouled the winding mechanism. It stopped it going back as far as it used to. I should in hindsight have copied the same style of bolts as B&D used, they were a mix of domed headed bolts and countersunk bolts, it's the countersunk ones that I didn't copy, they sink into the brackets and keep out of the way allowing the back panel to slide back further.
New bolts ordered, countersunk ones.
Also the new low level feet didn't fit, the head (the part that sits against the floor) was too big to fit inside the gap in the flip out feet (high level), I need to see if I can trim the head size down so they fit inside the gap as the high level feet fold up. It's 80% done, it's just not there yet, looks really nice though.
Post by: Laverdaroo on August 21, 2022, 01:34:30 PM
I know exactly what you're describing but could you not have employedsome roofing washers to take that slack up and dig into the timber top in a more appropriate way and not slip?
Just a thought.........
https://www.westfieldfasteners.co.uk/Metric-Washers/Shakeproof-Lock-Washer-External-Tooth-M12-A2-Stainless.html?google_shopping=qty_A2_Washer_ShkPrfExt_M12=20&gclid=Cj0KCQjwr4eYBhDrARIsANPywCiJtxjCtphUk-av4WP1Pi34EYrhqzTMHOncZ-LFeAJXbJA2olRv0p0aAp7eEALw_wcB
surely something like the above might sort it if its the issue that Im thinking you have.
If nothing else its been a great sideline project and it going to be mega when its done! ;) :)
Post by: Oddjob on August 21, 2022, 03:52:40 PM
Wrong sort of issue Roo. It was TBH a bad idea of B&D and clearly done for cost purposes. The mod I'm doing will improve it's robustness and should outlast the life of the workmate. Like all things though it can be a bit trial and error.
Post by: Laverdaroo on August 21, 2022, 03:55:47 PM
My bad bud, I have no doubt it'llbe the best workmate out there once its done Ken, eagerly awaiting the press launch if I'm honest.
Post by: Laverdaroo on August 21, 2022, 04:10:42 PM
(https://uploads.tapatalk-cdn.com/20220821/33469022dea70c3be50111316607a2a8.jpg)
Post by: Laverdaroo on August 21, 2022, 04:10:58 PM
(https://uploads.tapatalk-cdn.com/20220821/a53276e614ce51402edb7a2f3c1c097f.jpg)
Post by: Laverdaroo on August 21, 2022, 04:11:14 PM
(https://uploads.tapatalk-cdn.com/20220821/a84ebc2a104cb7fb817b5f0e1af37978.jpg)
Post by: Laverdaroo on August 21, 2022, 04:11:31 PM
(https://uploads.tapatalk-cdn.com/20220821/67e710c78389320bc643a5ed359d8448.jpg)
Post by: Laverdaroo on August 21, 2022, 04:13:52 PM
On a different note, I have an issue.
I took some stuff to have polished on friday  which consisted of the following.........
chain guard
rear brake pedal
kickstart and boss
Points cover
4 exhaust clamps                                  All rechromed
2 fork ears
grab rail
clutch cover
stator cover
2 x rims
front hub
sprocket cover                                       polishing only
while emptying the box of gubbins at the bench in the factory, I see this widget thing in the bottom of the box. I've obviously missed it on stripping the motor as it was such a gooey mess and it finally showed itself in this box of bits.
I have never seen it before but after going through the parts fich pages for all the bits that were taken, and a few extra pages; I see that there are several of these in the engine that have different measurements to what I have but are associated wth the bits I dropped off. I thought that being the best placet to start looking.
You can see from the piccies that the sizes are way different so after going all through my bagged bits this morning I cant identify its home. Can any of you lot help?
Obviously I don have the bits and so cant match it up which is making things a bit tricky tbh......!
I dont think its any of these and havent found any more in those area on the fiche's, any of you recognise it and suggest a good home for it?
24261-374000 Fork gearshift pin guide (gear cluster)
94303-08140 PIN C Dowel 8 x 14
94301-08140 PIN A Dowel stator 8 x 14
94302-06100 PIN dowel 6 x 10 sprocket cover
The sizes are nothing like I have so could it be wear? Basically got well muddled up and cant get me head round it......Anyone?
Post by: Nurse Julie on August 21, 2022, 04:42:21 PM
I've got a load of the different engine dowels in stock Roo,  I'll have a measure up to see if I can work it out. Are you sure it's not from the starter clutch?
Post by: mickwinf on August 21, 2022, 05:01:14 PM
is it off the stator cover, a locating pin?
Post by: Oddjob on August 21, 2022, 05:29:52 PM
It's solid so that limits what it can be. Not a casing dowel as those are hollow. To small to be a crankcase dowel as those are far bigger.
Few things come to mind.
Locating pin from the crankcases for the gearbox needle roller bearings.
Gear fork engagement pin, goes under the circlip.
Starter clutch as Julie says. Should be 3 in there.
My money is on the locating pins.
Post by: Laverdaroo on August 21, 2022, 08:04:47 PM
The nearest I can come up with after what was transported in the box, the measurements and the state of it. I think it might be from the back of the sprocket cover as it’s half a mil out on both measurements, it’s a bit mank on over half it’s length  so it’s been shoved in somewhere.
The fiche shows two of them, I’ve got one, still described as a dowel but it’s solid.
Thoughts?
Also I’m after new oil control valves for the barrels, anyone got any or am I getting stung for a new set from Mr Silverino?
Post by: Laverdaroo on August 21, 2022, 08:05:08 PM
(https://uploads.tapatalk-cdn.com/20220821/983c1fd06fc94c09f95ad9df35632864.jpg)
Post by: Laverdaroo on August 21, 2022, 08:05:31 PM
(https://uploads.tapatalk-cdn.com/20220821/5bbe5543f580fc22f5d3ab14004615e4.jpg)
Post by: Oddjob on August 21, 2022, 08:13:54 PM
Never been able to get those out Roo as there is so little of the projecting so not enough for any purchase to pull them out.
 I’ve got some oil control valves somewhere
Post by: Laverdaroo on August 21, 2022, 09:57:25 PM
That’s the thing mate, all three bits that have similar widgets were all in the same box and without the cases I don’t know. I’m going back down the polishers tmrw to have a look and take the rear mudguard in etc as I forgot it cos I’m blonde
Post by: Laverdaroo on August 21, 2022, 09:57:56 PM
If you have Ken chuck em in the pile and I’ll pay you as normal buddy, cheers.
Post by: Laverdaroo on August 21, 2022, 09:59:41 PM
No, Im not sure at all! :(
Post by: Oddjob on August 22, 2022, 12:34:52 AM
I’ve got some solid dowels like that soaking in brake cleaner after dismantling the 2 550 engines I just bought. I’ll see if I can measure them and see how they compare, I’ve also got a starter clutch lying about so I’ll check those as well.
Oil control valves FOC to you mate, I’ll throw them in with the other bits.
Post by: Oddjob on August 23, 2022, 05:54:36 PM
Finished it Roo. Bolts came today.
It's not to my satisfaction if I'm honest. I intend to replace the front board and modify the new one so it gives me more working area. It will do for the time being though. Not varnished it yet, might as well wait until I do the new board. I also need to do the bolts on the rear board.
(https://i.postimg.cc/BZhG0WXm/IMG-2805.jpg) (https://postimg.cc/WtJyGHmZ)
Post by: Johnny4428 on August 23, 2022, 08:34:02 PM
That’s quite something Ken. I have one the same and they are very handy. Got mine from an elderly neighbour who’s husband passed away in the mid eighties. It has been used a lot.
Post by: Laverdaroo on August 24, 2022, 01:05:17 AM
"It's not to my satisfaction if I'm honest. I intend to replace the front board and modify the new one so it gives me more working area. It will do for the time being though. Not varnished it yet, might as well wait until I do the new board. I also need to do the bolts on the rear board"
You miserable git ;D ;D
That looks the absolute swingers Ken,give over!
Now stop arsing about and crack on with those weeds in that path! ;) 8)
Top draw as ever mate, better than when new. 'Work Mate Monthly' are gonna flip when they see that! ;) :D
Post by: Laverdaroo on August 24, 2022, 01:12:55 AM
Sooooooo, started to get some bits in the cases and realised I'd not changed one of the bearings in the gearbox. Managed to keep everything in order and give it the once over but my question is..........Although the offending  bearing has a circlip and supposedly an 'o'ring, (which was long gone and needs replacing) straight after it. Is it a bearing that needs to be pressed off or should it yeald with some gentle thuds held through a vice with a block of wood n a mallet? I think i know the answer but some help required please if poss peeps.
Thankyou please :)
Post by: Laverdaroo on August 24, 2022, 01:13:08 AM
(https://uploads.tapatalk-cdn.com/20220824/1537be9c451e7008e6f7c87d7518c203.jpg)
Post by: Laverdaroo on August 24, 2022, 01:50:43 AM
(https://uploads.tapatalk-cdn.com/20220824/93427f7fd265bbdc95ccfab45080415f.jpg)
Post by: Oddjob on August 24, 2022, 02:58:45 AM
That's looks to be the countershaft. The bearing will come off with some whacks with a hammer, you just need to be careful when you do whack it, use a piece of wood to absorb the blows whilst loosely suspending the shaft in a vice so the shaft can move. The O ring is actually behind the bearing IIRC, it seals the bearing against the spacer which is what the outer seal uses. That will also come off if you want to clean it.
The problem is the bearing is almost unobtainable these days, very few left around. If it's not rumbling I'd leave it alone.
Post by: Sesman on August 24, 2022, 06:56:51 AM
Agreed. I’m pretty sure the only way to get a bearing is to purchase the entire assembly.  Like the man said, if it ain’t rumbling, leave well alone.
Post by: Laverdaroo on August 24, 2022, 11:40:18 AM
The red arrow is the BRAND SPANKING NEW ONE
Got it in the states whilst I was there! NOS(https://uploads.tapatalk-cdn.com/20220824/3be012504513e8acb9ee8fda2086ceaf.jpg)
The blue arrow is the set ring for that shaft, it’s the smaller one I need mate.
Post by: Oddjob on August 24, 2022, 01:07:40 PM
Lucky man, not many about.
Getting it off is fairly easy, it's getting it on that can be a problem. Hitting the sprocket end of the shaft isn't that much of a problem, it's fairly solid steel BUT I'd still use something between the shaft and the hammer, thin piece of metal maybe. However when installing the bearing you need to hit the other end and that's a lot more fragile, I seem to recall some brass bushing inside the shaft, so protecting the end of the shaft is vital because if you deform it then the needle bearing won't go on or it will bind inside it.
The O ring should be easy to find I reckon, nothing special about it, just really thin.
Don't forget, DON'T reuse the circlips. Not worth the risk.
Post by: Laverdaroo on August 24, 2022, 02:19:26 PM
I might bob up to the garage and see if I can use the press Ken, Ive new circlips on order too so no dramas on that one, my mate saidit was a no brainer so ordered them last night.
Cheers, mate.
Post by: Oddjob on August 24, 2022, 04:10:12 PM
A press would be fine Roo, again I'd protect the ends of the shaft, just in case.
Just found the setring and the oil control vales.
Also just found the dowels which hold the needle rollers in place, they are 6mm wide and 10.4mm long. That match what you were looking at?
Post by: Laverdaroo on August 24, 2022, 06:09:50 PM
jjust got in burt off to the cave of dreams a bit laterm Ill have  look and get bck to you mate.
Nice one Ken ;)
Post by: SteveD CB500K0 on August 24, 2022, 06:53:27 PM
Too much information
Post by: Laverdaroo on August 24, 2022, 07:14:10 PM
Not THAT cave Steve, that's Thursday nights! ;D :o
Post by: Bryanj on August 24, 2022, 11:27:11 PM
Is it a coincidence that mothers day is 9 months after farthers day?
Post by: Laverdaroo on August 24, 2022, 11:41:03 PM
 ;D
Post by: Laverdaroo on August 26, 2022, 01:51:47 PM
Some that I've spoken to and from bits I've posted on here, you will know I'm up to my wotsits in the engine at the min, building it up but currently awaiting parts so I can continue.
However, other things are moving along nicely with parts sent out for polish and chrome. I've not done Plastic coating  on a frame before but going to give it a shot with the 550 and see what we get. I've seen the chaps work before and he came reccomended so hoping for a great result, his other stuff looked awesome tbh so fingers crossed.
I've mocked everything up and made all the alterations I think I'm gonna do on it and had a rough fit up to see where evrything lives and to check clearances for the mods etc and happy to announce that 'Mejima' is off to get a nice new coat of shiney black on Monday. Hopefully I can get the Motor built and back in once I get everything in the post that I need to complete the it and have her in the frame in the next weeks?
 Been a bit of a swine so far during the whole build but thos who have had a read previous will have clocked that the starting point was an 'absolute shit*er' and barely had any original parts on it to start with so feeling chuffed-ish with the progress so far but as ever, wish I had more money! ;)
Post by: Laverdaroo on August 26, 2022, 01:52:29 PM
(https://uploads.tapatalk-cdn.com/20220826/155ad0b9d15189c4b0a9fd836ed553be.jpg)
Post by: Laverdaroo on August 26, 2022, 01:52:48 PM
(https://uploads.tapatalk-cdn.com/20220826/85862f26bd9520fcd76836de23bba2c0.jpg)
Post by: Laverdaroo on August 26, 2022, 01:53:10 PM
(https://uploads.tapatalk-cdn.com/20220826/9bfa7e84dcb01e358981d99cd4eee2fb.jpg)
Post by: Laverdaroo on August 26, 2022, 01:53:37 PM
(https://uploads.tapatalk-cdn.com/20220826/41cc58a22a72cf75a27a06ce0bf2641b.jpg)
Post by: Oddjob on August 26, 2022, 04:45:07 PM
A mod I did recently on the 1300 was to fit a grease nipple onto the headstock, you can then give the head stock bearings a new bit of grease every year without having to take it too bits.
Best done before having anything powder coated though. Uses a fair amount of grease but it's not as bad as you think. Also have one on the brake lever pivot tube, main stand and both the front brake arm pivots. Also have plans to modify the side stand pivot bolt to use a grease nipple, ok it's a bit OTT but it prevents wear and keeps things working as they should.
Just an idea, you don't have to do them but at least you know BEFORE you do any painting etc.
Post by: Laverdaroo on August 26, 2022, 06:49:20 PM
Well reminded Ken, I'd forgotten that, that's going onto the list. Still waiting for that O ring that sits on the countershaft, Cant really get much together til I have it.
Kick start's in the case and Ive done as many other pre fit jobs  as I can but waiting for this.
Tonights 'Planet Rock fest' in the shed is going to be lapping the valves and putting the gubbins back in. That should keep me occupied for a bit.
Question.
Whats the best way of building these units back together?
Upside down, fitting the starter clutch and Primary chain then leave it floating in the case albeit in position, then sliding the primary shaft through it once the cases are together. Is that possible
OR
Having the primary shaft in situe in the top case and crank etc and juggling to get it together that way?
I suspect the former is preferable to the latter but is there anything I should be warry of? Especially as I have fingers like bunches of pork sausages!...... ;D
Post by: Oddjob on August 26, 2022, 07:34:11 PM
Build in the top case. The problem is the gearbox, those needle roller bearings locate into 2 steel studs embedded into the top case, if you build in the bottom case you can fit the primary shaft etc BUT then you're fishing to engage the gearchange forks onto the gears and that tends to move the shafts and if you're not careful you don't get them located right and when you bolt the cases together the steel  studs get pushed right through the cases and usually break them or crack them. You'll see many examples of people doing just that on the site.
Build everything in the top case, fit the primary/camchain etc and then suspend the primary hub onto the primary chain, fit the bottom case and then threaded the primary shaft through when it's bolted together. Can be a little tricky when it's a new primary chain as it's very tight with no slack but a little leverage works wonders, just be careful where you lever against. Don't have the oil pump fitted and you can see the primary shaft coming toward you and know which way to turn it so it lines up.
Sounds harder than it is TBH.
If you fit a grease nipple onto the brake lever pivot tunnel look at the pin which goes through there, there is a small flat spot near the centre, the grease nipple should be situated so it pushes grease into that recess. File a flat spot on the tunnel where the nipple will sit and fit with a copper washer so the nipple seals and doesn't just pout out of the gap between the nipple and the tunnel. Same with the headstock and even the front brake pivot pins. Either drill 4mm and fit a 5mm nipple or 5mm and fit a 6mm nipple. You can buy stainless steel grease nipples now so no rust either.
Post by: Laverdaroo on August 26, 2022, 08:02:15 PM
As suspected Ken, I could heve described it a bit better but what youve just written is what I assumed, thanks mate. As soon as I get that box of goodies from you with that Baering c clip thingy and I have that seal, I'll have a bash at it. purely at the having a read and  a watch stage while I wait.
Post by: Oddjob on August 26, 2022, 10:24:09 PM
You want me to send the small stuff down now so you can start work?
Thinking of the headlight mounts, the oil control valves and the setring.
Those will just drop in a jiffy bag. Unless you can think of anything else that you need, oh just thought, you need the primary chain tensioner as well so you can modify the bottom crankcase. Large jiffy bag then  ;D ;D
Post by: Laverdaroo on August 27, 2022, 01:54:38 AM
Mate, if you could that would be bloody marvelous. I've one of those hollow knock pins to grab from 'Fowlups' in Brizzle on Sunday and hopefully that O ring should come tomorrow and with the gubbins from you I think I'm set to continue......hopefully ;D
Finally remembered tonight to punch the screws on the starter clutch on the primary drum. I've been on at myself to do it since w I put the new cush rubbers in. I got destracted, bagged it and then forgot I had to do it that was about a week ago!
 You know one of those jobs you remember when youre doing something completely un related? I was helping push an old chaps car out the way this morning in Wells where he'd a flat and just stopped in the middle of the road in a bit of a panic. Bless him, me and another chap changed it and got him away but whilst doing it I was thinking about pinning those three screws the whole time;D Mad how the grey matter works is'nt it? 8)
I meant to ask what were the details of the thread related to that tensioner mod that you were talking about, I went to have a look the other night and couldn't find it for the life of me! Can you bung us the link if yu get a chance?
Cheers Ken appreciated as ever for the help 8)
Post by: Laverdaroo on August 27, 2022, 02:16:33 AM
Forgot to ask, is the enclosed the right sealant for these motors, I'v eheard it mentioned a few times on here but are there different grades etc?
https://www.ebay.co.uk/itm/201929722303?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338749392&toolid=20006&customid=GB_131090_201929722303.136730267003~1658029614867-g_CjwKCAjw3qGYBhBSEiwAcnTRLsO05dN6fTMA0EpWlCrFtpFNYFGLA04a9hU8JD01ipc7yI50HoTh6xoC2OEQAvD_BwE
Post by: Sesman on August 27, 2022, 07:00:11 AM
That’s the stuff I used Roo, and good it is too. You will also have read how sparingly to apply it?
Post by: Laverdaroo on August 27, 2022, 10:00:06 AM
Yup, I have indeed. I have used various other stuff in the past but if this is the stuff I'll crack on and get some ordered up today.
Cheers Phil.
Post by: Oddjob on August 27, 2022, 12:23:18 PM
Think it was this link re the primary chain tensioner Roo.
http://forums.sohc4.net/index.php/topic,80690.25.html
Yep, that's the same stuff I now use. Expensive ain't it?
The bad thing about the primary hub screws is you don't need to remove them to change the damper rubbers.
Post by: Laverdaroo on August 27, 2022, 01:22:48 PM
I reaised that upon dissasembly but it all came apart to give it a clean as there was so much crud lurking in the engine I decided to strip everything to clean it. Its a good job as there was heaps of shite inside the hub and looks and feels a lot better for a good 'nanny up'.
Anyway, done now so all cool for school and ready for bobbing in the casses.
I've ordered that honda bondand should be here in a few days with abit of luck but its bank holiday Monday and they're on strike Tuesday so I might get it before the end of the week!
Yeah, is'nt it steep for that goo, I thought the RS stuff that Ducati foist upon you was dear but, kin el! :o
Post by: Oddjob on August 27, 2022, 03:18:58 PM
Primary chain tensioner and bracket, oil control valves, 2 headlight mounts and a setring all bagged up and will be sent down Monday Roo.
I know I said I'd sent those internal for your front forks but just thought, what's up with the current springs as those are proving a little difficult to package.
Post by: Laverdaroo on August 27, 2022, 03:27:21 PM
Thats cool Ken, dont worry about the internals, I have good ones from that set I bought off here so dont worry if it's a faff mate.
Does that mean I get a credit note? ;D ;D
I'm going to swap the lowers with the 'super bling, mirror finish,set' I'm getting off you to make a sooper dooper pair as these have freshly done stantions from Philpotts.
I've new washers, bolts and bits and bobs for the internals to replace so I'll build em up as a fresh set as soon as I get them.
Nice one Ken, appreciate it buddy 8)
Post by: Oddjob on August 27, 2022, 03:35:41 PM
You in a rush for these small parts, I can send them recorded or special or just 1st or 2nd.
Post by: Laverdaroo on August 27, 2022, 03:44:46 PM
Kinda but that's not your fault mate so save yer brass and send em which ever way suits buddy, just grateful you've managed to fettle what I need and happy to send em mate.
Post by: Laverdaroo on August 27, 2022, 09:54:36 PM
Can anyone confirm if this is jiggered or not?
I see there should be a twin tipped dimple on the top, the one removed doesn’t, is it vital to its operation meaning this is junk?
Not seen another one ever so have no comparison, just piccies from the interweave and the parts book which is less than detailed on its display of dinky bits like this?(https://uploads.tapatalk-cdn.com/20220827/a8732555a2452507594620924f1def88.jpg)
Post by: Laverdaroo on August 27, 2022, 09:55:28 PM
(https://uploads.tapatalk-cdn.com/20220827/daf7475c76cbcff1cd7c279aa22a4fcc.jpg)
This has an indent rather than a min or cast like tower. Is that knackered?
Post by: Nurse Julie on August 27, 2022, 09:58:52 PM
The big bit is fine Roo but that little brass bit is broken off of the electrical conducter thingy, so that's knackered.
Post by: Laverdaroo on August 27, 2022, 10:02:27 PM
Thoght so, just spotted that had fallen out of the bag it was stashed in.
Right, anybody got one or are they unobtainium now, dare I ask?
Post by: Bryanj on August 28, 2022, 08:54:36 AM
Found one on me study floor yesterday, you can fit it later if you want to, the big bit that is. Trigger had some of the contacts etched so you could replace just the contacts, the whole switch has long been discontinued and my stash of nos ones is no more
Post by: Laverdaroo on August 28, 2022, 11:12:59 AM
There's one on the internet around the 40 quid mark but the listing is a bit curious, I've messaged the seller to see what the score is. Failing that and I'm going to have to go back to that breakers yard in the states when I go back there next month.
Post by: Oddjob on August 28, 2022, 12:30:53 PM
Which bit do you need Roo?
I have a couple of the rotor bit, about the same nick as yours, there should be a small bump on the back which located into the slot on the end of the gearchange drum, the part which sticks through the seal. However it's not vital as so long as you fit it correctly and the screw/bolt is tight so it doesn't move it will work fine.
The other bit, you can either repair it or try and find a new one. I do have a couple of them if you need one, got 2 off those engines I just split.
Post by: Laverdaroo on August 28, 2022, 02:59:11 PM
To be honest Ken, I can't even see where that tang came from! Is it off the rotor or the stay???
There was talk on here about using a 350 rotor but the thread goes quiet before any info of  if it worked was divulged. Did anybody hear anything about the fix or Mod that chap did?  From what I read, the strip of metal that causes the connection was smaller on the 350 item than the 550 one but the photo he put up wont open so cant even compare.
If the 350 one is a goer that might be an option. Mine doesn't have the dimple on the top, you can see where it was though. As for that snapped  tang, happy for any info as I say, have no idea where it came from, there are no bright bits on the rotor or signs of snappage on the stay so not sure what it's about. I cant see it on any photos I've found either. That one for sale in Hull is NOS in the bag but its 40quid which is a bit steep for me just at the minute but if I have to I will.
If you think you have a replacement I'll have it Ken as having never fitted one, this one pretty much falling off on dissasembly and me never having worked on these before, I have no reference point for bodging a knackered on such as this so maybe be advantageous buying a new complete one if no body has one fit for re use.
I presume thats where the connector goes to the loom but no info here and bad photograhy means I'm flyong blind on this bit.
Post by: Bryanj on August 28, 2022, 03:19:02 PM
If you look at the stator part of thr switch there id a copper piece bent in a u shape and the free end rubs on the outside of the rotor, when it touches the brass in the rotor it grounds via the screw and green light comes on.
The loose bit is the end of the u section that rubs on the rotor, the hole should be a dimple and it has been weakend and broke off.
As i said Trigger had a sheet of etched copper contact strips so you could remove the original rivets and use small bolts n nuts. I will be seing them in november ask if he has any left and i will collect
Post by: Oddjob on August 28, 2022, 04:36:40 PM
I found one in an old box in the shed some months ago, switch and rotor IIRC.
I'll send it with the stuff with the fork sliders when I finally get round to doing them. The envelope with the small bits is sealed and TBH I don't think it would have gone in anyway.
Post by: Laverdaroo on August 28, 2022, 06:08:09 PM
 I get how it works, just havent seen a new one or one thats functional. So is it the rotor thats goosed or the actual 'stay' then? Still cant find any bright metal on it in the slightest depicting where this bit is from........, wonder if it was hanging on by a thread and gave up in the bag, with the removal being it's swan song??  It's no surprise tbh, everything else on this has been bodged, hacked, cut off or shagged out so its no surprise really!
In that case I'll hang fire for a bit then Ken, thanks mate, let me know how much and I'll fling you some spuds over mate.
Bryan, thanks mate you are a true Gent. Grab one/some anyway then, they sound particularly useful to have floating about in the workshop and you being so close makes it rather handy if I have to bob up and see you for a blag ;) 8)
Thankyo all, youre all mint! :) :) :) :) :)
Post by: Oddjob on August 28, 2022, 06:34:08 PM
Check the very last post on this thread.
http://www.sohc.co.uk/index.php/topic,19297.0.html
The bottom pic is the CB500/550 neutral switch and you can clearly see the part you found in the bag.
Post by: Laverdaroo on August 28, 2022, 07:33:32 PM
AAhhhhhhhhhhhhh!     DOH! ::)
Cheers for that, went for a blast up to Brizzle and it was in my head all teh way back! ;D
Post by: Laverdaroo on August 31, 2022, 11:29:14 AM
Anybody have any recomendations for chain and sprocket kits at not daft money? I've never had a split link on a bike I've owned aways prefering to rivet link them. Most available (DSS Wemoto, CB-four etc) appear to be with a clip, are they ok on these, I've never trusted them tbh. Any preferences chaps et al?
Dont want to spend the earth if I can help it........
Post by: florence on August 31, 2022, 11:40:26 AM
In my opinion and experience over the last 40 years of riding a motorbike, split links work perfectly.  The only problem you might have is with a badly adjusted or  poorly lubricated chain, and of course making sure you have it on the right way :)
Post by: Laverdaroo on August 31, 2022, 11:52:08 AM
Cheers Florence, never had oine, know theyve been used for years but just cant get it out of my head that its a weak point. My mates always carry a spare clip link and I dont want it in the back of my head whilst out but happy to bear down to greater knowledge.
Post by: Rozabikes Tim on August 31, 2022, 11:56:15 AM
Cheers Florence, never had one, know theyve been used for years but
Obviously too young you whipper snapper!
Post by: Laverdaroo on August 31, 2022, 11:58:09 AM
A very old, crabby and farty 49, Tim 8)
Post by: Rozabikes Tim on August 31, 2022, 12:05:54 PM
Practicing for when you are properly old then. Just turned the big 60 myself. Very intolerant, always right and remarkably forgetful too
Post by: Laverdaroo on August 31, 2022, 12:18:45 PM
You could actuallybe describing me according to The Long Haired general ;D ;D ;D
Post by: McCabe-Thiele (Ted) on August 31, 2022, 12:21:15 PM
49 & 60 your both spring chickens - at 74 my main problem is getting up out of a chair without emitting too many groaning noises.
Can't risk letting one out just in case it's not a dry one.
Wendy frequently tells me she knew she had married Mr Right but didn't know my first name was Always.
Post by: Laverdaroo on August 31, 2022, 12:24:49 PM
Can't risk letting one out just in case it's not a dry one. ;D ;D ;D ;D ;D ;D ;D ;D ;D
Post by: Oddjob on August 31, 2022, 12:47:15 PM
Waste of time carrying a split link. What for? If the chain snaps it generally does so much damage you're not riding home again. That's if you still have your leg intact  ::) ::)
500 is ok for a split link, had one fitted for many many years and very handy for removing the chain so you can clean/oil it. Especially if like me you used Duckhams Chainguard which you melted on the stove and put the chain in, great stuff until you drop the tin all over your mums kitchen floor and it sets instantly.
Post by: Laverdaroo on August 31, 2022, 01:11:47 PM
The chaps I refer to are on the four stroke off roaders not the road bike lot, I see your point though Ken, bit of closing the gate after the horse has bolted kinda thing int it.
I too have dropped a tin of molten wax on the kitchen floor at the grand age of 16...............on top of week old new lino. My mum beat the crap out of me with a slipper for that one ;D
Dont think it was duckhams but some other gubbins we used to get from the guys at Acklams in town. There was never a better looked after TY80 in existance at the time, I loved it. ;D
Post by: florence on August 31, 2022, 01:13:25 PM
I agree, never carry a spare link, no need.  It definitely isn't a weak point, the load is taken by the solid link part, there shouldn't be any great side to side forces if everything is adjusted correctly and the chain and sprockets are in good condition.
While we are on the subject, I would also recommend fitting a Scott-Oiler, marvellous contraption, maintains your chain in tip-top order.  I have one on my 500, hidden where the airbox used to go.  Cannot rate it highly enough.
Post by: Laverdaroo on September 01, 2022, 12:05:49 PM
Chain ordered, thanks peeps
Ken that bag came this morning with the gubbins in, cheers mate, I can get in now.
Although, whilst looking for some bits from my chippy box at the back of the bench, look what I found………….I bloody knew I hadnt lost it. Do you want yours back mate? The bloody thing had slithered down the back
I’ve had to order a gearshift drum stopper collar/washer bushing to get the mech put into the cases as that is missing also.
I’ve never seen it so deffo know it was never there which is a pain. I only looked at the fiche as I couldn’t suss how to fit it and discovered I have an issue!
There’s only two for sale and both in the USA so I’m waiting for that and until it gets here I’ll have to walk away from it which is a right pain as I wanted this back together before I take off for another 7 weeks again on the 15th
If anybody has one can I borrow it and I’ll drop you a NOS one back when I collect it while I’m over in the good ol’ US of A?
Quite hard to find at reasonable cost, even this one robbed me 10 bucks plus post
Part number: 24433-323-010
Thanks all.(https://uploads.tapatalk-cdn.com/20220901/b7d23508b8fa38e9ca1ce3d4e77e432f.jpg)
Post by: Laverdaroo on September 01, 2022, 12:06:23 PM
(https://uploads.tapatalk-cdn.com/20220901/6d7b2ae741e8cacc47702e849645fd55.jpg)
Post by: Oddjob on September 01, 2022, 01:18:15 PM
If you're sending stuff up to me then yeah send it back so I can marry it back up with it's mate. If not then wait until you are, no rush.
STOP bloody buying stuff like that collar, I must have one of them lying around somewhere, ask first before spending money, it's not a problem and I'd sooner all my little bits like that get used than thrown away when I kick the bucket  ::)
Post by: Bryanj on September 01, 2022, 04:01:47 PM
I will def have one you can borrow, will get to it on sat BUT as most of my books are put away at moment can you put up a pic of where it fits please
Post by: Laverdaroo on September 01, 2022, 05:08:18 PM
Bryan, you are a legend, I chatted to Ken earlier, not heard back yet but if you have one of those I will come up for it likea shot!!
Just landed in and having a brew, when I bob out to The Shed of Dreams' later I'll sort a piccy out and bob it up.
Post by: Laverdaroo on September 01, 2022, 05:20:19 PM
Yea gulped, …
It sits on the selector bits near the end of the shift drum. Bits it sits on shown, top case upside down showing area, on the fiche it’s number 12 Bryan.
Utter hens teeth this side of the Atlantic as far as I can tell. I reiterate, serves me right for excitedly buying a sh*tter! Should no better(https://uploads.tapatalk-cdn.com/20220901/dff2a652bff17368f448997db7a921e8.jpg)
Post by: Laverdaroo on September 01, 2022, 05:20:55 PM
(https://uploads.tapatalk-cdn.com/20220901/e162d57b0979262cc68f2fdd5b51b4c7.jpg)
Post by: Laverdaroo on September 01, 2022, 05:21:11 PM
(https://uploads.tapatalk-cdn.com/20220901/73115756df62206a3131ef6dfbfa31da.jpg)
Post by: Bryanj on September 01, 2022, 05:44:52 PM
I will look tomorrow and in sat morn mate
Post by: Laverdaroo on September 01, 2022, 07:49:14 PM
If the weather's resonable I'll wobble up on the bike saturday morning Bryan if you manage to find one. Appreciate it mate, you're a good un :)
Post by: Oddjob on September 01, 2022, 11:59:56 PM
I have one in a small box that been in the shed since 1980 at least. I keep spotting it and opening the box and I remember it vividly. However, as soon as I want the damn box it's gone on walkabout, I remember moving it when I started to empty to shed but buggered if I can figure out where I put it. It will turn up as soon as you've found one.
I'll also have some in a huge box of bits that's in the garage but being such a small part it will be right at the bottom among hundreds of other little pieces. I'll keep looking though.
Post by: Laverdaroo on September 03, 2022, 06:29:40 PM
Can anyone clarify, I’m having a brain fart?
Is the third gear on here the wrong way round, I’m only getting half over lap on the counter shaft. .
If I turned it round it would line up but can’t remember if that’s right, the books. It that finite and I can’t tell.
Ta in advance……..(https://uploads.tapatalk-cdn.com/20220903/55239918de59606664d9f2faf2392200.jpg)
Post by: Laverdaroo on September 03, 2022, 06:30:00 PM
(https://uploads.tapatalk-cdn.com/20220903/279f1613a31360d87bdf26a78a4caf09.jpg)
Post by: Oddjob on September 03, 2022, 06:42:17 PM
Looking at the manual it looks like the boss on that gear should face the other way.
Post by: Laverdaroo on September 03, 2022, 07:08:24 PM
Thats what I'm thinking as I'm not confident 4th is finding its way all the way home. I'm getting all th egears but 4th is not how I expect it to be. i thought I'd just have another go through th egears before trying th ecases together later. It just sit where I'd like it. I'll swap it round and have a look.
I've jhalf a dozen new circlips in a pot ready for just this sort of pre-buttonning the casestogether panic ;)
Nice one Ken, cheers mate. Kepp yer posted.
Post by: Laverdaroo on September 03, 2022, 07:52:24 PM
(https://uploads.tapatalk-cdn.com/20220903/8f75febd5a6fa741d0f5e11145e58007.jpg)
Post by: Laverdaroo on September 03, 2022, 07:52:34 PM
Thats it apart on the bench, I think we're right about flipping it, the diagram isnt very clear for a bear with very little brain mate ;D
Just so I wont ever be worrying, is that the right configuration for these two washer/shims? from what I can make out from the fiche, its this way round but am I mis reading it? Just dotting my 'i's' and crossing the 't's' so to speak.
Ive looked at the fiche for ages and I'm pretty sure its that way
Okay, so thats a shot of the box in 5th gear and things look a lot straighter and its made the box a bit tighter if you know what i mean, it feels a bit more connected ifthat makes sense..........
Post by: Laverdaroo on September 03, 2022, 07:53:31 PM
(https://uploads.tapatalk-cdn.com/20220903/edc1044d8384f5570b3e7d13e0bf7bc1.jpg)
Cut lips not on it yet but that’s 5th
Post by: Laverdaroo on September 03, 2022, 08:18:04 PM
cut lips? circlips ;D
Post by: Bryanj on September 03, 2022, 08:43:33 PM
Thought you was saying you kissed it!
Post by: Laverdaroo on September 03, 2022, 08:46:37 PM
 ;D
Having one of those ..........'is that right?' evenings Bryan ;D
Post by: Bryanj on September 03, 2022, 09:49:49 PM
Not just me then! Since you left ive been having a bit of a metformin day!
Post by: Laverdaroo on September 03, 2022, 09:52:28 PM
Oooo, that sounds remaredly familiar. Thats a crap day all round then isnt it? :(
Post by: Sesman on September 04, 2022, 08:00:00 AM
Does this help? I was surprised to find this as I’m not one for record photos.
Post by: Laverdaroo on September 04, 2022, 01:39:10 PM
Yes it does I shall go armed with that when I go out later. I had a reaonable evening there last night and happy to say that the cases are provisionarily dry fitted with the gear mech in place (THANKS BRYAN).
I'm gonna try the gears all together wiht everythng in and have a play. I think I've managed to get it right but not tighten everything down until I'm sure. That inkling of doubt is still there so playing it safe but that helps heaps Phil,mcheers mate that s treat
Post by: Laverdaroo on September 04, 2022, 01:43:07 PM
(https://uploads.tapatalk-cdn.com/20220904/00a82005183c5a2e0bc3ba15f973ac1a.jpg)
Post by: Laverdaroo on September 04, 2022, 01:43:27 PM
(https://uploads.tapatalk-cdn.com/20220904/8a6c68508555e0f662beff1242a26557.jpg)
Post by: Sesman on September 04, 2022, 01:49:21 PM
Oh, yes. Looks like a third world operating theatre….very nice.
Looks like an excellent finish on the cases by the way.
Post by: Laverdaroo on September 04, 2022, 01:57:07 PM
It is ;D
The cases came out reallynice, I'm realy chuffed with it tbh, the frame went off for plastic coating on Thursday along with a bunch of bits so that'll be ready ror when I come back.
Theres a ton of stuff at the chromers being done and some more polishing to go. I've a few bits to drop off at various places but I hope to have all prepped before I go away, come back, pay and pick up everything and have a monthe of shed time fiddling when I get back in October.
I've just discovered a hole in the petrol tank under where the badges go so need to find a some bits to get that sorted but in real time, I'm just  stuck for tyres, paint, and an end can and getting the seat covered once mocked up how thock everythings going to be.
I'm kinda getting there. Didnt think I'd be uttering those words quite yet but there's time for an enormouse carasroph*ck so not counting my blessings quite yet. ;D
Post by: gary123 on September 04, 2022, 04:14:15 PM
Thats looking great Roo. I think you went the right way doing the engine before cycle parts. I did the opposite and then spent time waiting for the engine to be done and had nothing to be getting on with.
Post by: Oddjob on September 04, 2022, 07:35:24 PM
I always do the engine last, I did the engine first one time and when I'd done the rest the engine had filled with condensation. The oil was like mayonnaise and it hadn't even turned over by that point. I ended up taking it apart again just to clean the insides.
Post by: Laverdaroo on September 05, 2022, 07:46:13 PM
This from you Ken, you’re the only person I’m waiting on bits for?
Just crossed my address out cos this is public etc but was this supposed to be the clutch shims?
I say supposed as it came to me open and completely empty. I’m only guessing that it’s from you.
If it was, don’t worry I’ll get some made I know you only had ten sets done and all sold, I’ll get some somewhere, could you send me the dims that I can pass onto a supplier?
Cheers mate, told you I had awful luck……………….case in point!(https://uploads.tapatalk-cdn.com/20220905/c68d2b369700be9e374736e250d0ff70.jpg)
Post by: Laverdaroo on September 05, 2022, 07:46:31 PM
(https://uploads.tapatalk-cdn.com/20220905/9d68dc4ae6f103a830aebdb14a12ef3a.jpg)
Post by: gary123 on September 05, 2022, 08:05:30 PM
Thats shit luck Roo.
Royal mail 1st class pays compensation up to £20. the sender must claim and provide proof of value, they usually try to fob you off with a few stamps, but stick with it and they will pay cos they have to. ( I ran a post office for 20 years). It helps if the sender has proof of postage. Save the envelope as evidence.
Post by: Laverdaroo on September 05, 2022, 08:40:52 PM
I would Gary but I simply just cant be arsed!
It's been one of those days today. 20 tonne JCB I've been on all day decided to grenade its fan blade into its radiator and die so thats anoter three day loss waiting to get anoter to finish this job I'm on, I go to the states next Thursday!! Puncture on the way home on the crappest commute through Bristol ever, to get home..........in the rain. I get home, Teds parcel of tanks plants came which was sent recorded last Tuesday, so he ended up with three pots of snot and to crown the day off, the post came pre opened and I had a sodding envelope put through the door! YAY!
I now have selection issues with the gearbox on the 550 now the cases are together, when I've had a brew and a massive sulk I'll put a post up explaining and see if anybody has any ideas.
I just cant be arsed with today, quite frankly it can sod off, i'm glad its nearly over if I'm honest.
Harrumf! >:(
Post by: gary123 on September 05, 2022, 09:15:44 PM
Totally understand. I find beer helps.
Post by: Laverdaroo on September 05, 2022, 09:20:32 PM
Type 1 diabetic and raging sugars tonight so thats off the menu! :(
Post by: Johnny4428 on September 05, 2022, 11:29:16 PM
Jesus Roo! If you didn’t have bad luck you wouldn’t have any luck at all! Things can only surely improve.
Post by: McCabe-Thiele (Ted) on September 06, 2022, 09:28:48 AM
Roo you must have killed a Robin.(Old expression).
Bad luck comes in threes so today should start to improve.
Post by: Laverdaroo on September 06, 2022, 12:49:14 PM
Got over yesterdays sense of humour failure. So far so good but there’s time yet
Post by: McCabe-Thiele (Ted) on September 06, 2022, 01:20:37 PM
A good rant helps the soul - it's an online version of couch therapy Roo.
Post by: Bryanj on September 06, 2022, 04:46:38 PM
DEFINATELY!!!!!!
Post by: Oddjob on September 06, 2022, 05:55:43 PM
Just to cheer you up a little.
Started the fork slider for you.
Only 1/3rd done but it's a lot further on now. Just tidying up some areas before repolishing it again.
(https://i.postimg.cc/XYVq1fv2/IMG-2809.jpg) (https://postimg.cc/crbdr8wY)god of war 3 wallpaper (https://suwalls.com/games/kratos-god-of-war-3)
Post by: Laverdaroo on September 06, 2022, 06:26:46 PM
Well, you know I said there's time yet?
Well, half three this arvo,  chap in the loader shovel gives me a little 'love tap' on my bumper which from behind,it's a common occuranceas for a bit of fun!         I was using the concrete pecker to smash out a load of rock at the time and for once had the door open, that shunt knocks my phone off my quadlock on the window and I just sit there and watch it bounce on the floor, then down onto the tracks of the 30 tonner I was on and landed on a rock but it landed at a funny angle that  flipped it into a beautiful,  rugbyball-esk spin whilst everything went 'slo-mo' for a second, I start to try tonleap out and I watch it go gently 'PLOP' into the reservoir......................which is 18meters deep just there.
With a swear I slammed the pecker down and split one of the hydraulic lines, there's another 130 quid and then getting out to swear louder, I catch my 'IV' that goes from my tummy to my insulin pump on my belt and snapped the line meaning no insulin delivery............................I didnt say anything, I just got in my van and came home.
Another right off of a day where it appears I like to work for nothing. >:( >:( >:( >:(
 New Line on the pecker and a new phone as I'm sim only................ Bout a grand for today...............Good going!
It's the only phone i've never insured as it was due for a contract renewal in October and a free handset..
F**KIN SICK!
Nice work Ken, sadly my enthusiasm for anything has evaporated today. Appreciate it mate.
Just so you know, my trip has been brought forward by 5 days so I go on the 15th. Dont kill yerself doing those sliders mate, I think I have to split the cases again as Im not happy with the selection. I had some shots to post but they're on my phone!!
 It appears now that all is buttoned up that the lever has full travel but the selecter wheel only turns half a selection leaving the upper selector wheel thing on the point of the star rather than going into the web and selecting the gear. If you spin the shaft that goes to the clutch, it will select up and down the box but only if you manually twist the shaft or the front sprocket shaft. Not sure if this is the norm but doesnt appear right to me. I cant see a fault and start the whole sequence of fitting the mech and finish it as described in the book, on the net, on you tube etc so head scratching but probably wont go out tonight into the shed, Havent the concentration nor the will TBH!
Post by: Sesman on September 06, 2022, 07:32:42 PM
Roo…do not get on that plane😳
Sorry to hear you are having a rough time. Good luck is just around the corner…🤞
Post by: Sesman on September 06, 2022, 07:35:58 PM
Out of interest Ken, what size motor do you recommend for this metal shining lark. I’ve just acquired two bench grinders. One is .33 hp(say 250w) and the other is more powerful. It must be cos I can’t lift it unaided! Both are Single phase jobs powered off a 13A plug.
Post by: Sesman on September 06, 2022, 07:46:38 PM
The big uns 750w.
Post by: Oddjob on September 06, 2022, 07:53:06 PM
Use the 750w one, 250w is far too underpowered.
Just for your Roo.
Almost done, final polish needed and some work on areas where the polishing mop won't reach.
(https://i.postimg.cc/rppNXjWh/IMG-2812.jpg) (https://postimg.cc/PCBw1mSZ)
(https://i.postimg.cc/zvTnScZf/IMG-2813.jpg) (https://postimg.cc/sGDQ3K2F)
Post by: Bryanj on September 06, 2022, 09:57:05 PM
Shiney my precious!
Post by: Sesman on September 06, 2022, 10:00:42 PM
That is fu£img mint. I’ve never been one for polish, but that’s too good for a Harrogate boy. Sorry Roo.
Post by: Johnny4428 on September 06, 2022, 10:36:29 PM
Hell! I had to fetch my sunglasses before I could view that Ken.🤣🤣🤣
Post by: Laverdaroo on September 06, 2022, 10:42:18 PM
Holy Sh*t balls Batman!
I'm astounded Ken,  I think I agree with Phil! You might have well chromed them, theyre gonna look mint!
Well that has cheered me up no end, I almost smirked then ;)
Thanks mate you're a good un.
Post by: Oddjob on September 06, 2022, 10:53:28 PM
I’m not 100% sure but I think the other one is fractionally better. It’s come out pretty well considering but it does have a fault. Just below where the dust seal sits, on those 2 rings near the top, there is a dip in the alloy where I tried desperately to get rid of some pitting. I didn’t succeed and eventually just gave up and used another set of sliders, you can’t really see it as it will be behind the slider when it’s fitted, so too good just to throw away.
Just so you’re warned Roo, the other one is fine, it’s just this one that has that slight blemish
Title: Re: 550 F2 started!
Post by: Oddjob on September 07, 2022, 01:51:50 AM
Forgot to add, the gear selection problem. You can sometimes get some gears to engage whilst not turning anything but you’ll never get more than one or two without spinning at least one of the shafts. Imagine the dogs on the gears, if they line up with the dogs on the gear it engages with then it goes into gear. However, if they are not aligned then it does what you’ve found and only half engages, as soon as you spin a shaft things move and it suddenly goes into gear.
If you can select all 5 gears whilst rotating at least one shaft then you’re good to go. You only need to spin one shaft as there is enough meshing going on for it to turn the other shaft enough for gears to engage.
Post by: Laverdaroo on September 07, 2022, 08:17:26 PM
I wondered tbh, surely the inertia of the motor would aid in th eselection through the mesh while the motor is running?
I went out at 3 this morning to strip the cases as it was niggling me so much it woke me up!
Stripped back to bear cases, reassembled and still the same so I'm leaving it and going to build the rest of it up complete. watching loads on the net it appears that others have a much free-er spinning assembly than I do and wondered if it was something to do with the assembly lube being really thick and making everthing drag somewhat? I've never used it before and tbh might not bother again as I really dont like it. Think I'l stick with engine oil next time.
Post by: mickwinf on September 07, 2022, 09:20:34 PM
I have had the same problem with gear selection and also stripped it down again, hope both work when together!
Post by: Oddjob on September 07, 2022, 10:34:17 PM
Just thought Roo, the fork sliders will not look right when fitted. Lets see how clever you are, why?
Post by: Sesman on September 08, 2022, 08:35:40 AM
Oh, oh….suspense. Waiting…..
Post by: McCabe-Thiele (Ted) on September 08, 2022, 11:37:13 AM
I only used assembly lube on white metal bearings & the camshaft - elsewhere I used oil.
TBH it never crossed my mind to use assembly lube on gearbox parts - I can see that might explain your issue.
Post by: Oddjob on September 08, 2022, 01:04:37 PM
Plus you must wash out any new bearings you fit as Honda fill them with a protective coating of grease which over the years goes harder and harder. My new countershaft bearing only just rotates it's so stiff. Wash with petrol or similar.
I only ever used engine oil on the gearbox when assembling, it gets plenty as soon as the engine starts, it doesn't rely on the oil pump for lubrication. I tended to use STP on the crank bearings and the camshaft surfaces back then. It was like golden treacle and did a fine job of protecting the surfaces until the oil got there. You just don't see STP anymore or Slick50.
Post by: Bryanj on September 08, 2022, 03:07:51 PM
Ooooh slick 50, i remember lister running an engine for about 30 mins with no oil after using that and no damage on stripdown
Post by: Laverdaroo on September 08, 2022, 03:43:45 PM
Because the glare from the polishing will have already damaged my retina’s and I won’t be able to focus, what?
Don’t tell me, there’s two lefts and you hadn’t noticed until now?….. go on
I’ve not been out there and kind of blanked bikes out this week, it’s been such a shocker I’ve not dared go in there
My Honda bearings were the same, they were all NOS and all the same hardly moved at all ex pet u set duress, washed them in petrol and left them percolating in a dish of lube for a day or so before I fitted them and they came out perfect. Re assembly gunk, I used some stuff recommended to me by the husband of a pal of mine, she drag races and atone point was UK fastest lady pr similar, on the funny bikes. He builds her motors and lashes everything in it and I appreciate her motor is stressed to buggery but any helps good help and all that. Perhaps not so in this environment. It really is proper sticky doings!
I know the box gets lashed with oil from the off but thought a) wouldn’t hurt bobbing a bit in, b) didn’t know when the engine would get any oil as might not be rigged up until I get back from Yeee-haaaw.  and c) It’s like green treacle,
 I mean it’s GREEN!
Well, with a poke of reassurance, I will continue blindly on and attempt to get the pots on and slide the barrels on.
I hasten to add, fitting the second shaft once the cases have gone together by threading it through, is far easier than expected.
Nice one Ken, et all for the advice
Post by: McCabe-Thiele (Ted) on September 08, 2022, 06:02:48 PM
et Al.  I love a bit of Latin.
Post by: Oddjob on September 08, 2022, 06:14:48 PM
No Roo, the end caps that hold the spindle will still be silver like the old finish on the sliders.
That would look odd.
Luckily I thought about it and polished 2 end caps today.
Just doing a few bits on the slider, areas the mop won't reach. Coming along nicely.
I'll need to dig the other slider out and make sure I did the final touches to that or they'll look odd.
Post by: Laverdaroo on September 08, 2022, 07:56:08 PM
Doh, of course.
They're going to be epic Ken, and you said they werent good enough for yours!!! Cant bloody wait to see your creation. That is if you stop spending all your time doing things for other folk, you might get a chance to do some of your own mate. Bless yer  :D ;) :)
Post by: Oddjob on September 08, 2022, 09:00:00 PM
(https://i.postimg.cc/gcC8nzYM/IMG-2815.jpg) (https://postimg.cc/HjtVNC85)
Finished.
Done both the slider and the 2 fork caps, just need to check the other slider now. That's hiding in the loft.
Post by: Laverdaroo on September 08, 2022, 10:54:11 PM
speachless mate, thankyou. :)
Post by: Oddjob on September 09, 2022, 12:36:55 PM
The arrows are still on them, so you know the orientation. Mine have been buffed off as if you ever need to know you can just put them on a flat surface, press down and the rear will always rise up as it's not as deep as the front.
Pic not a great one TBH, took it indoors as it was dark by the time I'd finished. They look much better in natural light.
I've got some stainless studs, washers and nuts for mine along with a stainless drain bolt and of course those stainless seal circlips. New dust seals as well and newly hard chromed fork stanchions. Brand new stainless top nuts as well. Should look pretty good I reckon.
Post by: Laverdaroo on September 10, 2022, 12:09:14 AM
Th stantions I have are rechromed , Ive a new set of internals coming and I have seals, those clips you sent, new exterior bolts, copper washers, gators, seals, studs all OEM and stainless drain bolts, the lot. I even have a new pair of the plastic clips that live on the internals, all in the bags ready to go, with your super effort on the polishing, It WILL be a net set going on 'Mejima' when shes done.
When I get to yours when they coem, I'll strip Simons and build up the new set from your bottoms, hit stansions and new gubbins Ive aquired. As the 'six toed bog hoppers' say down 'ere...........'Proper Job' :D
Nearly forgot, we have those bling top bolts to fit too...............ooo, shiney al the way to the top Ken.....nice ;D 8)
Post by: Oddjob on September 10, 2022, 02:36:02 AM
I’d forgotten about the air and preload caps Roo.
Post by: Laverdaroo on September 10, 2022, 06:27:07 PM
Ha haaa, I must have moved the box about 20 times before I slung them in a parts bin with the rest of the 550stuff and like you, forgot I had them until replying last night ;D
More bling, get in ;D ;D ;D
These forks are really going to be a bit of a cherry on the front end mate, really chuffed. Cheers.
Although I have taken on board everything that everone has said re the gearbox and the assembly, becausei  had the shaft apart changing bearings and the like, that and getting that gear back to front on the output shaft upon assembly, i think thats what's put all the questions and gremlins in my  head on poor selection issues.
This morning I had to bob up to Bryans to pick up that 500 to drop off to Ted later on so I took the motor up with me just to let him have a fiddle and give an appraisal..........For peace of mind and a bit of sanity in all honesty.
Aaaaanyhoo, Bryan gave the poor old girl the thumbs up so I'm hoping to get out and continue the saga tonight and get a bit more done before I leave later this week. Cheers everyone for all the suggestions and humour, all gratefully received. Thanks for the fiddle Bryan, bet you dont hear that too often? ;) :D
Que Phil:................
Post by: SPR on September 10, 2022, 09:18:28 PM
Excellent progress !! And with Bryan's seal of approval :) what more could you want
Post by: Laverdaroo on September 11, 2022, 12:17:53 PM
Deffer's ;D
Just had one of those brain afrts/gremlins that wouldnt go so it was a fortuitous visit and thought I might kill two birds with one stone.
Gremlins erradicated and I even managed to get the rings on the pots last night as a victory dance so I'm going to get the barrels and head on today if I get an elongated spell in the shed of dreams. I know there's a blues session on the radio this arvo so that sounds like a plan.
More later..... ;D
Post by: Laverdaroo on September 12, 2022, 12:52:42 AM
Reasonable day today cleaning bits n bobs, getting prep sorted. I’ve been on and off it all day fitting in other jobs but pleased with progress. Timing tmrw eve(https://uploads.tapatalk-cdn.com/20220911/d91dcb90374614d7cf9d15a0f658b88d.jpg)
 if I get chance, heaps to sort before departure but getting there
Post by: Laverdaroo on September 12, 2022, 12:53:12 AM
(https://uploads.tapatalk-cdn.com/20220911/2f59a106de2132520f800ded8cc36fb6.jpg)
Post by: Laverdaroo on September 12, 2022, 12:58:09 AM
Quick question in prep for wrestling on the cam sprocket…
I had a thin line on the points end of the cam on the 400, I don’t appear to have anything except this notch, I presume that’s the mark is it?
If so, do Ione up the bottom of the notch with the shite face of the top of my head? Would that be the correct way?
Just checking as I can’t find a ref just yet….
Ta(https://uploads.tapatalk-cdn.com/20220911/b636b8d302ee486a8103d8959d920a81.jpg)
Post by: Oddjob on September 12, 2022, 01:07:00 AM
T mark on 1-4 on advance retard mechanism and notch level with head pointing forward
Post by: Bryanj on September 12, 2022, 08:37:42 AM
Middle of notch level with gasket surface in your pic cam needs to rotatebackwards probably 1 tooth on the sprocket
Post by: Laverdaroo on September 12, 2022, 09:34:28 PM
Theres no sprocket on it I just laidthe cam in before I locked up last night and noticed it as shown.
I realosed I should have spun it a bit for the shot but couldnt be bothered to go out again to take another . I havent seen this before so hence the question. I'd asumed that it should sit with the bottom of the notch level with the surface of the head.
Ive not got as far as the A/R mech, that was tonights job but just got home so I think thats torn it for 'ce soir'.
Cheers fellas, I'll set it up if I get a vahnce but realstically I dont think I'm going to get a chance before I leave.
Cheers ;)
Post by: Sesman on September 13, 2022, 07:57:31 AM
Yes, that’s right Roo. Notch parallel to head. You probably won’t be able to get the chain on with the cam in that position though. The trick is to engage the cam wheel on the chain in a guesstimated location then locate one of the two cam bolts. A slow rotation will allow you to locate the 2nd bolt. Then check the the 1:4 timing position and cam slot. You will soon see if you have to step one tooth back or forward. Observe the manual carefully and make sure you start the process with the cam wheel, chain and cam as illustrated…it makes the difference.
Post by: Laverdaroo on September 13, 2022, 07:11:30 PM
spot on Thanks Phil, thats spot on mate. ;) :)
Post by: Laverdaroo on September 17, 2022, 06:18:04 PM
Presents when got here!
Hondaman box for Jezza
Gear selector spacer thingy for Bryanto replace the one he lent me
And this little NOS cracker……get in(https://uploads.tapatalk-cdn.com/20220917/54042b91629bcebaaf29d1cf38a1380b.jpg)
Post by: Nurse Julie on September 17, 2022, 06:26:56 PM
And here's your one that Trig has repaired 😁😁😁
[attachimg=1]
Post by: Laverdaroo on September 17, 2022, 06:29:18 PM
Fantastic, Thanks the pair of you. Happy to have a spare now though and a few bust ones to have a go at when i get home if you n Trigg can help me out with a couple of those tangs also Julie as per email etc.
Well chuffed all round then............having a better week already ;D
Post by: Sesman on September 17, 2022, 06:33:56 PM
What is that please….
Post by: Sesman on September 17, 2022, 06:44:53 PM
Is it the neutral switch contact?
Post by: Nurse Julie on September 17, 2022, 06:56:15 PM
Yes Phil, that's correct.
Post by: Sesman on September 17, 2022, 07:31:14 PM
Thank goodness. When Roo mentioned “gear selection” I nearly fainted wondering what I’d left out.
Post by: Laverdaroo on September 17, 2022, 08:00:57 PM
You get the gist Phil, no gears without it and a bit jet lagged still, couldnt remember wha it was called. Its one of them anyway... 8)
Post by: Sesman on September 17, 2022, 08:11:37 PM
Aye, no problem. I just had one of those heart stoppers, instantaneously developing terminal self doubt.
Hope it’s all going well in gator land.
Post by: Laverdaroo on September 18, 2022, 10:49:15 PM
Hi all,
could anyone measure the outlet at the collector end of the exhaust for me as I'm hoping to get an end can out here and stuff the import tax. Forgot to write it down before I left. OD to OD if poss please.
Mine's and F2 with the swoopy headers that go down the r/h side.
Fanks ;) :)
Post by: McCabe-Thiele (Ted) on September 19, 2022, 09:36:57 AM
Good to read it's not just me that experiences that feeling🫣
Post by: Laverdaroo on September 23, 2022, 03:46:55 PM
Hi all,
has anybody managed to find an alternative to the honda items for fitting the carbs to the motor or is the enclosed part number the preferred method as it's gen parts?
QUite expensive, special order and just wandered if anybody had any good looking alternatives?
Carb to engine, airbox to carb so theres 8 required.
Honda part number:-BAND B. AIR CLEANER *H17256-053-010
Post by: Bryanj on September 23, 2022, 04:18:38 PM
I got some narrow stainless jubilee clips and by the way you have to buy the screw seperate from Honda.
When looking for clips i think you need 7mm wide which can be awkward
Post by: Oddjob on September 23, 2022, 04:54:13 PM
Just to clarify Roo. But the airbox to carb are a different size to the carbs to engine, there are 8 of the later and 4 of the former.
I got quite a few in the boxes when I bought my 2 spare 550 engines recently, not sure what condition they are in and I'm ashamed to say I still haven't got round to setting up my zinc/nickel plating stuff.
How many would you need of each?
I used these when I first rebuild the L reg 500. https://www.stainlessmiddleton.co.uk/34317-extra-narrow-clip-5-16-wide-hose-clamps
They sat in the garage for over 40 years and they still look perfect. They are thin enough not to foul the rubber edges of the manifold rubbers. And they look very smart fitted.
Post by: Bryanj on September 23, 2022, 06:24:32 PM
Have a look at ebay item 402702096350 i used them then cut the extra band off with a dremel, seemed to work ok, narrow enough to fit groove in rubber and shiney enough to please magpies
Post by: Sesman on September 23, 2022, 07:12:16 PM
Try 4into1.com
Post by: Laverdaroo on September 24, 2022, 01:59:18 PM
Morning all,
I have the steel fragon air box to fit so I need the bands that attach from the carb to the air box, the bands that go from carb to rubbers and from the rubbers to the head.
Sorr Ken, I was looking late at night and didnt really explain that well.
Basically I have no clamps/bands of any description as they were all scrap or of dubious origin, condition.
Basically its all 12 that I need ::)
Post by: Laverdaroo on September 24, 2022, 02:06:18 PM
Thats a great website Phil, nice one thanks. I forgot they did all that gubbins..........
Thunking on I actually need just the ones from the carb to the rubbers and the rubbers to the head..........the steel dragon items dont use the bands!
Still on my first coffeem things will improve, I'm sure. 9am and 85 deg...............!
Post by: Laverdaroo on September 24, 2022, 03:39:51 PM
thanks chaps, sorted now ;) 8)
Post by: Laverdaroo on September 25, 2022, 05:47:52 PM
whilst quality and size grading 20k 3" Koi this morning from 05:30 :-\ I had a thought regarding bits and bobs and jobs moving forward when I get home and how to get things prepped/ordered in, ready to hit the ground running etc.
I looked at the state of the points before I left as a bit of torture. After a short intake of breath and a swear I decided that after all this work on the bloody thing, the least I should do is make sure that with all the new electrical items being fitted to the bike, as it never had a loom when I bought it; I should at least replace the grotty points and condensers as a matter of course. The surfaces are very pitted and a gorilla has already been in there with a blacksmith file more commoly used for shaving horses teeth I think, by the look of them and theyre pretty much shagged out.
A surrupticious sneeky peek at the internet at break shows various suppliers, costs and availabilities. Any thoughts?
 I reckon this is going to be a close thing to Mick's Lazarus, taking the trophy for being  Triggers Broom!
I remember reading on here about the dubius quality of condensers and the mine field that is of what's available. I also remember reading that some had some right hassles and I'm keen to avoid hunting for issues so could anyone remember the best source of the condensors as well as the points or is it going to be another cheque to DSS?
He sells various options and as I'm this deep into it sod the cost, do I go for the genuine ones or plump for the aftermarket ones? (wince)  :o
It might be that the condensors are ok and will clean up/ test OK but they are in a shocking state and being 40+ years old I feel that its worth the cost, I'm never going to sell this one, it's a keeper so feel its justified. Whats the general consensus on these without blowing my head off with technical data, I cant handle it after all these fish, and only another 120k to go before next week.
I don't even like Koi   ;D ;D
Post by: Nurse Julie on September 25, 2022, 05:56:05 PM
Opt for genuine/original if you can Roo.
Post by: Laverdaroo on September 25, 2022, 06:54:07 PM
Kinda thought so but  folk find cheaper alternatives that sometimes work better than original and remembering how much time was spent on the subject I thought it best to ask.
Thanks mate ;) :)
Post by: Bryanj on September 25, 2022, 07:17:29 PM
If you are going genuine get the complete plate as a part number, same price from your local dealer as DSS and no postage.
Post by: Bryanj on September 25, 2022, 07:34:00 PM
Part number is 30200300154 and DS is £99 plus drat and postage
Post by: Laverdaroo on September 26, 2022, 01:50:42 AM
presumably thats a supersession Bryan as the number on the fiche at CMSNL shows 30200323005 shown as discontinued.
Good shout though for the sake of 9 quid odd you get a whole new set up. Thanks Bryan thats a great swerve ;)
Post by: SPR on September 26, 2022, 05:28:56 AM
I got the complete plate when swapping mine back to points .... much cheaper way to do it than individual bits
Simon
Post by: Bryanj on September 26, 2022, 06:34:43 AM
Yup, it fits all the fours and have you priced genuine points and condensers recently
Post by: Oddjob on September 26, 2022, 01:02:03 PM
Cheaper in the states as well Roo, plus loads of them about over there.
Post by: Laverdaroo on September 26, 2022, 02:07:19 PM
Where are you looking Ken, I can only find dubious second hand ones over here, I'm struggling to locate a lot of genuine stuff here, for some reason the internet here is not that forthcoming on finding stuff. I had a look last night but found nothing. Who's sites are you looking at? If I could get one over here that would be a right result!
Post by: gary123 on September 26, 2022, 05:04:15 PM
Roo your welcome to any of this if it helps[attachimg=1]
Post by: Oddjob on September 26, 2022, 06:05:46 PM
https://www.ebay.co.uk/itm/165692341638?epid=5014904316&hash=item2694087d86%3Ag%3AfvEAAOSwNudjL6CX&amdata=enc%3AAQAHAAAAoCj7TXC9AjxzOXJVenj%2FKbYwqMk3nLSsQU%2BXHn1AWNDK0gMM3zMcgE1eEoQIDrVTAnZZQYYO%2F500tz0OjWilcTp6znJfm7%2BUVYB%2BIsuPY7Z63WjZnjvJZNLQZPSiMK2BApbFwD9zo7e2RG1Q2N1U6j0JKNvMn6WeJ%2BBqf4sorA694dWI7m%2FM969C74xR4NAUbRLaiJObJ6olNCPGkktxZQo%3D%7Ctkp%3ABk9SR-DO7avvYA&LH_ItemCondition=3
https://www.ebay.co.uk/itm/362392707478?hash=item546049e196%3Ag%3AvT0AAOSw4-1bU6hY&amdata=enc%3AAQAHAAAAoF%2BWIGjutrrdlbyMvA3iO4b243mnIzyVEMY1SHulf1chLxrRDe9q9phNkCdOJ0Z1FDNlWWfIcr87WLZVk4edtNUoUuoh8FpRw76s6KHPXn9hLrXdwiX4H%2FD4OV%2Fo10lUmkTauonKfTgeBtvFRemsm4CdbhHL2xCcBoYRbbmkhe0rzv3IxedNZE20ImStWlN8%2BGhF7lK0fxVubw%2BV%2F%2Fw9BaY%3D%7Ctkp%3ABk9SR-DO7avvYA&LH_ItemCondition=3
https://z1parts.net/ignition-contact-breaker-69-78-honda-cb750-750k-750f/
https://www.ebay.com/itm/383459509623
https://www.ebay.com/itm/155091535787
Took me less than 3 minutes to find those Roo.
Post by: Oddjob on September 26, 2022, 06:08:54 PM
Saying that, 3 are now out of stock. DS has 9 in stock at £118
Post by: Laverdaroo on September 26, 2022, 06:34:18 PM
I was advised to go genuine Ken, so discounted the first one and the rest are more expensive than DSS so discounted them. all the rest were as you say, out of stock. With the pound being the same as the dollar, I might aswell wait until I get home and get one of Mr Silver I reckon. I'm due a  chat with my pal at Revival Cycles in Texas tomorrow so i'll see what he has to offer. Thanks for looking mate, appreciate it as ever.
Post by: Laverdaroo on September 27, 2022, 12:18:29 AM
Roo your welcome to any of this if it helps (Attachment Link)
Cheers Gary, thats real nice of you. I'll have the most complete one If I may? I'll have it as a source of bits as some of the bits on the 400 one I have are a bit shoddy and those of yours wil clean up better than the bits I have for that.
Re the 550,  I have an electrical niggle that says fit brand new to reduce issues later so I think I'm going to go and buy a whole new plate, set up. Just for peace of mind. It seems silly to replace it all and then stick 40 year old electrical parts back on, that I have no history of.
I think I may have nabbed one off the net but waiting for conformation from Canada.
NOS $58...........be rude not to! Let me know how much you'd like and I'll sort it straight away.
Apprciate it Gary, cheers ;) :)
Post by: gary123 on September 27, 2022, 05:34:36 PM
OK Roo, Ill sort it in the morning still got your address. I reckon a couple of quid postage will do it.
Post by: Laverdaroo on September 27, 2022, 07:22:35 PM
You bloody satr, thank smate. Drop me a pm and we can sort it out.
big thanks Gary ;) :)
Post by: Laverdaroo on October 01, 2022, 07:47:29 PM
Ordered me pipe at a whopping £128 saving and the tax!
Bit of an unorthodox choice but in for a penny and all that(https://uploads.tapatalk-cdn.com/20221001/e1482594bb1136c19666a508066b6e3c.jpg)
Post by: heli_madken on October 01, 2022, 11:20:04 PM
You will love the noise a SuperTrapp makes and you can tune it with more or less discs.
I have a set on my CBX and just cant get enough of the noise -
https://youtu.be/UyHSEIxziGw (https://youtu.be/UyHSEIxziGw)
Post by: Laverdaroo on October 01, 2022, 11:26:29 PM
never heard one in the flesh on a 4 cylinderso thought why not!
I want a kerker on the VFR eventually but will have to get something made up for that as not many companies sell after market stuff on any quality. especially not Kerler orthe new interpretation of the brand.
I've ordered a couple of extra rings to help with tuning but we'll see what it looks like when it get here. :D 8)
Youre CBX sounds absolutely superb with those on. Thanks for that.
Post by: Laverdaroo on October 06, 2022, 04:52:28 AM
Right, scored these for $25 today with a view to tickling them up. Absolute bargain I thought.
Has anybody cleaned and revamped a set of these before? I was thinking gloss enamels from the model shop………thoughts?
My tank is having some panels put over where the emblems were as I found some pin holes so to be sure, having them snotted up so I thought once painted, double sided foam tape and jobs s good un. Anybody had a disaster with these or have a really cool way of stripping/painting them(https://uploads.tapatalk-cdn.com/20221006/c1a14bf6fc059ce0f6fdde027dcf8557.jpg)
that I’ve missed?
I was going to start to clean them up whilst here to have something to fiddle with if I get a chance.
Post by: Laverdaroo on October 06, 2022, 04:52:49 AM
(https://uploads.tapatalk-cdn.com/20221006/6c0a74aa2a53a7a1b10daea2dc40fe0e.jpg)
Post by: Matt_Harrington on October 06, 2022, 09:24:47 AM
Roo, never done Honda badges but have done some old Triumph ones that were similar in the way they were made. I thinned down some enamel paint and used a dropper bottle with a very thin tube (like a sawn off hypodermic needle) I then 'filled the area and let the paint level out. I neede to do this a few times as the pain was quite thin but the result was excellent. These were the blunt needles:
https://www.ebay.co.uk/itm/384805344102?hash=item59982f9366:g:uTEAAOSwIlFiQxzz&amdata=enc%3AAQAHAAAA4I00aEZpd96uQWICkzx%2FK%2BDTdi%2FTWPrIFpzaZhwGVm%2BGvhVNMEFGom3hyxyAKL4zquW8oseWPC01%2BMszRkYl52K%2FimeP1EbAj8t75Zb56MA55FIWT8vP1aax5UHC0nQL5Y8qe9Qo2fMMk98zPRIcu6mMA6aP%2F3U2vMJyg3Vec0xTmL6qEcVFf0MORsrfnsrMYrtUN%2FeIL%2B7vXUevEe%2FgmCiUFk8EBv32jgsrCJtIAfH%2BI%2BPAm%2BGDoBMwt6oanay0XBLaVvVryjWsDjr1kZ%2FbAloA4vhBDVmIMkuozC0pS3kV%7Ctkp%3ABFBM1NSexvVg (https://www.ebay.co.uk/itm/384805344102?hash=item59982f9366:g:uTEAAOSwIlFiQxzz&amdata=enc%3AAQAHAAAA4I00aEZpd96uQWICkzx%2FK%2BDTdi%2FTWPrIFpzaZhwGVm%2BGvhVNMEFGom3hyxyAKL4zquW8oseWPC01%2BMszRkYl52K%2FimeP1EbAj8t75Zb56MA55FIWT8vP1aax5UHC0nQL5Y8qe9Qo2fMMk98zPRIcu6mMA6aP%2F3U2vMJyg3Vec0xTmL6qEcVFf0MORsrfnsrMYrtUN%2FeIL%2B7vXUevEe%2FgmCiUFk8EBv32jgsrCJtIAfH%2BI%2BPAm%2BGDoBMwt6oanay0XBLaVvVryjWsDjr1kZ%2FbAloA4vhBDVmIMkuozC0pS3kV%7Ctkp%3ABFBM1NSexvVg)
Post by: Johnny4428 on October 06, 2022, 11:03:42 AM
Nice find Roo! I had a few layers of paint on mine, stripped using acetone and tooth brush. Then sprayed black and hand painted in the white, quite satisfied with results.
Post by: Laverdaroo on October 06, 2022, 01:45:24 PM
Thanks fella's, That was how I was going to do it in my head so youve just confirmed I'm not completely daft ;D. I was considering using cocktail sticks, thin tubes like you get with a can of WD40 or similar but I like the 'needle dropper' idea Matt.
I shall invest in some this very day..................(when Ive finished in teh fish house) ::)
Post by: Sesman on October 06, 2022, 03:01:13 PM
You lucky bastard. Yes, I’ve had a go with very good results. If you come across another pair I’d be greatful . The 550 F2 badges are anodised gold, which are difficult to redecorate . But I’ve refurbed the 500 ones to good effect.
I used Hycote BMW jet black with ford diamond white.
Paint stripper (paramos)
Acetone wash
Black first using dropper method
White using same method
Post by: Laverdaroo on October 06, 2022, 03:29:05 PM
Whats yer budget Phil? and Ill have a butchers later. Got a delivery this morning but mooching this afternoon as its time off well earnt. Tell me how much your happy with and if you need the bits on the back or happy to have em without and glue them on etc......
Post by: Oddjob on October 06, 2022, 03:47:03 PM
The VT1100c arrived today Roo. It needs some parts but I suppose it will be fine to leave that until you're there again. Trouble is describing some of the parts is probably harder than finding them.
Post by: Sesman on October 06, 2022, 08:04:13 PM
Cheers Roo. $50 bucks if they are in good nick with no gouges and have the fixing nipples intact. Bet you can’t find any…😀
Post by: Laverdaroo on October 06, 2022, 10:28:09 PM
Challenge on! 8)
Post by: gary123 on October 07, 2022, 12:11:36 PM
Hi roo-any chance you could sniff out a rear brake pedal return spring.
Post by: Oddjob on October 07, 2022, 02:23:37 PM
500 or 550 Gary as they are very different. 500 ones are easy to find as a rule.
Post by: Laverdaroo on October 07, 2022, 03:12:41 PM
Gary, I think youve more chance of knitting fog tbh. I had to make one for mine as i couldnt find one anywhere. I'm sending a list up to the chaps up teh scrappers today, soon  as i hear I'll let you know but like I say dont hold your breath buddy, theyre like hens teeth.
Look at the state of the one I took off mine earlier in the thread and what I managed to cobble together from one off a different model. It was the bet I could do.
Someone else might have a good shout for an aleternative I struggled like hell to get one hence the creative manufacture in the shed.
Post by: Oddjob on October 07, 2022, 03:17:48 PM
Yours is a 550 though Roo, much harder to find. 500s are a lot easier.
Post by: Laverdaroo on October 07, 2022, 03:22:50 PM
I’ll shut up then, forgot it was a 500
I’ll add it to the list Gary
Post by: Laverdaroo on October 09, 2022, 05:31:15 PM
First pass with some orange good was given over here by a pal. Told to wear glasses………………..yer think?
They were only in there for 10 mins and back to metal. Not bad for a first pass!
Especially as I only had to rinse it off with hot water and zero scrubbing/shuffling about.
Gotta decent pile going but running out of weight limit, basically, I’m leaving a pair of trainers here and two pairs of knackered jeans to make the weight limit in my suitcase.  I brought stuff out here that was bin it’s last legs so I could leave it when it was time to leave
Scrap yard next week………..exciting! A day rummaging about in a dank field, can’t wait
Those that have requested stuff,l’ll do-my best(https://uploads.tapatalk-cdn.com/20221009/104af33c10f27676aed5cb19fd464a5c.jpg)
Post by: Laverdaroo on October 09, 2022, 05:31:44 PM
(https://uploads.tapatalk-cdn.com/20221009/91ce093515c18b69fc2d0acacf4e19d2.jpg)
Post by: Laverdaroo on October 09, 2022, 06:20:42 PM
I still havent learnt to spell check so just deal with it,......It's me OK? ;D 8)
Post by: Bryanj on October 09, 2022, 07:03:51 PM
Is that contact breaker box the complete plate or just points?  The Yanks hate Daichi because of quality problems BUT if its 10yr old old stock its probably ok as they were better then
Post by: McCabe-Thiele (Ted) on October 09, 2022, 07:05:06 PM
You might have noticed Roo most of my posts are later amended in the futile attempt to defeat my phone's predictive text. I can't spell check on this site either.
Post by: Laverdaroo on October 09, 2022, 08:34:06 PM
I dont know if its period it has a white/very light grey wire covering. The chap had them advertised for over a hundred dollars but i t's the complete plate, condensers, points the lot. The seller came back to me and made me an offer so in the end with Fedex milking it dry, it came to about £60...............bit of a result I thought.
Ken poked it my way on a PM as something he'd stumbled over looking as we do, for other folk, so sent the seller a message but the seller said he didnt have any and that they were listed incorrectly. A week later he contacted me to say he'd found one and did I want it cheap?.......Pope's and silly hats were mentioned and I nabbed it.
The spares I've been sent by Gary will go to make a new, 'refurb' one that can be in the stash for others or indeed for something I'm pondering on at the minute. Either way they wont get wasted and will get a good 'nannying' in the burrow of dreams at teh end of the garden and should deffo either help me out or somebody else on the forum for minimum fuss and zero cost.
Post by: Laverdaroo on October 09, 2022, 08:36:40 PM
(https://uploads.tapatalk-cdn.com/20221009/24164d9449b57b82c57036dde01ea7ac.jpg)
Post by: Laverdaroo on October 09, 2022, 08:40:08 PM
No doubt it's one of the crap ones Bryan and I've bought a pile of crap ;D ;D ;D ;D ;D
Ted, you're amongst good company, and besides, ther's nothing like a good 'triping' error
Post by: McCabe-Thiele (Ted) on October 09, 2022, 08:43:00 PM
Just take care not to end with kisses.xxx
Post by: SPR on October 09, 2022, 09:00:36 PM
Those badges will end up looking great !!
Simon
Post by: Bryanj on October 09, 2022, 09:09:28 PM
Roo, worth it for that mate and way easier than changing all the bits
Post by: Laverdaroo on October 09, 2022, 09:15:10 PM
Thats what I thought. Is it a crap one then, the box looks quite new. Just so I know ;D ;D ;D ;D ;D ;D ;D
Post by: Laverdaroo on October 09, 2022, 09:16:08 PM
But you said you didnt mind Ted  xxxx
Post by: McCabe-Thiele (Ted) on October 09, 2022, 09:27:38 PM
I thought we agreed to keep the love that dare not speak it's name secret. 😤😤😤
Post by: Bryanj on October 09, 2022, 10:00:14 PM
Cant tell for certain mate, looks same as the one i bought 18yrs ago
Post by: Laverdaroo on October 09, 2022, 10:51:47 PM
 ;D ;D ;D ;D ;D ;D ;D ;D ;D yer smoothy Ted ;)
Post by: Laverdaroo on October 09, 2022, 10:52:31 PM
ha haa, that'll do for me Bryan 8) ;) :D
Post by: Oddjob on October 11, 2022, 04:17:31 PM
I think you may be sitting on a fortune Roo. Just spotted this today.
https://www.ebay.co.uk/itm/284998196832?epid=1153295322&hash=item425b375e60:g:kKQAAOSwRmFjRX~i&amdata=enc%3AAQAHAAAAoCF41te4AtLanesbhirQn8DzE9A5039lNKgXWvAs9OMKW47H%2FGKmfzHea5a3vs8FkfVGtCl73KwIm2UxiJRF7SatOfMMPFUHZSh3CJ%2FEy5OCWHk%2FTU%2Fk4ZYcpLM7hz9DLdLoegow4VAdz1Mkmk5YJjyHbP%2BIc2PqVKtmMNiYldwqT1Q7lrLCDtfinOK09zSouz28YKcq3qMhr7RgWXdql34%3D%7Ctkp%3ABk9SR7yAy_n4YA
Post by: Laverdaroo on October 11, 2022, 06:51:41 PM
Holy sh1t balls batman!
Ill tryand find  a few more! ;)
Post by: Seabeowner on October 11, 2022, 07:13:08 PM
You thought the tray price was high, but little chance of finding these:
https://www.ebay.co.uk/itm/284589804909?epid=1752725869&hash=item4242dfcd6d:g:9qsAAOSw4sRhz1Dm&amdata=enc%3AAQAHAAAAoDIm6eG%2BXHERrjaMqlgOZPdMQh1MOfhNpUHpJEhWTCGALXucHryk7QuV9vwnfZGj2MHVynlS6LhnMcYXIC3iM1EGRnKYmnqzKP5eCrFhDpA4eeswhG5Q4cofT5UmCDMRdrgzYkEhJIC12tMCRIbUXwogSyjqvqZv1yinlr3EKJMQIHmh3ZOwUGTz%2BPnl0ROw4cCF8ABt2ELJ0qbk%2F0cQzxE%3D%7Ctkp%3ABk9SR96bwYP5YA
And he sold one for the same price in September (but it was in better condition)!
Post by: Oddjob on October 11, 2022, 08:04:03 PM
Trigger had some of those made the other year. I have one that's not used as I'm going to fit spade fuses. Might sell it now.
Post by: Laverdaroo on October 11, 2022, 08:07:50 PM
I've got four! 8)
Post by: gary123 on October 11, 2022, 08:16:56 PM
I've got four! 8)
Oh your just showing off now, I had two, but chucked one away  :'(
Why dont the emoji thingys work for me
Post by: Laverdaroo on October 11, 2022, 08:24:47 PM
Folk must be bonkers to pay that money!
Nice one Gary ;D
Post by: gary123 on October 27, 2022, 01:01:37 PM
[attachimg=1][attachimg=2]
Post by: Oddjob on October 27, 2022, 02:42:50 PM
Reason for the pic Gary?
Ones a 550 rear brake plate and the other (right) is a 500 one.
I'd be interested in the sprocket chain plates if they are for sale.
The bearing retainer looks past it, I'd throw that away if it was me.
Post by: gary123 on October 27, 2022, 03:31:21 PM
Sorry ken I forgot about an explanation of the pics. They will make sense to Roo, I cant send pics via pm.
Hes got first dibs on the parts. If he doesnt want them Ill let you know.
Post by: Laverdaroo on October 27, 2022, 04:08:35 PM
Wicked, Nice one Gary,
Can I have the 550 brake plate and the sprocket guard please?
Ken,
 Which one of thos is the sprocket carrier for the 550 hub, is there a way to tell without manhandling them, I have one that fits but its off what  I think is a 500 hub that I bought as a job lot but ideally want the right one so that when I put my finished piccies up on here in the next century, you lot of vultures wont pull it to bits on wrong parts and take the piss? ;D ;D :o ;)
Post by: Oddjob on October 27, 2022, 08:23:25 PM
Only one sprocket carrier in that pic Roo, bottom right. Same as 500 though. The chain guard is also the same. The hub is different from the 500 as is the brake plate and the sprocket spacer and the rear brake spacer.
The brake plate on the left looks like a 550F one Roo, in case you need one.
Post by: Laverdaroo on October 27, 2022, 08:44:17 PM
I'm buying that one you refer to.  I thought I had one in the bundle of gubbins I bought  but it appears to be for a 500 and obviously wont fit. Hence the shout to Gary to see what he had.
Post by: Laverdaroo on October 28, 2022, 01:27:41 AM
Right, so clutch question,
In the middle of the steels there is a big, fat ,almost double steel as indicated on the parts diagram but on all the vidoes I've seen of replacing these cltcheson the 550,  they dont have them, is that because mine's and F2 and not a K?
It's not very clear from the parts manual as to whats what but if I reassemble in the order it came out I should be right? Right?
I diidnt take much notice upon taking it apart as it came out as one, glued together lump which was hastily zipped up in a bag and put in the nanny pile. It' only upon starting on that side of the motor I saw it and had to have a gander at the parts book.
Not seen one of these thick jobs before, whats the crack there then?
I'm sorted with the one big tooothed friction plate just not seen one of these before.
Post by: Bryanj on October 28, 2022, 04:07:28 AM
Its there to try and stop clutch rattle, actually a gl1000 part. The top fibre plate should have wider "tangs" to fit in wider grooves in the basket. Later clutches are like it
Post by: Laverdaroo on October 28, 2022, 09:35:55 AM
Thanks Bryan,
Yes I know about the wider tangs and its position, just not seen one of these before and watching a lot of how to vids and the like, I haven't seen anybody else with one in their clutch set up. Just got me interested enough to ask the question. Thanks Bryan.
Post by: Laverdaroo on October 29, 2022, 01:32:44 AM
Could anybody point me in the right direction of a good JIS screw supplier for the engine covers or should I be asking Julie?
A complete set preferably.
Not into the Allen key type so after a nice shiny set of the JIS ones.
Phanks in advance
Post by: SPR on October 29, 2022, 07:31:40 AM
I got mine from here
https://www.zed-parts.com/j-i-s-fasteners
Simon
Post by: Bryanj on October 29, 2022, 07:40:21 AM
I think Silvers does cover sets
Post by: Laverdaroo on October 29, 2022, 12:47:06 PM
Sorted, thanks chaps 8)
Post by: Laverdaroo on October 31, 2022, 03:00:50 AM
Interesting cleaning tonight, just getting bagged bits sorted for fitting and some I left in their own grease to be fettled prior to fitting.
I’m starting to sort the twin disc conversion sorted now I’ve got my rims back and was cleaning the drive gear from the front hub and found that the previous owner had kindly run a razor blade round the centre!
Why on earth would anybody do that. It now means I’m on the hunt fir one of these now. I’ve found one in the states typically and one in Japan. I’ll have to bob up a desperately seeking but if anyones got one could I relieve you of it?(https://uploads.tapatalk-cdn.com/20221031/72642db14b1b886a22f44bfd8e0582e3.jpg)
Post by: Laverdaroo on October 31, 2022, 03:01:33 AM
(https://uploads.tapatalk-cdn.com/20221031/a94d5d6fcc7bd1d5a20239d3ccff5f6a.jpg)
Number 8
Post by: Laverdaroo on October 31, 2022, 03:02:52 AM
(https://uploads.tapatalk-cdn.com/20221031/ac5e4c78f367b4ed3b19f4bf2f9e5be0.jpg)
Post by: Oddjob on October 31, 2022, 09:35:59 AM
I had one but gave it to Sesman for his twin conversion.
Post by: Bryanj on October 31, 2022, 09:45:18 AM
You dont want one of the originals for a twin disc, it needs modifying, email me or ring me tonight or tomorrow(away after that)
Post by: Laverdaroo on October 31, 2022, 10:56:51 AM
will do Bryan, cheers mate.
Post by: Sesman on October 31, 2022, 11:06:18 AM
And very grateful I was too. I know you will be onto it Roo, but take great care when modifying the Speedo drive, particularly with centralising, alignment and countersunk screws. I presume you have read the notes in Aladdin’s Cave?
Post by: Oddjob on October 31, 2022, 11:44:20 AM
Here's how I did it Roo.
Remove all parts of the dish the drive sits on, so it's totally flat, I ground most of it away and finished it off by using grinding paste on a piece of glass to ensure it was totally flat. Drill 2 x 3mm small holes in the flange of the dish, where you'd be expected to fit the screws. Next, fit the drive into the speedo drive and put that onto the spindle, fit the spindle into the wheel and press the speedo drive up against the wheel so that the flat part of the modified plate sits flush against the hub, keep pressing against the dish whilst removing the spindle and drive, care needed here to ensure it doesn't move. Mark through the holes with a felt tip so you know where to drill, drill and tap the holes, depending on space either 4 or 5mm. Tap holes and countersink the dish holes, fit with countersunk screws. Fit spindle and drive and test off the bike to ensure it a smooth run out. Doing it this way ensures the drive plate is central to the speedo drive. You may need to reduce the size of the dish to make sure it fits inside the disc, I had to do that so I presume you will to.
Post by: Laverdaroo on October 31, 2022, 11:45:08 AM
Yean phil, just had a recap but in all honesty I wont start anything until I have all the right kit. This was jaut the first 'kick in the pants' and i was only cleaning ;D Keeps my average up though, which is good ;D
I know Bryan mentioned to me before that there were errors in the wright up in the drop box and was going to bell him but was after the right bits after finding that cock up. I was awaer there was a differing way of doing this and after a yap tonight that should become apparent, we did speak about it a while ago and I really cant remember.
The 'flange' of a previous owner  cut it out and then glued it back together. The piccie of it 'as removed' from the hub gives you no clue as to it being ruined. It was only after cleaning it and it falling apart that I 'twigged'that it had been got at by an absolute arse!.
Post by: Sesman on October 31, 2022, 12:07:44 PM
I did it the second time exactly as Ken has written…..success.
Post by: Laverdaroo on October 31, 2022, 12:15:10 PM
Things moving on in the shed of dreams although this week has seen it renamed the shed of “really??!”
After various discoveries from Bridgett I the past I’ve actually started to progress!
Frame is due back from the powder fosters on a week or so, got my rims back all sorted and the front hub has seen some action so cleaning fettling and generally grabbing fixings and replacement for shagged parts and the like. It’s going reasonably well even considering the new discoveries so can’t grumble too much.
The engine is about thete Barca few cover bits and a ball bearing and springfor the kick start but they should be here by the end of the week with any luck. Reasonably chuffed tbh.
Tank to ‘un-dent’ and solder up, liner to order and that can get dropped off for paint with the side panels and I’ll get cracking on the front wheel conversion.
Just sent the pipes off for chrome at a whopping £250 so I await them coming back to see how they look, they’re not the best set but the best I could find got what fish I had, we’ll see.
Thoroughly enjoying my time though which is what it’s all about(https://uploads.tapatalk-cdn.com/20221031/221e45c2822a51005c257f24fcac64ba.jpg)
Post by: Laverdaroo on October 31, 2022, 12:17:38 PM
(https://uploads.tapatalk-cdn.com/20221031/3d712e538c237813512ba5053229d355.jpg)
Post by: Laverdaroo on October 31, 2022, 12:18:38 PM
That looks the part Phil ;) :)
Post by: Oddjob on October 31, 2022, 12:19:57 PM
You'll need the clutch shims to shim the clutch basket out Roo, they'll be in the post today.
Post by: Oddjob on October 31, 2022, 12:22:52 PM
That looks really good Phil, love the tyre, might go for those when I get round to buying some, which will be some time yet I'm afraid. So long as they make them in the sizes I want of course. I'll be going for 100/90x19 front and 110/90x18 rear IIRC. I've got wider rims than standard so I can use wider tyres.
Post by: Laverdaroo on October 31, 2022, 12:24:54 PM
Yeah, just a mock up so Icould have alook.The old shim was 0.3 and it deffocould do with a bit more to be solid. Having not shimmed these up before, I take iyt that there shouldnt be any lateral 'wobble' abd a direct, 'firm' fit?
Post by: Laverdaroo on October 31, 2022, 12:29:04 PM
I bobbed those on the 400, always liked these, theyre great on the road and pretty good in the wet too. Not over dear either which makes a change. Buy em after crimbo Len, theyll be cheaper by about 20 quid each in some cases as the raw, cost rubber price drops after December each year. I saved £40 on a set last year which is practically unheard of as there is so little mark up on tyres as it is.
Looks proper that Phil ;)
Post by: Laverdaroo on October 31, 2022, 12:29:46 PM
Ken not Len!  ::)
Post by: Sesman on October 31, 2022, 12:33:52 PM
That’s coming along Roo. Stay with it.
Thanks Ken. Some photos of the finished article. Still got to fit the brake hoses and a brake hose clip/ restraint to the r/h fork leg….bit of a head scratcher. These are old photos as the bike is finished, with the exception of a seat and brake hoses. 550 F2 seats seem to be very thin on the ground!
Post by: Oddjob on October 31, 2022, 12:38:08 PM
Just try and pull the basket out without the springs fitted, so just after you fit the circlip, if it moves it needs shimming, I tend fit shims until I can just about fit the circlip on. Easier on the 500 as it's designed slightly differently.
You need the proper chrome countersunk screws for the points cover Roo, they didn't use those type of JIS screws for that cover  :o :o :o
If you haven't got any yet don't buy them as I may have some NOS as I don't think I'll be using the chrome cover on mine, found a NOS 650 cover instead which I intend to polish up, not sure what screws or bolts it uses to attach itself but I'd imagine the normal 8mm headed flanged bolts Honda love to use. If so my NOS screws are available.
Post by: Oddjob on October 31, 2022, 12:38:59 PM
How'd those new springs work out on the brake calipers Phil?
Post by: Sesman on October 31, 2022, 12:40:05 PM
That’s what I fitted Ken. I went for the slightly wider rear end to comply with the tyre fitment guide.
Here’s another photo  nearer to completion. It’s now got the rechromed fork ears, grab rail etc on now. I’ll take some final photos when I’ve sorted the seat and hoses.
Won’t be before Xmas though.
Post by: Laverdaroo on October 31, 2022, 12:40:15 PM
Ny pal has a few bases in the states and I can get them sent over cheaper through the fish farm if it helps Phil? He mentioned he had a few if youre struggling mate I can have a chat with him. I'm having a par el sent over in a coupleof weeks so could tag it in? Is it he base youd settle for or the whole seat to fiddle with?
Post by: Oddjob on October 31, 2022, 12:41:28 PM
No chain guard yet Phil?
Post by: Sesman on October 31, 2022, 12:42:24 PM
Springs worked just fine thanks Ken.
Post by: Laverdaroo on October 31, 2022, 12:45:31 PM
They're purely for show at the minute Ken, Ive rederedall the right fixings for it, thats all I had in the workshop at the time. I'll just swap em over when the new hardware comes in.
All my cases needed new fixings as they were all hammered. Just wanted another part off the bench so bobbed it on. the sprocket cover has only two in it of dubious quality just to get the wire routes right behind the cover as i had to re wrap them all and fix a break in the green cable from the windings, I've none at all for the clutch cover theyre that bad so ordered a complete set to look puuurty! ;D
. Cheers for the offer though mate.
Post by: Sesman on October 31, 2022, 12:45:51 PM
Yes, chain guard and rear mudguard have been rechromed and fitted. I’ve fired the engine and it runs mighty fine. I’ve even been round the block….slowly. Just the seat and hoses to source and fit.
Roo, if you can source a seat pan in very good nick at a reasonable price I’d be ecstatic.
Post by: Laverdaroo on October 31, 2022, 12:46:59 PM
Love that build Phil,beautiful from front to back, super impressed ;)
Post by: Sesman on October 31, 2022, 12:47:54 PM
Roo, are you still puzzling over the Clutch metal inner plate, or have you sorted. I mention it simply because I have my clutch cover off for polishing and shimming.
Post by: Laverdaroo on October 31, 2022, 12:48:02 PM
Yours an F2 Phil? (showing my model ignorance)
Post by: Sesman on October 31, 2022, 12:50:06 PM
Yes, 1977 F2. Roo, I’m sure you are aware that the F2 seat pan is unique?
Post by: Laverdaroo on October 31, 2022, 12:57:52 PM
No, sorted, I think. Bryan mentioned it was a gold or silverwing 'absorbsion' apparently, taken from their set ups. I can see it in the parts book but the doubt set in when looking on Youtube amongst other sources, I couldnt see the same steel in any I saw making me wonder if this was another cock up by the PO. Not seen it before, its almost like, as I understand it, a  'clutch cush drive' without the rubber..... type thing. Odd thing. I presume it acts a bit like a dual mass fly wheel on the VW's taking up someof the slack before total engagement? I think thats what I understood from Bryan.
The steels were in a shocking state and were 'steeped' in rustoleum for a coupleof days before going on the brass wire wheel to tart up.  Thebits left in the oild were a right manky mess and stained really badly a nasty brown and a couple had to be poked apart from the old friction plates or what was lleft of them.
They came out surprisingly well and none twisted or out of tolerance on the glass with the feelers and verniers. A leg up for once as this has been one hell of an expensive build, nice to have a bit of a break for once :)
Post by: Sesman on October 31, 2022, 12:58:05 PM
Sorry to hijack your thread Roo. One chain guard for Ken and one knackered F2 seat pan for you.
Post by: Laverdaroo on October 31, 2022, 12:58:21 PM
Yup, neem there!!! ;D ;D
Post by: Laverdaroo on October 31, 2022, 12:59:47 PM
Sound, I'm off as my mind to finger skill is obviously going down hill looking at my spolling! ;D
I'll send out an APB accross the pond.......
Post by: Sesman on October 31, 2022, 12:59:56 PM
Ok, glad your clutch has worked out. I won’t bother stripping mine.👍
Post by: Laverdaroo on October 31, 2022, 01:01:20 PM
Just quickly though, that guard is nice, I picked up mine from the chromers the other day with the lamp ears, I'll bob a shot up later, tell me  what you reckon. Thumbs up/dowm.
Post by: Oddjob on October 31, 2022, 01:09:25 PM
That seat pan would sell on Ebay, just list it as a barn find and it will sell.
Need some nice stainless bolts for the guard Phil.
Post by: Laverdaroo on October 31, 2022, 03:14:36 PM
Well, after getting a little excited about opportunities in the show n tell chat of recent chrome fitting et on here I was going to say ….. look, look, look at mine, go on, look……. But under close inspection it’s crap and after a brief call to the player today, I have an appointment with them tomorrow for a chat. They’ve got my pipes so I’m not pressing the go button to have them done if this is what’s going to happen.
Is it me or am I being piccy?
I asked when I dropped them off if the putting was reversible and could they do it.
Also, on the clutch cover there’s staining still and shit in the corners so having a mild tantrum and taking that back too!(https://uploads.tapatalk-cdn.com/20221031/cba2c7ba4d576b0ae83b463b2ccee54a.jpg)
Post by: Laverdaroo on October 31, 2022, 03:15:15 PM
(https://uploads.tapatalk-cdn.com/20221031/8acba09f3320889dc3b19567b5f757ab.jpg)
Post by: Laverdaroo on October 31, 2022, 03:20:13 PM
(https://uploads.tapatalk-cdn.com/20221031/df26438f17bff88ecd8a56e17cd122cc.jpg)
Post by: Laverdaroo on October 31, 2022, 03:20:39 PM
(https://uploads.tapatalk-cdn.com/20221031/269dddf85ed57344fa16215055f1fd9b.jpg)
Post by: Laverdaroo on October 31, 2022, 03:21:37 PM
However, the kickstart’s nice(https://uploads.tapatalk-cdn.com/20221031/148c62a33c8e09f871ea99ebbfa9ddb8.jpg)
Post by: Laverdaroo on October 31, 2022, 03:22:23 PM
And the brake pedal, so they can do it if they try!(https://uploads.tapatalk-cdn.com/20221031/eefec1dc922ce034ff63f9d1dd7c37d7.jpg)
Post by: Sesman on October 31, 2022, 04:02:35 PM
Mmmm. I’d suggest poor prep on the chain guard and ears. The kick and brake look nice, much easier to prep of course. Ken is a miles better judge on these things if I’m honest.
Obviously fork ears are difficult to detail and mudguards need the most work.
Difficult call here, but I’d expect better attention to detail.
Post by: Laverdaroo on October 31, 2022, 04:58:22 PM
The fact that theyve managed to get it right in other places on teh same peice means tey can do it so I'm not that impressed. The whole point of paying for it to be done is because I dont reallyhave the kit, nor wish to do it. That clutch cover just needs more work. I'mnot being fobbed off, I spent a few quid there.
I cant do bikes to the same standard  as you guys, or type but I thought that was crap tbh
Ipaid them to do it,m they havent done it, so it again! simple really. Thats what I expected.
Post by: Oddjob on October 31, 2022, 05:58:09 PM
The chroming is about average TBH, well not average, maybe below average but TBH it's what to expect from such old parts. The back of the ear is like that because A. It was never polished beforehand, and B. They are generally rusty as hell in that area. The bit's around the welds, again because there was surface rust in those areas and they just haven't the time ort the tools to get rid of it. That's why I tend to do my own prep these days.
Chain guard, pin prick holes in the old chrome, which TBH the chain guard never got on the reverse side, unless you get rid of these pin prick holes any subsequent chroming will just plate over them but sink, meaning the chrome looks like it has a rash. Only real way to get rid of them is to sand the surface flat or grind it flat then sand the grinding marks out, as the metal isn't all that thick they tend not to try it as the tools they use, like a Linishing machine, will just hole the metal and then it's junk.
Solid, thick metal, like the kick start and brake pedal however can take the linishing, hence why they turned out ok.
Clutch casing, now that's poor, they seem to think that because there buffing mops can't get into those places you can't see them, and they didn't get rid of the oil contamination beforehand hence the rash like effect. Plus the finish is frankly bloody awful, they are supposed to get it to a mirror finish and that's not even close.
Post by: Laverdaroo on October 31, 2022, 06:08:40 PM
That's what I thought Ken, Its been made to look shiney and that's it. I spoke to them re the chain guard and said would they over plate it in copper after finishing to get rid of the pin pricks and they said no problem, so to get them back like that is a bit much!
Worst case scenario is that I put the chain tension sticker over them to hide them. Like you say, the backs fine, just not the front.
I was told all the finishing before plating would be done in house and due to the amount of metal left shouldnt be a problem. I'm familiar with the process and what's possible, I just thought it had been whipped in and whipped out to shuffle it out the door. I was expecting and was told to..expect a better finish than that. The rotor cover and sprocket cover are similar under scrutiny  so I'm taking it off and taking it back I think. I'll keep you posted as tohow things develop.
Post by: Oddjob on October 31, 2022, 06:19:03 PM
I've got a few CB550 clutch covers when I bought the job lot, maybe 3 or 4, not sure. I was thinking of removing all the parts, lifter arm etc and zinc/nickel plate these, polish the casings up to my usual finish and bung em on Ebay, they are no good to me as mines a 500 engine and uses a different casing so it will get them off my hands and at the same time pay for the cost of buying all these parts. What you reckon, I have a sprocket cover as well, just 1 but I may be using that when I do the hydraulic clutch conversion on my 500, not sure yet. I also have a rotor casing but it's been down the road and I was toying with the idea of seeing if I could salvage it, just for a laugh. It's in pretty bad shape, some deep gouges but I like a challenge.
Take one of the new sliders with you and tell them you want your covers to at least match that finish, which TBH isn't my best work even though you'll be more than happy with it I reckon.
Post by: Laverdaroo on October 31, 2022, 06:52:25 PM
From what Ive seen Ken, my tin plate is not a patch on anything I've seen you do.  Ive paid for this lot so  getting it right by hookor by crook!
Iwas going to take one as a matter of course toshow them what a job is supposed to look like!! 8)
Post by: Laverdaroo on November 01, 2022, 02:52:41 PM
I had some post today, cheers for the wheel stuff Gary, its already apart and in the dishwasher. I also had a box from Ken!
Ive never had to put a pair of sunglasses on to open a box up. BLOODY HELL! :o 8)
Not blowing smoke up anybodies arse here but I have NEVER seen anything polished as good as that!
 Ken, you have a  problem mate ;D ;D ;D.
To give a fair indication of how good they are, I took my bits and pieces back down to the polishers and platers this arvo. We spoke about the chroming and they tried to talk their way out of it saying, "Oh, thats in the metal and we cant clean that" I pointed out that they had done ok on the reverse side so what happened to the front then, get bored? Then it was because they couldn't de grease them and that wasnt their issue either.......I politely asked for an adult!
 Throughout the entire conversation I was being TOLD rather than talked to about an issue but was having none of it, I really had to dig in and not budge. I then said, thinking I'd change the conversation over and blindside him with the clutch cover.  He picked up the clutch cover and asked why I was complaining, I talked him through the staining and the soap left on them where they hadnt even been cleaned, the scratches and uneven finish etc etc. At this point the chap was getting a bit 'argey' starting to sigh and then put everything down on the table and asked what was I expecting as the clutch cover was 40+ years old and the finish they had done was good for metal of that vintage?
It was clear he thought I was being awkward.................it was this moment that I brought my secret weapon out..... 8)
I went back into my rucksack and brought out Kens fork sliders that I recieved this morning,  I asked him to unwrap them and before he could stop himself he said, "Oh, they're nice"   I said,"see these, thats what polished metal looks like and they're of the same vintage if not older than the clutch cover!"  He said nothing and went into the factory to get the gaffa out who was a lovely fella but already i could see he was on the back foot and in apology mode so I knew it was game on for a win, he asked where I had them done (which I didnt reveal)
His next line was simply, "Yep ,Mr Newby, I'll have thoses redone for you, I'll do the quality check myself and they'll be ready by the end of the week".
I wasnt smug but thanked him and then went back to the van for a silent 'whoop'  with the dog and a rollie................. 8)
Cheers Ken, theres SOME work gonei nto those, thangyou mate they're bloody awesome. I'll bob some pics up later
Post by: McCabe-Thiele (Ted) on November 01, 2022, 03:03:21 PM
Good result Roo - it pays to persevere & keep your cool.
Title: Re: 550 F2 started!
Post by: Oddjob on November 01, 2022, 03:07:34 PM
I'm not being smug or anything here Roo but honestly I wasn't that happy with them. There were still a couple of pinprick holes I spotted when doing the final polish and of course the area where I couldn't remove the casting fault. In fact they were such a disappointment that I bought a new pair of forks just for the sliders as I wasn't going to fit them on my bike, not saying you've got second best Roo, just that my pride wouldn't accept they weren't as good as I visualised them to be when starting off.
I was intending to either bin them for scrap or have them powder coated, only the fact that you were after a pair made me go back to them and finish them off. I've still got my second pair to polish, they are flatted and ready to do that and then I've got another pair that were originally chromed, those could be hard work if any of the nickel plate is still left on them after stripping.
Been looking at buying some spare camshaft end covers like I did for Simon, I may do a few pairs and sell them on but TBH they ain't cheap to buy, around £25 if average and some up to £40 if they are even half decent. I'm sure you could buy a couple of NOS ones for cheaper than that.
Glad to see they came in handy.
Post by: Laverdaroo on November 01, 2022, 03:14:30 PM
Well hopefully nobody will be looking at my bike with a microscope except you it seems Ken so I'm absolutely over the bloody moon with them.For me they are perfect and set the bar really high for the rest of the visible metal on the bike!
Thanks mate 8)
Post by: Oddjob on November 01, 2022, 03:26:17 PM
Just spotted a NOS camshaft end cover on Ebay £96 bloody hell what's the world coming to, that's obscene.
Glad you're happy with them, now get them built up and matched with your new hard chromed stanchions etc and they should look even better, the black fork caps etc should make the sliders even brighter by comparison. Oh and don't forget the new adjustable fork caps, I'm going to polish mine  ;D ;D ;D ;D
Post by: Laverdaroo on November 01, 2022, 04:00:23 PM
I'm going to get everything out to have a look at with a view to starting on the forks. I have the lump to finish first but as soon as that's done its gonna be the forks I think. It's alright Ian getting all happy in Orkney about his new toy and being like a kid at christmas, it's been commented on that and I've been accused of humming!!! I must be pleased ;D
£96!!! you could probably cast one for that couldnt you?  ;D Bloody hell thats extortionate!
I've stopped looking for replaceent stuff unless its actually knackered. It's just too expensive and I figure my time in the shed is free so nanny them up rather than part with your hard earned cash for them. Yes, I'm tight but thats only cos we only have a small pot rather than a big pot to pee in here, I'm from 'Oop Norf' as they say down here and I think folk are just robbing others of their cash for parts that were as easy to find but cheaper last year. I know the restoration thing is big and that parts that are as rare as unicorn poo are worth the money, reference James's stunning Police bike but £96 is an utter joke. Some bugger will buy them though, you know it!
Post by: Oddjob on November 01, 2022, 04:32:11 PM
Worst of it was is that even at that price it was damaged, as you say though, someone will buy it.
I think that as soon as my current project is finished I'll sell all my NOS parts, should get me enough to get my driveway done, the prices they are quoting now are ridiculous, last quote was £12000. I know it's a big garden but I was getting quoted £3000 just a few years ago and I passed on the offer.
Post by: Laverdaroo on November 01, 2022, 04:41:39 PM
Bloody hell, thats dear, what do you want putting down, gold bricks? :D
I used to like doing block pavia's, I used to get right into those jobs. Not done one for a while, last one was 114 square meters. Looked the boss but took  a bit of doing on my own. Mashed it out in a week but I was dead for a few days after.
I've bobbed some dosh over tp you mate, should be in yer account as I badly type ;)
Post by: Oddjob on November 01, 2022, 07:17:34 PM
I decided after much debate to go for impressed concrete as most of the other methods had more cons than pros except for resin and that was out of my price range.
I'll wait till next year in the hope prices will drop.
Post by: Laverdaroo on November 01, 2022, 07:32:21 PM
Top choice although depending on impression, can be really skippy. 12k is an awful lot. Especially as it’s basically a pour with a giant potatoe shape pushed into it. Ok I’m the moulds are dear but from 3 to 12 is quite a hike.
I think I’d hang on too. Anyway you never know, Putin might zap us all yer
See, saved you a load of cash already
With it all laid out, I think I’ve a busy couple of days ahead of me, and some plating and nannying on that tear bunny brake plate too!
Wheels came out nice though especially as they’re 44 year old Akron’s (is that how you spell it?) and we’re beaten to buggery. Quite chuffed how they came out(https://uploads.tapatalk-cdn.com/20221101/e3eb7faf820802f312c242d5ae2cf18a.jpg)
Post by: Laverdaroo on November 01, 2022, 07:32:41 PM
(https://uploads.tapatalk-cdn.com/20221101/f9f8470c9dbf35b91026568e2ff93be5.jpg)
Post by: Johnny4428 on November 02, 2022, 08:03:18 AM
Some great looking hardware there Roo, loved the post regarding second rate polishers, great they took onboard. Of course the bar was set high by Ken.😉
Post by: Sesman on November 02, 2022, 08:07:20 AM
Mutts nuts. . It starting to come together now.
Got your PM. I’m out and about today, but will try to do the business later today.
Admire your perseverance with the polisher…….
Post by: Matt_Harrington on November 02, 2022, 09:35:57 AM
Rim looks good, oh and the lump looks like it is just about there...
Post by: Laverdaroo on November 08, 2022, 02:34:31 PM
Just had some post from Max on here, a new set of stainless spacers. NICE!
Proper chuffed with those thanks heaps Max, great work mate.
Bestest still, they won’t need sodding polishing!(https://uploads.tapatalk-cdn.com/20221108/26432232325398fd3947d19c0450f830.jpg)
Post by: Oddjob on November 08, 2022, 04:44:13 PM
You COULD polish them Roo, you know you want too  ;D ;D ;D ;D ;D
Post by: gary123 on November 08, 2022, 04:57:24 PM
Looking really good Roo. Bit jealous of those spacers.
Nice to see Im not the only one who works on an old bath mat ;D
Post by: Laverdaroo on November 08, 2022, 05:00:53 PM
Bloody couldnt!!!!!!!
Post by: Laverdaroo on November 08, 2022, 05:02:53 PM
Stops stuff bouncing if you drop it! plus I'm attempting to polish this bloody brake plate and it wont sand but you mark it if you look at it so every little helps and all that! ;D
Post by: Sesman on November 08, 2022, 05:14:25 PM
Paint the fecker. Polishing is over rated…..
Post by: Laverdaroo on November 08, 2022, 05:44:45 PM
I can't now, Ken will never forgive me and I won't get my first gold, achievement star  for the fridge door!
Post by: Sesman on November 08, 2022, 05:49:48 PM
I too have joined the college du Ken buff.
Post by: Oddjob on November 08, 2022, 06:05:20 PM
Don't forget, dimples facing the Dremel. 2 on a mandrel seems to be best.
Post by: Sesman on November 08, 2022, 06:07:04 PM
Post by: Laverdaroo on November 12, 2022, 04:28:20 PM
Well,busy coule of days in the shed of dreams...
Dual disk conversion.done, managed to resuse tha gear retainer plate after gobbing it back together with windscreen adhesive, works a treat and still enough give fo it to work spot on hopefully.
Managed to get the clutch cover on with all the old tabs flattened out, painted and re-bent to suit on the covers, although not completely happy with where they go, is the routing right on that, can anybody advise if not? I dont like the white cover either so thats getting some heat shrink over it at somepoint in th enext couple of days.
Found a small hole behind where the badges go on the tank and after talking to Bryan and a few others, (including the Painter) on how to fix it, all mentioned, solder.
I'llsolder it then, I thought!
So after opening the hole up a bit to allow a bit more purchase for the metal to run, I  melted what can only be described as a pile of solder over the hole afyer cleaning it with wire brush etc.
With the tank held, (propped) up on some wood blocks and using a plumbers blow torch, just started to heat the little 'turd' of solder until it became liquid. At this point you can see it run down the hole a bit like a miniture plug hole so I knew it was getting through and by increasing or decreasing the heat you can get a bit to go solid or run it more or even spread it out but its a very finite line betwixt, success or ruin.
Thanfully it ran perfectlky and worked first time but I did have to bob quite a bit of flux in and around it to get it to move how I wanted.
Basically I've got what appears to be an 'egg-timer' shaped plug in the hole which has sealed it up beautifully and more to the point the painter is chuffed with it so I'm good.
The areas where the badges are going are so worn with all the tabs snapped off that I'm going to have the recess's filled and put the badges over the top with a good bonding, carpet tape or similar yet TBA.
Saved potentially ruining the tank through heat and was easy to perform so a minor win this week on that front.
Whilst on with the tank, I mentioned somethng dropping off a shelf and banging the top surface some time ago and still need to get this out.  After trying form the inside I can't reach it so had an idea,........ has anybody used Dent Doctor or Chips Away or whatever theyr'e called for ths sort of thing? Didnt know if it was going to be cost prohibitive or not. Need to get that sorted before it goes up for some colour but unsure what to do with it if I'm honest. Piccies enclosed.
Rear brake plate is ongoing and I'm bitching about that on the polishing thread so I wont go over that and besides its a hateful task and the least said about that the better!
New fork stansions (isit an 's' or a 't'?)have arrived so fitted them last night and built the forks up ready so I can get on with hopefully starting the wheels when the spokes come.
I alsohad a stock take and a re-arrange of the gubbins on the bench and the various stashes I have out of the eyes of The Long Haired General and managed to find alsorts in bags that I would nevr have thought would be in there.
Incidentally, Bryan, recocnise the washer/spacer?.......................bugger! ;D
Got a new addition to the shed also, spoke to a chap at the show at the weekend who recons' tools from house clearances etc and paid him £30 for this 'liddle beauty'! PROPER win that one and works a treat with only the minutest amount of throw so really chuffed.
Everything into consideration, its been a good week although not done yet and off out there in a bit hopefully to continue sanding :-[ but the engine is done all bar getting the sump on and oil in it (once it comes) and checking for its delivery at the head through the galleries via the kick start as kindly reminded by Ken.
Once done, top on and hopefully in the frame..........which I'm  STILL waiting for...........hurrumph! ;)
Post by: Laverdaroo on November 12, 2022, 04:28:28 PM
(https://uploads.tapatalk-cdn.com/20221112/f89cc15448385d1721a11c12a56d17d1.jpg)
Post by: Laverdaroo on November 12, 2022, 04:28:44 PM
(https://uploads.tapatalk-cdn.com/20221112/33b3bf24cf4854bc1b1ef8774769f908.jpg)
Post by: Laverdaroo on November 12, 2022, 04:29:03 PM
(https://uploads.tapatalk-cdn.com/20221112/7d5c1f28faf03e76ac930cbff64efdf7.jpg)
Post by: Laverdaroo on November 12, 2022, 04:29:37 PM
(https://uploads.tapatalk-cdn.com/20221112/5300ac3672ff4076b2ee44e1f7e9a03b.jpg)
Post by: Laverdaroo on November 12, 2022, 04:30:28 PM
(https://uploads.tapatalk-cdn.com/20221112/7e1b850919c4af5e73d7f2c1413ba935.jpg)
Post by: Laverdaroo on November 12, 2022, 04:30:50 PM
(https://uploads.tapatalk-cdn.com/20221112/debe0e2025dc42cf5ba2787071646ddd.jpg)
Post by: Laverdaroo on November 12, 2022, 04:33:14 PM
(https://uploads.tapatalk-cdn.com/20221112/db142d04292812b5af10e05d5e17ab5d.jpg)
Post by: Laverdaroo on November 12, 2022, 04:36:17 PM
(https://uploads.tapatalk-cdn.com/20221112/375b2e0c35e91eeb7a1be57fbfb88baa.jpg)
Post by: Bryanj on November 12, 2022, 04:48:38 PM
Told you it would turn up after you got another one! Cable looks right to me
Post by: Sesman on November 12, 2022, 05:02:32 PM
Oh, aye. Coming on very nicely.You gonna build the wheels yourself?
Post by: Matt_Harrington on November 12, 2022, 05:17:44 PM
Plenty of progress there Roo. The engine looks great!
Post by: Nurse Julie on November 12, 2022, 05:18:32 PM
Getting there Roo. It's a 'ch'.... stanchions
Post by: Laverdaroo on November 12, 2022, 05:22:09 PM
Its ther original one, I had it in a bag with all the fixings for the gear mech behind the clutch, must have had it in my hands about 30 times and still not twigged! Doh!
Lesson here is, wash everything and put it in clean bags whilst stripping and try not to write on the bag with whitr board marker so it doesnt rub off yer pillock Roo! ::)
Gonna have a go at the wheels meself Phil, the 400 ones turned out really well so ordered spokes etc today as part of another £250+ order to all and sundry!  with the forks, thats over £500 this week.................eek!
Post by: Laverdaroo on November 12, 2022, 05:23:26 PM
You need to be on Countdown Julie :D
Couldnt remember,
I think I'm Lexdislick! ;) ;D
Post by: Sesman on November 12, 2022, 05:38:41 PM
I know, it adds up. I’ll never get back what I have in the 550, which is why I’ve favoured it over the 500. I need to ride the 550 just to get some ‘value’ out of it. To be fair, if I’d been able to snag a 500 for what the 550 cost, the restoration cost would have been similar, but the cost/value deficit would have been less…..sob, whimper.
My future plan is to restore the Triton, sell it and wait patiently for a substantially complete 500, even a completed one if the ‘price is right’. That will be a while, as the Clipper RTW cost is punitive.
I’m still looking for a benefactor……..
Post by: Oddjob on November 12, 2022, 05:46:26 PM
Professionals get dents out by spot welding a small rod onto the dent, then use a slide hammer action on the rod to pull the dent out, the spot weld is then ground off.
Should have put a close up pic of the clutch cover up so we could see how the chromers did with the repolish. Doesn't look to bad from a distance but could be pants close up.
Post by: Laverdaroo on November 12, 2022, 05:52:14 PM
It’s not great but passable I suppose!
Should have paid you to do it Ken if I’m honest!
Least it would have been right!
Here’s the routing of the points lead, forgot to bob a piccies up
Just looks odd to me, anything Vance moved but just thought it didn’t look very Honda and didn’t take a piccy cos I’m stupid(https://uploads.tapatalk-cdn.com/20221112/086c4160012713f6acfc93713a0bbd6b.jpg)
Post by: Laverdaroo on November 12, 2022, 05:54:49 PM
That’s after them doing it twice! It doesn’t photo well but the staining is still there.(https://uploads.tapatalk-cdn.com/20221112/dd9418fba87e08697fe51d3593e39f84.jpg)
Can’t get the light right to get a decent shot of the rippling and graunching they added onto it for free FFS!
Post by: Oddjob on November 12, 2022, 06:21:07 PM
See if you can get some largish shrink tube, put it over the cable clamps and just shrink it into place. Sharp edges like those will wear the covering away. Position looks ok TBH. If you need some I've probably got some lying around.
Not great that is it, I can see the staining and the scratches, which TBH usually look worse in a pic than they do in real life, I can see where they caught the edges on something as well. Got to be honest and say I've seen much worse. I can't say for sure that I'd have done better without doing one myself first, they could be complete bitches to do OR they could be pretty easy, hard to say without doing one. I've got more than a few of them TBH so maybe I'll have a go and see how one comes out.
My lads grab rail is looking to be the best I've ever done I think, if the finish before you start to polish is anything to go by it should be better than you're sliders. They were really really bad to start off with, one of the worse I've ever started with I reckon.
Post by: McCabe-Thiele (Ted) on November 12, 2022, 06:39:54 PM
.............................. wait patiently for a substantially complete 500, even a completed one if the ‘price is right’.
I've advised  Wendy if I fall off the perch unexpectedly to contact Roo to offer up my 400 & 500 here on the sohc site before giving her brother the oportutnity to move it on.
Post by: Sesman on November 12, 2022, 06:52:18 PM
Excellent plan. Keep moving Ted; motion is lotion.
Post by: Laverdaroo on November 12, 2022, 06:58:29 PM
Good man, as long as it will be brown Ted
Ken, I’ve just ordered some shrink tubing amongst other finishing off bits.
Yeah, looks odd in white so it’ll get sleeved with the tangs.
I’ve got a few and I think I’ve done brass sheet .5mm somewhere, Iva always use that and tosh them up like these. (That’s a ford silver but don’t tell anyone, s’all I had)
Yeah, that cable just looks a bit of an afterthought tbh and I need to do something with that, it might get shuffled about when idk the rewire as I’ll be starting from scratch.
I’ve mocked up Lecky plate with all my Munit gubbins, darter so etc so I can go wherever I like with stuff really…….(https://uploads.tapatalk-cdn.com/20221112/56d682c525a481fd76588d185693ecac.jpg)
I’m hoping the dazzling front forks will distract the eye from the shite polishing of the clutch cover. If they approach from the front and don’t look over the side I’ll be sorted
Post by: Laverdaroo on November 12, 2022, 06:58:43 PM
(https://uploads.tapatalk-cdn.com/20221112/e11c0162b1a80c9a5def2bdbbf6663f2.jpg)
Post by: Laverdaroo on November 12, 2022, 07:14:37 PM
Question,
I’m putting a stainless sump bolt kit on it but in the book there’s no torque settings for the sump……….M6…8ft/lb’s?
Also I know they are supposed to be flanged bolts but these come with a 10mm washer and a split ring. Is the split ring needed if I just dab a dot of red loctite on em?
I ask because,
a) they look a pig sticking the bolts out.
b) they’re only 8ft/lb’s (?) so they’re not really compressing much under that and a dab of thread lock would do the same job and I can loose the splits?
I know it’s a bit, form over function but just a thought in my addled head
No?
Advice required
(https://uploads.tapatalk-cdn.com/20221112/28b58d5ff0b5ed9c4f646d0645eacd80.jpg)
Post by: Oddjob on November 12, 2022, 08:33:14 PM
Roo there is no spring washer on a flanged bolt so why would you need one on a stainless one. Just put a plain washer under the head, preferably a slightly thicker one than standard then just do them up to standard torque, not that I ever did torque the casing screws up, just used the pressure on my thumb against the head of the ratchet and never had one come loose yet.
I've replaced every engine crankcase bolt on my rebuild with stainless this time, the casings I use the more modern 8mm headed flanged bolts that Honda use today. I'll zinc/nickel plate them all before fitting.
Post by: Laverdaroo on November 12, 2022, 09:16:37 PM
That's what I've done bud, 'nipped with a thumb', and lost the spung diddlies, looked crap and not required, thanks mate.
Post by: Bryanj on November 12, 2022, 09:31:19 PM
Only put locktite on a stainless bolt in alloy if you are 110% certain you are never taking it out again, copperslip on stainless in alloy
Post by: K2-K6 on November 12, 2022, 09:53:38 PM
I do like the sound of "spung diddlies"  ;D
Post by: Laverdaroo on November 12, 2022, 11:54:48 PM
Roger Roger
Post by: Laverdaroo on November 13, 2022, 03:11:55 PM
All removed, cleaned, spung diddlies removed and bolts refitted with a bit of ginger grease on the threads.
Made a well designed engine stand that, as can be clearly seen,.....took hours to design and build but meant the filter could go on enabling the motor to be ready for the oil coming in the week, to check the delivery to the head. Just the dreaded polishing to do until I get some bits back I've out sourced and some reading to do.
Polishing!  :-\
Post by: Laverdaroo on November 13, 2022, 03:12:11 PM
(https://uploads.tapatalk-cdn.com/20221113/bacab20a785a0a0efca34d110b77881a.jpg)
Post by: Laverdaroo on November 13, 2022, 03:12:39 PM
(https://uploads.tapatalk-cdn.com/20221113/546244334c3ff51ecc1c212329e521e7.jpg)
Post by: Oddjob on November 13, 2022, 04:34:46 PM
I bet you forgot to have the dipstick polished to match the case  ;D ;D ;D
Post by: gary123 on November 13, 2022, 04:47:41 PM
Had to read that twice, thought you called Roo a    oh never mind.
Post by: Oddjob on November 13, 2022, 06:31:43 PM
I'll rephase that then Gary.
"HEY DIPSTICK, DID YOU DO THE DIPSTICK"
How's that, better  ;D ;D ;D ;D
Post by: Sesman on November 13, 2022, 06:32:39 PM
Well did he?
Post by: Laverdaroo on November 13, 2022, 07:01:51 PM
Yes, much better............
Oi, SILLY PILLOCK, yes I did..............Ka pow ;) ;D ;D ;D
Post by: McCabe-Thiele (Ted) on November 13, 2022, 07:05:50 PM
Thought you had cobwebs on your block,
then I realised it's Cling Film.
Post by: Laverdaroo on November 13, 2022, 08:01:23 PM
It’s halloween cling film Ted
Post by: Laverdaroo on November 13, 2022, 10:17:13 PM
Could anyone confirm what material the two washers are made from on the fiche numbered 12 and 14?
Are they copper?
I’ve new o rings on the back of the caps, anything else I’ve missed? Mine came without both washers so have no point of reference(https://uploads.tapatalk-cdn.com/20221113/6b573ace98f922d70309f3ddfcd1e774.jpg)
Help required.
Post by: Bryanj on November 14, 2022, 12:08:36 AM
Originally soft alloy between bracket and cam cover, not sure about between bolt head and bracket.
A thick copper will probably do
Post by: Oddjob on November 14, 2022, 12:48:11 AM
I'm like Bryan, the underneath washer is definitely a soft alloy one, I tend to fit a copper one under the head of the bolt.
I've got both kinds if you need any Roo. I also fit the same type copper washer under every bolt with a number 12 washer under it as well.
Post by: Oddjob on November 14, 2022, 12:53:27 AM
Just started a 550 clutch cover tonight Roo. Went to the box they are all in and just picked one at random, damn it's BAD, really really really bad. Massive amounts of corrosion. Just spend 2 3/4 hours tidying it up a little, did I mention it's bad. Got about 1/3rd done but many many more hours to go on it yet. I've taken some before pics and I'll take some more as it progresses, don't hold your breath, this will be a whenever I feel like it project. Actuating arm is in nice condition though.
Post by: Sesman on November 14, 2022, 07:48:15 AM
Definitely soft alloy. I believe Trigger has a modification to eliminate weeping from this area. I think it involves some machining and the use of an o ring. I’ve not tried the copper washer alternative solution.
Post by: Laverdaroo on November 14, 2022, 10:12:43 AM
Thanks fellas, mine had absolutely nothing on them and only thought it should  upon having a look last night.
Ken, could you bob some in a bag to suit and fling em in the post mate, that would be extaordinarily useful? ket me know how many camels yuo want and I'll reimburse you .
I'll go with yur advice and do all the ones listed as 12 if you've got enough?
Phil...."I think it involves some machining and the use of an o ring. I’ve not tried the copper washer alternative solution".
What is this weeping problem you talk of???????? :o
Post by: Sesman on November 14, 2022, 10:14:52 AM
Dunno, mate. I think it was mentioned by one of the following: Julie, Delta, Ash, Ken….. I may of course be talking boll£:s.
Post by: Laverdaroo on November 14, 2022, 10:17:44 AM
highly likely.................. ;) ;D
Post by: K2-K6 on November 14, 2022, 10:29:35 AM
For the copper washers, heat to red and quench in cold water (annealing) to make them soft for those that don't all ready know "how to suck eggs"  :)
Then they'll have the best chance of taking any discrepancy out of the surface to seal it effectively.
Post by: Laverdaroo on November 14, 2022, 10:48:17 AM
Morning,
Familiar with the heating and qunching but I was under the impression that was for when you reuse copper?
Would I have to reanneal them as they'll be new or are you suggesting doing that as a matter of course?
Post by: Bryanj on November 14, 2022, 10:56:28 AM
Shouldnt need to aneal new washers mate, and the weeping is because oil feed to the cam bearings is via the ends so oil can leak from that bolt.
Personally after a rebuild i leave the end caps and brackets off until i have spun the engine over enough to see oil come out at both ends, then fit the brackets and covers
Post by: Laverdaroo on November 14, 2022, 11:33:42 AM
I thought so but K2K6 threw me a bit there with his post.
Thats the plan Bryan, I'm just making sure I have what I need to get the engine back together after the spin up and just want the right kit as and where required.....as yer do!
. When I saw them I new there should be some form of seal behind etc and remember speaking to you about it earlier in the year mate, washer,  there wasnt any on there as I said earlier hence the question. TBH, there wasnt much of anything of any use realistically ;D ;D ;D ;D
Post by: Sesman on November 14, 2022, 12:36:47 PM
Good tip.
Post by: Oddjob on November 14, 2022, 01:19:38 PM
TBH they do tend to leak for a couple of reasons, the soft washer is replaced by another type because they didn't know what it was there for or the threads were stripped out by either overtightening OR the thread hole was full of oil when they tried to insert the bolt, hydraulic pressure caused by this causes the bolt to try and lock up, you keep on trying to tighten and it strips the threads right out of the head. Make sure the hole is empty before fitting the bolt, oh and in case you didn't know Roo the brackets hanging off that bolt are handed, stamped left and right. The hole doesn't line up if you fit them wrong.
I'll dig some out and send them down Roo. No charge. I'll send 3 alloy ones and 10 copper, there is an alloy one on the camchain tensioner upper bolt IIRC so one for there as well. Just need to find them now. Many, many boxes of parts lying about.
Post by: Laverdaroo on November 14, 2022, 01:46:11 PM
Nice one mate cheers.
Yeah i knew they were handed and my mind refreshed last night cleaning them up. Think I'll bob them into the plate bath with the rest of the hardware I've just cleaned up ready to go in. They're all degreased, just need a final clean up and an etch but other bits being fiddled with before  I get to that. just prepping for when the frame comes back then I can get the motor in, swing arm on and the center stand. At least it can be upright and a bit easier to manage in the shed than all over the place in bits. Ive just a tray full to plate up then ;m good to go
I've been round the whole block and covers etc, every hole cleaned and rerun with a tap to get them all super clean but thats another for the memory bank like, cheers ;)
Post by: Laverdaroo on November 17, 2022, 01:57:13 AM
OK, I was asked a question today on a subject that I had completely over lookedon my 550 quest and one that Ireally should have looked up. A pal who's done similar activities to me was talking about my hubs and askedif there was any off et on the rear,hid exact question was, "Have you a rim offset dimension or mark on the hub where the centre line of the rim needs to be or is there a dimension that you have to work with?". I don't even know if there is one!
.........Is there one and if so Can anyone suggest what it might be?
I've not stumbled over much about it on the various pages Ive searched, on't net so it hasn't really been on my radar up 'til now. As I've found very little on the subject can I asume it's not really a topic of discusssion as it doesn't have one or am I just hoping.
Has anybody who's built a rear wheel on one of these, enlighten me at all?
Post by: Nurse Julie on November 17, 2022, 08:43:20 AM
No offset on any CB SOHC/4 wheels Roo.
Post by: Bryanj on November 17, 2022, 08:47:50 AM
Thats only for old british bikes Roo when frames were not straight
Post by: Laverdaroo on November 17, 2022, 11:12:28 AM
I know about the British stuff but had no info on the 550, you read so much on here and other places on the net regarding this and that and it completely didn't click that there might be an off set, I hadn't read anything about it so it wasnt  on the radar so to speak.
 After burning the midnight oil last night, that was the conclusion I came to but there's an awful lot on here to throw you off.
Even Hondaman refers to there being off set on a number of the Honda fleet, so you think, 'ooo', better chase that and of course it comes to nothing but you have to check. What a pain in the ar*e though!
Cheers Bryan, appreciate it mate.
Post by: Oddjob on November 18, 2022, 02:16:59 PM
Sitting down Roo?
Thought this might interest you. I'd advice seeing if they have any more next time you're over there before they see what it's worth.
https://www.ebay.co.uk/itm/204156719367?mkevt=1&mkpid=0&emsid=e11021.m43.l3160&mkcid=7&ch=osgood&euid=90cafac477e54725baa807080c211eab&bu=43136868494&ut=RU&exe=0&ext=0&osub=-1%7E1&crd=20221118070116&segname=11021
Prices are going really silly.
I need a key ordering for my 500, found one, genuine Honda, same key number as mine but the seller won't post to the UK and he doesn't accept messages, if you're going again let me know.
Post by: Laverdaroo on November 18, 2022, 02:21:42 PM
Stop looking at expensive stuff!
I have loads of these (6) all without the mesh screens but have the rubber seal the mesh sits in intact so could be rebuilt!
That’s bloody silly money!
Where’s this key and I’ll sort it bud…
Post by: Oddjob on November 18, 2022, 02:28:42 PM
Someone does the mesh holder on site, 3D printed IIRC. The mesh can be bought off Ebay, get stainless so it doesn't rust.
I have an alert set up so when one comes up on Ebay it lets me know, my BIL wanted another as he stood on his, well mine as it my bike but he's sort of adopted it. So I set up the alert in case one turned up.
I'll PM you the details of the Ebay auction it's on, the key number is very rare, this is the first time I've ever seen one, my daughters in NY right now and I asked her to buy it for me but she's not sure if they'd deliver to a hotel and what happens if it's delayed and she's gone home by the time it arrives etc.
Post by: Laverdaroo on November 20, 2022, 10:54:48 AM
Cheers, didnt think so,a lot of miseading info out there...and from folk who you'd think would know too!
Thanks 8)
Post by: SPR on November 20, 2022, 11:05:54 AM
I've a USA forwarding address if you need it
Simon
Post by: Laverdaroo on November 20, 2022, 11:12:12 AM
Good day fiddling yesterday, grabbed down all the electro plating I’d done the day previously and checked it all. Apart from a few drying marks, pretty chuffed tbh, it came out well!
Also spent a lot of time trying to get the exhaust pipes cleaned up prior to chrome.
 Where the bike was parked on its side stand the skyward facing edges of the pipes were heavily pitted and has taken a lot of time to get somewhere near presentable.
4 hours in and a selection of files more commonly used by vets on on horse teeth, bands of abranet on the drill, blisters, blood sweat and Anglo Saxon and they’re not tooooooo bad
I’m not too bothered about the shallower of the little pits as the chromer will sort those I wanted to get the deep pits and rust build up off them and try to get to a better finish once done. Think they’ll be reet but will probably revisit them before they go to get shiny.(https://uploads.tapatalk-cdn.com/20221120/baac847989fc765603f9e2a7ecb8a261.jpg)
Post by: Laverdaroo on November 20, 2022, 11:12:37 AM
(https://uploads.tapatalk-cdn.com/20221120/679d3e1dd6b6bd74127ce9a972089d20.jpg)
Post by: Laverdaroo on November 20, 2022, 11:12:56 AM
(https://uploads.tapatalk-cdn.com/20221120/7a55a499a8b7591d5c0241247cc96754.jpg)
Post by: Laverdaroo on November 20, 2022, 11:13:23 AM
(https://uploads.tapatalk-cdn.com/20221120/b0b78e6f703caef25e3cf91008359c48.jpg)
Post by: SPR on November 20, 2022, 11:35:21 AM
You must be chuffed with those ... they are night and day different !!
Simon
Post by: Johnny4428 on November 20, 2022, 11:42:39 AM
Nice job on the pipes Roo! Bloody awkward to do too! Great progress.😉
Post by: Laverdaroo on November 20, 2022, 11:42:58 AM
I am actually, they were a pig to do but I hate sanding metal at the best of times tbh. Like I say, there are pits all over but the chromer will have a better way of remiving those that I have. The abranet on the drill is a good swerve and works really well, I tried it with some sand paper yesterday as the abranet had finally given up the ghost and that wasn't as good but still removed material.
Quietly chuffed, indeed ;D
Post by: Laverdaroo on November 20, 2022, 11:47:11 AM
Cheers, arent they just, 1 & 4 are a right sod!
Radio 4 Extra, planet Rock and a packet of digestives liberally dunked in Yorkshire tea at regular intervals turned out to be the correct anesthesia for a job such as this...........the required formula 8)
Post by: Oddjob on November 20, 2022, 02:34:08 PM
I hate to say this to you now Roo but my new secret weapon tools would probably have been ideal for that job.
Good result though, the better they are going into the chromers the cheaper they charge and the better the end result is in my experience.
Just done a set of handlebars, reasonable amount of pitting, like you get on bars, as you can't seem to find OE bars anymore it's vital we look after the ones still around. They have turned out pretty good, took me some time to do them as you'll have found, steel parts are so much harder to do than the alloy ones.
Getting a few more steel parts ready and then off for a run to the chromers. Grab rail is turning out a real PITA.
I've also got an idea on how to get dents out of the back of fork ear tubes, for some reason they get dented there on a regular basis, even got a NOS with a small dent there. Trying it on a 550F1 ear where it's clearly been in an accident and the bracket part got pushed back and really dented the tube. Gonna see if I can get that out. Will help others if it works I reckon, can't just be me with damage like that.
Keep up the good work.
Post by: Matt_Harrington on November 20, 2022, 03:50:03 PM
I can see there was a lot of toil in those pipes, Roo. Good job! Do you save much at the chromers by do this yourself?
Post by: Laverdaroo on November 20, 2022, 04:51:12 PM
The better you can get them to the chromer's, the less thay have to do and so cheaper. I spoke to a chap last week whilst at the painters and he does a lot of cleaning, like Ken. He was confirming your qestion and comments by Ken on other threads; the less the chromer has to put right the better basically less timeless to pay for. There's places that I cant get to on the set so the chromer chap said he would fettle but advised to get as much crap and bad surface off as i could to give him ahead start.
It'll still be around the £250 mark I should think. If so, this will be the 3rd most expensive exhaust I've ever bought .....in 35 years;D topped only by a full system bought for my old ZX7R at just over a grande! :o ???
Saying that I'msetting about the VFR thios winter and that needs a full system!...........thats going to be an ouch moment I know it ;D ;D
pipes, £53+ p&p
Sanding materials  £30
Chroming  £250ish
Supertrapp end can $200
blasting and dechroming £20 and a jar of coffee and a box of Yorkshire tea
Post by: Laverdaroo on November 20, 2022, 04:52:53 PM
Ordered but thanks on Ken's behalf Sy
 8)
Simon
Post by: Laverdaroo on November 20, 2022, 04:57:30 PM
I've also got an idea on how to get dents out of the back of fork ear tubes, for some reason they get dented there on a regular basis, even got a NOS with a small dent there. Trying it on a 550F1 ear where it's clearly been in  ;D ;Dan accident and the bracket part got pushed back and really dented the tube. Gonna see if I can get that out. Will help others if it works I reckon, can't just be me with damage like that.
I'd be interested in hearing about that Ken...........We'll be calling you Mr Dentmaster before long! ;D
Post by: Oddjob on November 20, 2022, 05:58:33 PM
I get loads of ideas like that Roo, I have that sort of mind I think. I successfully did it on one set of ears but any that have reinforcing rings won't do it, I had to think of another way to do them. Just thought of something the other day and was scouring Ebay for the part I need to buy but then thought of another way using some stuff I already have that was basically scrap. I'll test the theory soon.
Rotor cover coming on, sanded down to 400 now. Just got 800 and then 1000 and that will do I reckon. Looking at it I'd say it will be a fantastic finish when polished, as good as chrome I reckon.
Post by: Laverdaroo on November 20, 2022, 06:33:00 PM
Looking forward to seing it mate and doing me make up in the reflection! 8) ;)
Back in the shed of dreams in a bit to carry out round two of the great exhaust cleaning saga! :-\
Post by: Laverdaroo on November 20, 2022, 08:08:22 PM
Thanks for the support folk, nearly there!
As a sideline, can anyone confirm this is bolt ID number 13 on the fiche, lost the bag it was in, it measures 32mm?
I’ve three shouldered ones here.
So,
1 for the rear brake arm/hub
1 for the side stand
The knackered one for the front of the brake arm.
Which is which for the other two. I’ve no kick start, stand or anything here at the min, it’s all out at my pals so I could use his kit for a bit of a change of scenery and I’ve my lump here and don’t want it covered in metal filing and polishing this kit I’m on with!
Needles to say, I’m not there I’m at home tonight so can’t check.
Just want them labelled up and sorted as I need o get them off to max for replacements to be fettled in stainless……….cos I’m a tart
Post by: Laverdaroo on November 20, 2022, 08:08:41 PM
(https://uploads.tapatalk-cdn.com/20221120/c0c002fffb99fc75033faf0d7b5ecd58.jpg)
Post by: Bryanj on November 20, 2022, 08:19:32 PM
Cant answer that one, too dark to find a kickstand in my garage at moment
Post by: Laverdaroo on November 20, 2022, 08:25:26 PM
No commitment
I have a feeling in me water that the bigger one is for the kickstand and the smaller for the other end of the torque arm but happy to be corrected.
Just boggling me as I hate loose parts floating about. I’ve got everything sorted bar these two bolts and it’s proper ‘twining’  me
Post by: SPR on November 20, 2022, 08:25:55 PM
If it is the same as the 500 I suspect the sidestand is on your right - just measured mine and it is 35mm overall
Post by: Laverdaroo on November 20, 2022, 08:28:03 PM
That’s just it Sy, they’re not the same by all accounts……
Post by: Bryanj on November 20, 2022, 08:31:12 PM
The stands are different but the bolts may be the same, check the number in my parts book, if the middle is 323 its the same
Post by: Oddjob on November 20, 2022, 08:31:42 PM
The side stand one has a 17mm head, the front torque arm bolt has a 14mm head IIRC.
I may ask Max to make me a side stand bolt for mine but slightly different, you may want to hang on and see what it looks like before buying one.
Post by: Bryanj on November 20, 2022, 08:40:51 PM
Correction the 500 bolt has a 283 middle number making it a 450 part
Post by: Laverdaroo on November 21, 2022, 12:14:26 AM
Yup! ;)
Im sending them over to Max anyway to measure up so I'll get back exactly what I send, his stuffs ace. I was purely trying to get my listigs right to reduce the ferreting about. I spend more time looking for stuff than doing stuff. The shed's too full!!!
 Its my own fault but the planned extension will solve it. In the meantime.........just trying to be as organised as possible!
I'll get round my pal's in the weekand solve my brain worm and attack of OCD over the weekend ;D
Post by: Laverdaroo on November 24, 2022, 05:26:10 PM
Evening all,
could anybody confirm the width of the rear mudguard on a 500T? I'll bob it on that page also before anyone mentions it.
You'll remember, I got a near mint rear mudguard  from grovelling around that scrappers in the US...
It appears the rear mudguard I salvaged from said scrappers, that was lost in my bag for 6 weeks, ......which I finally got back from the airport, .......that I  worked on for two days so it fitted the rear subframe and its modifications,......... and then gave to the chromers to re chrome..................has been lost!......But apparently after taking so much care of it, I lost it walking from my car to the chromers front door!!!
The lady states she remembers the conversation we had about it whilst we were looking at it in the reception and mentioning about the freshly filed edges needing a bit more 'oomph' by the polisher, but because nobady wrote it on the paperwoprk as a list item, they've not had it nor never seen it!! If it wasnt written down they havent had it. FACT!
Apparently after driving to drop all the bits off to them, (24miles each way), we had a chat about it and I took it home with me! Not sure why I would do that after waiting to finish fitting it to the frame and cutting it to suit before I took it with the rest of the parts is apparently fiction. So I drove all that way, took everything and although WANTED it chroming, brought it home to take down another day?
This was three days before going back to the states for the 2nd time expecting it all to be done when I came back so I had loads of time to make multiple trips,obviously!
The manager then came on as this lady stated that the reason nobody there had rung me back is because her daughter has just had a very difficult birth and theres been other things on her mind while she was off. OK, so does nobody else work there or just her, it was ten days ago I enquired as to it's whereabouts........she didnt like that so this plillockcalled Nick took the call and moaned about me losing it between my car boot and their front door, I kid you not.........at which point 'the can' was open!
For a start they had to do pieces twice..)which I have since taken elseware to be done properly) when theydid have  a go for the 2nd time, there was no change and more marks. The mudguard on the other hand, they relinqish all responsibility of ever seeing it although it was handled by them in front of me. Beacause its not on the paperwork you see............WTF!!!!!
No apology for bad work, no apology for fleecing me nearly a grand and then get shirty when I take my exhausts back off them as i dont want those ham fisted idiots who work there touching them now Ive seen what they can do.........or cant!
Its my fault for not thinking their work is good and its my fault that I have lost my mudguard in between pont A and poiint B which is nearly, wow, 30 feet!
So in my first rant about the shocking Chroming and polishing I mentioned I wouldnt say the company in question as its bad form. After today, sod that,.................................
 if you ever need anything worked on PLEASE PLEASE DONT take it to DOUG TAYLOR Platers and Metal Finishers, Western Supermare, what a bunch or utter, utter lying ars*holes........I now have to source a new rear mudguard, work on it, have it drilled and fit it to a newly painted frame back from the painters without scratching it.
More cost,more time, more backtracking.
I was going to keep this one but I think It's going to be sold the minute its finished, I've had enough of this bike now, its fought me every step of the way, I'm looking forward to seeing it together with its new paint etc but not as much as I will be see it gone, the love's gone sadly.
Super fed up, and indeed................Hurrumph! :'(
Post by: Sesman on November 24, 2022, 05:31:59 PM
Post by: Matt_Harrington on November 24, 2022, 06:24:16 PM
Bloody 'ell Roo - I feel for you. I suggest an evening in the pub!
Post by: Nurse Julie on November 24, 2022, 07:36:55 PM
Oh dear Roo, that sort of service is really appalling. Good, reliable customer service is more important these days than ever.
Post by: gary123 on November 24, 2022, 08:20:41 PM
Wow, feel for ya Roo. Puts my shit day under a ducati into perspective.
Post by: McCabe-Thiele (Ted) on November 24, 2022, 08:59:08 PM
What a Bummer Roo I thought that those type of things only happened to me - clearly there are lots of businesses out there who do not care about good customer PR or service.
Post by: Phil Ward (RIP) on November 24, 2022, 09:23:28 PM
Bludy hell Roo, I'd be tearing my hair out!!!! (if I had any).
Post by: Sesman on November 25, 2022, 10:29:43 AM
Try tearing their hair out…😀
Post by: Laverdaroo on November 26, 2022, 04:43:53 PM
I dont go to the pub anymore, diabetic and its too expensive so gave it up! My mrs is the assistant manager of onbe and I only live 75 yards from the village watering hole, cant remember when I went last time!
Post by: Laverdaroo on November 26, 2022, 04:45:20 PM
F*ck em! :-[
Post by: Sesman on November 26, 2022, 05:36:18 PM
….and the horse they rode in on. 😉
Post by: Rozabikes Tim on November 26, 2022, 05:38:53 PM
And with the wrong end of a ragman's trumpet. :o
Post by: Laverdaroo on November 26, 2022, 06:10:00 PM
'S' is for 'Sideways!
I have never had such a 'rear up' with a supplier over awful service...................I'm still spitting bullets and very much seethingseething! :-X
I had all that faff with getting it here and about 7 bours in it fettling,  to fit how I wanted!
In the wordsof Hugh Laurie in Black Adder..........,"I shall have my rewengi"  ???
Post by: Rozabikes Tim on November 26, 2022, 06:43:48 PM
Perhaps we will know when by "the look on their long faeces"
Post by: Laverdaroo on November 26, 2022, 06:55:24 PM
stop making me laugh, I’m really grumpy and fed up!
Post by: Rozabikes Tim on November 26, 2022, 07:01:44 PM
Ok so sorry...
https://youtu.be/LC_6DA1vki4
Post by: Laverdaroo on November 27, 2022, 10:16:49 AM
Would anyone know how these pipes might go together? If so then i can take them apart.
The chromer bloke I’ve been put into via a vintage car specialist says he’ll need them apart to get them to chrome up properly.
I don’t want lack, they’ve GOT to be chrome so this is the next conundrum to sort.
(https://uploads.tapatalk-cdn.com/20221127/2e9b3789d5c4ebe6c45c0dc99cbda0ed.jpg)
Post by: Laverdaroo on November 27, 2022, 10:17:39 AM
(https://uploads.tapatalk-cdn.com/20221127/85516b27c4b491f3e0a3693e422e4136.jpg)
Post by: Oddjob on November 27, 2022, 02:48:02 PM
Dunno Roo, I'd have thought spot welded on the outside but looking at the pics they could have been assemble onto the mounting plate, welded on the inside of that plate and then the plate welded to the collector box.
One thing you may have considered but decided against because your not sure how it would look but I had a set of 1300 headers done in CermaKrome a few years ago and they were all in one piece like yours, looked like this at the end.
(https://i.postimg.cc/pL7P7Dhv/DSCF0021.jpg) (https://postimages.org/)
(https://i.postimg.cc/d3vs6w7T/DSCF0020.jpg) (https://postimages.org/)
(https://i.postimg.cc/cCXScYyV/DSCF0022.jpg) (https://postimages.org/)
Not as bright as chrome but no rusting afterwards and extremely durable. Still in perfect nick when the bike got written off, I'd have salvaged the exhaust headers but one pipe got crushed.
Post by: Laverdaroo on November 27, 2022, 02:55:44 PM
Was it mouth watering lay expensive though Ken? They look sound.
I’d be up for that cos I really don’t want to faff with these and potentially knacker them. That sounds a much better option!
Got any deets of who and what etc ?
Post by: Oddjob on November 27, 2022, 03:08:35 PM
That cost me about £140 in 2010 IIRC, it was done at CamCoat in Warrington but your local ceramic coater should also be able to do that. Admittedly my headers weren't as bad as yours and they did sort of complain about the fact they couldn't split the pipes but they did a decent job.
Maybe pop into your local ceramic coater and see if they have any samples of how it looks, it's not a dull finish but not as bright as chrome but I'd say unless you stood right by the bike you'd not notice the difference.
Same pipes, about 18 months later, taken in December after running the bike through the winter, the dull coating is road dirt, this was taken when the bike was recovered after the accident. Bike hadn't been cleaned for weeks. The inner pipe shows the finish better as I think someone cleaned some dirt off it when moving the bike.
(https://i.postimg.cc/pXQZsHTY/IMG-1676.jpg) (https://postimages.org/)
Post by: Laverdaroo on November 27, 2022, 03:35:21 PM
That’ll do, more bling to fool the buyer and to get over a problem sounds spot on to me. I’ll call them tmrw, cheers bud
Post by: mickwinf on November 27, 2022, 04:51:28 PM
I think the original pipes were chromed first then welded as the area around the join is painted with a silver paint which is then disguised with a chrome cover. also it would be a nightmare to line them up again so the ceramic coat sounds like a better idea.
Post by: Laverdaroo on November 27, 2022, 08:26:06 PM
I thinkit's a great swerveand one tp chase up tmrw I reckon. Thatswhy I love the forum, talk about a 'get out of jail free card' or what.
I shall report back..................
Post by: Matt_Harrington on November 28, 2022, 10:46:27 AM
Ken, That cerakote 'chrome' looks surprisingly good - much better than I had anticipated.
Post by: Laverdaroo on November 28, 2022, 11:34:07 AM
I’m impressed Matt, call to Nathan later me thinks…..
Post by: Oddjob on November 28, 2022, 02:18:01 PM
It's also extremely robust Matt. It had to pass a test for the Army where it has salt water sprayed onto it for thousands of hours to see if it affects it. Passed easily, so must be more than good enough for our usage.
They reckon when it starts to dull just rub with some wire wool and solvol and it brightens it back up. Never had to do that but that's what they say.
Post by: Matt_Harrington on November 28, 2022, 02:22:47 PM
Indeed! Be interesting if he can do it.
Post by: Laverdaroo on November 28, 2022, 06:56:55 PM
Very interesting.......
https://www.youtube.com/watch?v=wSADRXo07EM
Post by: Laverdaroo on November 28, 2022, 09:03:42 PM
This evenings rant will be a revisit of a previous rant………wheel based but still polish related!
Got the rims back from cluster f*ck & Sh*tstorm Ltd, Western Supermud,  which, in all fairness, they’re shiny…………. but still not fab as was expecting!
The more pressing matter was that I did’t measure them before sending them off.  You see, they’re a lovely shape and I really dig the style and they’re period Akront’s (Sp.) and really wanted to use them as they look bloody ace but after lacing the front, I thought “summits not right here”.
The front should be a 3.25 x 19
The rear should be a 3.75 x 18
What I’ve got are
2.75 x 20 front
3.00 x 19 rear FFS!
School boy error, too excited by the cool shape and didn’t think to measure them! Only twigged when the spokes wouldn’t fit!
So option-one would be to get them laced up and have it steer dead slow and probably handle like a jellyfish on roller skates,which would be the cheapest option as I’d only have to buy another set of spokes and see if ‘Uncle David’ will give me a credit note? But it’ll ride horrible.
Or
Find some correct rims, new spokes etc.   at even more cost!
Bear in mind I’ve bought new spokes nipples() and paid to have them polished so I’m quite deep into this money wise now….
What do we think???
The handling thing is my main concern obviously
I know it’s my fault for not chucking a tape at them but I’ve never had a build go this awkwardly! Was really looking forward to doing the wheels as well.
It’s the problem when you strip and try to build a bitsa I suppose, that and me being a Hampton!
Not enjoying this as much as I used to, ………. Only myself to beat up, my fault, ‘you dick’ etc. Tempted to get the rods out for a couple of weeks and see if I can scare some fish into submission instead!
Probably cheaper!
But an equally poor result I should think
Opinions folk?(https://uploads.tapatalk-cdn.com/20221128/7f67b9f44bf2bc8ada3f238c8db946c2.jpg)
Post by: Laverdaroo on November 28, 2022, 09:04:00 PM
(https://uploads.tapatalk-cdn.com/20221128/744c2b73576b635fe126ae98d3890bad.jpg)
Post by: Sesman on November 28, 2022, 09:36:49 PM
Oh, yes.some nice trinkets there. Like the flanged alloys.
Post by: Sesman on November 28, 2022, 09:44:05 PM
Jesus, just read your earlier mail. I’m not sure a 20” front is the right way to go at all. Which is a shame
 as the Akronts are the business. I’d favour shifting the Rims to the British crowd. Tricky one this…
Post by: Laverdaroo on November 28, 2022, 10:13:30 PM
Having looked at a few On't 'Weave', I think theyre supposed to be on a Guzzi of some sort similar to the Boranni Record ones on flea bay. The chap's in Italy so already I'm not keen but looking at his shop, he has the sizes I need and the profile is the same as these so there's one lead to cautiously follow. I'm gonna get some rims and respoke the lot. I LOVE these as well, they're really the part but I'm not keen on a 20" front.............On a 'Translap' or XL but not on this.
Bit annoyed!
I shoud have packed it in when the frame went walkies ;D ;D ;D
More cash to find.........bugger >:( :o ::) ;)
Finished the motor yesterday which is why I dug the rims out, all happy and buzzed up.    Then.............aaaaaahh, sod it ::)
I've only the static timing to do and the valves etc to set and she's ready to go. I'll re synch the carbs again on the bench and run a bit of juice through them nearer the time. I only put them on for a quick look.....like yer do. Over a coffee and a tab 8)
Oil went in yesterday and through a few texts to Ken, discussing the finer points of amounts to be expected at the head and rates of flow whilst winding the starter etc and a clean bill of health brought a small win and a small  smerk
Top on, bolts all in the right holes and the right colour,..... I think, bar one and I thought I'd just poke the carbs on for a bit of a gloat.  Think it looks alright actually, it'll be better in the frame when I eventally get it back from the PC's (shiny black before you start....or it might be beige, cant remember ;)) and not so pale although the top lamps in the 'Shed of Dreams'
 dont do camera phones that well.
Post by: Laverdaroo on November 28, 2022, 10:36:42 PM
(https://uploads.tapatalk-cdn.com/20221128/1d40e8621fa380096342ac959335a046.jpg)
Post by: Laverdaroo on November 28, 2022, 10:38:48 PM
 (https://uploads.tapatalk-cdn.com/20221128/fd5f4eee748251bc6b87a65e31585923.jpg)
Post by: Laverdaroo on November 28, 2022, 10:40:44 PM
Oh, and finished painting those tank badges, just need  a little tickle and there getting bagged ready
They look a bit yellow there but it’s the seductive kitchen lighting she insists on!
(https://uploads.tapatalk-cdn.com/20221128/233596d1e1a9f427c11fc562f73b74e4.jpg)
Post by: Sesman on November 29, 2022, 08:02:50 AM
Looking mighty fine. The badges have come up a treat too. Obviously they won’t work on the tank you are looking at as it’s an F1 or F2 unit, but that comes with badges anyway.
Post by: Matt_Harrington on November 29, 2022, 09:43:47 AM
Badges look really good - did you use the dropper technique?
Post by: Laverdaroo on November 29, 2022, 11:19:41 AM
Yes Matt, I got a set of three needles and a syringe, did them four times before I was happy though, air bubbles, bits of crap in the paint. Yer know
Quite chuffed though.
I’ve got a tank Phil, just saw that last night whilst looking at rims………..eBay worm hole
Just thought it was quite good value with all the lock intact etc. my tanks at the body shop getting de dented
(https://uploads.tapatalk-cdn.com/20221129/3305ce420b031c0a7618c7f112694afc.jpg)
Post by: Sesman on November 29, 2022, 01:00:24 PM
Err, you do know that the 500,badges won’t fit that F1/F2 tank? I’m betting you do, but just saying. I’m guessing you have flat sided the tank and you are going to stick them on?
Post by: Laverdaroo on November 29, 2022, 02:05:17 PM
Yup.
There are no tabs left on my tank so having it filled in and painted over. The badges are indeed getting stuck on, probably with gaffs tape and expanding foam more than likely
Post by: Oddjob on November 29, 2022, 08:13:34 PM
Presume you've already seen these Roo.
https://www.central-wheel.co.uk/catalog/product/view/id/889/s/velocette-non-valanced-alloy-rim/
I'd advise a 2.15 rear rim size.
https://www.central-wheel.co.uk/polished-non-valanced-alloy-rim-honda-all-models.html
BTW, the sizes you stated in your first post on the subject were the tyre sizes not the rims sizes. AFAIR they are 1.85 as standard. The 750 got 1.85 front but a 2.15 rear. I fitted 2.15 front and rear and found that perfect for my style of riding, the larger section rim means you can use slightly bigger section tyres without suffering from the rim creep you get by retaining the standard rim sizes. As most of my riding was hanging off the side of the bike around corners the larger section tyres were ideal.
Post by: Laverdaroo on November 29, 2022, 09:03:37 PM
You've totally lost me ken, in the HONDA manual, it says RIM size of the ones I posted, is that not right then?
why they cant  just say 180x55, 17 or similar god only knows.
Not keen on the vellocette ones as they arent valanced,    If I have to shell out otll be these but only at a push.......the dear ones ;D
https://www.central-wheel.co.uk/honda-excel-valanced-rim.html
Post by: Oddjob on November 29, 2022, 11:48:02 PM
If you still have the original rims or even any rim off a Honda look on the rim itself, they are stamped with the size it is, https://www.ebay.co.uk/itm/275435929210?hash=item402142be7a:g:PI4AAOSwGQZjCO3N&amdata=enc%3AAQAHAAAAoHH5A1oEM2L2xmp5mHAGrXD1Wz0tOMCGFiSXnQ2FDDE3KUkr5zUstpaZVwgn0I9aaGNy%2B7ZQfQCq2isq9zleFN8u2f300YeJt1JwQ5FcGp0WJrga9zi2p70Sq%2BXneaeQqSWefZQ73Us7YzdHySuIQtjzi7XxNW1j7HKopbnATVjDkXHoPw%2Fzcs970NWtMrXKVOW2KCKpOGNrNoDUVWmhnow%3D%7Ctkp%3ABk9SR5LPityYYQ 8th pic down and you can see it.
The rims must match the tyres, you need a bigger width or section rim in order to properly support a wider tyre. The max tyre width they recommended for the standard 1.85 width rim was around 4.10 and even that was considered to be pushing it, some would say 3.60. I used to run a 4.25/85 x 18 tyre on a standard 1.85 rear rim and it was ok but when fully banked over the tyre used to flex upwards as the tyre moved because the rim wasn't really wide enough. When I fitted the Lester mag wheels they were both 2.15 and I was fine to run a 4.10 front and my favourite 4.25/85 rear. They were great and I was able to get insane angles of bank, which was just what I was after then as I was proddie racing the 500 back then.
If like me then your an edge of the tyre merchant and corners are what you live for then get wider rims.
Post by: Sesman on November 30, 2022, 08:08:28 AM
Roo. If it’s any help I went for s/s rims 19” WM2 Front and 18” WM3 rear. I wasn’t brave enough to go 18” front as I was fitting the standard front guard and there wasn’t sufficient supporting opinion on handling/stability effects to persuade me otherwise. I used Avon tyres and I think they look just fine. Handling seems ok.
Post by: Oddjob on November 30, 2022, 02:33:54 PM
Just measured my Lester rims width Roo. From edge to edge they are exactly 70mm. That's the outside edge not the inside. At the bottom of the trough? it looks to be 2 1/4 inches. Does that help identify your existing rims?
Post by: Laverdaroo on November 30, 2022, 02:40:43 PM
Cheers Phil and yes that might Ken, I’m in there tonight as the LHG is working til midnight so I get a pass to bugger about outside
First task is to get on those rims so I’ll pop  a moan up later
Cheers pal you’re a good un
Title: Re: 550 F2 started!
Post by: Oddjob on November 30, 2022, 03:26:09 PM
What about these Roo.
https://www.ebay.co.uk/itm/255844538448?epid=17017083962&hash=item3b9185d850:g:wi0AAOSwgiRZ3JBW&amdata=enc%3AAQAHAAAAoJC4lawGEO0fOSCa%2B%2Be1HvYH%2F8uyvKdJe6QJwq609ISJwDLOACTRv2wztRODluVXOBwqj01eCOoIafOPULuEEHZi7i181eBKW00Lfy%2FMWyYF7wIsBcn6r3d8Be3d6cvfSQZfwssFAsOOqSdN0DW%2Bm7OBrIkKyXLMOhM%2FOR4klyqJHkLhG%2FS%2FiHZvROnQFQ%2FEJQC0DxmMHiJFzvGAPqYmi%2BQ%3D%7Ctkp%3ABk9SR9SenZKZYQ
And this. Hubs no good, only 5 holes for disc.
https://www.ebay.co.uk/itm/334646460901?hash=item4dea7bc1e5:g:YygAAOSwxEFjhgnM&amdata=enc%3AAQAHAAAAoBBUMl5LGQK7aD2ywEptoxMggJc23%2FmhlrA8k76Cdi6AUm%2BJIoovdhKcJbKgYLecsqFogeQLfMRwfOnHekRDbtazHEW583Eq6Z8I3QLOt0HflUzqXF%2FlhzO3ic4VHKjesE30Rab%2BceLfxCLODtU9vwlPrZKS9iw7qj5RmPxquUPl28Id6%2FNogpSiZmH8w8RRfSW3qvJFv1FrUDJNBlSL4Z4%3D%7Ctkp%3ABk9SR6L2gpKZYQ
Post by: Laverdaroo on November 30, 2022, 09:28:35 PM
possibility arent they..........I'm waiting for a few repliesfrom variou suppliers before Imake a move............ thnaks fr having a look though mate..
Post by: Laverdaroo on November 30, 2022, 10:11:35 PM
I’ve been out in the burrow to see if there’s any marks on them and there’s absolutely nothing. I was measuring the outside of the rim like a gimp so foisted over a load of gumf to you lot, I’m not sure what’s going on at the min my thinking has totally gone west. I’m doing it at work as well, just doing stuff that needs doing later not first in the machine meaning I have to do it twice as a result, yer know……rookie stuff, I think I’m going nuts. I think it’s summing to do with being in a considerable amount of pain with my knackered hip and torn shoulder, it’s keeping me up at the min………speacialist next week for a scan hopefully!‍
The result of an 80mph get off after a monster slapper changing lanes and dropping into a lorry groove on a French motorway in 2018.
Anyway enough of my ailment ridden excuse for a carcass.
As mentioned there’s no marks at all so I’ve taken some proper pictures this time for your
inspections ‘unt’ comments
And so…..front then back???
(https://uploads.tapatalk-cdn.com/20221130/c4329dfa64a8689a7fa9e41f9ba9639a.jpg)
Post by: Laverdaroo on November 30, 2022, 10:12:27 PM
(https://uploads.tapatalk-cdn.com/20221130/a02e1e3b4213cb8ad5f08f0150a10af2.jpg)
Post by: Laverdaroo on November 30, 2022, 10:12:48 PM
(https://uploads.tapatalk-cdn.com/20221130/817d1cb32e05b5816a1b47257910035f.jpg)
Post by: Laverdaroo on November 30, 2022, 10:13:26 PM
(https://uploads.tapatalk-cdn.com/20221130/60c19204177e8654995b95b782b97a99.jpg)
For bottom of trough measurements as you mention Ken…..
Post by: Oddjob on November 30, 2022, 10:52:40 PM
What's the width from outside edge to outside edge?
I can see the rim stamped with 40, which clearly means 40 spoke version, you sure there's nothing else stamped on the rim, most likely it the same sort of place.
They look like an 18 and a 19 to me. Most likely 1.85 rim size.
Finally got back in the garage after a week or so off.
Did your collets, just tidying em up ready to be done, need to be polished next.
Before.
(https://i.postimg.cc/FKLTHDgh/IMG-2964.jpg) (https://postimg.cc/3y3XLjcq)
After.
(https://i.postimg.cc/SRydVq0K/IMG-2966.jpg) (https://postimg.cc/k6pWX0gr)
Post by: Oddjob on November 30, 2022, 10:54:22 PM
Just thought. What's the problem with the spokes, looking at those rims the standards spokes will be too long.
Post by: Laverdaroo on December 01, 2022, 11:20:10 AM
The standard spokes are too long, that’s what raised  an eyebrow to start with.
There’s deffo nothing else on em I’ll measure again tonight when I get in.
Post by: K2-K6 on December 01, 2022, 11:53:58 AM
I'd be very tempted to paint those rim interior areas to prevent further corrosion. There appears to be some occlusion in corrosion areas too. Worthwhile carefully inspecting after building for any disturbance around the spoke Wells to make sure non have been affected and will subsequently hold good tension.
Prime with etch, then something like gloss grey to give neutral finish.
Post by: Oddjob on December 01, 2022, 12:00:22 PM
Of course the spokes are too long, the spoke holes sit much higher than the standard rim ones do, as soon as I saw those pics I wondered if they used shorter spokes, the outside can’t change size because you need to fit a standard size tyre on it so with the spoke holes sitting much higher in, due to that deep dish effect the rim has, it has to use it’s own type of spoke. Could mean you’ve got the right rims but the wrong spokes.
Post by: Oddjob on December 01, 2022, 03:26:14 PM
I didn't realise you'd had them professionally polished Roo until I re-read your post on them. It's possible that they polished off the markings showing what the rim size was, especially if it was just lightly stamped or even printed on the rim.
If you still have the old steel rims you could try this. Place upright on a flat surface, get a small spirit level and place it on the highest point of the spoke hole, across the wheel, level the bubble and measure what the distance is from the lower edge to the flat surface. Do the same with the new alloy rims, the difference is how much shorter the new spokes should be.
You could also try lacing the front wheel with the rear wheel spokes, as they are 1" shorter they may fit. If they do at least you only need to buy or alter one set of spokes, depends on how much shorter they have to be.
You could also re-thread the spokes yourself, find out the size and pitch and just run the thread down the spoke more, cut off any excess spoke after fitting and trueing etc.
Post by: Laverdaroo on December 01, 2022, 07:16:17 PM
These are the wheels that came on the bike and the only wheels I have Ken!
That’s the problem……..
I’ve not measured wheels of this dirt before and never had anything to do with spiked wheels before re-lacing the 400, they were standard though so it was an easy search, buy and re-lace.
Apart from that faint 40 which as you say is for the number of spokes…..there are NO MARKS ON THESE AT ALL!
Two more photos front first and then the rear. Basically they are not right so I’ll have to get some more I reckon, serves me right for not doing my homework.
(https://uploads.tapatalk-cdn.com/20221201/4bdf1c9cfa2f3b897b1b03b9cdcc53d6.jpg)
Post by: Laverdaroo on December 01, 2022, 07:16:33 PM
(https://uploads.tapatalk-cdn.com/20221201/9ed9cf38a8251c8624ac88af47052a33.jpg)
Post by: Laverdaroo on December 01, 2022, 07:31:54 PM
I very much doubt they'll get used in all honesty as they're not right and looking back at the picture of the bike when I bought it I remember saying the wheels were odd and the bike sat funny, see for yourself. I think its gong to be a remortgage and a new set of rims tbh! A real shame as I really like these they look fantastic!
I wanted it rolling before crimbo so I could get the VFR on the ramp to get the back end swapped but it looks like another couple of evenings grovelling on the floor to do it as this isn't going to get done for ages now I think and without the rims I cant move it.
Least it gives me a bit of time to try and sort some replacements, and save up! :-[ :-\....
See what I mean?..............
Post by: Laverdaroo on December 01, 2022, 07:32:49 PM
(https://uploads.tapatalk-cdn.com/20221201/02f62afde4134f7d26142c0149cb2340.jpg)
Post by: Oddjob on December 01, 2022, 11:03:12 PM
I really wish you'd stop being so negative Roo, they fitted before, they can be made to fit again. You keep saying they won't fit but you never say why, the only thing you've said is that the spokes didn't fit. You don't describe why they don't fit, are they too short or too long? Do you still have any of the original spokes around, I presume you've bought new ones, a simple side by side comparison will show where the problem lies.
Looking at the pics of the bike the problem seems to be the front forks are not the correct length, far too much of the stanchion showing between the top of the fork slider and the bottom yoke, it makes the bike look hump backed, the back looks fine TBH although I also suspect the rear shocks are over long, it's probably why the side stand is too short, elevated by the forks at the front and the rear shocks at the back. Must a been a doddle to put on the main stand as it would hardly need to lift the bike if at all.
Looking at the width of 70mm from side to side, not 2.15 rims as those are 90mm, I'll see if I can find an original rim from somewhere, I had a few but threw them away, I suspect they are 1.85. Anyone with a set of original rims should be able to give you a definitive side to side measurement, must be loads of members with bare rims lying around.
I appreciate you're having a hard time at the moment but take a moment, look at the problem, don't let it defeat you, work out what's wrong and fix it, if you can't think of a solution, explain what's wrong in detail and I'm 100% sure someone on here will have the answer, it's why we are all here, to help others get their bikes on the road and keep them there.
Post by: K2-K6 on December 02, 2022, 08:16:42 AM
As Ken says, worth double checking throughout to see what is out of kilter, they can't be too far away from solving it.
[attachimg=1]
Your rear could be a WM3 on that illustration.
I though the rim profiles were standard in WM designated elements, even with the large external wall flanges on that type.  The spojes can still be positioned in tbe same place to use normal length spokes.
Worth check the spokes you have against std length. Diameter of rim across nipple seats for this against std. Possibly loosely build wheel with nipples all turned to be flat with spoke ends to define if and by how much the length is out.
http://www.luytenimport.be/lsp-rims-morad-alloy some more info here, interesting that they appear to have bought Akront kit to produce these now in Spain.
Post by: McCabe-Thiele (Ted) on December 02, 2022, 08:31:57 AM
I can identify with Roo being negative - sometimes a rebuid can overwhelm you - self doubt creeps in & all you see is problems not any solutions. This can be made worse if you have any work pressures.
FWIW Roo I've found taking a break - just spending a few days leaving the bike alone or just doing something else that is easy helps.
Have you a spare wheel(s) that you can fit in place to move the bike around even if its not the correct one - then sort out the VFR?
Post by: Matt_Harrington on December 02, 2022, 01:10:23 PM
Ted, wise words! Probably why I have numerous projects on the go, so I can flit from one to the other!  ::)
Post by: Laverdaroo on December 05, 2022, 02:01:17 PM
No wheels Ted sadly. I’m resigned to buying a set for central wheel remortgages in Birmingham. £200 an end!
With the fork debacle that’s an extra 450 quid I’ve had to find and the spokes are a hundred a set so £600 ish all in, plus a new brake arm once found.
Bloody expensive this isn’t it
Docs on Wednesday to see the specialist, going for a double whammy of new teeth and my shoulder muscle sewn back on before March.
Fingers crossed!
Post by: Oddjob on December 05, 2022, 03:25:31 PM
Pointed out a cheap brake arm.
Sell the newly chromed one and it should easily pay for the replacement.
You still haven't described why the rims won't fit Grasshopper.
Post by: Laverdaroo on December 05, 2022, 08:52:27 PM
They’re the wrong size Ken!!
The fact that they’re too thin also has lead me to price up some shiny new ones. I don’t want of rims on it as nice as they are. They’re not the right size for the bike so I’m not using them. I’d rather struggle getting it set up on the right rims and geometry etc than piss about making allowance for this as a result of that and so on.
This is what I e found (under suggestion by you on widths)…….
They’re not over cheap in the grand scheme of things but a necessity for this build. It’d be like buying a Rolls Royce and fitting escort rims to it. Nope, sod the cash, you never know I might fall back in love with it again. Even after it’s kicked my arse so much this last 8 weeks………bloody thing she is
….insert ……(Wagging of fist emoji)
I’ve always ordered spare parts in advance of the next job and it was the same in this instance, however if you fail to check the rim size and width before you start it can really stuff you up!
Anyway, going to press fire on the parts cannon and get them as they’re absolutely spot on in terms of looks. I’m going to have a good clear out of bits over crimbo and get a list organised, that will pay for the extra dosh for the spokes……….how much, blimey!(https://uploads.tapatalk-cdn.com/20221205/409268de84a5c5d266c6f002db0f13da.jpg)
Post by: Laverdaroo on December 05, 2022, 08:55:25 PM
(https://uploads.tapatalk-cdn.com/20221205/a0d5c3229e74c82cf8eb6c98459d839c.jpg)
Post by: Laverdaroo on December 05, 2022, 08:55:41 PM
(https://uploads.tapatalk-cdn.com/20221205/f80141403abb4f4f61c887615fb0d0e6.jpg)
Post by: Oddjob on December 05, 2022, 10:40:29 PM
The trouble is Roo the pics you're showing look like the rims are actually the right size, surely the tyres that came off them would tell you what the size is, unless of course you're referring to the width of the rim and not the rim size like 19 and 18" as they are supposed to be.
The new rims are nice, maybe the spokes you've already bought will fit them?
Oh and it was me saying you're being negative, it was a comment to say, don't look on the dark side, look at what you need to fix the problem, look at it as an opportunity, a chance to shine, to show that you're not defeated by a little set back. The initial post really did read like you'd been defeated by the problem and started to give up, that would be a shame and not the person I think you are.
Chin up mate.
Post by: Laverdaroo on December 05, 2022, 10:44:56 PM
Too thin, yes. the spokes will fit the new rims but they're zinc plated and I'm not spending good money on these rims and then stick those on, it'll look crap and they rust when you turn yer back and i dont want to do it twice...........back in a min gotta dash out to the shed..........
Post by: Laverdaroo on December 10, 2022, 06:09:31 PM
Sadly Matt Nathan is having 'chipping' issues after polishong so hasn't quite cracked the process and is experimenting further but had a good chat with the chap recommended at CAMCOAT, what a cool bloke, super helpful!
Sent me links to process, examples of work hes done etc and was cool to collect them and everything so I'm hopefully sorting them out next week and getting them sent off. £260 plus the Vodka & Tonic. Cheaper than chrome and better than the billion hours of 'mental white noise' sanding them down.....(if there was enough metal left), in a cold shed 8)
Didnt think that was too out of sorts and the results and process look fantastic. I shall report the results up on here but liking this aready tbh.
Cheers Ken, top lead and a 'reet problem fettler' that is.
As ever, you ledge ;)
Post by: Laverdaroo on December 16, 2022, 10:17:43 PM
Cold weather be dammed, got a pass for drying stuff in the kitchen, always said she was alright
Crimbo dec’s being put to good use too(https://uploads.tapatalk-cdn.com/20221216/d0556b4c9e67ce5931dbc4d9adad036a.jpg)
Post by: Laverdaroo on December 16, 2022, 10:18:06 PM
(https://uploads.tapatalk-cdn.com/20221216/e1cd8b6bb1946a32b3eb7c7830c466d2.jpg)
Post by: Oddjob on December 16, 2022, 11:46:18 PM
Looks like a cbr600 mc, same as used on my cb1300, I’m also fitting the same except I’ll be trying to fit a matching clutch mc as well if I can figure out the way to convert the 500 to an hydraulic clutch. You may find that any brake fluid leakage will peel that paint off which is why I’m having mine ceramic coated in satin black. I’ve got some spare sight glass windows if you need one Roo. Just use a small screwdriver and drill it through the glass and lever it out. You can also buy the lever pivot pin in stainless if you look around. I even got custom made covers for the top with 500 four engraved on them.
Post by: SteveD CB500K0 on December 17, 2022, 06:34:49 AM
We can now all use your wifi Roo.
Post by: Laverdaroo on December 17, 2022, 09:06:03 AM
You’ll be lucky, I struggle to get on it most days, you fill yer boots!
Post by: Laverdaroo on December 17, 2022, 09:43:45 AM
That would be cool Ken, cheers. Yeah they’re offa 93-97 cbr6
I’ve not had any issue with brake fluid stripping paint in about 20 years of painting these on and off for various repairs, tart ups and crash damage. It’s calliper paint and I’ll hit it with 2 pack gloss lacquer when they’ve dried for a bit. They usually come out looking good and with fair durability too.
The coffee jar with the budget in has had a hit because of the rims so reigning in a bit and making do. Just means a bit more nannying.
SLR  front cal for a pall a few years ago now like but looked fair to say it was slid down the road at 45mph(https://uploads.tapatalk-cdn.com/20221217/504235cfa508761d003f4fcf588c334f.jpg)
Post by: K2-K6 on December 17, 2022, 12:12:06 PM
If you'd like any suggestions to go with this I've a few ideas Ken.
Something like this uses piston and seal that could be used as slave for clutch system
[attachimg=1]
They are mtb caliper but easily available seals usually and using conventional brake fluid. Possible to get a cylinder designed and machined from alloy bar that would just sit in place of 500 mechanism to push clutch rod. Obviously hydraulic feed through cable hole in casing, could either bleed with cover off or put a "chimney" bleed back up out of case to facilitate.
Post by: K2-K6 on December 17, 2022, 12:22:47 PM
Along the same thought lines, MTB brakes (quite a few of them) use oil for hydraulic system that's not corrosive. The seals are the only real change needed as DOT liquids and these are definitely not compatible with seals swelling badly in wrong application.
There's long history via Citroën system though with their LHM (liquid hydraulic mineral ) systems routinely used for both suspension and brakes. Many European original power steering system/pumps also mineral oil specific too. Easy to get oil for them.
Post by: Laverdaroo on December 17, 2022, 01:33:45 PM
Loving the HOPE stuff you mention, My pal always has it on hs down hill bikes he uses, always swears by them fo their ability to never go wtong. I just love the engineering.
While I'm on, could anybody recommend a shop that might want to work on my tan and get these dents out? Ive taken it to three different places and all have nung onto it, decided they dont want to do it and then not ring me. Just been to collect it for the third time anfd running oit of options really down here.
I really wan to take it to somewhere where they do this sort of thing rather than a body shop that deals with cars as they simply cant do it. I just want the dent out, the painter said he would nanny it up pre paint ans was under the impression that a slide hammerf and some tacked on rods th grip would be the way  forward but two places have said that they need to patch it or cut bits out!......................I dont bloody think so!
Any help gratefully logged and acted on if poss,
Thanks all.
Post by: Laverdaroo on December 17, 2022, 01:35:20 PM
(https://uploads.tapatalk-cdn.com/20221217/bea5c94af4ec0b7dffbab7d721619972.jpg)
Post by: K2-K6 on December 17, 2022, 01:45:54 PM
For the dent, have you tried a car dent repair specialist rather than bodyshop?  There's some good kit with those guys for getting/massaging dents out as they are aiming to do that without repaint if they can. Quite a few focused on lease car prep before handback as they get hammered for any condition problems at lease end.
I've seen them getting some very restricted dents out of door panels and rear wing sections with extremely limited access, usually they're mobile operators that may give you a look-see to assess.
Post by: Laverdaroo on December 17, 2022, 01:56:02 PM
I spoke and took it to a couple of local fells's who do that sort of thing as I thought it might be able to be pushed out rather than pulled but they shyed away from it. Including Dentmaster! One said it was too thick, I did mention rangerover panels are about as thick but he said he wasnt up for it........so be it, move on ;D
If I cant find anybody I'll drill it and put some self tappers in  and pull it myself. Im sure they can be brased up afterwards to get it sealed again and just found a wicked chap in Brizzle that can brase like a pro so Icoud take it to him. A little bit dissapointing but there must be someone that does this sort of thing. Thought it prudent to ask on here, you never know, somebody might have had a good experience with someone tucked away up an ally or something somewhere.
Not that sort of experience up an ally, Phil!! (sesman) ;) ;D
Post by: Sesman on December 17, 2022, 02:19:53 PM
He, he…you anticipated that well Roo. A missed opportunity 😀
Post by: Laverdaroo on December 17, 2022, 02:24:20 PM
Got your number mate ;) ;D ;D
How are the hooves, you Irish dancing and back at your Zumba classs yet?
Post by: Sesman on December 17, 2022, 02:36:50 PM
Still hobbling and doddering. Sat on the cat yesterday….very alarming.
Post by: Oddjob on December 17, 2022, 02:45:45 PM
Already got the slave cylinder I'm planning on using. It's a lot smaller than that pictured and already satin black, also found a longer pushrod as well in case I need to extend the current one. All I need to figure out is how to mount the slave cylinder, the bike it comes off uses a thick metal bracket hiding under the sprocket cover, it's adapting that to fit the 500 that's proving a problem, saying that until I get the engine round to my garage I don't really know how I'll do it. It may turn out to be incredibly easy in the end. I haven't worked out whether to use the existing 500 sprocket cover or use the 550 one that doesn't have the clutch push rod mechanism in it. The problem with the 550 one is getting the hydraulic line in without cutting a hole in the cover.
I'll find a spare sight glass and send it down after Xmas Roo, might get lost by or lovely PO the way they are at the moment.
Post by: Laverdaroo on December 17, 2022, 03:03:54 PM
In nomrush mate, thanks pal :)
Post by: K2-K6 on December 17, 2022, 04:06:48 PM
I was thinking more along the lines of using a hope piston and seal kit only, then getting a simple cylinder turned out of billet alloy that would sit into the original Honda casting (where the clutch lifter sits) with the hose going out through the original cable hole. It would just be a concentric cylinder, maybe a tab to stop it turning, that would replace original cable lift mech and you wouldn't know it's there.
Post by: Oddjob on December 17, 2022, 05:28:29 PM
You'd still have the problem of where the banjo hole would be, it needs to be behind the piston and that puts it either on the outside of the casing or a compromise somewhere on the inside. TBH until I try a test fit on a 500 sprocket carrier it's academic, it's all in my head ATM and like most of my ideas they constantly get updated and evolve. My idea at the moment is to either mount the slave on the steel plate it's originally mounted on and adapt the plate to fit OR it's mounted on the casing with the upper part visible and the line and banjo coming through the casing rather than running down the outside of the casing. My slave cylinder is very small, not a lot wider than the standard hole in the 500 casing.
Post by: Laverdaroo on December 17, 2022, 05:54:52 PM
Keep going fella’s, I’m enjoying this……..
Post by: K2-K6 on December 17, 2022, 07:54:13 PM
Interesting if you could fit a drop-in solution to convert that other's may find attractive too.
Hope items to be clear, I've used those as impetus as you can usually buy replacement piston and seal kits that could be useful and from 14mm up to about 25mm in different bore sizes that could impact design.
They use fluid entrypoint close to face of piston (brake pad location) with a diagonal drilling that passes to rear of a blind bore chamber rather than being restricted to entry at any particular point, this may facilitate hydraulic through original cable route with no modifications as they also go into the caliper with banjo or straight thread coupling. So it's the design detail that looks interesting.
Hope are recognised for the ease of spares supply and should make it easy to use any component if suitable.
Roo, we currently have a few different types on DH bikes, like these monobloc six titanium piston calipers
[attachimg=1]
[attachimg=2]
For those that haven't seen them, or their scale, they'll fit into the palm of your hand easily. Beautifully made and designed.
Post by: Oddjob on December 17, 2022, 08:39:32 PM
Just a thought Roo but if you removed the lever arrangement inside the clutch cover of a 550 I wonder if you could fit a small hydraulic slave cylinder on the outside, the metal I think is thick enough to stand the pressure, so the little bar end thing goes inside the slave cylinder, like the end of the push rod did on the 500 and pushes straight down instead of the cranked arrangement it currently is. That's if you fancy an hydraulic clutch of course. The 550 isn't renowned for having a heavy clutch but the lighter the clutch action is the better as we get older. You'd need to leave the cable lever in place or fit a blanking plug.
I've got a spare lower part of the L/H switchgear which I've ground off the cable and lever bracket, so as to accommodate the clutch master cylinder, that's if I get solve the problem of course. The MC already has a mirror mount on it so that's another bonus as it sits the mirrors higher so you avoid the elbow view. Also has a starter switch. Both my MCs are apart ATM as they'll be ceramic coated in satin black. Hence why I bought spare sight windows, plus they are a matching pair so another bonus. I do have a spare clutch MC if you ever need one to match the brake MC.
Post by: amx1992 on December 18, 2022, 05:44:34 PM
I made a hydraulic clutch for my 400, using the seal from a hope master cylinder (10mm ish), and machining a cylinder and piston out of some aluminium. Worked really well and the clutch was really light, too light for me really. I ended up swapping back to cable with a bearing in the pivot.
I've just mocked it up so you can see roughly how it looked
[attach=1]     [attach=2]
[attach=3]     [attach=4]
Post by: Laverdaroo on December 18, 2022, 08:18:57 PM
Haven't had a chnce to read any of this yet but going to...not ignoring you all, looks fascinated but hard at it and havent had a 30mins sot to have a proper digest..............
thanks all
Post by: K2-K6 on December 18, 2022, 08:23:09 PM
Nice work and overall concept am.
Yes you'd certainly get a potent ratio with that bore size, think you're right at 10mm or they may be 10.5mm. Probably from a mc like this one
[attachimg=1]
Same concept by pulling but using a piston and seal from a caliper at 15mm (still with mc shaft seal though) and perhaps a coil spring in blind end of cylinder to help return piston and avoid holding force against clutch could be a development step.
Post by: K2-K6 on December 19, 2022, 08:55:13 AM
Thinking that through  :) it's the other way round regarding ratio and slave bore size. Larger piston will give less travel and more power to accentuate how easy it is to operate.  Hope now make a smaller mc piston (9mm I think) in their 4 series brake system that may help, but with this of course adding to the bike's original ratios accumulated from the cam and cable lever effects built in .
You'll likely need the bigger sized piston if going straight to the clutch push rod as it will delete those leverage elements built in above.
Post by: Laverdaroo on December 21, 2022, 07:28:56 PM
Right…………exciting and hurried unwrapping commences(https://uploads.tapatalk-cdn.com/20221221/ed2387f72fa5649be4c2f0d60fdd011e.jpg)
Post by: andy120t on December 22, 2022, 12:14:14 PM
Hold on with the unwrapping - It's still 4 days until Christmas!
Post by: Laverdaroo on December 22, 2022, 12:28:28 PM
I have Andy
Well, proper chuffed with that!
It’s come out really nicely (https://uploads.tapatalk-cdn.com/20221222/500358fd1f195cd79212b889cff03abc.jpg)
Post by: Laverdaroo on December 22, 2022, 12:29:09 PM
(https://uploads.tapatalk-cdn.com/20221222/1931f399b373d471efd4a3f019a591b4.jpg)
Post by: Laverdaroo on December 22, 2022, 12:29:37 PM
(https://uploads.tapatalk-cdn.com/20221222/3859a4f485cf994568677e1e909808a3.jpg)
Post by: Oddjob on December 22, 2022, 03:04:04 PM
Thought you were going for nut brown?????? I know you steered Ted away from it just so you could be the first  :D :D :D :D
Post by: Sesman on December 22, 2022, 03:06:31 PM
Yup, nice job that- really smart..
Post by: Bryanj on December 22, 2022, 04:08:33 PM
Be running by boxing day
Post by: SPR on December 22, 2022, 06:04:25 PM
That looks excellent - going to be a cracking bike when assembled
Post by: Laverdaroo on December 22, 2022, 06:37:54 PM
I actually asked for beige! ;D
New levers came today, adjustable for length, span and the move up and pivot  rahher than snapping. I had them made by a pal abroad..really rather impressed TBH     The wheel rims and spokes came as well via Parcelfarce. I asked to have them delivered to the PO in the village  as I wouldnt be in so of course when I came home they were on the door step in the street being splashed by the tractors.......... surrounded by idiots! ;D ;D ;D
Post by: McCabe-Thiele (Ted) on December 22, 2022, 06:47:32 PM
What colour is the frame Roo in some shots its looks pewter-silvery, some bits black - is it heat sensitive paint or an odd lighting effect ?
I knew I should have stuck to the colour that dare not speak its name " tun nworb"  ;D ;D ;D
Post by: Laverdaroo on December 22, 2022, 06:53:37 PM
It's super dooper, extra jubbly, 'shiney as buggery' gloss black. Its just close to the lights on the bench so looks a bit weird as Ive got LED bulbs in my battroom lights that hang above it.
You know the rules, you cannot mention the 'Voldemort' colour, Oddjob will be chastised later as per Coucil Brown, rulings statute 7b, fig 2.6. ;D ;D ;D
Post by: Laverdaroo on December 26, 2022, 01:15:49 AM
Smashing day today, The Long Haired General was working at the pub so Santa brought me a whole day and evening in the shed……..bliss
Set the valves, drained the oil out, got ‘sammed up’ and managed to bob the engine in on me own without so much as a mere graze of the frame.
Chuffed with that.
I fitted on as much as I could whilst stopping for some snap at about 6pm but had a great day. Loads done and back on it tomorrow(https://uploads.tapatalk-cdn.com/20221226/d7a324d0662478efbd4171e34f526d51.jpg)
Post by: Laverdaroo on December 26, 2022, 01:16:23 AM
(https://uploads.tapatalk-cdn.com/20221226/48fd5013a16fe550cb4c37f4532c7894.jpg)
Post by: Laverdaroo on December 26, 2022, 01:17:33 AM
(https://uploads.tapatalk-cdn.com/20221226/0b2b771e9e6b22634959975777f17a2a.jpg)
Post by: Laverdaroo on December 26, 2022, 01:18:08 AM
(https://uploads.tapatalk-cdn.com/20221226/a74ac191a11779b5c0e80cc71fa47a6a.jpg)
Post by: Laverdaroo on December 26, 2022, 01:18:51 AM
(https://uploads.tapatalk-cdn.com/20221226/d917851d04d1bd26a3ee4b6a10a1ad5e.jpg)
Post by: Laverdaroo on December 26, 2022, 01:19:25 AM
(https://uploads.tapatalk-cdn.com/20221226/6ea6c2d54f92db3995cb2c9acd036622.jpg)
Post by: SPR on December 26, 2022, 07:59:44 AM
Great work ..... looking good
Post by: McCabe-Thiele (Ted) on December 26, 2022, 08:04:20 AM
Looking good Roo - nice one.
Post by: Trigger on December 26, 2022, 09:39:17 AM
Look like it is coming along.
 Are you using a 16" rear wheel as, i see you have gone for a flat hoop ?
Post by: Laverdaroo on December 26, 2022, 10:16:56 AM
No the rear is 18 but there’s heaps clearance for it. It was all tried and test fitted with a pals rear wheel before bits were bought.
Post by: Trigger on December 26, 2022, 11:20:28 AM
I did a load of road test some years ago to see what could be fitted with a flat hoop. With 325mm and 335mm length shocks the wheel hit the bottom of the seat pan and locked up the rear over pot holes and a hump back bridge and, tried to kick me off the bike like buckaroo  :o
Increase the shock length over 340mm and it effects the handling while braking into corners ( the rear end tries to over take the front ) and the drive chain angle had changed that much that it was cutting in to the swinging arm.
The only way i found it to work was, a kick up hoop to give that extra 25mm of travel with 335mm shocks.
I am surprised that it worked for you on a road test. What length shocks are you using ?
Post by: Laverdaroo on December 26, 2022, 12:13:15 PM
I can’t remember without digging them out of the spares bin, they’re YSS  after market hobbies. I did have concerns hence the measure up. There’s so little of anything standard on this I had doubts that everything would work together as I had no reference points to work from and the info is vague at best as so many have been messed with etc.
I’m hopeful I’ve done my maths right but this build hasn’t half been a bugger so there’s time yet for a catastraf*ck of a scenario to pop up and wee up me leg
Lacking a swing arm pivot bolt at the min as I had to cut the arm off the old frame and sacrifice it to save the arm, there’s one left at CMSNL but reluctant to spend £44 plus the dreaded vodka and tonic plus import duty. Hoping somebody on here might have a spare lurking under the bench somewhere!
Post by: Bryanj on December 26, 2022, 01:12:25 PM
Roo, i can lend you one for mock up till you aquire one, 500 that is
Post by: SPR on December 26, 2022, 01:14:41 PM
I've got a 500 one that I got as a spare with my other swing arm - you are welcome to it if it fits ..... just PM me your address
Post by: Laverdaroo on December 26, 2022, 03:00:04 PM
Is this how that U shaped bit goes on, I’ve bought this as mine didn’t have a serviceable one and not fitted one before. I realise the swinger isn’t on but it looks high, touching the rear footpeg bracket. Does the stand or the swinger have a ringer stop or similar?
Hint like the thought of it banging me lovely, not-nut brown powder coat?(https://uploads.tapatalk-cdn.com/20221226/853c22ef0dd9c5643f53af616c2ecf0f.jpg)
Post by: McCabe-Thiele (Ted) on December 26, 2022, 03:17:01 PM
I beleive that is normal as you need tension in the stand when its up to stop it bouncing aroune. The bump stop will most probaly be mounted on the silencer bracket or silencer itself.
I just taped a temporary rubber stop  on the stand to prevent any damage until the silencer is in place.
FWIW on my 500 I could mount the brake pivot in place with the swing arm & shockers  in position unlike the 400 where it had to be fitted beforehand.
Post by: Laverdaroo on December 26, 2022, 03:28:55 PM
That’s good to know cheers Ted, I knew I’d read summut about brake arm in first or you can’t with the arm in but you’ve reminded me that that was on the 400. Nice one mate. You get the boiler sorted or are you still huddled round a pile of burning books in the conservatory
Post by: McCabe-Thiele (Ted) on December 26, 2022, 04:59:37 PM
We've managed to keep the house reasonably warm hopfully it will be sorted tomorrow - just to make life easy my Jeep battery died a couple of days ago - the battery was two months out of its 4 year warranty - after two days on charge it's only 12.2 volts - replacement on its way from Tanya Batteries.
If it comes in threes we have one more thing to pack up before 2023. ;D ;D ;D
Post by: Bryanj on December 26, 2022, 06:52:50 PM
Just make sure its not you Ted!
Post by: McCabe-Thiele (Ted) on December 26, 2022, 06:56:24 PM
I plan to wake up with a pulse for a while yet but I guess that's down to a higher manufacturer than Honda or Jeep.
Post by: Sesman on December 26, 2022, 07:10:48 PM
Certainly a higher authority. How’s the build coming on Ted. Not see a post for a while.
Post by: McCabe-Thiele (Ted) on December 26, 2022, 07:35:26 PM
Cold weather has slowed me down to a snail pace - presently just tinkering - I've replaced various plastic block connectors with Kojaycat ones. Done stuff not worthy of a post like cleaning the top column nut with Evaporust as the threads were slightly rusty. I need to finish polishing the fork legs but just too dam cold. Can't heat the garage with the tower heater as that's heating the Hall/Staircase/ Landing until the CH is sorted.
Post by: Sesman on December 26, 2022, 07:53:44 PM
Ok, all the best and looking forward to progress…
Post by: Laverdaroo on January 05, 2023, 08:02:28 PM
Evening all,
not written anything for a while as I've been up to my neck at work during the day and not had much free time.
Anyway, since the engine went in on christmas day I've done odds and sods and slowly got as much on the bike as I can to keep it rolling although at pottering speed ;) :)
The electric tray is on, new reg rec, Munit, starter sol etc, headstock bearings in, fork tops on and set to what's available in terms of room, time will see if I have to try something else but for the min, the front end is firm but not 'crashy and bangy' like it gets when there's too much pre load. Besides you cant tell withought riding it, After fitting them I soon realised that heres no enough room, to the bottom of the bars, for the tops to offer their full range of preload capability. So far they are wound down to just  1 and a half bars on the rising centre and there's half a mm to spare before they touch the bars. Bit of a bugger but I'm going to wait to get it all on there and some juice in it to see what effect that has had on the front. I may still have a smidge of adjustment on the forks and the bars but it's hard to judge when you're balancing on a bike lift that's on a sheet ofply in a wooden floored shed! You're only 6" up but you can feel the flex in the floor and it doesn't half make you nip up so I'll wait until she's down and see what's occuring
Fuddled about with the fork ears to get them on which worked a treat as I had to pass wires through for the new indicators and bugger about a bit. All went well until I realised I hadn't taken the gaters off the front.............(Cheers Ken) ::)
Anyway, they're off and away in the 'to sell' pile and anything else thats in the parts box that didn't need taking off again to fit something else later on, has been put on so it's starting to look like a bike again, just a proper one, not the heap that I bought!
 I've rebuilt the front master cylinder I bought from a 97 CBR600, a great unit and I've used heaps of them over the years as they work well, 'mate' to heaps of different systems and are resonably cheap. I'm waiting for the 2K laquer to harden up aftyer giving them a make over and I'll probably revisit them at the weekend and get the masking off and the the thread bolts off them with a view to getting the front brakes rigged up........maybe.
It sounds like I've done loads of stuff but I havent really, you lot know how long these things take! I'll just do those couple of jobs, probably take an hour or so, PA! by the time you've got sorted, had a thunk, got the bits out, cleaned them, faffed about, made a  brew then decided the bolts that are there aren't as good as you thought so need to find some more, gone for a poo etc etc.................you've spent the morning in there and got nowt done ;D
But progress is good, I've also built the wheels whech turned up on Christmas Eve, not done any since the 400  but it went well and the process was fairly painless again,  they had to come apart during aborted attempts, but only twice ;D ;D ;D
Really chuffed how they look and I came home tonight to a kitchen table full of 'Avon Roadrider'  with a note on them which simply said MOVE!  ;D ;D ;D best get them shifted and hopefully she'll forget for a while before I get reproached ;) ;D ;D
Thats the sort of post I like coming home to ;D ;D
The indicators are all on as are the stands and the carbs went on the other night after a check over, bench sync and the floats reset to proper heights. When I built them I never did it as I knew they would be on the shelf for a while and probably get  knocked so waited to just before fitting them.
So, heaps done, progress is steady and looking forward to a day off to get a bit more done, the weekend looks hopefull but there was talk of a 27 cube concrete pour happening Saturday so things may change................me, personally, I'm praying fpr torrential sleet and high winds then it deffo wont happen ;D ;D
Would somebody that has an F2.............Yup, you Phil ;) would you mind taking some piccies of the O/S foot peg and brake switch mounting area for me? there are some differences in how the PO bodged the system on it when it had those awful rearsetts on and I have no reference to where everythig goes, Ive set it up but the spring seems at a rather daft angle and wpudnt put money on it being correct so dome decent piccies woud be dead handy if you get a min?
As normal I cant post piccies from this Chrome book as its bloody useless so I'll bob them on under here, a post at a time through the tappatalk farce so bear with.
Bit of an epic but a bit to bore you with and hopefully made you smerk cos I mentioned poo etc.
Cheers all..........
Post by: Laverdaroo on January 05, 2023, 08:02:54 PM
(https://uploads.tapatalk-cdn.com/20230105/2813a33da6d86bfceb2618a24be75014.jpg)
Post by: Laverdaroo on January 05, 2023, 08:03:32 PM
(https://uploads.tapatalk-cdn.com/20230105/6882b91f229971574492e5ddb24d60d2.jpg)
Post by: Laverdaroo on January 05, 2023, 08:04:04 PM
(https://uploads.tapatalk-cdn.com/20230105/84ea3ad27da059aae2b327a9eaa03673.jpg)
Post by: Laverdaroo on January 05, 2023, 08:04:41 PM
(https://uploads.tapatalk-cdn.com/20230105/4c3a503688392587f73e53d09783c756.jpg)
Post by: Laverdaroo on January 05, 2023, 08:06:15 PM
(https://uploads.tapatalk-cdn.com/20230105/4fa37d7e87bd14834988bac777bc9c0c.jpg)
Post by: Laverdaroo on January 05, 2023, 08:06:59 PM
(https://uploads.tapatalk-cdn.com/20230105/ed14efcd3684fe576d8a97f74911fbc0.jpg)
Post by: Laverdaroo on January 05, 2023, 08:09:36 PM
(https://uploads.tapatalk-cdn.com/20230105/dbef6e441bf476658408fba174cde35f.jpg)
Post by: Laverdaroo on January 05, 2023, 08:12:51 PM
(https://uploads.tapatalk-cdn.com/20230105/a9ee1e20430ff91ce6fdb2ba4234ff60.jpg)
Post by: Johnny4428 on January 05, 2023, 08:14:46 PM
Nice work Roo, most definately looking like a nice job. Going to end up with a ice bike there!
Post by: Laverdaroo on January 05, 2023, 08:21:58 PM
I hope so! Still in two minds whether or not to get rid once done, this ones kicked all the way and Ive kind of fallen out of love with it. That'll probably change when I get stuck into the nice jobs like the wiring and getting some sound out of those exhaust pipes but up until then, she has been and will be referred to as 'That bike' ;D
Post by: andy120t on January 05, 2023, 08:23:18 PM
Every time I read this I'm thinking  'Born in the USA' .. great backdrop! (bike is looking fab too!).
Post by: Laverdaroo on January 05, 2023, 08:31:25 PM
I know, terrible isnt it ;D
My dear friend from the states gave it to me to fly from my house!..............eeer, yeah, right ;D As a comprimise and as  I generally skype him when I'm in the shed, I have 'humoured' him by putting it up in there. Bless him, he's an absolute star.
A bit of 'taking the piss'ammo when we're chatting.
cheers fella's
Post by: Laverdaroo on January 07, 2023, 12:50:01 PM
Somebody that has an F2.............would you mind taking some piccies of the O/S foot peg and brake switch mounting area for me? there are some differences in how the PO bodged the system on it when it had those awful rearsetts on and I have no reference to where everything goes, I've set it up but the spring seems at a rather daft angle and woudnt put money on it being correct so some decent piccies woud be dead handy if you get a min?........anyone? The parts book is less than helpful and I'm struggling finding anything on face tube or the like where a good look is available so help needed please.
Its the little 'L' shaped bracket thats got me, the one that holds the brake light switch, does it sit on the inward side of the frame    or the outside?  If the latter, the spring doesnt appear 'happy' but theres a captive nut on the rear of the frame so in that case, does it sit between the frame and the plate that holds the clutch cable and engine mount?
Any suggestions gratefully accepted.
Post by: Sesman on January 07, 2023, 01:40:29 PM
Like this.
Post by: Laverdaroo on January 07, 2023, 01:53:52 PM
Aye, I have mine mounted the same but when you put the spring onto the bottom of the switch and poke it onto the arm on the pedal, the spring sits at a really funny angle and you dont get a great deal of movement from the switch even at full adjustment before the switch activates. It just doesn't seem very honda like and looks like an afterthought. If the plate was mounted at the rear of the vertical frame rail the movement would be a vertical pulling action rather than a sideways and upwards type affair. The spring sits at a daft angle and, well, just doesnt look right. I've a genuine honda switch and all the hardware has been put back to standard so clearance isnt an issue. Just looks crap. If this is how its supposed to be, I'm a bit surprised tbh. Cheesr Phil, Simon sent me some night time shots of his earlier  ;D ;D but he said he'd send some more of his set up with the spring on etc a bit later so Ican compare all.
He said his spring is shonky also so it might be just the way?
I'm out there in a bit to have a fuddle about so I'll rig oit up and post a piccie,moght just be me being thick but with no reference I'm shooting in the dark so to speak!
How's the recovery coming along mate, you back  to long jump practice on a Tuesday evening yet? ;)
Post by: Sesman on January 07, 2023, 04:04:37 PM
Arm on the pedal? Sorry to be pedantic but do you mean the pedal pivot shaft. Just checking to make sure you have the correct pedal and not some other unit with a spring hook on the actual pedal lever.
Post by: Laverdaroo on January 07, 2023, 04:26:23 PM
Soz, it’s me naming stuff wrong……
See piccies but the shaft that the spring attaches to on the inside of the frame at the top and at 90 degrees, the arm to the rear brake. It goes through the frame and the pedal goes on the other end on the ones(https://uploads.tapatalk-cdn.com/20230107/6c72d9efb8ff9ffc4ff9852ab20adf2d.jpg)
Post by: Laverdaroo on January 07, 2023, 04:26:44 PM
(https://uploads.tapatalk-cdn.com/20230107/9ac7105a5256298ae5d176043d04ba97.jpg)
Post by: Laverdaroo on January 07, 2023, 04:27:22 PM
(https://uploads.tapatalk-cdn.com/20230107/82d8ee79a3fe31cd48f11bebf06cd7f0.jpg)
Post by: Sesman on January 07, 2023, 05:10:04 PM
Yup, just like mine.
Post by: Laverdaroo on January 07, 2023, 05:20:36 PM
On the bit of the spring that goes behind the frame, I’m ok to bend it back up and around the hook arent I?
Post by: Sesman on January 07, 2023, 05:27:03 PM
Yep. Sure it’s the correct spring? I’ll have a totter around the garage tomorrow and see if I can find the original.
Post by: Laverdaroo on January 07, 2023, 05:32:33 PM
Came out of the right Honda bag so I have no reason to doubt it’s right, like.
It’s the open end on the right, doesn’t take much to slither off the hook so I’m ok to just tweak it up and make it more hook like, yer reckon?(https://uploads.tapatalk-cdn.com/20230107/786de36a99f93ae09514f88058892552.jpg)
Sorry crap photo, put me specs somewhere but can’t gfind em!
Post by: Oddjob on January 07, 2023, 05:59:19 PM
Try angling the bracket back so it lines up more with the brake arm.
You could always try and fit it behind the bracket and see if moving it more inboard helps.
Post by: Laverdaroo on January 07, 2023, 06:01:57 PM
I think that might be the way forward then it’s just up and down, instead of diagonally upwards against the bend in the spring.
Post by: 3scs on January 07, 2023, 06:05:34 PM
This is mine try turning yours round abit
Post by: 3scs on January 07, 2023, 06:24:15 PM
And this is the other end
Post by: Trigger on January 07, 2023, 07:11:02 PM
The brake shaft needs adjusting more or it is fitted with a K3 shaft  ;)
Post by: Laverdaroo on January 07, 2023, 10:44:29 PM
The dots are lined up and it’s sitting thus so for fit it appears ok it’s just that angle of dangle, bear in mind ths is the wrong spring and one I made to make do until I found a replacement but this was fitted with the old spring first and the same outcome. I’ve a NOS one coming from Holland in the next week.
The nuts off at the min waiting fir some ring terminals to get here tomorrow so I can get the earth sorted and button it up. Rear tyres going on Monday hopefully so it might be easier to suss when all that’s in and lined up.(https://uploads.tapatalk-cdn.com/20230107/a04667db201a1229e842424264140989.jpg)
Post by: Laverdaroo on January 07, 2023, 10:44:57 PM
(https://uploads.tapatalk-cdn.com/20230107/ab8e387d4cded1bd2cffde484bce1783.jpg)
Post by: Laverdaroo on January 07, 2023, 10:49:25 PM
(https://uploads.tapatalk-cdn.com/20230107/5885bf2c7a1933fe7c3dfb4b655e5995.jpg)
Post by: Bryanj on January 08, 2023, 08:59:50 AM
Looking at you pic the switch needs rotating clockwise, if the little bracket has a lock to stop it its probably from another model so needs modifying a tad
Post by: Sesman on January 08, 2023, 09:14:52 AM
Yes, the switch bracket needs rotating about 15deg clockwise and stop switch spring eye needs to be inserted Left to right as opposed to the Right to left?
Post by: Sesman on January 08, 2023, 09:29:15 AM
This is picture of the bike as it arrived. I was lucky in that mine was a very original unmolested. The pics a little grainy, but if you zoom in it will provide an indication of the switch position relative to .the clutch casing
Post by: Sesman on January 08, 2023, 09:33:04 AM
This one shows the original mounting arrangement. Again the photo quality is poor.
Post by: Laverdaroo on January 08, 2023, 11:30:37 AM
Cheers chaps that’s dead helpful, just bobbing out then back to go have a look. I’ll report back later
Post by: Laverdaroo on January 08, 2023, 09:54:48 PM
Evening all. Daft question but as the one that came with the bike was glued to the headstock I suspect it shouldn’t have been there but I have no idea where the VIN tag goes
Is it headstock job or is it one of the rear frame rails for this year on the off side?
Anyone got a piccie?
Post by: Oddjob on January 08, 2023, 10:07:19 PM
Only the US imports got a VIN plate Roo, there was a black and chrome sticker on the headstock that said Made In Japan though.
Post by: Nurse Julie on January 08, 2023, 10:20:18 PM
UK model F2's have a VIN plate. It goes on the off side on the downward rail at the back of the side panel. There should be 2 little holes for the rivets.
Shown in this photo
[attachimg=1]
Post by: Laverdaroo on January 08, 2023, 10:32:36 PM
Aha!
I knew I’d seen reference.  Cheers both for swift responsidge
Post by: Laverdaroo on January 11, 2023, 09:17:34 PM
Oh I do like coming home to a load of post in ‘box’ form(https://uploads.tapatalk-cdn.com/20230111/20a3e892bbc61295e9229c6ccd982df5.jpg)
Post by: Laverdaroo on January 19, 2023, 01:08:24 PM
Afternoon all.
So I’ve got the twin calliper’s on the front of the 550 but thought of a question whilst driving about this morning in me digger.
Is it the done thing to use two of the rigid brake lines to mount onto the calliper before using braided lines there after?
Also,  twin lines or single to a splitter and a separate line to each calliper? Has anyone had good results with either methodology?
I’m going to have to get some wire out tonight and see if I can get a length for the different lines as my heap didn’t come with brake lines attached hence the ask.
Obviously if using two of the solid lines means my braided ones will be shorter, I can’t see any advantage in using them but happy to be corrected by this in the ‘know’
Cheers all(https://uploads.tapatalk-cdn.com/20230119/b3c88b44000454f3ac1880b7c305a79d.jpg)
Post by: K2-K6 on January 19, 2023, 01:22:38 PM
It won't make any difference to operating if you go two seperate, split both, single to somewhere then split, the pressure is all the same, so free choice from that point.
I'd favour two banjo on mc then straight run to caliper twice as simplest, least joints, extra kit etc.
Think you can only come straight out of caliper with pipe as that's conditional on sealing the taper at bottom of hole. That's as opposed to using a banjo that seals on the casting face.
Post by: Oddjob on January 19, 2023, 02:52:10 PM
My last way of doing this was single braided line down to the splitter box in the bottom yoke and 2 braided lines from there direct to the caliper. This did away with the rigid line altogether. These were made by Goodridge back in the 70s. Due to them not using stainless steel fittings in that era they rusted badly when in storage so they aren’t really reusable. This time I went to HEL as I’ve used them before and there service is great, slightly different setup this time, still single braided line from mc to bottom yoke, then 2 braided to the hard lines and hard lines into the caliper. Explain to whoever makes them that you want an extra bottom line due to the twin calipers and that should solve you having to measure anything as the lengths are well known by now.
Post by: Sesman on January 19, 2023, 04:59:45 PM
I’ve done the same as Ken, but my only gripe was not being able to find a ready made grommet holder for the solid line on The RHS. But I’m using the standard front guard.
Post by: Laverdaroo on January 19, 2023, 07:55:38 PM
Interesting chaps, cheers.
I have taken the metal brake line holder holder off a knackered mudgard half that I scut off a damaged one in the states ready for this and brought home and had it welded on the OS of the mudguard so for all intense and purposes it looks like it's off a twin disc bike with matching line holders in symetry. Just drilled the weld out and had it 'snotted' on' via the medium of a particularly clapped out mig welder  by a pal.
So after what you guys are saying, get a pair of hard lines and come off them to the master or the splitter depending on how the mood takes me?
I'm going to have to invest in new ones as I dont have any at all and would prefer new bits....it s the brakes after all and seems silly to scrimp on the stoppers when the rest of the bike has had this much work done!
Thanls fpr the replies chaps, any piccies woud be appreciated just so its in my head as a mental image, yer know? But only if you've time.
Got the holy grail in the post this morning all the way form Germany at record speed too. :o......................4 weeks! Two days from Germany to the UK and the rest of the time languishing in the post office sorting orrifice in London apparently!................The UK, great arent we? ;D
check that bad boy out....................Piccie to follow, (crap laptop and its on me phone ;))
whoop whoop, the last (apart from the brake lines) sought after part for the build. Just waiting on sending bits off to get them Cemachromed up in Wigan and then paint n seat and thats it for spends hopefully. S another 600 quid then Roo?? DOH! ;D ;D
Surprisingly the rear shoes were brand new so saved a bit there.........they were the only new bits on it, so they've gone back in. ;D ;D...........still winning..a bit ;D
I had a right faff trying to get the rear wheel in and it just wouldn't fit! there wasnt enough room between the rear end of the swing arm to get both tentioners in and the hub!!  HUGE SWEARFEST!
 After getting a hub from here, a brake plate from there, new rims and spokes I had that 'cold sweat' start thinking it was going tp be an expensive cock up but on pondering over half a packet of digestives and a brew, followed by a good shot of insulin ::) I looked at the rear of the bike and noticed that the swing arm was, what appeared to be twisted, or so I thought. As it turned out, all is fine except the NS plate part  that the chain tensioner goes on and that the spindle goes through was twisted inwards at the bottom. I can only presume its had a knock or been dropped at the powder coaters and I hadnt noticed. It came off the bke OK and unless you were looking for it you'd never know so I bobbed it on and admired the shiney!.
The fix was, and dont roll your eyes it worked like a bloody charm, was to put a piece of 3"x1" on either side of the arm on the inward faces and wind it apart again with pressure from a scissor jack..........and a few taps with a plastic mallet! it all checks out and everything is parallel so Im happy with the bodge, I mean fix.
Anyway, first time success and a sigh of relief, albeit a sketchy bodge. When in Rome and all that! ;)
 Once the chain link is found and I can get it on the bike I can get the back end buttoned up and ready to get it off the ramp and the viffer on for some surgery. It was out by nearly a strong eighth 3/16th's (for the younger crew, about 3 n a bit mm). Squeaky bum moment averted and moved onto other stuff like the brake MC and bar associated gubbins but things are moving on.........which is nice :)
Post by: Laverdaroo on January 19, 2023, 07:55:55 PM
(https://uploads.tapatalk-cdn.com/20230119/630881b0279daab6ddea47c314178634.jpg)
Behold the 'Grail'! Only been looking since December 2021 and made one already but saw this NOS............expensive though but bugger it, Happy Christmas 'Mejima' ;) :)
Post by: McCabe-Thiele (Ted) on January 19, 2023, 08:00:49 PM
What spring is that Roo?
Post by: Laverdaroo on January 19, 2023, 08:02:11 PM
Rear brake pedal return spring OMG!
Post by: 3scs on January 19, 2023, 08:16:39 PM
Foot rest should be with you shortly
Post by: Bryanj on January 19, 2023, 08:17:15 PM
Its a different shape totaly on Teds 500 Roo
Post by: Laverdaroo on January 19, 2023, 08:21:40 PM
Yeah, I know mate. Me n Ted have had several false alarms on my behalfm If I;m hinest I think I might have altered one for a 500 to make a temporary one but dont tell Ted, he'll be gutted!
In my defense this was Feb last year and he wasnt looking at the time, nor did I know how rare they were, paid fiver for it at a jumble. That one's for me to go on Mejima  :) :) :) :) 8)
Post by: Laverdaroo on February 16, 2023, 12:47:13 PM
Afternoon all,
quick update and a few piccies.....
Back end, all sorted and chain on,wheel sits great and free spins beautifully so all chuffed and the bodge appears to have sorted the twisted problem!
Front caliper from Ian has been dutyfully nannied up and is languishing on the bike ready for some new lines, master cylinder prepped and ready, new levers, horn and a few other bits and bobs but mainly....THE WIRING!
It's been chatted about on other threads and Comfy Sofa (Andy) is ploughing his way through the process at the min but I set about it last weekend and got the main cables in such as the starter sol, battery etc. This week has seen the 'input' and 'output 'wires being sorted and on the first attempt............... all 'lit up' and is as it should be.  ;) :) 8)
I have momentary switches on the bars and have done away with the standard ones as the ones I had, (well, one) was shot to hell so it was decided to go the Motogadget route and get some nice dinky ones.
In total theres 5 switches on the bars
Top right- indicator (push once for on, once for off)
Bottom right -start/stop (push once to start, twice to kill)
Top left (facing away from rider) - lights, flick for flash, hold for sides, press again for low, again for High beam. Tap back the same way to turn off, press and hold.
Top left facing rider - Indicator (once for on, once for off)
Lower left, Horn.
Nice and simple.
I've activated the alarm albeit it's on service mode so I can move things without setting it  off, the schematic programme is in the bike and running as it should showing me individual circuits and their draw down via the APP. Keyless isnt activated yet as the Wifi is being a pig at the min, but all in all, a painless excersize with the only issuee being a faulty starter sol which meant I had to wait until yesterday before I could give it a system check with a new one.
Few loose connections but to be expected as all the Ground wires were just clipped together and I dont like to fix anything until its all on then the routing starts. They were sorted with a wiggle and it meant I could check the system out. All appears fine although I cant tell if it's charging yet as I cant start it because the pipes are being 'shinyied up' and I wont see them for a few weeks but aesthetically it's all coming together nicely.
Tank has gone off for a dent to be taken out, rear mudguard is being worked on by a pal (who does that brass thing with a torch that my PC simply wont recognise or spell right so you'll have to guess!) and I'm going to start the tidying up of the wires and get them all wrapped up this week but super chuffed with all the elastictrickery virtually complete.
I had to move the ramp last weekend so dragged her out into the sunshine for the first time and whilst there I realised that that was the first time I'd been more than 2 feet away from it. Looks OK, I reckon. Ken did notice I'd put the footpegs at the rear on backwards ;D, that'll be me standing too close!!
I spotted a few other bits but done those now and they were only routing of this n that so no drama's there.
Anyway, she's coming on.................
Title: Re: 550 F2 started!
Post by: Laverdaroo on February 16, 2023, 12:47:50 PM
(https://uploads.tapatalk-cdn.com/20230216/53ccc8b6a0047a1499399acc0103b810.jpg)
Post by: Laverdaroo on February 16, 2023, 12:48:19 PM
(https://uploads.tapatalk-cdn.com/20230216/620cb898c110d29a8c9c0c01b3538cff.jpg)
Post by: Laverdaroo on February 16, 2023, 12:48:57 PM
(https://uploads.tapatalk-cdn.com/20230216/a3793ec40724d500ff6fa3cd2db1c800.jpg)
Post by: Laverdaroo on February 16, 2023, 12:49:40 PM
(https://uploads.tapatalk-cdn.com/20230216/4f9f2f889a4859a5f4aa6db3fdf48478.jpg)
Post by: Laverdaroo on February 16, 2023, 12:50:14 PM
(https://uploads.tapatalk-cdn.com/20230216/03ea562b07a5bb717d7738512ed09d79.jpg)
Post by: Laverdaroo on February 16, 2023, 12:50:36 PM
(https://uploads.tapatalk-cdn.com/20230216/996c334c5a62b70f4236eecef5e74317.jpg)
Post by: Laverdaroo on February 16, 2023, 12:51:01 PM
(https://uploads.tapatalk-cdn.com/20230216/fd4b7f2a86ede29a3b5135288987ccb6.jpg)
Post by: McCabe-Thiele (Ted) on February 16, 2023, 01:11:44 PM
Plenty of Pasta there Roo. ;D ;D ;D
Post by: Oddjob on February 16, 2023, 01:28:41 PM
Yeah, that's ever so tidy  ;D ;D ;D ;D ;D ;D
Post by: Multiman on February 16, 2023, 01:53:54 PM
Looking really nice mate!
Post by: Laverdaroo on February 16, 2023, 01:55:50 PM
Give over you can hardly see the wiring! somnefolk are sooooooooo  critical ;D ;D ;D
Post by: K2-K6 on February 16, 2023, 02:07:00 PM
At least if they're all labelled clearly, then you know which one to pull out and connect to battery to hot wire it  ;D
Post by: Laverdaroo on February 16, 2023, 03:07:11 PM
Of course, there'd ne no fun  if they werent! ;D
Post by: McCabe-Thiele (Ted) on February 16, 2023, 03:24:15 PM
There seem to be quite a lot of white cables in loops or is that just the flash from the lighting?
Post by: Laverdaroo on February 16, 2023, 06:32:04 PM
yeah, there's loads there Ted nothing is cut to finished length,jjust installed to rig up. I leave it as long as possible for as long as possible in case I might have made a mistake and to allow as many routing options as possible.
As it's not standard I'm making it up as I go along so any advantage is a good one and by pre empting cock ups they dont become quite as awkward to sort. I'm no auto sparks but its all going well, everything works and I'm rather enjoying it.. 8)
Post by: Laverdaroo on February 17, 2023, 12:23:41 AM
Just had a look after reading that again Ted, yes it's the camera flash, they're not all white, each circuit has i's own individual colour.
Theres a secret 'dead mans handle' in amongst that lot anyway band they'd have to know the Munit wiring to hot wire it, but a valid point  never the less. I fitted the same sort of thing with the 400 install too. Saying that all you haveto do on an OE system is poke 4" of wire into the ignition circuit block at the bars and stick the other end in one of the others (I forget which, have it written dow)to get one to go so this is a distinct improvement ;D
Post by: Oddjob on February 17, 2023, 09:19:22 AM
That doesn't work with mine, 2 ignition switches, the handlebar one is completely dead until the other is switched to park. On the F and K3 model it's even easier than that to start them Roo, you just jump the fusebox.
Post by: Laverdaroo on February 17, 2023, 11:11:53 AM
I’ve put a similar thing on mine underneath, one switch has to be in a certain position for the other to work but I. Ths instance it’s that you have to hold it in for 4 secs for it to energise the circuit and allow the ignition to work.
Post by: McCabe-Thiele (Ted) on February 17, 2023, 11:25:45 AM
Hi Roo these are what I have the one on the far right is more like rubber the others seem plasticky/PVC ish not split.
PM me with your address and how many you need - no fees involved.
(https://live.staticflickr.com/65535/52694550423_494581a5a4_o.jpg) (https://flic.kr/p/2ohrkZr)PXL_20230217_111742145 (https://flic.kr/p/2ohrkZr) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
Post by: Laverdaroo on February 17, 2023, 11:30:43 AM
PM sent Ted 8)
Post by: Laverdaroo on February 19, 2023, 12:17:47 PM
Morning folks,
I'd managed to forget to organise some jets for the bike and as I've not had to buy any for the last 15 years, (last LC ownership) could anybody point me in the right direction as to where I might procure some?
I'm after a set of pilots and mains and going form others in my situation with these air boxes I read that a good starting point will be  40 on pilot  and 110 on mains, could anybdy suggest a good source to order some from?
Thanks in advance
Post by: Bryanj on February 19, 2023, 01:21:48 PM
Sirius consolidated in canada do jet kits and pilots, i find their website orrible but i am a luddite with puters, dumfones and suchlike
Post by: Laverdaroo on February 19, 2023, 01:50:22 PM
Well as you know Bryan, youre among friends here talking to me ;D
I have little if no interest in them at all, providing somebody sets it all up, I can use them. If I have to do it you might as well give me a pen and paper and or two cups joined with a bit of string. I simply cant be bothered to be interested in tech ;D ;D
Thanks for the heads up buddy I'll have a look.......
Post by: Laverdaroo on February 19, 2023, 07:46:23 PM
Wow! That’s a terrible web site isn’t it?
I sent them an email, I was going round in circles and all a bit clunky!
Thanks pal
Post by: Johnny4428 on February 20, 2023, 08:57:57 AM
Kicking myself here, I have just posted a set of 40 pilots back to Sirius. Doesn’t help you anyway you still need mains. Late last year I ordered new pilots for the 550, something I should have done a couple of years age when I restored the bike. Anyway probably thought I had spent enough on it. So I had to remind myself of what I had already fitted in carbs, so as the bike was in winter storage I found info online for pd carbs, so thought I had 38 pilots and thought safe bet to order 40’s, turned out I had 42’s (bugger) so had to exchange them. Although it was a couple of months ago they were happy to exchange no questions asked.
Post by: Laverdaroo on February 20, 2023, 01:38:37 PM
Bugger, never mind Johnny, you werent to know, I'll wait to hear back and see what they have., Is it beneficial to get three sizes up to allow for tunage as theyre coming from afar? I dont know what sort of money to expect or anything, are they dear?.......
Post by: Johnny4428 on February 20, 2023, 09:19:33 PM
Not cheap by the time postage and vat from there, think it was about £70 delivered, just for a set of pilots.
Just had a look back at eBay 79.14 USD
Post by: Laverdaroo on February 20, 2023, 09:56:58 PM
blimey! Cheers Johnny :-\
Post by: Oddjob on February 20, 2023, 11:30:33 PM
I gave a set of 105 main jets away last year Roo, wish I’d known.
Post by: robvangulik on February 20, 2023, 11:39:14 PM
Roo, do you need 105 mains? I think I have at least 2 sets stashed somewhere, and maybe 40's pilots as well. I still have your address...
Post by: Laverdaroo on February 21, 2023, 12:16:40 AM
Aaaah, Rob that would be killer, man! :)
I'll deffo have a set of each please and more than happy to pay whatever they owe you as this is a massive favour, that's two I owe you now! ;) :)
If I can source a set of 110's I think I might be sorted  then at least i can go whichever way then. Rob thast ace pal, thanks mate :D :)
Please insert as req'd (HUGE firework emoji)
Post by: Oddjob on February 21, 2023, 06:50:50 AM
Start with the 105s then see how she runs, you can always try to raise the needles a notch as well if it feels flat mid range.
Post by: robvangulik on February 21, 2023, 03:25:54 PM
You DO have the same screw in type mains as the 750, not those with O-ring push in like the 400? Just to be sure....
Post by: Oddjob on February 21, 2023, 03:50:05 PM
No Roos are push in like the 400. Screw in for the 550K3 with the PD carbs IIRC.
Post by: robvangulik on February 21, 2023, 05:02:46 PM
Ookay, the largest I have of those are 100. The screw ins i have in 115 118 120 122 125 128 130 and 140.
And the idle jets I have in 2 different configurations, see pic.
Post by: Sesman on February 21, 2023, 06:59:10 PM
Roo will need those #40 pilot jets. The middle bag. If not I do 😉
Post by: Laverdaroo on February 21, 2023, 07:58:35 PM
Bagsey the 40's please? ;)
Post by: robvangulik on February 21, 2023, 08:06:32 PM
The middle bag.OK.
Post by: Oddjob on February 21, 2023, 10:52:01 PM
Not sure what the other jets are off but the middle bag is the right one for Roos carbs.
Post by: Laverdaroo on March 02, 2023, 07:42:18 PM
Just come home to a box from Camcoat with the ‘zausts’ in! Whoop whoop.
I’ve waited to get a brew down and opened
He up…………chuffed with those!(https://uploads.tapatalk-cdn.com/20230302/43ff312adaa5324393959a6837b8a89d.jpg)
Where there was heavy pitting, you can still see it but it’s on all the bits that are pretty much underneath the bike on the n/s but where I managed to reduce the areas resembling the moon, they’ve come out rather good!
I paid 60 quid for the pipe off fleabay, spent several nights trying to nanny them up and to be fair they’re a billion times better than they were but it’s hobby time do that’s free. A fat wad of abranet sheets and the final bill for the process of 360 including the vodka and tonic and carriage both ways so a shade over £400 for the set of pipes I wanted for the build and a set that are passable and will look ace on the bike
I’ve not seen a decent dent free set for sale for ages and when they do they’re knackered they still go for over a ton so I don’t think I could have done it any cheaper. Still pricey but rock n a hard place and all that. Well chuffed none the less.
Highly recommend Camcoat and the service, spot on and super quick turn around.
Cheers Ken, top contact
Post by: Laverdaroo on March 02, 2023, 07:42:37 PM
(https://uploads.tapatalk-cdn.com/20230302/0e390cd62710056ab0fcafb41da2b943.jpg)
Post by: Laverdaroo on March 02, 2023, 07:43:03 PM
(https://uploads.tapatalk-cdn.com/20230302/ede455d89d09bb69e678c2ab76e5334b.jpg)
Post by: Laverdaroo on March 02, 2023, 07:43:33 PM
(https://uploads.tapatalk-cdn.com/20230302/6578649877a3e52071c272061dcee455.jpg)
Post by: Laverdaroo on March 02, 2023, 07:44:16 PM
(https://uploads.tapatalk-cdn.com/20230302/a34dd97b53100ffb89cc0b47f8f3d908.jpg)
Post by: Laverdaroo on March 02, 2023, 07:44:43 PM
(https://uploads.tapatalk-cdn.com/20230302/5f5a497f9d27d22d69a63c85a4a00b70.jpg)
Post by: Laverdaroo on March 02, 2023, 07:45:12 PM
(https://uploads.tapatalk-cdn.com/20230302/3ad394116b676c94396e871ae7df52c6.jpg)
Post by: Laverdaroo on March 02, 2023, 07:46:31 PM
(https://uploads.tapatalk-cdn.com/20230302/9d2d75fdd9ddb745600e22f8e9a2ea17.jpg)
Post by: Laverdaroo on March 02, 2023, 07:47:10 PM
They can’t tape boxes up for shit though(https://uploads.tapatalk-cdn.com/20230302/87b1d5f578e8d04615546aa6eea81d8f.jpg)
Post by: Rozabikes Tim on March 02, 2023, 07:51:37 PM
Ca c'est les ballons de le Chein monsieur.
Post by: Laverdaroo on March 02, 2023, 08:00:03 PM
Aye, tres bon Rodders ;D
Post by: Oddjob on March 02, 2023, 08:32:26 PM
FFS Tim I had to put that into Google so I could see what it meant.
Made me laugh.
Post by: Laverdaroo on March 02, 2023, 08:44:21 PM
Post by: Oddjob on March 02, 2023, 08:49:38 PM
Try giving them a little polish yourself Roo, they'll only have done so much due to time constraints. Do a section you'd not see just in case.
Post by: Laverdaroo on March 02, 2023, 08:50:09 PM
Already started……..
Post by: K2-K6 on March 03, 2023, 10:26:29 AM
 ;D ;D
With my industrial French I once asked if the waitress in a restaurant would show me the menu (was thinking of later eating there) but the shock on her face and blushing gave me cause to think I'd properly mucked it up  :o I really don't know to this day my mistake and didn't dare go back there to find out what I'd asked  ;D
Post by: Laverdaroo on March 03, 2023, 10:54:57 AM
When my then mrs went with some pals one year to Spain on the bikes she was in a restaurant and I’d blagged myself up saying I was good abroad and spoke a bit of French, Spanish etc (French yes, Spanish, nope) She asked for advice ordering some snap and told her in a text to ask for….(and the Spanish escapes me) of which she was dead chuffed and dutifully toddled off to impress her mates with her new found Spanish lingo from her other half.
Well,  when the restaurant gasped and all looked at her when she uttered this to the waiter apparently, was astonishing.
She thought she was asking fur whatever but actually she told the waiter ‘he had a really nice arse and that she could suck the chrome off a tow bar’
I was in a hit of trouble but it was funny at the time.
Learnt my lesson? nah, I’d do it again in a heartbeat
Post by: McCabe-Thiele (Ted) on March 03, 2023, 10:56:07 AM
Are you sure it was a restaurant? 8) 8) 8)
Be funny to know what word you used for Menu. ;) ;) ;)
Post by: Laverdaroo on March 03, 2023, 10:59:38 AM
She was a bit daft bless her………….and easily lead
I’d catch her out all the time, funnily enough she bloody hates me now
Ooo, the irony
Post by: K2-K6 on March 03, 2023, 11:47:28 AM
Roo  ;D
I honestly can't work it out Ted,  it's the same word (isn't it ? ) and pronounced "mey noo"  I thought. En Famille laugh at my efforts, but won't have a go themselves  ::)
Post by: Johnny4428 on March 03, 2023, 11:52:04 AM
🤣🤣🤣 I like it!
Post by: Rozabikes Tim on March 03, 2023, 02:37:48 PM
Ironically just sitting in the sunshine in Normandy at the moment.
These tales remind me of my  efforts when I was in the Dordogne in my late teens. Sitting outside in a bar and we were talking to a local character. For too long it would appear when his wife flung the window open and shouted him home. I said " votre femme est ne pas tres jolie"  - thinking I was saying she was not very happy. In reality I had told him his wife was not pretty. Oh how we laughed when we realised....!
Post by: Nurse Julie on March 03, 2023, 02:40:19 PM
Post by: McCabe-Thiele (Ted) on March 03, 2023, 02:40:41 PM
Roo  ;D
Might have been your intonation ooh la la
Post by: Johnny4428 on March 03, 2023, 06:53:42 PM
Oooops! 🤣🤣🤣
Post by: Laverdaroo on March 04, 2023, 11:41:41 PM
Couldn’t wait, bobbed em on this evening……
Likely, likely(https://uploads.tapatalk-cdn.com/20230304/4d93df447f6f08b6a37a1b2d9e49d7d0.jpg)
Post by: Laverdaroo on March 05, 2023, 12:22:48 AM
Likey, likey! Rather!
Post by: Johnny4428 on March 05, 2023, 08:00:23 AM
That’s looking swish Roo! Quite like the satin finish.👍
Post by: andy120t on March 05, 2023, 08:15:35 AM
Sat-in Finnish? Sounds like a sauna!
Post by: Laverdaroo on March 05, 2023, 08:17:04 AM
Side effect that needs to be just tickled with a bit of really fine wire wool and some autosomal, apparently.
I’ll get round to it, was too excited so needed to have a look
Post by: Sesman on March 05, 2023, 08:18:25 AM
Ohh aye. Reet smart. Have you fired it up yet?
Wish I’d kept my original header now.
Post by: Laverdaroo on March 05, 2023, 08:21:31 AM
Not yet, they only went in late last night and I’m just off to site now so it won’t be today either, soon hopefully
Post by: Johnny4428 on March 05, 2023, 08:50:17 AM
Oops! Sorted! 🤣 back to school! 🤨🤨
Post by: Matt_Harrington on March 05, 2023, 09:08:00 AM
Roo, was a bit dubious of whether they would look OK but they are MUCH better than anticipated - they look good...
Post by: Oddjob on March 05, 2023, 02:55:50 PM
The plus point is that unlike chrome they won't go rusty, they are virtually impervious to salt water as well.
I'll have a small go at some of my Cermakrome parts Roo and see if I can really get them to shine. If I can I'll post a pic and instructions on how to do it.
Post by: Laverdaroo on March 05, 2023, 05:28:34 PM
That would be ace Ken, I phoned Nick to sy thanks for a good job and asked hiom what I could get a bit of a twinkle on them with and he suggested really fine wire wool and autosol...............who am I to argue?
I'll have a fiddle maybe later bjut just got home anf need a coffee marathon, knackered!
Bit of 'a sit' and some crap You Tube and I should be right. That is if I dont nod off which is a distinct possibility. I was waiting to load a dumper today with Type 1 and as he took off loaded to go dump I just had an 'elongated blink' and before I knew it he was banging on the door waking me up, ;D and he'd been and made a brew ;D ;D
Think I need an early night tonight..............Netting 40lb carp tomorrow and really looking for ward to it so need my 'A game' on tomorrow.
Might go for a bit of shed, might not dunno, we'll see.. :D
Post by: Laverdaroo on March 05, 2023, 06:58:25 PM
I was only going to fit these as I just love the shape and design and really think they make the bike. secretly want a Yoshi but dont like the headers really. Its only a bread fetcher anyway, its not like its a racer of any description. Just for bimbling aboout on but I love the way they've turned out. I'm glad I persued what I wanted even if it was the more difficult option.
Post by: Laverdaroo on March 05, 2023, 07:00:07 PM
Alright aren't they Matt, turned out pretty good really for the dosh and they're pretty much as new apart form the odd ding and a bit of pitting..........
Post by: Sesman on March 05, 2023, 07:19:01 PM
Yes, got to hand it to you. The swept pipes really make it. Unfortunately mine were ground out on one side as a result of Mr Trotters ‘off’ . In retrospect a good man with a welder and pipe grinder could probably have sorted them.
If you hadn’t been so selfish and got round to this build sooner I’d have probably attempted the reclaim and cerakote finish. Hope you are suitably ashamed😁
Post by: Laverdaroo on March 05, 2023, 07:41:18 PM
Sel flagulating as I type, sorry, I will try harder.
I still have that set of headers in the shed Phil. Theyve been attacked by a mig welder but savable if you know a decent fab/welder. The pipes are actually not bad. You want me to send you some piccies or are you sorted now I presume you are?
Post by: Sesman on March 05, 2023, 07:54:01 PM
Thanks Roo. Being the unimaginative type i settled on a S/S dekelvic job….it’s ok.😌
Thanks for the offer by the way but I’m out of energy now. With some potential help from JH I’ll sort the seat and then it’s finished-again. Then it’s on to the Triton. I’ve spent a fortune with Andy Molnar, Amal, Norvil, Andover and Morgo. I have to get on with it.
I’ve got the cases off again and I’m going for glacier silver or satin silver cerakote. Not sure which, just yet…Might even go back to Simoniz, but I’m striving for that original slight colour contrast between crankcases and covers.
Post by: Laverdaroo on March 10, 2023, 01:26:14 PM
Afternoon all, still plodding through it all, then we had 5” of snow and from previous experience I’ve not been out to the shed as everything gets blathered in condensation. So I just wrapped everything up and left it for a few days. Plus I was waiting on ethanol to arrive for my heater/burner. It’s not a furnace but when it’s a bit parky it doesn’t half take the nip off.
Anyway,
Had a tidy up of the wires and got all my boots on from the donations on here, cheers chaps, general husbandry etc etc. one thing I have noticed is that even just after testing briefly and for a total of about 2 mins total,  the lovely lenses on the front indicators have managed to burn off the smoked coating leaving one clear and one a weird dirty brown??
Spoke to the sellers and a new set in its way but a bit weird, bit like when we used to put a bit of superglue in a bottle cap in a lunch box to strip imperfections in coatings on sunglasses when I worked at a big importers years ago. The fumes effect the coating and dissolve it away………..dunno how, just did as I was told
Anyhoo that done, had a fiddle about doing some more cleaning etc, the right bar clamps from Max, cheers mate and started the fuel cap I mentioned the other day in a different  thread….
Coming on but check the casting marks out on the clamp I’ve not started yet. That was under smooth, black, OE paint. The one I’ve started was worse!
Things moving on slowly, still waiting on the rear mudguard before i can finish the wires but in the meantime I’ll get on with the static timing and get the carbs wet with a view to maybe……..MAYBE, trying for a start up  over the weekend if all checks out.(https://uploads.tapatalk-cdn.com/20230310/0deb3836235be9c129c841ca1a16d137.jpg)
Post by: Laverdaroo on March 10, 2023, 01:26:54 PM
(https://uploads.tapatalk-cdn.com/20230310/433b3d844999d430f3dfe8ed8537f365.jpg)
(https://uploads.tapatalk-cdn.com/20230310/3b565ce220e40d878ff124a7035fe0fa.jpg)
Post by: Johnny4428 on March 10, 2023, 02:00:54 PM
Nice work there Roo! That’s fairly sorted handlebar clamp there. We will await the fire up.😜
Post by: Laverdaroo on March 10, 2023, 02:02:02 PM
I'm checking, checking, and checking everything again before any fuel goes anywhere near it ;D
Post by: Johnny4428 on March 10, 2023, 02:06:48 PM
Of course Roo! Nice one.😜
Post by: Oddjob on March 10, 2023, 04:46:05 PM
Ahhh Grasshopper, it is time for you to leave and can I have the stone back from my hand you thieving git, that was a diamond not a piece of gravel.
Amazing what the paint covers up on the original castings, some of them as really bad but most look something like that, good job there, came out really well.
Petrol cap, you could try and get that chromed? does the inner part come out? should do. Maybe post a pic so I can advise.  I'd work a little more on right where the raised section meets the flat section Roo, all those little dots will detract from the finish. I know it's difficult, if it was easy we'd all be doing it. Try using some purple or light blue discs in there and then polish with some felt tips on the Dremel. Oh course that's just me, but the job is 99% perfect, a little more effort and you can get 100%.
Post by: Laverdaroo on March 10, 2023, 07:08:09 PM
It was primary attack last night Sensai, you can see there’s a bit more to do.
The underneath is pressed into the cap, you reckon it’s detachable? Via the crimped in. It’s?
The black is Karust inhibiterby the way…..(https://uploads.tapatalk-cdn.com/20230310/ef0653d47386d294df3cd7d8151696a5.jpg)
Post by: Laverdaroo on March 10, 2023, 07:08:36 PM
(https://uploads.tapatalk-cdn.com/20230310/d35dffffae22691f12e038279b9d271d.jpg)
Post by: Laverdaroo on March 10, 2023, 07:08:53 PM
(https://uploads.tapatalk-cdn.com/20230310/ba500106d48798da6b11d37f21aeb369.jpg)
Post by: Sesman on March 10, 2023, 07:16:58 PM
Nice bit of buffing. They were yellow passivate when new…..I think?
Post by: Laverdaroo on March 10, 2023, 07:26:22 PM
Yeah it was but more orange with rust……
Post by: Laverdaroo on March 10, 2023, 07:31:14 PM
It’s game on for a bit of shed action then, methanol delivery……whoop whoop(https://uploads.tapatalk-cdn.com/20230310/ea6350540a6268117a5f59ae4e617ee1.jpg)
Post by: Laverdaroo on March 10, 2023, 07:42:31 PM
Forgot to ask……
When it was taken off the bike like in the 400, there was a black paint type coating on the inside, presumably as a barrier so sparks don’t jump.,……maybe??
Anyway, do I need to replace as it was removed during the chrome g process?
If so, wot wiv, like?(https://uploads.tapatalk-cdn.com/20230310/5fd0febbe2b42e0f77a71bec9474f055.jpg)
Post by: Oddjob on March 10, 2023, 07:46:05 PM
Glue a small circular piece of rubber on there instead Roo. Will stop ringing as well, bit like sound deadening. Ohh use sound deadening for cars.
Cap, yeah unlike the 500 that looks crimped in. No rubber seal?
Post by: Laverdaroo on March 10, 2023, 07:49:36 PM
Yes, it was knackered so I bought a new one to fit as thats an orderable part. It’ll go on come  re fit
Bit of 1977, motorcycle rear wheel inner tube it is then. I think I’ve got some left from making the hinges for the bay boxes I make up lurking under a bench, that sounds just the job. Cheers pal
Post by: Sesman on March 10, 2023, 08:14:13 PM
That’s interesting, mine was painted in what looked like Matt grey primer.
Post by: Oddjob on March 10, 2023, 09:57:24 PM
All mine are done in that grey stuff too.
Post by: Laverdaroo on March 10, 2023, 10:21:07 PM
Mine was black, so was the 400 but the. Anchor of a twin cam I’ve got in the shed has grey on the inside.
Post by: Laverdaroo on March 11, 2023, 12:02:46 AM
Pass 2 and no polish yet and no polishing wheel yet. Bit bored so onto summut else for a bit but really coming on now and judging by the ferkectuon, not far off…..
Look out Kenneth, you’ve got some competition
(https://uploads.tapatalk-cdn.com/20230311/65f3efeaae1320e761c71dc4d99799d1.jpg)
Post by: Laverdaroo on March 11, 2023, 12:04:14 AM
(https://uploads.tapatalk-cdn.com/20230311/b1cabbe8050fbb0700a796f16df764eb.jpg)
Post by: Laverdaroo on March 11, 2023, 12:04:50 AM
(https://uploads.tapatalk-cdn.com/20230311/94a885787b54a5ba588ee2b9fa54762b.jpg)
Post by: Laverdaroo on March 11, 2023, 12:05:14 AM
(https://uploads.tapatalk-cdn.com/20230311/4220fa7b343a7f7bac14cbafc87a6310.jpg)
Post by: Laverdaroo on March 11, 2023, 01:32:07 AM
Still hate polishing, Ta daaaaaaa!(https://uploads.tapatalk-cdn.com/20230311/aa5a5d6e5ad631db78e89abe7928a760.jpg)
Post by: Oddjob on March 11, 2023, 04:06:08 AM
No polish eh? still using the little discs, sure is amazing what they can do when you start to get the trick of using them the correct way.
I can barely make out any faults with that Roo, a very small amount left of the micro pitting but that's being hyper critical. Glad to have the competition Roo, you do know that will just spur me onto the next level don't you  :D :D :D :D
When you finally get round to polishing the clamps you'll find they polish up really quickly and much brighter than normal, as I keep saying, the more prep you do the better the results are..
Proud of you Roo, glad you could make it to my level, I was getting lonely up here all by myself  ;D ;D ;D
Post by: Laverdaroo on March 11, 2023, 10:15:56 AM
Not sure if I’ll ever be as modest though
Post by: Sesman on March 11, 2023, 10:25:57 AM
Ken and Roo Ona day out….💥🔥🥰
Post by: Laverdaroo on March 11, 2023, 10:28:06 AM
I don’t wear a top hat!
Post by: Sesman on March 11, 2023, 10:29:54 AM
Post by: taysidedragon on March 11, 2023, 10:37:37 AM
It's very difficult to find a top hat with crash hat approval! And they blow off too easily.  👨‍🦲😲
Post by: Laverdaroo on March 11, 2023, 11:46:33 AM
Can’t believe you said ‘blow off’……..snigger
Post by: Oddjob on March 11, 2023, 03:45:50 PM
You're the one in the flat cap, I'm in the chair  ;D ;D
Post by: Laverdaroo on March 11, 2023, 04:09:30 PM
Irony eh, Phil
Stop disturbing me Ken, I’m in the shed having a right polish.
Post by: Laverdaroo on March 11, 2023, 04:16:58 PM
You reckon glueing that rubber on Ken? What sort of glue? In stock at the min I’ve ; super, epoxy, contact, liquid poly and possibly some hondabond. Oh and a glue gun but that’s a right off for obvs reasons
Whadda ya reckon folks?
Post by: McCabe-Thiele (Ted) on March 11, 2023, 05:00:07 PM
lol ;D ;D ;D
Post by: Oddjob on March 11, 2023, 05:36:06 PM
I'd epoxy it Roo.
Post by: Laverdaroo on March 11, 2023, 07:24:54 PM
ta
Post by: Laverdaroo on March 11, 2023, 09:37:28 PM
Evening, currently bobbing about checking tightness of bolts, stuff working ok, oil at level, you know.
Now setting the timing static tonight and checking spark to plugs, which is all there in abundance() after rebuilding the coils thanks to Ash’s ace file in the drop box thingy and finishing the new loom, I notice a kind of squeal/Parp noise immediately after the starter stops! Wtf??
It sounds just like that as well, the only way to describe it is it sounds a bit like the starter Parp after an old Mini or Moggy Bobbler starts. The starter didn’t do it on the bench, it’s mounted right and nothings catching/rubbing so at a bit of a loss. I’ve good oil pressure and the light goes out on cranking so all good there and oil at the head. Not heard this on a bike before. Any ideas to concentrate my investigations? And don’t say crank shells?
Yours sincerely,
 Not Over Concerned but Very Intrigued (Mr).
 South Bristol.
Post by: Nurse Julie on March 11, 2023, 11:04:51 PM
Possibly clutch bearing 🤔🤔🤔
Post by: Laverdaroo on March 11, 2023, 11:07:45 PM
Mmm, hadn’t thought of that, bit if a curious one it’s deffo that area of the engine…….
Post by: Oddjob on March 11, 2023, 11:57:44 PM
Hate to say this Roo but pop the camcover off and check the camshaft journals, I had the same thing many years ago and it was because there was a layer of paint on the journals and that caused a small lack of oil feed.
Post by: Laverdaroo on March 12, 2023, 12:07:16 AM
Ok, I hadn’t thought it was from there but that’s a good shout, I was going to re check the valves tmr and do the tap pits so I might bung my camera in there to see if there’s anything apparent before stripping the top off.
I’ve just done the screwdriver to the ear and tried it several times and it didn’t do it once but I’m going to go over it tmrw morning, I’m just waiting for the methanol to burn out in the burner and I’m in.
Before I assembled the top end, all the journals were fastidiously cleaned and gawped at and I was pretty happy with them, I can see how a layer of paint could be missed though.
I went round every gasket surface and journal on it as there was a bit of over cerekote lurking after getting the cases, barrels and head etc done.
Good call and I might whip the clutch cover off and have a wiggle if the guns are coming out and I have to start looking at cam cover removal with no joy etc…..
Interesting one never the less……
Better to find it now then blow it up on the bench like
Post by: Laverdaroo on March 12, 2023, 05:37:09 PM
Ok, so had the cam cover off today and everything is as it should be, clean surfaces the lot. I’ve reassembled everything and the Parp is there but intermittently on every fourth prod of the starter
With my ear pressed against the clutch housing I think it’s probably there as the top end was Spock and span and loads of lovely oil.
If this does indeed, come from the clutch thrust bearing, what am I liking for? Is it the basket over shimmed creating a metal squeak when the pressures off the motor?
Advice required while I drop the oil please as this is still my first complete reassemble of one of these and any hint is a good one…….
Post by: Oddjob on March 12, 2023, 05:53:16 PM
Does it make the sound if you kickstart it?
I don't think you can overshim it Roo, I used to squeeze as many on as I could and then remove the thinnest and fit the circlip and I never had any problems.
As for the gearbox bearings, did you change them?
Good news on the cam journal surfaces though.
Are you 100% sure it's coming from the bottom end?
Have you got a spare starter? Just in case it's that.
I did have a starter motor oval the bronze bearing that sits inside the end covers, AFAIK though those bearings are self lubricating, however a little oil in them couldn't hurt. Have you worked on the starter motor at all, I think it may be possible to overtighten the screws holding it together and that could cause the shaft to squeak inside the end of the bearings I suppose.
I could also be that the starter motor has dried out over the years and what you are hearing is rust and dirt being removed. It may just go away on it's own.
If the motor starts and runs ok and when shut off emits no undue noises I'd not be that worried if I'm honest.
Post by: Sesman on March 12, 2023, 06:02:55 PM
Not wishing to be a pessimist, but did you ensure that the cam blade tensioner was correctly seated in the crank case pocket?
Post by: Sesman on March 12, 2023, 06:11:41 PM
On the topic of starter motors. Mine ran fine on the bench, but couldn’t resist stripping it anyway to clean out the carbon and install new brushes and holders.  To be fair it was pretty pointless as the bushes were only about 1/5th worn. I did note a little play in the shaft though at the bushed end. Excessive wear might create a backlash engagement issue on the over run when load comes off. Just wondering. 🤔
Post by: Laverdaroo on March 12, 2023, 06:12:43 PM
I completely refurbed the starter, bushes, cable, paint the lot. I bench tested it several times, just in case of a fluke, you know
All spot on and refitted. I’ve not dropped the oil yet as been sorting the dawg’s tea out
After your starter mention, sounds like a worthwhile mission, I’ll whip the starter out and have a look at that as that’s the path of least resistance to start, leave the oil until I need to.
Every bearing in the cases was replaced with NEW. So I have no worries with that and all worked lovely on the bench and post assembly. I even had Uncle Bryan cast an eye over the selection etc and was given the nod and a thumbs up so not worried about that end of the motor. I could understand the clutch squealing a bit but never experienced it before.
Do you mean the two long screw/bolts that go from top to bottom as on here? This was when it went in…..(https://uploads.tapatalk-cdn.com/20230312/d4b17731c85984ad4c5bf7ee1cb75395.jpg)
Post by: andy120t on March 12, 2023, 06:15:08 PM
Run it until something breaks? Then you'll know what was making the funny noise!
Post by: Laverdaroo on March 12, 2023, 06:16:11 PM
Yup, had that mental discussion with myself whilst chewing on-it. I remember ping it three times before I was happy. It’s deffo in right.
I crossed that off a while ago and concentrating on all ‘spinny’ things but hadn’t for some reason, thought of the starter. I was hoping to fire it today n all bugger!
Post by: Laverdaroo on March 12, 2023, 06:18:05 PM
Aaah, cheers Andy, do you know, I don’t know what the forum would do without technical brilliance such as yours.
Saying that, if it was a land rover, I would
Post by: Oddjob on March 12, 2023, 10:29:26 PM
Yeah those 2 Roo. It's possible to overtighten them and that puts pressure on the armature as it compresses the space it has to fill.
Does the squeal come from spinning the motor over but it not firing up or when it's fired up and it gets turned off.
If the former does cranking the motor over by the kickstart produce the same noise, if not it's pointing to a starter motor fault, if it does then it's an engine fault somewhere.
My BIL had a similar problem when he built up his or should I say my 500 last time, kept complaining of this squeal just as the engine died, turned out the camchain tensioner wasn't in right.
It was why I kept saying to you to check, check again and finally do another check. I always fit mine in the barrels before I fully lower them, if the barrels are fully down it's really hard to locate it properly, when they are raised an inch or so it goes it pretty easy.
You could also try releasing the camchain tensioner adjusting bolt, if the chain is overtight for whatever reason it would allow it to slacken off a little as the engine spins. With a new chain there is little danger.
Post by: Laverdaroo on March 12, 2023, 10:31:11 PM
Well, bit of coaxing on the throttle and it fired in the first attempt……..which is nice!
However,
The Parp is evident on engine stop and restart. Bugger!
The tappetts aren’t quite there so that’s my first port of call now, then delve back into the clutch as I checked the starter, all good, re oiled up, put back and no dramas. Presumably I’ve not done the valves as well as I could have after todays lift of the lid so sort that and clutch.
Plugs were sooty black, to be expected with the wrong jets, air filter, pipe etc but that’s to fettle in a bit.
So far……..ball bearings in a baccy tin
Post by: Trigger on March 12, 2023, 10:32:04 PM
That was just a zinc plated part that was yellow passivated in its original form  ;)
Post by: Laverdaroo on March 12, 2023, 11:05:30 PM
 Yes, I know, it looked awful and I hate yellow passivate, just looks dirty.  hence the tart up
Post by: Trigger on March 13, 2023, 12:24:14 AM
Just BZP it and that will stop it from going rusty and leave it with a good finish  ;)
Post by: Sesman on March 13, 2023, 08:40:33 AM
Roo. What’s your plan for process of illimination.
Post by: Laverdaroo on March 13, 2023, 10:20:38 AM
I’ve been in and checked the cams etc, nope…
Had the starter out and inspected, nope….
Kind of running out of stuff to check but the clutch is the next stop I feel, if I find nothing there the lumps’ coming out and I’ll have to split it I guess. Dunno really. Just can’t figure out what the ‘Parp’ is! Sent you some footage Phil, didn’t send last night when I tried.
I’ll get to it later, got a pre op this arvo so need to get that sorted out first.
Post by: Laverdaroo on March 13, 2023, 10:51:07 AM
Turn yer wattsapp on Phil it won’t send through…..
Post by: Sesman on March 13, 2023, 10:59:17 AM
Ahh, got a new  phone.
Post by: Laverdaroo on March 13, 2023, 10:59:58 AM
That’ll be it then
Post by: Laverdaroo on March 13, 2023, 11:06:12 AM
Tell us when you’ve fettled it and I’ll bob it through to yer mate.
Post by: Oddjob on March 13, 2023, 03:53:35 PM
My footage didn't play Roo, I got to the point where you move and you can see the bike and you say "Right" then it stops everytime.
Post by: Oddjob on March 13, 2023, 05:02:20 PM
Just tried again and the vid worked this time. I only heard the parp once, when it stalled halfway through. Not sure what to make of the noise TBH, could it be the new airfilters making it? It sounded a little like a lot of air being dragged through a small opening and that opening vibrating as it did so.
Post by: Sesman on March 13, 2023, 08:49:51 PM
Roo.
https://www.youtube.com/watch?v=D5kzgiQlOsk
Post by: Sesman on March 13, 2023, 08:55:11 PM
Christ knows how one refs.
Post by: Laverdaroo on March 13, 2023, 09:02:57 PM
That’s exactly what I’m doing now. Had the lid off again and turned her over with a screwdriver as a stand in cam sprocket and the noise is there still. So it’s nothing to do with that side of the motor. On a metal bench on the centre stand,  the noise reverberates through the frame and bench making hard to pin point.
That being said, not that I’d seen the above but I’m just bobbing the starter motor off again and odds on from observations, it’s that swine
Fingers crossed, I’ll report back.
Cheers for all the help fella’s
Post by: Laverdaroo on March 13, 2023, 09:03:16 PM
(https://uploads.tapatalk-cdn.com/20230313/ecc02fc08b818c947be12660ed1ee805.jpg)
Post by: Sesman on March 13, 2023, 09:31:10 PM
If that ain’t it, obviously it’s a sump drop to get some lube on the starter mech. Sorry you are going through this Roo. Stick with it. If it’s easy, it’s not worth doing or having.
Post by: mickwinf on March 13, 2023, 10:42:50 PM
could it be the starter clutch mechanism?
Post by: Laverdaroo on March 13, 2023, 10:46:22 PM
OK, so under investsigation yet again, the starter is doing the 'parp' as I hold it in my hand and power up so new end caps sorted and a fix on the way. Under inspection yesterday I saw and heard no issue but session 2 has thrown up  the full fault and I can replicate it so 99.9%, that's the offending issue.
Winning! 8)
BUT............... and you knew there was going to be a but, this brings me to a point  brought up whilst talking to a fellow miserable, sarcastic northerner this evening who righty says or questioned. why does it do the 'parp' when you swich the engine off, it shouldn't be spinning?
Technically, as soon as you've let go of the start button, the starter isn't powered up and stops spinning. Other wise if it kept going it would be the same speed as the engine and would probably blow up at 9k on the tacho with yer chin on the tank?.
So it obviously makes the 'parp' as the motor is spinning up to speed, ok, and when the motor is turned off, presumably at a similar speed as it slows?
If I poke my finger into the hole onto the idler gear I can turn it only one way but not the other as its against the turn of the internals indicating it's maybe  the balbearings in the cush assembly in the drum, one on the wonk or something and its taking up the slack ....................Bas*ard!!
I'll take the pan off tomorrow night and poke about and see if anything is visible but also we discussed there being a thread on folk getting to all the internals somehow through the pan......anyone read/seen anything or indeed carried out the operation? It will be a pig I should think but its game on and needs doing so before I fire the parts cannon, just checking to see if anybody has any experience.
thanks all, shit happen's I'll sort it ;D
Post by: Trigger on March 13, 2023, 11:55:40 PM
The starter clutch can make some clattering if worn. Did you replace all the parts in the starter clutch and did you check the cog surface ?
Post by: Trigger on March 14, 2023, 12:01:34 AM
There is a picture of a bad ring gear cog half way down this page >> http://www.sohc.co.uk/index.php/topic,20419.120.html
Start striping and check every part as you remove and double check on reassembly  ;)
Post by: Laverdaroo on March 14, 2023, 12:04:13 AM
Yes and yes,  new rubbers the lot hence why I might have buggered up putting in the nall bearings. I didn't think so and thought it was all good, but it fits the symptoms as a possible so I need to look and trying not to split the cases as I'm sure you can understand ;)
Post by: Trigger on March 14, 2023, 12:22:03 AM
I know it is a bummer but, as my old man always said : it is all a part of growing up and learning  ;)
Post by: Oddjob on March 14, 2023, 02:54:00 AM
I can't find it right now Roo but on the USA SOHC site there was a large thread about removing the primary chain hub through the sump, something I must add I thought was impossible until I saw pics of it being done. This was quite a few years ago and this makes it very difficult to find especially as our American cousins lump all the SOHC engines into one section so searching for primary drive etc gives you loads of results from 750s and such. The way I remember it being done was to remove the sump, engine was still in frame BTW, remove the primary shaft (use the lower footrest bolt as a slide hammer with a foot peg still on there, if you don't have one), make sure you catch the thrust washer as it drops out, tilt the drive and it will wiggle out with a little effort. Getting it back in was the same, I'd imagine getting the thrust washer to stay inn place could be difficult so remove the oil pump so you can dangle it off a screwdriver or something.
I have 2 spare primary hubs out of 550s just lying around, welcome to one if you need one, bloody heavy things though so maybe just need the starter ring part?
Of course if replacing/repairing the starter motor works then it won't be needed to be done.
Post by: Sesman on March 14, 2023, 07:47:47 AM
This fecker.
Post by: Trigger on March 14, 2023, 08:55:29 AM
Going in through the sump is fine if you are changing the starter roller kit, if you know what the problem then that is fine. But, i would advise stripping the engine to diagnose a problem. There is no point in doing half a job and it maybe a couple of problems that could be elsewhere in the engine or something simple that may have been missed. ;)
Post by: Sesman on March 14, 2023, 09:26:30 AM
Good advice Trig. I think in this case though Roo has identified the issue….thank goodness.
Post by: Laverdaroo on March 14, 2023, 10:13:13 AM
Yeah, the fact that the idler gear isn’t idling indicates that the starter farting has identified a more serious issue with the idler and starter clutch. I don’t see the value in stripping everything to do a job that can be tackled in a less time consuming fashion or more cost effective way.
I shall be taking the path of least resistance on this, if it turns out that my digits are too large to make it satisfactory or indeed possible as I’ve got bunches of bananas for fingers,  then a strip will happen but that’s the last case scenario at the moment.
Research is my first port of call.
Post by: Laverdaroo on March 14, 2023, 10:14:50 AM
Phil, can you send me a page link to that bud, just what’s in the search bar and bob it over and I’ll have a read at break time?
Cheers cocker.
Post by: Johnny4428 on March 14, 2023, 10:31:09 AM
Roo, it’s a daunting prospect the thought of having to remove engine and strip down again so naturally you would try any alternative to sort it out. I had to take the engine out of the 550 after having it run but wasn’t happy with it, I covered up and couldn’t look at it for 6 months 😡😡. Confidence in my own ability was just one of the problems! So glad I did take the engine out and strip it right down. Found a couple of issues to sort. Imagine how I felt when I had to remove engine in the 750 as well after it had been done.😡😡😡. But decided to tackle it right away so I could get the summer out on it. I wasn’t daunted by having to strip the engines again, I was only daunted by getting the engine out and back in without damage. So if the worst comes to worst Roo just get in there! Rooting for ya! “We do it right cos we do it twice” 😁😁
Post by: McCabe-Thiele (Ted) on March 14, 2023, 11:17:07 AM
Listening to that noise it reminded me of a dry starter Bendix on a car. The trick back in the day before pre-engaged solenoids were a thing was to lubricate the solenoid unit. Lazy folk would use a small drill to put a hole in the bell housing in the right spot so you could squirt some oil in - some plugged the hole some didn't.
 I certainly would not be rushing to remove the engine. I would be looking at making sure everything I can reach is fully lubricated with
a light grade of oil if it's outside the engine using engine oil elsewhere. Did you use any oil when you were rebuilding the gearbox etc. If you use the kick start does that still result in the noise at any point?
It's a dry of oil sound to me as a complete amateur or something too sticky causing a drag somewhere. Does it still make that sound when the engine has earmed up?
Post by: Sesman on March 14, 2023, 11:39:10 AM
https://www.sohc.co.uk/index.php?topic=9173.0
http://forums.sohc4.net/index.php?topic=122084.0
Post by: McCabe-Thiele (Ted) on March 14, 2023, 11:52:27 AM
Great links Phil.
Post by: Oddjob on March 14, 2023, 04:27:40 PM
This fecker.
Good find Phil, I looked but it was using the correct terminology that I suppose counts. First pic though and he leaves the oil pump oring just hanging off the case, along with one of the dowels and it's oring, why?
I knew I'd seen it.
Post by: Oddjob on March 14, 2023, 04:36:38 PM
Roo, on the off chance you might need them I'll throw in a complete primary drive hub as well as the starter motor end caps.
I'll check the hub first to see if the springs and rollers look ok as well as the surface where they engage.
Post by: Bryanj on March 14, 2023, 05:20:33 PM
Not sure if i read it right but the big gear you see through the hole the starter fits in is supposed to spin free one way and lock up to turn the engine the other, thats how the sprag clutch works
Post by: Sesman on March 14, 2023, 06:50:14 PM
That’s as I understand it. The engine speed overcomes the stater rotation speed overtaking and disengaging the starter drive. A nasty noise will arise if the drive mechanism is slow to release, but release it must…eventually. I’m crossing my fingers for Roo hoping it’s just a bit of float in the starter shaft causing a suboptimal engagement under load. I do fear however that’s it’s the drive mech. It’s all guess work on my behalf mind.
Post by: Laverdaroo on March 14, 2023, 10:22:08 PM
Reet, I’m bits, liking at the starter motor first…..
Had it apart again and notice there’s a good 2.5mm of end float laterally on the brass bearing so think that’s shot but I’ll bob(https://uploads.tapatalk-cdn.com/20230314/0d9e593fdfd194944b8f0b6d72b28a94.jpg)
 it back together and see if it replicates after another ‘nanny’ and a re oil.
Now, never noticed this before (probably due to the years of cack which is cosmically attached via nuclear fusion through no cleaning over 40 years) but behind the bushing in the starter cap there’s a felt washer……….who knew?
Re-doused with oil and I’ve put the old brushes and original springs, I’d taken the stings off a knackered unit as they were in better nick and bought new brushes,  so just in case the profile is causing the vibration I e put the original ones back in to test. They’ve loads of meat on them but are worn in so maybe make it spin with a bit less friction???
Interested to see anyhow
Post by: Laverdaroo on March 14, 2023, 10:23:27 PM
This is the order it came out when originally split as I have photos, but just thought, is this the right order of shims?
Potential issue?(https://uploads.tapatalk-cdn.com/20230314/773ffb47fb845a457af7dbca9aa01a68.jpg)
Post by: Oddjob on March 14, 2023, 10:33:09 PM
Thought there was some shims on both ends not just one.
Post by: Laverdaroo on March 14, 2023, 10:38:13 PM
That’s all that was in there bud, crap photo this was on the other end….(https://uploads.tapatalk-cdn.com/20230314/b3da7c2a2e6d7a9fd634026d0497d284.jpg)
Post by: Laverdaroo on March 14, 2023, 10:39:45 PM
Times 3 stuck to end of shaft!!!(https://uploads.tapatalk-cdn.com/20230314/305820bd87374a60c3b8dd56b1a48676.jpg)
Post by: McCabe-Thiele (Ted) on March 14, 2023, 10:49:46 PM
So Roo might it be the starter motor shaft float?
Post by: Laverdaroo on March 14, 2023, 10:58:37 PM
’Cest possible’ (said with a galic shrug and in an ‘Allo Allo’ accent).
From posted gubbins and trawling the t’interweave after the hosp this arvo that’s what it’s pointing at.
The Parp on shut down is another story Ted. More research required I feel before starter clutches are removed via keyhole sergery but it’s looking that way or split the lit. Boooo!‍
It is what it is, I’m totally annoyed but got bigger things to sort at the min, full tooth removal with the worst toothache I’ve ever had plus solicitors being dicks on a property I’ve been trying to get on for the last 12months. Think we’re there with the site today but not counting chickens, or indeed carp, yet!
Anyway progress tonight so that’s good and one thing to potentially sort as found to be an issue but not there yet I feel!
Post by: Laverdaroo on March 14, 2023, 11:06:49 PM
Forgot to mention as well, cheers Ken,  for the bits that would be smashing mate
Post by: Laverdaroo on March 14, 2023, 11:25:34 PM
With said bits potentially on their way soon from Uncle Ken, I’ve bobbed it all together again and cannot replicate the park at all, I’ve tried it and counted 40 goes at various spinning times up to 30 seconds and can’t get the Parp to return. Going to put it back in and try it against the engine inertia to see if it parp’s spinning it up with the screwdriver back inas the top cam sprocket. If not I’ll tentatively start the top end reassembly.
It would only do it after the engine had run on shutting down indicating that the motor was spinning as the motor was, not good?! Either way that means cam back in, sprocket and the lid and try a brief fire. I’ll report back.
Post by: Laverdaroo on March 14, 2023, 11:26:26 PM
(https://uploads.tapatalk-cdn.com/20230314/35b9763c4dba7dc9a0f8a4c9afa4e69e.jpg)
Post by: Oddjob on March 14, 2023, 11:39:29 PM
You want me to hang fire on posting the bits Roo, just in case you’ve fixed the problem?
Post by: Laverdaroo on March 14, 2023, 11:47:13 PM
Yeah, gimme a couple of days(evenings), to poke it all together.  Just sent you an email with some video attached re idler. Have a gander.
There is a float on it but only when apart. It sounds sweet to me when spinning both power on and powering off. The only thing I found was a bit of detached felt from that washer stuffed into the end cap which was metal coloured so never saw it, surely it wasn’t that?.  That shouldn’t have been there so hoiked it out and bobbed some ZX1 friction eliminator in the felt washer to soak in before reassembly. There’s a short clip of the end float an I’ll bob that over also if you wouldn’t mind having a look at that too?
Sorry to be a pest kid, just reassurance on things I know nowt about is a right help.
Post by: Trigger on March 15, 2023, 12:00:14 AM
Don't worry about the end float, the shaft moves in and out on every Sohc starter motor that has been in my hands  ;)
Post by: Laverdaroo on March 15, 2023, 12:03:04 AM
Post by: Laverdaroo on March 15, 2023, 12:35:02 AM
Well, spinning on the screwdriver, no noise at all. Tested it 30 plus pokes at the button up to 10 seconds or oil pissing over the top, whichever came first. Still reading on the starter clutch. Spins beautifully one way but not the other, why Parp on shut down?……
A fat ‘mull’ and a chew  required.
Post by: Laverdaroo on March 15, 2023, 12:36:15 AM
(https://uploads.tapatalk-cdn.com/20230315/e37d66e7a2e5c0723c388a11bcb35734.jpg)
(https://uploads.tapatalk-cdn.com/20230315/89cb1035cba5d25eac9c7b56fa9ddc6f.jpg)
Post by: Oddjob on March 15, 2023, 02:40:57 AM
You could try using a piece of wood/plastic to stop the starter gear from moving, start the engine on the kickstart and see if it spits out the wood due to the sprag clutch engaging with the starter gear when it shouldn’t be. If the gear is spinning with the engine I’d say that means the sprag clutch is either broken inside or it’s sitting at an angle which allows it to grip the body where the rollers sit and thus spin with it.
Moving a starter motor shaft by hand requires some effort, they don’t spin free at all. So if it’s being spun by the engine when the engines in motion there is clearly something wrong going on inside there.
If it doesn’t spin then I’d say fixing the starter motor should solve the problem. Even if it only cures it for a year or so it would be worthwhile as that allows the primary chain to slacken off a little, I’d imagine disengaging the chain from the gear on the hub would be very difficult when it’s brand new, that’s of course referring to the keyhole method of removing the primary hub.
I’d agree on the end float question as well, they all have some.
Post by: Trigger on March 15, 2023, 07:34:49 AM
You are over thinking the starter motor, It turns easy between the thumb and finger with the only resistance being the brushes contacting the commutator.
Once i have checked the insides of a starter motor, i just test it by earthing one of the long screw on a car battery and touching the live wire. It will start spinning with a it jump in your hand. If it spins fast and only a slight whirling noise, it is fine  ;)
Post by: Laverdaroo on March 15, 2023, 09:55:52 AM
Yeah,Graham if you read, the starter is fine it’s the starter clutch under investigation/under question as a result of fault funding. The starter is tested and is all good and refitted on the engine, as written last night
Post by: Trigger on March 15, 2023, 10:10:49 AM
Sorry, missed that bit, you are working too fast for me  ;D Starter clutch is easy, just fit a new kit as, it is hard to sort out what is worn if, you don't have a new set to compare. That is if you never fitted a new kit when you first built the engine  ;)
Post by: Laverdaroo on March 15, 2023, 11:38:34 AM
I was out til 2am fiddling. That and excuse of roaring jaw ache meant no sleep for me so better off doing something. Cam is back in to test then I’ll put the lid back on and try to fire it and see if I can replicate the issue.
New ball bearings, springs, circlip, new rubbers the lot went in when the motor was apart. There’s very little that was off the old motor internally!
It’s the fact that I went in there that points as a possible culprit, still not convinced but I’ll have a gawp when I get home. Just struggling fitting a security door for a pal. It’s got 8 drop/shoot bolts on it, 200mm thick and is well over a hundred kilos!
Sodding thing, I’m waiting on reinforcements as I don’t think Charles Atlas would shift this sod you’d have to have muscles on yer ears……..bloody hell!
Post by: Oddjob on March 20, 2023, 03:07:39 PM
Just thought I'd let you know that did a little bit of work on restoring the tank badges last night, just did the back of the badge to see how it came out and made loads of mistakes BUT the result was still promising. Did a little research and hopefully I know how not to make the same mistakes for when I do the front.
Early days Roo but I'd say this may turn out very interesting, especially for 550F owners as it was the gold part of the badge I was doing last night. Watch this space.
Post by: Orcade-Ian on March 20, 2023, 03:40:11 PM
Ken,
I tidied up my original badges - gold was acceptable to start with, so only the black needed doing but I just looked at the badges that came with the spare tank and they are quite a bit bigger. Pins still same spacing - so what model might they be off?
The spare tank I'm using had a different flap too - with a slot to trap the filler cap whereas the original had a cap with a hinged lever.  I ended up making a ring that goes around the filler hole (not present on spare tank) and aradited it on prior to painting so it looks stock.  Hadn't realised there had been so many variations.
Ian
Post by: Oddjob on March 20, 2023, 03:59:35 PM
Usually have the model number embossed on the reverse of the badge Ian, have a look. Might be 750F2 as I seem to recall they had the same black and gold badges.
Just done the front of the badge, needs another go though. Looking ok at the moment, test will be when the white and black go back on though. I also intend to lacquer the result so as to help it cope with the weather etc.
Post by: Laverdaroo on March 21, 2023, 01:25:53 AM
Just having a bit of a nanny whilst making an exhaust bracket for the new end can and just had a quick bob round making sure things are tight and in the right place and all that like yer do.
 When upon tightening the exhaust nuts, or just making sure after running for the first time the other day, one sheared off……..at about 81/2ft/lbs!!!
Nothing really and definitely not tweaked. I had enough thread on it to get an abstract or on it and pull it but noticed two things;
Firstly, lol at the centre of that
Secondly, sitting next to a Honda one on the left you can see the shoulders are a lot different too and deffo NOT OEM, me thinks.
I’ve checked them all and four of the eight are the same.
I bought 8 from DSS, 4 of which were in Honda bags and four in a zip bag with the Honda part number on a printed slip inside.
On the paperwork it states 8 x (said pt no) so a call to them in the morning to ‘discuss’ I feel is the way forward
More to the point if any of you have bought any from there just have a look and make sure they’re the longer saddled ones that are the OEM chaps
The others are knackered in the middle……(https://uploads.tapatalk-cdn.com/20230321/dad1b88237ca00505748b310c38d70d7.jpg)
(https://uploads.tapatalk-cdn.com/20230321/3265d21955f220d49ead74089b2b747b.jpg)
Post by: Oddjob on March 21, 2023, 02:26:22 AM
I’m replacing mine with stainless steel studs Roo, the trouble with using mild steel in that location is the heat burns off the zinc plating, they go rusty as a result. Corrosion sets in, especially in the part covered by the exhaust flange, the threads left exposed by the nut rust for fun as well, you go to remove them a few years later and the nut binds on the rusty thread, you use for force and it refuses to move but the force is now transferred to the part left in the head, that also doesn’t want to move as it’s rusted in place, this means the centre of the stud starts to twist, as it’s already weakened by the rust it breaks off, if you’re lucky it leaves enough for you to grip, if you’re unlucky it snaps flush with the head.
Use stainless and pair those with deep domed nuts like the ones on your vfr750. Just bought 8 6mm deep flanged domed nuts for when I do mine.
Post by: Laverdaroo on March 21, 2023, 02:30:21 AM
I think I will bud, can’t be doing all this bloody cleaning and polishing for the sodding thing to go rusty
Have you a supplier sorted out yet for them? Saves me looking and all that
I have news te starter clutch but just got in and shagged out so off for a Kip, I’ll catch yer tmrw
Title: Re: 550 F2 started!
Post by: Sesman on March 21, 2023, 10:43:53 AM
C’mon, Roo. We are waiting for starter news…is it fooked?
Post by: Oddjob on March 21, 2023, 03:41:47 PM
I bought these Roo, exhaust and inlet.
https://www.ebay.co.uk/itm/254206786071?hash=item3b2fe7ba17:g:ORgAAOSw9rthReyM&amdata=enc%3AAQAHAAAA8NuvCEsH9U5nDnF8VxjEQDvfQibV5IT43%2FuFKvA5JY5aBG0XdkQHfcpKA8v5TlDDjwrqWxxIAoznKuA8EDVn%2Fa7wkcEyc2cs4yTuxXNMzMitQQmEeKfzl1x%2FZnhZe2QHiP7mBs1JR7ZYO4g9ua%2FOMbQ8lI7NOB1YPwo4tnEVJqUFlVXc1%2F7tDIWUXj%2BFdBKQc%2Bj9ABRxWALVDMaOV8jJdXL80HZUDFrDza4RP95tsv%2BMly%2FNm01kFmLkqvy%2BsNM%2BwZOHKIDWz%2BYSCWJtLciQQ21fiqlN4hDUbC053UHEH%2FGphKcm7W%2Fanub5XDkylMN%2Bvg%3D%3D%7Ctkp%3ABk9SR8jdhc3gYQ
You may have to ask Trev about the inlet ones if you're interested, he does do them though.
Nuts from here.
https://www.ebay.co.uk/itm/234896491875
I don't intend to use a flat or spring washer under them, the modern bikes don't use them and they don't seem to lose them so I'll go that way as well. Unless the stud is too long for the nut in which case I'll bung a spring washer underneath.
Post by: McCabe-Thiele (Ted) on March 21, 2023, 04:20:07 PM
Removing exhaust studs from the cylinder head - that is something I would avoid if the steel studs are okay - call me chicken but it's a recipe for snapped studs IMHO.
Post by: Sesman on March 21, 2023, 04:25:34 PM
I understand your caution, Ted. Strangely enough after degreasing and painting the head I bobbed it in the oven at 200 degc for 90mins and the studs wound straight out. I double nutted the studs before baking.
Post by: McCabe-Thiele (Ted) on March 21, 2023, 04:36:47 PM
Did you have to wear Oven Gloves or did you remove them when it had cooled down?
Post by: Oddjob on March 21, 2023, 04:42:23 PM
Precisely my point Ted, do it now before they corrode to the point where they break when you don't want them to, at least you stand a chance when they still have some strength left.
Plenty of heat and a good extractor and you should be fine. A lot of studs actually come out with the nut as the threads behind the nut are so corroded they act as a double nut.
Post by: Sesman on March 21, 2023, 04:47:29 PM
Hot, Ted. I had the work bench ready to accept the head and clamped it. Thought I’d double up on the oven time after painting. A bit risky, but saved me 10bob in leccy 😁
Post by: Sesman on March 21, 2023, 04:48:39 PM
Did burn my forearm on the bloody wire support thing, though.🔥🥲
Post by: Oddjob on March 21, 2023, 05:24:36 PM
I had a full engine melted once, way back in the 70s. I wanted to have it stove enameled satin black to match the 750F engine which I thought looked mint in black. So I stripped it all down and assembled it bare cased so I could have it done, dropped it off and waited for them to ring me to say it was ready. 2 weeks later I got a phone call to say they'd had a fire and my engine had melted. It was only many years later I found out it was arson and an insurance con, I didn't get paid a penny for my loss, there was a Laverda Jota engine right next to it that was also melted. Went to pick up the engine and the bottom half was just a bit blob of alloy, only the head survived. The heat was so intense the newly installed valve guides had risen out of the head by about 15mm, no springs on them and the engine was upright so how they rose up is beyond me. I never used that head again and in fact it was left at Crich a few years ago when I went to the bike meet there. Couldn't be bothered bringing it home. Just shows you what heat can do.
Post by: Laverdaroo on March 22, 2023, 11:33:08 AM
Starter clutch update.................
Right, well, after a fraught week where my gob has reduced fettling time due to the flock of woodpeckers in my head with Hilti guns, I havent got as much done as I wanted but never the less progress has been made in the 'Shed of Dreams'.
I've sorted the 'parp' via the dry bearing on the starter and that now runs beautifully and I've not managed to replicate the noises it was making before which I bored you all with earlier, so thats sorted. Now the question of the the starter clutch still being engaged once the engine had started, this would mean the starter motor would be spinning at the same speed as the engine once in use and so potentially a ticking time bomb next to my left foot.
My Primary chain is brand new and is pretty taught so trying to get at it from underneath the bike meant that without splitting the cases, would have been virtually impossible to get out so I havent gone to that degree yet although I dropped the oil and had the bike virtually lying flat on its side with the sump off to inspect and see if theres anything to see, waggle etc., Also going through my pictures from assembly I noticed that all the bits that need to be there are in fact all there in th eright place so I have no issues with assembly so I cancelled that off the list. After finding nothing visual and finding nothing, moving where it shouldnt, rocking or catching or rubbing I put the sump back on and refilled the oil but this time removed the starter and kicked the bike over to view through the hole that the starter goes in to see if the idler spins. when the engine is running...................it doesnt..................get in!    (firework emoji) ;D
It free wheels and although turns with the engine if I poke a plastic wedge in there the idler stops dead and can be pushed the other way indicating its doing what it should and all is well so I have no issue so that's avoided a strip down although its something to keep an ear out for now that its reared its head and I will keep an eye open and an ear in that direction once I get it running right and moving a bit later down the line.
Had the primary had a bit of wear on it I may have been able to get it out but thankfully it can stay put as I didnt relish that job IIH!
A bit of good news which makes a change.  8) 8)
I'm not doing Honda stuff today, my mate up the road has a really nice Yamaha DT125 YPVS that he's had from new which he wants to sell so wants it checking over before he advertises it. Today is going to be a nice change and playing with a two stroke for a bit. We aways referred to them as a "Death Trap 125" but they are a hoot and one of the easiest bikes to wheelie.........ever ;D, just a shame this one is a nasty white and pink one...eeessshhh!    Why would you buy a pink bike??? FFS!
So after the worry that the engine may have to come out, thankfully thats not the case and I can relax a bit, but only for a bit ;D
Top news though!
I have however, finished and had welded the bracket for the end can. Due to it's size and shape theres not many places to attach it to so have to make the best of a bad do and although these arent the bolts that will stay on it Theyre just there until I can get some  new stainless ones ordered. Theyre fine, just allen heads and the only ones on the bike and I'd prefer dome heads or something similar to the rest so I'll invetsigate that.
£4 peice of ally form the kitchen fab place down the road and a bout 5 hours fiddling time, plus a drink for the welder at the tractor place down the road and the whole thing stands me at about £18 and a fist full of Neproxin pain killers. I did about 6 different templates but decided this wold be the better fit and the least fussy so went with that. Needs a polish but doesnt look too bad. I appreciate it wont be everyones cup of tea but it suits the bike and should add to the look once done.
Cheers for the heads up on the stainless Ken, I've ordered those. I had some stainless dome head nuts here so they can go on, dont know why I didnt fit them anyway, think I forgot I had them. They should be coming later in the week so I can cross that off the list now too.
Although far from my best week, things are still creeping on by and getting sorted, just got to get the running right now and I might have a bike.
cheers for all the help with th estarer issue and the advice, info etc. Top drills fellas, cheers
Post by: Laverdaroo on March 22, 2023, 11:33:18 AM
(https://uploads.tapatalk-cdn.com/20230322/bb5eb208ea2ec3dab05906444247ef54.jpg)
Post by: Sesman on March 22, 2023, 11:49:05 AM
Good news on the starter, Roo. Bracket looks mighty fine.👍
Post by: Laverdaroo on March 22, 2023, 12:00:13 PM
Hate drilling frames, especially when they've just been powdercoated! Measure 50 times and drill once!
Bit of a buger as the can is conical, the footpeg stay is striaght but the bottom part that connects the bracket to the frame is also pitched 7mm from front, upwards to the back. The angles involved were a bit bonkers as there wasnt a straight edge to start from as a datum and I could have dont it an easier way no doubt but it was a good thinking excersice and a welcome distraction. I had bits of tape, sliding bevels, alsorts strapped to it so I could get it cock on. Quite happy with it though, going to get back on it tonight and try to make it a bit more presentable.
Releived is and understatement Phil re the starer clutch ::) :o :)
Post by: McCabe-Thiele (Ted) on March 22, 2023, 12:05:55 PM
Great news about the starter motor/noise issue - exhaust bracket looks bob on - might need to change the bolts like you said but not something that shouts at you.
Post by: Laverdaroo on March 22, 2023, 12:16:44 PM
Hey mate, yeah my thougts exactly but it's all I had in the drawers to mount it with for now. There aren't any other hex head bolts on the bike as Ive tried to keep everything Honda and I think the list so far is bolts,  nuts and fastenings etc from 1991 vfr750, 1992 VFR400, 2002 vfr800, CB500, CB550, NS125RK and CB900. Just stuff in the bolts bins in the workshop, use what you've got and as long as it fits and looks ok and in keeping, no problem. Saves a bit on buying new stuff and theyre perfectly sevicable items tha thave come up like new.
I think the only bits of the bike that came from the original pile are the motor, carbs, top yolk (not tripple tree ???) and coils the rest has had to be sought and bought.
Did somebody mention Triggers Broom a while ago? ;D
It was never going to  be a concourse resto and was only ever going to be a mongrel ;D
Post by: McCabe-Thiele (Ted) on March 22, 2023, 12:34:29 PM
That made me smile - we have all done it I guess - we had a set of those Silicone rubber safety wrap edge things that Aldi used to sell to stop me doing it again.
They work great but look a bit crap after a few months when burnt fat marks them - binned when we had a new kitchen.
Post by: Sesman on March 22, 2023, 12:34:53 PM
Mongrels can be better to own than pedigrees.
Post by: Laverdaroo on March 22, 2023, 12:54:46 PM
I agree completely Phil ;D
Post by: Sesman on March 22, 2023, 03:34:37 PM
You meet the nicest people on a Mongrel Honda….😁😁
Post by: Oddjob on March 22, 2023, 03:45:49 PM
You've clearly never met Roo then  ;D ;D ;D ;D
Post by: Laverdaroo on March 22, 2023, 04:31:43 PM
Do you mind?!
I resemble that remark!
Least I’m not from Manchester though and from the bestest county
Post by: Bryanj on March 22, 2023, 04:40:57 PM
Warch it Roo, that coffee might have extras in it, but at least i was 30 miles north of manchester!
Post by: Laverdaroo on March 22, 2023, 04:41:42 PM
That’s excusable……….just
Don’t worry, I’m immune to rohipnol
Post by: Oddjob on March 22, 2023, 07:34:23 PM
Be careful using normal domed headed nuts, if they are too shallow the threads bottom out and you think the nuts tight and it's not OR the thread comes right through the head of the dome and ruins the nut. The ones I listed are very deep so this shouldn't happen.
Post by: Laverdaroo on March 22, 2023, 07:56:27 PM
Measured up and got the bits today bud from a local supplier, dome nuts are on washers so that doesn’t happen, gonna bob em on tonight as I’ve been fiddling withDT125R carbs today getting a good one together. It’s a tired bike but the engines really good so it’s worth the nannying and there’s some beans left to bank at that dosh when it sells
Ordered £150 quids worth of if good parts and service items for it today and started to get get rid of all the shite that’s been stuck on it in the past 29 years, (M plate 95)
Road ready, fully serviced and a ticket it’ll go on eBay for about £2,500 probably.
Thankfully I was wrong it’s a white one with blue bits on it not white and pink…….phew!
Post by: Sesman on March 22, 2023, 09:43:12 PM
Still not from Yorkshire, though eh Roo😉
Post by: Rozabikes Tim on March 22, 2023, 10:38:54 PM
Will that be pre 12hp law Roo?
Post by: Laverdaroo on March 22, 2023, 11:45:51 PM
Ha haa
Post by: Laverdaroo on March 22, 2023, 11:54:15 PM
No Tim it’s a UK bike but as it’s 1995, it’s well passed the date that that came in in. It’s got the Yamaha fitted,  cover plate over the YPVS valve port at the front so it’s never been a full power one.
It’s got the obligatory Fresco pipe on the end and KnN filter, upgraded silly  plug etc but it’s probably still 22hp now. They were good for about 18-21bhp depending on the fettle I their day. They were just the TZR motor and you could make those go like hell but also grenade quite nicely if removing too much of the standard stuff and replacing it with 17 year old engineering
We had a pals clocked at 114mph once which was positively supersonic to us at the time.
I shouldn’t go no the reducer washer has been ground out of the pipe at the front but that’s to come. Took the carb off it tonight to clean up and found this. It works and is sealed but bloody hell, that’s proper gash‍
(https://uploads.tapatalk-cdn.com/20230322/4a937ba7607bcd4348a987abd1f21667.jpg)
(https://uploads.tapatalk-cdn.com/20230322/85d5d4ac329e5b15f831cf6418ba06cb.jpg)
Post by: Oddjob on March 23, 2023, 12:34:51 AM
Same one as this Roo?
Dirt cheap
https://www.ebay.co.uk/itm/334147945714?hash=item4dccc504f2:g:AecAAOSwhT5hQFn3&amdata=enc%3AAQAHAAAAwITuCRbbcbVn3KV%2BNNuTT%2BMFl%2B9S7KvAicsVcDhlYrZN0fCYTBmNtl91%2F8LC4ZxJ2xoc%2F2Kih7BIW0%2Bh2S7PPNK9wDZineGCklyAl8uTg%2BLCBogyAVMlUTRYJjzJPdfR7kQyL9ui1NLOWdizNw8P9%2FLuy78YuBaRsE%2F6lD%2FbrpPquVYC4K65VdPwkcx%2Fe7tg4aUA2VVIDuC%2BF%2FZLuC4dI5QoNCxJ9%2FPUSgzKgvmk2eDO%2Fl8fODq220VQeH9kcfvYiA%3D%3D%7Ctkp%3ABk9SR9ydgr7hYQ
Post by: Laverdaroo on March 23, 2023, 12:46:39 AM
Probably but not buying Chinese tat mate, even the ones for the strimmers are crap after a short period. We got one for an Italjet 180 paddock bike a pal had, it  just wouldn’t set up.  Same with the one he bought for an rm250, April’s pegs so etc! He doesn’t learn, think the only one that would set up half decent was for his xl250 which got nicked off his bike whilst parked up at the pub, tje miserable buggers!
I reckon I can get a  float bowl from somewhere haven’t really looked yet. Yambits might do one, they’ve pretty much got most of Yamahas old stock so it’s highly likely.
I did look at that but it’s not worth the bloody hassle mate.
Post by: Oddjob on March 23, 2023, 03:35:56 AM
I was thinking of just buying it for the float bowl Roo and the oring, that ones flatter than Twiggys chest.
Post by: Laverdaroo on March 23, 2023, 03:39:02 AM
Ha haa, that’s a good shout actually, top idea! Now get to bed or you’ll be all cross n moody in the morning
I’ve just come in, been awake with tooth rot so went and did some polishing while that carb pickled in the sonic cleaner thingy for bc a bit. Just climbed back to me put. 🥱
Post by: Rozabikes Tim on March 23, 2023, 09:20:48 AM
If you say your mates had that from new, if he did that to the carb, he wants a friendly clip round the ear! ;)
Post by: Laverdaroo on March 23, 2023, 01:40:37 PM
I think it occurred when his Number One Son took the bike to agricultural college some years ago but nobody is admitting the bodgery.
I wouldn’t either it’s a bloody awful fix. But having been 17 once and needing to fix things on the fly on the way to work etc, I can understand why it’s been done
Post by: Laverdaroo on March 23, 2023, 01:49:29 PM
Didn’t spell check that did I, meant to ready, ‘barely 12hp now’
Post by: Oddjob on March 23, 2023, 02:09:59 PM
I've got some new polishing weapons Roo, just arrived today. If they pan out ok I'll let you know, in theory I may be able to polish a carb body even into the little crevices. They'll also come in handy for getting inbetween the fins on the barrels.
Post by: Laverdaroo on March 23, 2023, 02:21:01 PM
Oo, that sounds interesting mate, I I was in polishing heaven last night. The sprocket cover that those muppets did for me started to bloom and looked like it had a load of coffee splashed over it so started to take it back again ast night.
Usual state of soul destroying affairs, you think that you can get that little mark out but as you just get rid of it it starts to grow and get bigger. Getting there now but it was a 2:30am sesh again last night!!
Being sol close to it and working on it for so long last night you notice stuff and it’s fairly apparent that they actually put marks on it in their crap process they do.
Really disappointing.
If you say you’re gonna do something, just do it, that’s what I’m paying for but bar about 5 or 6 companies I’ve dealt with this year, it seems folk just can’t be arsed anymore.
I’ll get it right but it possibly means that this is the most expensive sprocket cover on the planet
Post by: Oddjob on March 23, 2023, 02:45:27 PM
Usual to see blooming especially if the weathers cold and at that time in the morning it would be, it's the fact it's polished which makes it stand out, the staining is actually that, oil and crap starting to weep out of the alloy which they should have removed but didn't.
The new polishing stuff is for very small areas only Roo, maybe areas like screw holes on those casings where the polishing mop can't get into and little sunken areas that the mop misses as well, I'd do some of those using a Dremel and a small felt tipped mop but the level of shine wasn't as good as you can't get the same amount of pressure or power in there to get that level of shine. Better than leaving them as dull areas though. The best thing about the new stuff is they don't use any polish, whether that means the finish will be crap is the question, only time will tell.
I found my old brake plate the other day, the one I'd given up on and thrown in a box, I saw it and thought I'd get it ceramic coated satin black instead and see whether I liked it better than the polished one I've done. However after looking at it again I decided to give it another go and see if I can get it polished up, must be 50-60 hours of work gone into that piece, even if I charged £5 an hour that would make it bloody expensive to buy.
Doing the lettering on my switchgear at the moment, done 2 coats and may not at least one more before I clean off the excess. Then fit all the gubbins back inside the 3 switches, and that's one job finally finished, already replaced the external wire sheath and they are looking really nice, better than original in fact. Just got to finish the handlebars and get them chromed and I can finally mount them on the bars. Started to take shape a little, very soon I'll have at least one eighth of the bike finished  ;D ;D
Post by: Laverdaroo on March 23, 2023, 02:50:57 PM
A whole eighth, get you!
It’ll be the cleanest and shiniest eighth of a bike in existence mind
The blooms I can be doing with, the fact that they grow into puts is amazing. I’ll get there and those little fingy’s youve got sound great, keep me posted. Those area on the downward side they haven’t even bothered with so need doing from scratch, I’m already 12hours into this! No fingerprints left in my right hand, no, not from that Phil
Post by: Laverdaroo on April 13, 2023, 06:11:23 PM
New pipes have come for the VFR
She’ll be off the road from next week with a bit of luck for a much needed fettle
Not 550 related but just thought I’d leave it here rather than faffing about with a new post
£200 and a great deal. Stainless steel and lovely welding, what’s not to like? Let’s see if this octopus fits(https://uploads.tapatalk-cdn.com/20230413/f33d4c91e3d2e09fa44209383eaa775c.jpg)
Post by: Bryanj on April 13, 2023, 08:10:24 PM
You never said you had a degree in origami mate
Post by: Laverdaroo on April 13, 2023, 09:11:59 PM
Bonkers innit
Post by: Johnny4428 on April 14, 2023, 11:40:54 AM
£200! That’s got to be reasonable Roo!
Post by: McCabe-Thiele (Ted) on April 14, 2023, 11:44:19 AM
Trust the front pipes are numbered Roo otherwise it will be like trying to solve a Rubik's Cube!
Post by: Oddjob on April 14, 2023, 01:47:17 PM
Bargain at £200, why can't we get stainless pipes for the 500 and the 550, they'd sell loads at that price.
Post by: Laverdaroo on April 14, 2023, 02:50:22 PM
Yup, couldn’t quite get over how cheap they were and like I say, the welds are nice! Not fab, but, nice so all good!
Yeah I think they’re numbered and should be too much of an issue, more the fact I still have the original pipes on her, they’re 21 years old now so not done too bad I reckon but one of two things will happen.
1. Snapped studs, Anglo Saxon a go go
 or…..
2. They’ll fall off as they’ve had enough now and time to die
Considering it’s a known fault they‘be lasted really well. The reg rec is supposed to be an Achilles heel too but I still  have the OE one on there
You think of the time gone into them, materials, wages, transport and packing and you wonder how there’s a profit in it for the manufacturer
Post by: Laverdaroo on April 22, 2023, 12:21:57 PM
Bit of progress due to the tank coming back from a chap in Bristol who’s been fettling the dents for me, a few folk shy-ed away from it as they didn’t want to play with anything this old but this chap’s  done a fab job!   Â£60 all in
Primed it for me too which is nice!
I saw it before it was painted and there’s minimal filler and all boshed out by hand so quite chuffed with that.
That spurred me on to fiddle further with mudguards etc so we’re on it with the Isopon P38 this morning to get things ready for paint(https://uploads.tapatalk-cdn.com/20230422/e5e07e63c76a5a6f7f973cde50e2cd75.jpg)
Post by: Laverdaroo on April 22, 2023, 12:22:22 PM
(https://uploads.tapatalk-cdn.com/20230422/3156777d78dd38dfa6da48cc2f8bf30c.jpg)
Post by: Laverdaroo on April 22, 2023, 12:22:56 PM
(https://uploads.tapatalk-cdn.com/20230422/aa35ae021a13d49cc6492647c45a25ed.jpg)
Post by: Laverdaroo on April 22, 2023, 12:24:36 PM
(https://uploads.tapatalk-cdn.com/20230422/36ea7d8a45452c14566b22a31b4ae976.jpg)
Post by: gary123 on April 22, 2023, 12:39:45 PM
Looking good Roo. :)
Post by: Laverdaroo on April 22, 2023, 12:59:24 PM
Cheers Gary, few messy jobs to do then paint, whoop whoop.
Coming on over a packet of rich Tea’s(https://uploads.tapatalk-cdn.com/20230422/539be629759c9ea738131307cd6fd982.jpg)
Post by: Oddjob on April 22, 2023, 01:49:05 PM
Been thinking about what we were talking about the other day on the phone Roo and I think someone is pulling yer plonker mate.
That firm that's saying they think the rear mudguard is made of cheap stainless steel and so won't chrome well is wrong I think.
Just remembered seeing a pic of Micks Lazarus project where his rear guard has clearly been rechromed, http://www.sohc.co.uk/index.php/topic,26913.165.html reply 177. You can clearly see the pits under the chrome where the guards aren't properly chromed by Honda and they rust quite badly. These never seem to clean up well and you're forced to chrome over the top of the pits. If Mick can get his done and I'm fairly sure there are loads of others who have also had a rear guard done then no reason you can't get yours done, unless the guard isn't a genuine Honda one of course.
Sure you've got the same power supply as me for the zinc plating. What do you set it at?
Post by: Laverdaroo on April 22, 2023, 02:28:09 PM
I didn’t plate it it went off to a firm in South Gloucester to sort.
Said it was not possible so it’s already filled, sanded and primed at the min. Gonna paint it instead of buggering about at loads of cost.
If I see a better mudguard later in the year I’ll swap them but it’ll have to do for now.
Funds are a bit low so nannying up stuff seems the wise thing to do
Post by: Laverdaroo on April 22, 2023, 03:03:15 PM
Forgot to say, came off a 76 500 from that bike yard in the states so I have no reason to believe it not to be OE. Good thought though bud…….
Post by: Laverdaroo on April 23, 2023, 05:22:20 PM
Afternoon,
Could anyone that has one on their bike provide me with the height and width dims of this badge please?
Just investigating options………
Fanks(https://uploads.tapatalk-cdn.com/20230423/b33246865aae024d0a9628bd726034ff.jpg)
Post by: Johnny4428 on April 23, 2023, 06:35:12 PM
Hi Roo, 37x40mm that is width 40.
Post by: Laverdaroo on April 23, 2023, 06:36:32 PM
Nice one, cheers Johnny
Post by: Oddjob on April 23, 2023, 06:59:47 PM
I've still got the remains of the 500 four badge I stole the F out of in front of me Roo, looking at it and I think it may be possible to make a 550 Four badge out of 2 badges by cutting out the centre 0 and fitting a 5 off another badge.
If I could find my spare scrap badges I'd give it a go.
Post by: Laverdaroo on April 23, 2023, 07:04:32 PM
I’m sorted for the side panel badges Ken, I’m working on the rear mudguard and rather than get a decal  I was looking at one of those for for under the rear lamp but just wanted some sizes so I could cut some cardboard out and have a look.
Post by: Laverdaroo on April 24, 2023, 07:48:35 PM
After prep at the weekend, two layers of gloss on after prep, two coats of clear Togo on this and the rear mudguard. Any recommendations on aerosol 2k clear laquer that’s not extortionate?
I’ve got normal clear and might use that but if there’s anything better out there happy to have a go.
Cheers(https://uploads.tapatalk-cdn.com/20230424/8bf16bf59b1a4a4b61d00f30fcd66653.jpg)
Post by: Laverdaroo on April 24, 2023, 07:48:58 PM
(https://uploads.tapatalk-cdn.com/20230424/ce3fb9eb2bb04bb41a0b42e691a1a49b.jpg)
Post by: Oddjob on April 24, 2023, 07:56:05 PM
Zinc plated bits arrived today, cheers Roo.
Post by: Sesman on April 24, 2023, 09:03:45 PM
Oh aye. That’s smart. Did you paint it yerself?
Post by: Oddjob on April 24, 2023, 09:11:53 PM
The only problem with those hose clamps Roo is that if you're using braided steel lines they don't exactly fit them. The rubber lines are much thicker and sit snug in those but braided don't.
I intend to reduce the hole in mine so they fit better.
Post by: Laverdaroo on April 25, 2023, 12:46:07 AM
I've overcome thst buy aquiring some from my contact at HEL who fit them on the VFR set up. They fit the hoops on the mudguard and are a really nice fit with a bit of initial fiddling to get them sited. I was lookig at a spare set up I had and had a lightbulb moment which saved reducing anything to fit. Seemed to be thep ath of least resistance.
Post by: Oddjob on April 25, 2023, 02:52:58 AM
Post a pic of these magical pieces Roo, I may be able to blag a pair from my contact at HEL before they ship my brake lines for the 1300.
Post by: Laverdaroo on April 25, 2023, 08:10:25 PM
Forgot before I went out but found these in the net, HEL DO em on loads of kits described as rubber gromits.
Just describe em to the chap on the phone, they’ll sort you out as only a LCI to them.(https://uploads.tapatalk-cdn.com/20230425/0bf2b52e8bccad9be6d6520565f7492b.jpg)
Post by: Sesman on April 26, 2023, 08:38:03 AM
Roo, could you send me the details of the twin disc line set up you are using please?
Post by: Matt_Harrington on April 26, 2023, 09:17:07 AM
Roo, Have you tried refinish systems in Yeovil for the 2k lacquer spray cans. Reasonably priced unless you want colour matched 2k cans!!
Sent from my SM-A032F using Tapatalk
Post by: Laverdaroo on April 26, 2023, 07:18:37 PM
No not yet only because I haven’t had anything to get down there for. Trying to reign it in as haven’t had much work and gonna be off line for the next couple of weeks, my op’s Friday
I was going to rely on post as I won’t be going out in the next 14 days. Not looking like bloody steptoe
Post by: Sesman on April 26, 2023, 07:24:39 PM
Best of luck with the op🤞
Post by: Johnny4428 on April 26, 2023, 09:22:15 PM
All the best with the gob r3cunstruction work! You’ve suffered enough.
Post by: Laverdaroo on April 26, 2023, 09:24:29 PM
Cheers.
Get stuffed Phil
Post by: Oddjob on April 27, 2023, 02:54:04 AM
BTW Roo, I'm doing my Harold impression, you know what I'm saying without me saying it here.
Post by: McCabe-Thiele (Ted) on April 27, 2023, 05:43:11 AM
Best of luck with your operation Roo.
I had my eye operation on Tuesday - good news is I thought it was less painful than a visit to the dentist on the day(sorry).
However the pain was on hold for 24 hours now I feel as though my right eye socket and cheekbone have run into a brick wall at 30 mph.
Post by: Bryanj on April 27, 2023, 05:54:04 AM
Best of luck mate!
Post by: Rozabikes Tim on April 27, 2023, 08:04:04 AM
Good luck Roo
Post by: Nurse Julie on April 27, 2023, 08:12:52 AM
Hope all goes well Roo.
Post by: Laverdaroo on April 27, 2023, 02:16:05 PM
Fanks team
Post by: Laverdaroo on May 01, 2023, 03:49:54 PM
First set of new ‘grinners’ coming tomorrow
No matter how much you look forward to being allowed to live off as much angel delight as you like, by day two it’s a bit dull
(https://uploads.tapatalk-cdn.com/20230501/ff8fadbd4b863b8ca385cc8ba6c678ef.jpg)
Post by: McCabe-Thiele (Ted) on May 01, 2023, 06:24:23 PM
There is always Yogurt & Gazpacho.
Post by: Laverdaroo on May 01, 2023, 06:56:22 PM
I’m in yoghurt as it is
Post by: gary123 on May 01, 2023, 06:57:11 PM
Jeez Roo, Thats a hell of an improvement. Face lift as well?  ;D ;D ;D.   Loose the shades though.
Hope you doing well. ;)
Post by: Laverdaroo on May 01, 2023, 07:01:02 PM
I especially like the ‘one big tooth’ in the middle.
I dunno, the shades kinda kill it baby
Cheers Gary
Just got the Long Haired General’s 400 on the bench to swap the bars while I wait on deliveries. Cut the grass first like to gain the shed time(https://uploads.tapatalk-cdn.com/20230501/94785b170caf2dc8930d7f9d51937601.jpg)
 Nice change working on a BMX, it’s so light  compared to the 800
Post by: Laverdaroo on May 15, 2023, 02:54:09 PM
Tuning day in the spring sun, lovely
(https://uploads.tapatalk-cdn.com/20230515/d803889c88f94b1822ce4c8434411b20.jpg)
Post by: Matt_Harrington on May 15, 2023, 03:01:11 PM
You changing the 550 exhaust or is that just to fire it up....?
Post by: Laverdaroo on May 15, 2023, 03:03:32 PM
No that’s fitted, might have to jig it a bit if clearance is an issue but I’m fairly sure she’s staying as is. Only the second time I’ve been more than three feet from it in about 12 months
Spotting all sorts of stuff to do
Post by: Matt_Harrington on May 15, 2023, 03:07:00 PM
Ah, mixing up the bikes and now see I was looking at the LHG's one not the 550....
Post by: Laverdaroo on May 15, 2023, 03:18:23 PM
Yeah, hers is a bit of a construction job. Had a link pipe made by that chap in Birmingham at an eye watering £50 in stainless but it was awful so made that one out of various bits off a mini metro pipe i blagged from the local garage’s scrap bin for a fiver
Post by: Laverdaroo on May 15, 2023, 03:22:00 PM
(https://uploads.tapatalk-cdn.com/20230515/150f23163d8af2624971a6c6ea4346a4.jpg)
Post by: Laverdaroo on May 15, 2023, 10:49:57 PM
Been a good days fiddling and had both motors running and a few jobs done including the rear mudguard on the 550. Starts great but have a cooler than others, couple of pipes but that’s will hopefully be in the tune.
Did spring a leak however but going to get some  new o rings for the cover and have a look how things are sitting. The other side is a lot drier and shows no signs of excess oil so it might be me on assembly?
Anything to keep an eye out for?(https://uploads.tapatalk-cdn.com/20230515/a1385f99b0a5213ca58b462cba44a8c1.jpg)
Post by: Laverdaroo on May 15, 2023, 10:50:18 PM
(https://uploads.tapatalk-cdn.com/20230515/0e2daa4f180690a1772572b733e42d6c.jpg)
Post by: Laverdaroo on May 15, 2023, 10:50:46 PM
(https://uploads.tapatalk-cdn.com/20230515/4ba9c2618701b2fa63c8162d37b23033.jpg)
Post by: Laverdaroo on May 15, 2023, 10:52:17 PM
(https://uploads.tapatalk-cdn.com/20230515/9949d2d8004d822dd61bc38d7eea9ca4.jpg)
Post by: Johnny4428 on May 15, 2023, 11:07:26 PM
Hi Roo, not convinced you have a sealing washer under that bracket! In other words between end cover mounting bracket and engine.
Post by: Oddjob on May 15, 2023, 11:18:31 PM
Roo, there should be an alloy washer UNDER the bracket, copper is ok above, but it needs the alloy one underneath.
Post by: Laverdaroo on May 15, 2023, 11:23:47 PM
Haven’t taken it off yet but I’m aware it’s copper on top and alloy underneath, both sets were new but I’ll have it to bits tomorrow and see if the alloy one made it under there.I’m pretty sure it did but I’ll check.
It was going to be either the rings or those washers in some configuration but didn’t know if there was anything else to be wary of and to keep an eye out for
Post by: Oddjob on May 15, 2023, 11:30:12 PM
Check to see if you nipped an O-ring when pushing on the cover. Also make sure you didn't strip out the thread in the cylinder head, easy to do if it's full of oil and you force the bolt down the hole when it's full. Been there, done that.
Post by: Laverdaroo on May 15, 2023, 11:32:45 PM
Will do, I’ll get it cleaned up tmrw and have a look, I’ll report back
Post by: mickwinf on May 16, 2023, 09:04:08 AM
I have had similar trouble on some of my bikes, check the little bracket is not misshapen where the washers fit or it will never seal.
Post by: Laverdaroo on May 16, 2023, 10:17:41 AM
I was cogitating that possibility whilst thinking about it during the washing up last night
It’s a possibility and if you’ve suffered Mick, I’ll be sure to check it out.
Post by: davidcumbria on May 16, 2023, 09:07:13 PM
At least there’s plenty of oil getting up thereto come out  ;)
Post by: Laverdaroo on May 17, 2023, 10:03:07 AM
Not short on oil
Post by: Laverdaroo on May 22, 2023, 11:01:06 PM
Had a look at the oil leak at the weekend and found the culprit straight away. The cover brackets as you know, are labelled L and R so after making sure that it was  the 'L' one on top of the number 1 pot , which it was, I noticed that under the copper washer that was present, there was an indent I hadn't noticed. It appears that the bolt had been wound in really hard deforming the top so it would have never have sealed. I had put both washers on so there was no fault found except that.
Laid it on the vice end and tapped it flat, annealed the copper washer again and replaced the ally one that goes underneath. Bolt in, sorted and no leaks even if the motor is faffing about at the moment due to ignition issues.
Anyway, all good and apart from the ignotion fault,  quite happy to have no disasters appear so far. Mangaed to get both the mudguards on and finished so I have to
sort ignition
Tune up and check
Tweak headstock bearings
Bleed front brakes, fix lines and mount staying rubbers into mudguard
De rust tank and paint
Start to make the seat and cover
Nearlt done, whoop whoop, theres a chance of getting her out on the road this year at this rate.
Post by: Laverdaroo on January 24, 2025, 09:38:36 PM
So,
Thought I’d bob summit up to state that i do actually still own Mejima and I’m still fiddling……..just haven’t had a chance for a long time and three rounds of the USA in between has meant fiddling time has been minor.
Redone the patio, working on the fishery still, new soffits and facials the lot last year and fiddling with the road bikes to keep them going meant she took a back seat somewhat, it’s a been a busy year.
2025 is looking similar already with a move coming up in the next 4 or 6 weeks but don’t know where to yet ……….long story
Anyway,
Managed to finally get some bits on her so tonight and I bobbed on the new TEC shocks I wanted and finally got round to getting, opinions?
 Not the best shots  but it’s dark and I’m struggling a bit.
I’ve swapped out the YSS set I had  as I found these which is what I wanted but couldn’t find any at the time.
As a result of fitting the TEC’s I’ve a new set of YSS shocks for a 500/550 for grabs if anybody is after any?
 Part number
RD 222-320P-29-18
KBA91113
They’re brand new and were fitted in the build but hadn’t turned a wheel since so still in mint nick. Gimme a shout if you’re after any. Open to offers.
Also remembered to put the newly done seat on her and fix it down. Chuffed with that tbh.
Don’t pick at the ally, she’s been under a tarp since September and it’s bloomed a bit. I feel a couple of hours of rag n Autosol coming on
Everything crossed for a test ride once she gets her colours done which won’t be til march at the earliest I reckon but it’s still progress and soul restorative to boot(https://uploads.tapatalk-cdn.com/20250124/9f86b08cdaf37970137689a85932e493.jpg)
Post by: Laverdaroo on January 24, 2025, 09:39:24 PM
(https://uploads.tapatalk-cdn.com/20250124/442ebcb0d6c33f4fa96c122469001978.jpg)
Post by: Laverdaroo on January 24, 2025, 09:45:26 PM
(https://uploads.tapatalk-cdn.com/20250124/2b22bd66fa7d189fdf102e683ffc1894.jpg)
Post by: Bryanj on January 24, 2025, 10:24:00 PM
Keep going Roo, still in same place, do you want a rotten 550 to keep it company?
Post by: Laverdaroo on January 24, 2025, 10:40:44 PM
I’d love one but currently in limbo for a week or two then need to find some Digs with a garage somewhere. Not sure where that’s gonna be yet…..weird scenario mate but yes I’d love one just nowhere to put it or I would, I’ve got quite a parts stash going here for the 550 so another is deffo on the cards, just need to finish this bugger first
Post by: DomP on January 25, 2025, 08:14:09 AM
I've been thinking getting those piggyback TEC shocks Roo, very nice! Bikes looking good mate, mine has taken a similar back seat since going full steam ahead on my workshop.  Out of interest how much were you wanting for the YSS?
Post by: Rozabikes Tim on January 25, 2025, 08:42:37 AM
Looks like a comfy ride that Roo. What colours you going for?
Post by: Matt_Harrington on January 25, 2025, 09:01:02 AM
Roo, It's been more than hectic here as well. Bike is looking great and those shocks are the biz. Coffee soon!!
Post by: Laverdaroo on January 25, 2025, 10:20:05 AM
Cheers Dom, they cost me £112 and as I say, theyve never turned a wheel, dunno really, would £80 sound terribly greedy?
Post by: Laverdaroo on January 25, 2025, 10:25:23 AM
Ehyup Matt,
you were going to give us a bell after last weekend as you were at the coast last week. I'm free or can be any  day next week if you're about, let us arrange a rendezvous with caffine based  ;)
Post by: Laverdaroo on January 25, 2025, 10:38:54 AM
(https://uploads.tapatalk-cdn.com/20250125/aff0a439eef3f4b43ac2d0cc1e4f4728.jpg)
Something like this but might go a bit bigger in the flake. Not quite ‘dodgem car’ metal flake but something with a bit more than that. Kinda like the orange though. Gloss black side covers, should look good I think and a bit different from the norm.
Post by: Matt_Harrington on January 25, 2025, 12:38:08 PM
Ehyup Matt,
WhatsApp message on it's way.....
Post by: Rozabikes Tim on January 25, 2025, 12:47:25 PM
Absolutely love that retro with a twist. Go for it matey. Rattle cans at dawn!
Post by: Laverdaroo on January 25, 2025, 02:52:57 PM
Ooo, no, this is going to TCS in Bristol, he does an epic job and it’ll come back looking like glass from him.
Not bracelet enough to do it myself tbh
Post by: taysidedragon on January 25, 2025, 07:22:18 PM
Bracelet?? One very confused welshman! 🤔
Post by: McCabe-Thiele (Ted) on January 25, 2025, 08:22:58 PM
New AI predictive text, I think he means brave enough.😄😄😄
My PC and phone are coming up with Google predicted words that are daft
Post by: Laverdaroo on January 25, 2025, 09:55:40 PM
Sorry, thanks Ted
Post by: Johnny4428 on January 25, 2025, 11:07:42 PM
Nice looking 550 Roo! Going to look awesome in the two tone.👍
Post by: Laverdaroo on January 26, 2025, 12:15:28 AM
Cheers Jonny, bit of a stop start project but it’s finally coming together. Having a tough time at the min but ever hopeful mate
Post by: DomP on January 26, 2025, 08:39:28 AM
Thanks Roo, I'll have a think on it, don't suppose you know what weight spring they come with?  Being 10 ½st means they are nearly always to heavily for me
Post by: Laverdaroo on January 26, 2025, 10:40:59 AM
I'll have a look today but failing that I'll give them a call and find out for you Dom, get some pies in yer!
Post by: DomP on January 26, 2025, 12:11:38 PM
😆  love pies!  I was also looking at the YSS Ecoline but they don't do a 550 version, tgey do a cb400 four but they're 360mm
Post by: Laverda Dave on January 26, 2025, 11:41:44 PM
When I drilled the pin out in the 400/4 carb rail I replaced it with a grub screw after taping out the location of the old pin. I turned the end of the grub screw in the trusty myford to the same diameter and depth of the slot in the spindle. I also used a locknut on the grub screw to prevent it falling out in use and leaving me stranded!
On a previous 400/4 restoration I used a roll pin to replace the pin, a lot quicker but not so easy to remove in the future.
I remember Ken posting about a suitable grub screw in the past.
If you find the spindle is rusty when you remove it you can either get it hard chrome plated and ground (I was quoted about £140 by Philpotts!) but I contacted Max (formally on here) and he made one for me from stainless and it was excellent quality. He makes them for the 500/550 as well.
Post by: Laverdaroo on January 26, 2025, 11:47:23 PM
Have you posted on the wrong thread Dave, you've lost me? ;)
Post by: Laverda Dave on January 26, 2025, 11:58:26 PM
Sorry Roo, I've posted on an old thread about your carbs when you took them apart and the bowls were green inside,
 :-\. I must be living in another dimension (or I'll have another pint of what I must have just drunk :o)
Post by: Laverda Dave on January 27, 2025, 12:01:17 AM
I've just checked it again, you posted it in November 2021, Gez what happened there, how did I post on a three year old thread weird!
Post by: Laverdaroo on January 27, 2025, 12:03:35 AM
Have you been tim'e travelling again Dave? I know the bit you replied to as I read it the other night reading through the build, not sure what youve been drinking but send a four pack of them round here would you ;) ;D
Post by: Laverda Dave on January 27, 2025, 12:08:40 AM
Just read your thread again about the TEC shocks. I bought a set for the RE Interceptor although not fitted yet.
Did you find them a bit harsh and stiff for the first few miles as reviews have said? Apparently the soften up pretty quickly and then you can dial them in. The remote type I've bought for the RE will certainly be an improvement on the originals!
PS - Don't forget to send me the bill for the TL toolbox 👍🙂
Post by: Matt_Harrington on January 27, 2025, 11:03:08 AM
 ;D ;D
Post by: Laverdaroo on January 27, 2025, 01:33:23 PM
I’ve only just bobbed em on Dave, it states they’re hard to start in the meagre info that comes with them so I’m expecting that.
It won’t be turning a wheel for a while but I’ll let on what occurs when it does.
I’ll get round to it mate, keep forgetting
