SOHC.co.uk Forums => CB500/550 => Topic started by: DomP on February 28, 2024, 09:10:12 PM
Title: CWC spokes
Post by: DomP on February 28, 2024, 09:10:12 PM
I've received my spokes from Central Wheel Components today, just laced up the front wheel but they've got the outers wrong on the bend, there's not enough length on the bend to allow it to have the right angle towards the rim nipple.  I've ordered from them before an d so far never had them sent correctly.
Title: Re: CWC spokes
Post by: DomP on February 28, 2024, 09:49:38 PM
This shows the arc that the outers are needing to take to meet the rim, this is holding them well off the inners where they cross.  If I torqued them up I think it could weaken then at the point the butted section slims down, what do you all think?
Post by: Nurse Julie on February 28, 2024, 10:16:27 PM
Have you got a side on Photo Dom, from that angle it looks like the spokes are in the wrong holes or facing the wrong way.
Post by: DomP on February 28, 2024, 10:59:23 PM
No it's all correctly laced Julie, it's the bend on the outer spokes that is the issue.
Post by: ozzybud on February 29, 2024, 12:01:15 AM
The Spokes don't normally touch where they cross. Are you saying the Bend at the Hub is incorrect?  making them bow outwards? Having inner spokes in the outer  holes would cause this.
the picture below is an outer spoke(bent over 90 degrees)
Is there a possibility that you have them switched?  or the company sent you all inners ?
Maybe remove 2 and compare to the spokes you removed.
In the first picture it looks as if the outer spokes are riding on the inners.
Post by: DomP on February 29, 2024, 07:19:39 AM
No I've got them in the correct sides, I've built wheels before so I'm certain if that, I think the small straight section before the bend is too short the the thickness of the hub
Post by: DomP on February 29, 2024, 07:30:48 AM
This is what I'm getting at
Post by: Johnny4428 on February 29, 2024, 09:46:31 AM
I had exactly the same problem with my 750 front wheel. I had emails back and forth with CWC and pointed this out to them. They tried to assure me that this was the way all the spokes were and the build would be fine. And I have to say it seems to be fine so far.😜
Post by: DomP on February 29, 2024, 10:00:03 AM
Exactly the response I've got from them but I think they are wrong.  Terrible sketch as I'm rushing at work but you get the gist.
Post by: Johnny4428 on February 29, 2024, 10:19:24 AM
That was my conclusion too, spokes just didn’t sit well like the old ones did. Must be the way the machining is set up. However by the time I had tensioned and trued up my wheel it didn’t look too bad. Don’t think it’s going to be detrimental to the tensile strength of the spoke fitting them like that.
Post by: Johnny4428 on February 29, 2024, 10:24:29 AM
Not very good pics.
Post by: DomP on February 29, 2024, 10:28:35 AM
Yes Johnny that's exactly the issue with mine, your photos show it perfectly! The way the butted end contacts the hub causes the spoke to arc towards the rim.  Hopefully that doesn't weaken them as a result but I can't see how they can say its right.
Post by: paul G on February 29, 2024, 10:50:51 AM
I had exactly the same issue with them a while ago on the CD175 sloper rear wheel.
They were adamant that they were correct even though they didn't match the samples that were sent to them.
They wanted me to send them the wheel and they would lace it for £80, as I explained to them I was capable of doing it myself with the correct spokes as the samples they had.
After much ranting they did the wheel FOC just post costs.  >:( >:(
Post by: McCabe-Thiele (Ted) on February 29, 2024, 10:52:44 AM
I'm a complete chicken when it comes to wheel building so CWC did my 400 and at present have my 500 wheels.
It must be very satisfying to lace your own wheels. My brother is a very keen cyclist with over 40 years of experience. He used to cycle over 10k miles a year though he has slowed down a little now he is 65 but still hovers around the 8k miles a year mark. He uses a local retired wheel builder. He has recently bought a cycle wheel building rig - to date his fancy rig has yet to produce a single wheel. I think he quotes Technical issues -ffs it's not a jet engine I tell him.
Post by: Orcade-Ian on February 29, 2024, 11:39:45 AM
I've had serious issues with that company too.  Most recently on a pair of sloper wheels with spokes too short.  I think I built those wheels 11 times as they kept asking for more and more photos. They kept quoting their 'bible' and years of experience and wanted us to pay for another set to my dimensions.  I said that if they were so confident that the ones they sent were correct, then put them back on the shelf and sell them to someone else and provide us with sets to my dimensions.  They accused me of lacing them incorrectly (more pics) then the rims must be wrong so I used a profile gauge on them and the originals (more pics) I was really pissed off with them by the end and will never deal with them again or recommend them to others.  Whether their system has changed or their 'bible' has been computerised (with all that that entails) I don't know but must have had 30 sets of spokes supplied correctly by them in the past without problems.
I can feel my blood pressure rising as I write this!  I was doing this as a favour for a mate!
Ian
Post by: paul G on February 29, 2024, 11:48:36 AM
Ian
I would not mind Ian but I sent them samples from the front and rear wheels, inner and outer spokes and they still got one of them wrong  ::)
Post by: Johnny4428 on February 29, 2024, 12:00:47 PM
Twice I had the wrong nipples, wouldn’t go through the holes. They tried to tell me that my rim was wrong.😳 even although the holes were exactly same size as the original. It was a DID replacement.
Post by: McCabe-Thiele (Ted) on February 29, 2024, 12:02:59 PM
Daft question but presumably DS sell spoke kits so are they not more reliable or are they very expensive?
Post by: Johnny4428 on February 29, 2024, 12:04:30 PM
Don’t know if they sell SS ones Ted?
Post by: McCabe-Thiele (Ted) on February 29, 2024, 12:06:51 PM
Of course not considered that.
Post by: DomP on February 29, 2024, 01:10:03 PM
I think the problem is they have a monopoly on the product
Post by: SteveW on February 29, 2024, 01:29:38 PM
My mate has just placed an order from these guys, I’ll let you know what they’re like when they arrive.
He’s ordered stainless for his RD250
https://e-spokes.eu/
Post by: ozzybud on February 29, 2024, 03:54:20 PM
I have had great luck  with the CMS.NL Kits. They even have the correct gold/yellow Cad nipples.
not sure if they have stainless.
Post by: DomP on February 29, 2024, 06:21:50 PM
CWC have offered to take the outer spokes back and copy my samples, in the meantime I've torqued them up and this is the extent of the bow.  Is it something I can get away with or should I get then remade?  I'm just concerned that if they come back wrong or even worse than what I currently have I won't have a leg to stand on.
Post by: McCabe-Thiele (Ted) on February 29, 2024, 07:12:27 PM
Reading this Horror story about spokes makes me glad I've passed any problems with rims or spokes to the team at CWS.
I dropped off  my bare F&R hubs 500 hubs for powder coating & building with new valanced alloy rims SS spokes etc & for tyres to be fitted in December 2023.
When I enquired as to progress a couple of weeks ago the rims were at the Anodisers. That said when they did my 400 rims they were spot on aside from a tyre being fitted wrongly - an error they sorted foc by collecting the wheel & delivering it back.
My BiL has used them for many years never having an issue with the standard of builds mainly on old 2T Yamahas.
Post by: ozzybud on February 29, 2024, 08:14:34 PM
I would get them re made. It will not only make it correct for you but it will help the next guy as they hopefully  start making them correct in the future.
Post by: Laverda Dave on February 29, 2024, 08:44:33 PM
Hagon Shocks also supply spoke kits in both galvanised and Stainless with various nipple options.
Post by: Johnny4428 on February 29, 2024, 09:35:12 PM
That’s great to know there are other suppliers of stainless spokes.
Post by: sye on March 01, 2024, 06:50:14 AM
I have used this guy a few times. Excellent and he makes the spokes to fit. He builds wheels and will supply spoke kits to pattern if you send him your old ones. Works from a shed at his house and knows his stuff. Been doing it for years.
http://wheelbuilders.blogspot.com/
Post by: DomP on March 01, 2024, 07:21:59 PM
I'm not sure I can be bothered with sending them back unless the slight cilurve the outer spokes are taking is a big issue, visually its next to unnoticeable unless I put a steel rule against it.
Post by: peterengland on March 02, 2024, 04:13:18 PM
Had mine laced by a guy who lives 5 minutes from DSS, DSS had sent me the wrong spokes but he went and got the correct ones and laced it all up, job done! (by him)
